[MOAB-dev] r2726 - MOAB/trunk
kraftche at cae.wisc.edu
Wed Mar 18 13:43:31 CDT 2009
Author: kraftche
Date: 2009-03-18 13:43:31 -0500 (Wed, 18 Mar 2009)
New Revision: 2726
Modified:
MOAB/trunk/AEntityFactory.cpp
MOAB/trunk/AEntityFactory.hpp
MOAB/trunk/MBInterface.hpp
Log:
make MBInterface::get_adjacencies append than assign to the passed std::vector and document that behavior
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp 2009-03-18 17:38:20 UTC (rev 2725)
+++ MOAB/trunk/AEntityFactory.cpp 2009-03-18 18:43:31 UTC (rev 2726)
@@ -100,9 +100,6 @@
if(target_dimension > 4)
return MB_FAILURE;
- if(!target_entities.empty())
- target_entities.clear();
std::vector<MBEntityHandle> vertices;
@@ -157,8 +154,6 @@
MBErrorCode result;
const MBEntityHandle* adj_vec;
int num_adj;
@@ -175,8 +170,7 @@
std::lower_bound(start_ent, adj_vec+num_adj, CREATE_HANDLE(dim_pair.second, MB_END_ID, dum));
// copy the the meshsets
- target_entities.resize(end_ent - start_ent);
- std::copy(start_ent, end_ent, target_entities.begin());
+ target_entities.insert( target_entities.end(), start_ent, end_ent );
return result;
@@ -875,7 +869,7 @@
if (MB_SUCCESS != result) return result;
if (target_dimension == 0) {
- target_entities = vertex_array;
+ target_entities.insert( target_entities.end(), vertex_array.begin(), vertex_array.end() );
return MB_SUCCESS;
@@ -1065,7 +1059,7 @@
it1 = std::lower_bound( end1, vtx_adj->end(), tgt_beg_handle );
end1 = std::lower_bound( it1, vtx_adj->end(), tgt_end_handle );
- target_entities.erase( intersect( target_entities.begin(), target_entities.end(),
+ target_entities.erase( intersect( target_entities.begin()+in_size, target_entities.end(),
it1, end1 ), target_entities.end() );
@@ -1163,7 +1157,7 @@
std::vector<MBEntityHandle> tmp_vec;
if (!equiv_entities) {
// get elems adjacent to each node
- std::vector<MBEntityHandle> *elems = new std::vector<MBEntityHandle>[num_source_vertices];
+ std::vector< std::vector<MBEntityHandle> > elems(num_source_vertices);
int i;
for(i=0; i < num_source_vertices; i++)
@@ -1189,8 +1183,7 @@
// elems[0] contains the intersection, swap with target_entities
- target_entities.swap(elems[0]);
- delete [] elems;
+ target_entities.insert( target_entities.end(), elems[0].begin(), elems[0].end() );
else if (source_type == MBPOLYGON) {
// get adjacencies using polyhedra's connectivity vectors
@@ -1251,8 +1244,7 @@
std::copy(start_ent_td, end_ent_td, mb_range_inserter(target_ents));
// now insert the whole thing into the argument vector
- std::copy(target_ents.begin(), target_ents.end(), std::back_inserter(target_entities));
+ target_entities.insert( target_entities.end(), target_ents.begin(), target_ents.end() );
return result;
Modified: MOAB/trunk/AEntityFactory.hpp
--- MOAB/trunk/AEntityFactory.hpp 2009-03-18 17:38:20 UTC (rev 2725)
+++ MOAB/trunk/AEntityFactory.hpp 2009-03-18 18:43:31 UTC (rev 2726)
@@ -52,12 +52,27 @@
//! remove all adjacencies from from the base_entity.
MBErrorCode remove_all_adjacencies(MBEntityHandle base_entity,
const bool delete_adj_list = false);
-//! get the elements contained by source_entity, of
-//! type target_type, passing back in target_entities; if create_if_missing
-//! is true and no entity is found, one is created; if create_adjacency_option
-//! is >= 0, adjacencies from entities of that dimension to each target_entity
-//! are created (this function uses AEntityFactory::get_element for each element)
+/**\brief Get adjacencies for a single source entity.
+ * Get adjacent entities.
+ *\param source_entity The entity for which to retrieve the adjacencies.
+ *\param target_dimension Retrieve adjacent entities of this dimension. Must
+ * be in the range [0,4], where 4 is used to indicated entity sets.
+ *\param target_entities Requested adjacent entities will be appended to this list.
+ *\param create_if_missing If true, adjacent elements of the specified dimension will
+ * be created if they do not already exist. If the target dimension
+ * is less than the dimension of the input entity and greater than zero, the
+ * elements will be created as required to represent the "sides" of
+ * the source element. If the target dimension is greater than that
+ * of the source entity and less than 3, then sides of the specified
+ * dimension on that are a) of greater dimension and b) adjacent to
+ * the input entity will be created.
+ * \param create_adjacency_option If create_adjacency_option is >= 0, adjacencies from
+ * entities of that dimension to each target_entity are created
+ * (this function uses AEntityFactory::get_element for each element)
MBErrorCode get_elements(MBEntityHandle source_entity,
const unsigned int target_dimension,
std::vector<MBEntityHandle> &target_entities,
@@ -89,6 +104,14 @@
const MBEntityHandle source_entity = 0,
const int create_adjacency_option = -1);
+ /**\brief Get adjacent entities
+ *\param entity The source entity for which to retrieve adjacent entities.
+ *\param to_dimension The adjacent entities to retrieve, specified by dimension.
+ *\param create_if_missing Create adjacent entities that do not already exist.
+ *\param adjacent_entities The resulting adjacent entities are appended to this
+ * list.
MBErrorCode get_adjacencies(const MBEntityHandle entity,
const unsigned int to_dimension,
bool create_if_missing,
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2009-03-18 17:38:20 UTC (rev 2725)
+++ MOAB/trunk/MBInterface.hpp 2009-03-18 18:43:31 UTC (rev 2726)
@@ -510,7 +510,7 @@
\param to_dimension Dimension of desired adjacencies
\param create_if_missing If true, MB will create any entities of the specfied dimension
which have not yet been created (only useful when <em>to_dimension < dim(*from_entities)</em>)
- \param adj_entities STL vector in which adjacent entities are returned.
+ \param adj_entities STL vector to which adjacent entities are appended.
\param operation_type Enum of INTERSECT or UNION. Defines whether to take
the intersection or union of the set of adjacencies recovered for the from_entities.
