[MOAB-dev] r2724 - MOAB/trunk/parallel
kraftche at cae.wisc.edu
Tue Mar 17 15:22:58 CDT 2009
Author: kraftche
Date: 2009-03-17 15:22:58 -0500 (Tue, 17 Mar 2009)
New Revision: 2724
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
Log:
add function 'exchange_all_shared_handles' to assist in testing and debugging
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2009-03-17 19:18:45 UTC (rev 2723)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2009-03-17 20:22:58 UTC (rev 2724)
@@ -4492,8 +4492,114 @@
remote_handles[num_part_ids_out-1] = entity;
return result;
+MBErrorCode MBParallelComm::exchange_all_shared_handles( shared_entity_map& result )
+ MBErrorCode rval;
+ int ierr;
+ const int tag = 0x4A41534E;
+ const MPI_Comm comm = procConfig.proc_comm();
+ std::set<unsigned int> exch_procs;
+ rval = get_comm_procs(exch_procs);
+ if (MB_SUCCESS != rval)
+ return rval;
+ const int num_proc = exch_procs.size();
+ std::vector<MPI_Request> send_req(num_proc), recv_req(num_proc);
+ const std::vector<int> procs( exch_procs.begin(), exch_procs.end() );
+ // get all shared entities
+ MBRange all_shared;
+ MBTag pstatus = pstatus_tag();
+ for (MBEntityType type = MBVERTEX; type < MBENTITYSET; ++type) {
+ rval = get_moab()->get_entities_by_type_and_tag( 0, type, &pstatus, 0, 1, all_shared );
+ return rval;
+ // build up send buffers
+ shared_entity_map send_data;
+ int ent_procs[MAX_SHARING_PROCS];
+ MBEntityHandle handles[MAX_SHARING_PROCS];
+ int num_sharing;
+ SharedEntityData tmp;
+ for (MBRange::iterator i = all_shared.begin(); i != all_shared.end(); ++i) {
+ tmp.remote = *i; // swap local/remote so they're correct on the remote proc.
+ rval = get_owner( *i, tmp.owner );
+ return rval;
+ rval = get_sharing_parts( *i, ent_procs, num_sharing, handles );
+ for (int j = 0; j < num_sharing; ++j) {
+ if (ent_procs[j] == (int)proc_config().proc_rank())
+ continue;
+ tmp.local = handles[j];
+ send_data[ent_procs[j]].push_back( tmp );
+ // set up to receive sizes
+ std::vector<int> sizes_send(num_proc), sizes_recv(num_proc);
+ for (int i = 0; i < num_proc; ++i) {
+ ierr = MPI_Irecv( &sizes_recv[i], 1, MPI_INT, procs[i], tag, comm, &recv_req[i] );
+ if (ierr)
+ return MB_FILE_WRITE_ERROR;
+ // send sizes
+ sizes_send[i] = send_data[procs[i]].size();
+ ierr = MPI_Isend( &sizes_send[i], 1, MPI_INT, procs[i], tag, comm, &send_req[i] );
+ if (ierr)
+ // receive sizes
+ std::vector<MPI_Status> stat(num_proc);
+ ierr = MPI_Waitall( num_proc, &recv_req[0], &stat[0] );
+ if (ierr)
+ // wait until all sizes are sent (clean up pending req's)
+ ierr = MPI_Waitall( num_proc, &send_req[0], &stat[0] );
+ if (ierr)
+ // set up to receive data
+ result[procs[i]].resize( sizes_recv[i] );
+ ierr = MPI_Irecv( &result[procs[i]][0],
+ sizeof(SharedEntityData)*sizes_recv[i],
+ MPI_UNSIGNED_CHAR,
+ procs[i], tag, comm, &recv_req[i] );
+ if (ierr)
+ // send data
+ ierr = MPI_Isend( &send_data[procs[i]][0],
+ sizeof(SharedEntityData)*sizes_send[i],
+ procs[i], tag, comm, &send_req[i] );
+ if (ierr)
+ // receive data
+ if (ierr)
+ // wait until everything is sent to release send buffers
+ if (ierr)
+ return MB_SUCCESS;
#ifdef TEST_PARALLELCOMM
#include <iostream>
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2009-03-17 19:18:45 UTC (rev 2723)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2009-03-17 20:22:58 UTC (rev 2724)
@@ -32,8 +32,37 @@
#include <map>
#include <set>
#include "math.h"
+#ifdef SEEK_SET
+# define SEEK_SET_OLD SEEK_SET
+# undef SEEK_SET
+#endif
+#ifdef SEEK_CUR
+# define SEEK_CUR_OLD SEEK_CUR
+# undef SEEK_CUR
+#endif
+#ifdef SEEK_END
+# define SEEK_END_OLD SEEK_END
+# undef SEEK_END
+#endif
#include "mpi.h"
+#ifdef SEEK_SET_OLD
+# undef SEEK_SET
+# define SEEK_SET SEEK_SET_OLD
+# undef SEEK_SET_OLD
+#endif
+#ifdef SEEK_CUR_OLD
+# undef SEEK_CUR
+# define SEEK_CUR SEEK_CUR_OLD
+# undef SEEK_CUR_OLD
+#endif
+#ifdef SEEK_END_OLD
+# undef SEEK_END
+# define SEEK_END SEEK_END_OLD
+# undef SEEK_END_OLD
+#endif
extern "C" {
struct tuple_list;
@@ -670,8 +699,25 @@
MBErrorCode update_iface_sets(MBRange &sent_ents,
std::vector<MBEntityHandle> &remote_handles,
int from_proc);
public:
+ struct SharedEntityData {
+ MBEntityHandle local;
+ MBEntityHandle remote;
+ int owner;
+ typedef std::vector< SharedEntityData > shared_entity_vec;
+ //! Map indexed by processor ID and containing, for each processor ID,
+ //! a list of <local,remote> handle pairs, where the local handle is
+ //! the handle on this processor and the remove handle is the handle on
+ //! the processor ID indicated by the map index.
+ typedef std::map< int, shared_entity_vec > shared_entity_map;
+ //! Every processor sends shared entity handle data to every other processor
+ //! that it shares entities with. Passed back map is all received data,
+ //! indexed by processor ID. This function is intended to be used for
+ //! debugging.
+ MBErrorCode exchange_all_shared_handles( shared_entity_map& result );
//! replace handles in from_vec with corresponding handles on
//! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
//! if no remote handle and new_ents is non-null, substitute
