[MOAB-dev] r2720 - MOAB/trunk
kraftche at cae.wisc.edu
Tue Mar 17 08:37:01 CDT 2009
Author: kraftche
Date: 2009-03-17 08:37:01 -0500 (Tue, 17 Mar 2009)
New Revision: 2720
Added:
MOAB/trunk/configure.ac
Removed:
MOAB/trunk/configure.in
Log:
For some time now the recommended name for this file is "configure.ac" rather
than the old "configure.in". Some Linux distros (e.g. Debian and derivatives)
are installing autoconf as a wrapper that calles either a very old version
of autoconf (2.13) or the current version based on the configure.in/ac suffix.
So rename the configure file.
Copied: MOAB/trunk/configure.ac (from rev 2716, MOAB/trunk/configure.in)
--- MOAB/trunk/configure.ac (rev 0)
+++ MOAB/trunk/configure.ac 2009-03-17 13:37:01 UTC (rev 2720)
@@ -0,0 +1,972 @@
+# Standard Stuff
+AC_INIT(MOAB, 3.99)
+AC_CONFIG_MACRO_DIR([m4])
+AC_CANONICAL_SYSTEM
+AM_INIT_AUTOMAKE
+AC_PROG_SED
+EXTRA_GNU_FLAGS='-Wall -pipe -pedantic'
+SNL_CHECK_COMPILERS
+AM_CONDITIONAL(PARALLEL,[test "x$WITH_MPI" != "xno"])
+LIBS="-lm"
+AC_PROG_LN_S
+AC_PROG_MAKE_SET
+AC_DISABLE_SHARED
+AC_PROG_LIBTOOL
+AC_CHECK_PROG([ZCAT],[gunzip],[gunzip -c],[])
+AC_CHECK_PROG([ZCAT],[gzip],[gzip -cd],[])
+AC_CHECK_PROG([ZCAT],[zcat],[zcat],[])
+if test "x" = "x$ZCAT"; then
+ AC_MSG_WARN([[Cannot run tests: no way to uncompress input files.]])
+fi
+AC_SUBST([ZCAT])
+AM_CONDITIONAL([HAVE_ZCAT],[test "x" = "x$ZCAT"])
+SNL_TEMPLATE_SPECIALIZATION
+SNL_TEMPLATE_FUNC_SPECIALIZATION
+DEFINES="$DEFINES $TEMPLATE_SPECIALIZATION $TEMPLATE_FUNC_SPECIALIZATION"
+if test "x" != "x$FC"; then
+ AC_FC_WRAPPERS
+fi
+# Version Stuff
+AC_DEFINE(MB_VERSION,["AC_PACKAGE_VERSION"],[MOAB Version])
+VERSION_MAJOR=`expr AC_PACKAGE_VERSION : '\([[0-9]]*\)'`
+VERSION_MINOR=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.\([[0-9]]*\)'`
+VERSION_PATCH=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.[[0-9]]*\.\(.*\)'`
+test "x" != "x$VERSION_MAJOR" || AC_MSG_ERROR("Invalid version string: AC_PACKAGE_VERSION")
+test "x" != "x$VERSION_MINOR" || AC_MSG_ERROR("Invalid version string: AC_PACKAGE_VERSION")
+AC_DEFINE_UNQUOTED(MB_VERSION_MAJOR,$VERSION_MAJOR,[MOAB Major Version])
+AC_DEFINE_UNQUOTED(MB_VERSION_MINOR,$VERSION_MINOR,[MOAB Minor Version])
+if test "x" != "x$VERSION_PATCH"; then
+ AC_DEFINE_UNQUOTED(MB_VERSION_PATCH,$VERSION_PATCH,[MOAB Patch Level])
+ VERSION_STRING="AC_PACKAGE_STRING"
+elif test $VERSION_MINOR -eq 99; then
+ VERSION_STRING="AC_PACKAGE_STRING (Alpha)"
+else
+ VERSION_STRING="AC_PACKAGE_STRING (Beta)"
+fi
+AC_DEFINE_UNQUOTED(MB_VERSION_STRING,"${VERSION_STRING}",[MOAB Version String])
+# Extract libtool config
+ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [MOAB_CXX_LINKFLAGS])
+ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [MOAB_CXX_LIBS])
+AC_SUBST(MOAB_CXX_LINKFLAGS)
+AC_SUBST(MOAB_CXX_LIBS)
+# HANDLE SIZE
+AC_CHECK_HEADER([inttypes.h], [AC_DEFINE(MOAB_HAVE_INTTYPES_H, [], [MOAB qualified HAVE_INTTYPES_H]) ])
+AC_CHECK_HEADER([stdint.h], [AC_DEFINE(MOAB_HAVE_STDINT_H, [], [MOAB qualified HAVE_STDINT_H]) ])
+AC_CHECK_HEADER([sys/types.h],[AC_DEFINE(MOAB_HAVE_SYS_TYPES_H, [], [MOAB qualified HAVE_SYS_TYPES_H])])
+AC_CHECK_HEADER([stddef.h], [AC_DEFINE(MOAB_HAVE_STDDEF_H, [], [MOAB qualified HAVE_STDDEF_H]) ])
+AC_CHECK_HEADER([stdlib.h], [AC_DEFINE(MOAB_HAVE_STDLIB_H, [], [MOAB qualified HAVE_STDLIB_H]) ])
+AC_ARG_ENABLE([64bit-handles],
+ [AC_HELP_STRING([--enable-64bit-handles],[Force MBEntityHandle to be 64 bits])],
+ [AC_CHECK_TYPE([uint64_t],
+ [AC_DEFINE(MOAB_FORCE_64_BIT_HANDLES,[],[Use int64_t for handles])
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-64bit-handles"],
+ [AC_MSG_ERROR([Platform does not have uint64_t. Cannot force 64-bit handles])])
+AC_ARG_ENABLE([32bit-handles],
+ [AC_HELP_STRING([--enable-32bit-handles],[Force MBEntityHandle to be 32 bits])],
+ [AC_CHECK_TYPE([uint32_t],
+ [AC_DEFINE(MOAB_FORCE_32_BIT_HANDLES,[],[Use int32_t for handles])
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-32bit-handles"],
+ [AC_MSG_ERROR([Platform does not have uint32_t. Cannot force 32-bit handles])])
+if test "x$HANDLE_TYPE" = "x"; then
+ AC_CHECK_TYPE([size_t],
+ [AC_DEFINE(MOAB_HAVE_SIZE_T,[],[System provides size_t typedef])],
+ [AC_MSG_WARN([size_t not defined, assuming sizeof(void*) == sizeof(long)])]
+ AC_CHECK_TYPE([ptrdiff_t],
+ [AC_DEFINE(MOAB_HAVE_PTRDIFF_T,[],[System provides ptrdiff_t typedef])],
+ [AC_MSG_WARN([ptrdiff_t not defined, assuming sizeof(void*) == sizeof(long)])]
+fi
+# System Headers
+AC_CHECK_HEADER([ieeefp.h],[DEFINES="$DEFINES -DHAVE_IEEEFP_H"] )
+if test "xyes" = "x$enable_debug"; then
+ AC_CHECK_HEADER( [valgrind/memcheck.h], [CPPFLAGS="$CPPFLAGS -DVALGRIND"] )
+fi
+# BOOST OPTIONS
+dnl SNL_CHECK_BOOST( [boost/pool/object_pool.hpp] )
+MK_CHECK_UNORDERED_MAP([CPPFLAGS="$CPPFLAGS -DUNORDERED_MAP_NS=$result -DHAVE_UNORDERED_MAP=${incdir}unordered_map"])
+# MPI OPTIONS
+AC_ARG_VAR(MPIEXEC,[Program to use to run parallel tests (default: mpiexec or mpirun)])
+AC_ARG_VAR(MPIEXEC_NP,[Command line flag to specify number of processors to use (default: -np)])
+AC_ARG_VAR(NP,[Number of processors to on which to run parallel tests (default: 2)])
+if test "x$WITH_MPI" != "xno"; then
+ DEFINES="$DEFINES -DUSE_MPI"
+ AC_CHECK_HEADER([mpi.h],[],[AC_MSG_ERROR([mpi.h not found or not working])])
+ AC_MSG_CHECKING([If -DMPICH_IGNORE_CXX_SEEK is necessary])
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ AC_PREPROC_IFELSE([AC_LANG_PROGRAM( [[#include <stdio.h>
+ #include <mpi.h>]],[])],
+ [AC_MSG_RESULT([no])],
+ [save_CPPFLAGS="$CPPFLAGS"
+ CPPFLAGS="$CPPFLAGS -DMPICH_IGNORE_CXX_SEEK"
+ [AC_MSG_RESULT([yes]); AM_CPPFLAGS="$AM_CPPLFLAGS -DMPICH_IGNORE_CXX_SEEK" ],
+ [AC_MSG_ERROR([mpi.h is not usable])]),
+ CPPFLAGS="$save_CPPFLAGS"])
+ AC_LANG_RESTORE
+ if test "x$MPIEXEC" = "x"; then
+ if test "x$WITH_MPI" != "xyes"; then
+ AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true],[${WITH_MPI}:${WITH_MPI}/bin])
+ else
+ AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true])
+ fi
+ fi
+ if test "x$MPIEXEC_NP" = "x"; then
+ MPIEXEC_NP="-np"
+ fi
+ if test "x$NP" = "x"; then
+ NP=2
+ fi
+fi
+AM_CONDITIONAL(USE_MPI, [test "xno" != "x$WITH_MPI"])
+AM_CONDITIONAL(USE_MPIEXEC, [test "x$MPIEXEC" != "xtrue"])
+# HDF5 OPTIONS
+SNL_CHECK_HDF5
+if test "xno" = "x$HAVE_HDF5"; then
+ AC_MSG_WARN([Support for native HDF5 file format disabled])
+else
+ DEFINES="$DEFINES -DHDF5_FILE"
+fi
+AM_CONDITIONAL(HDF5_FILE, [test "xno" != "x$HAVE_HDF5"])
+AM_CPPFLAGS="$HDF5_CPPFLAGS $AM_CPPFLAGS"
+AM_LDFLAGS="$HDF5_LDFLAGS $AM_LDFLAGS"
+AC_SUBST(HDF5_LIBS)
+HAVE_HDF5_PARALLEL=no
+if test "xno" != "x$HAVE_HDF5"; then
+ if test "xno" != "x$WITH_MPI"; then
+ old_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
+ AC_CHECK_LIB( [hdf5], [H5Pset_fapl_mpio], [HAVE_HDF5_PARALLEL=yes],
+ [AC_MSG_WARN("libhdf5 library does not include parallel support. Parallel HDF5 I/O disabled")],
+ [$HDF5_LIBS]
+ LDFLAGS="$old_LDFLAGS"
+ fi
+fi
+AM_CONDITIONAL(PARALLEL_HDF5, [test "xno" != "x$HAVE_HDF5_PARALLEL"])
+if test "xno" != "x$HAVE_HDF5_PARALLEL"; then
+ DEFINES="$DEFINES -DHDF5_PARALLEL"
+fi
+# NetCDF OPTIONS
+SNL_CHECK_NETCDF
+if test "xno" = "x$HAVE_NETCDF"; then
+ AC_MSG_WARN([Support for ExodusII file format disabled])
+ NETCDF_LIBS=
+else
+ DEFINES="$DEFINES -DNETCDF_FILE"
+ NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"
+fi
+AM_CONDITIONAL(NETCDF_FILE, [test "xno" != "x$HAVE_NETCDF"])
+AM_CPPFLAGS="$NETCDF_CPPFLAGS $AM_CPPFLAGS"
+AM_LDFLAGS="$NETCDF_LDFLAGS $AM_LDFLAGS"
+AC_SUBST(NETCDF_LIBS)
+# Documentation
+AC_ARG_ENABLE([doxygen],
+[AC_HELP_STRING([[--enable-doxygen(=DIR)]],[Specify directory where Doxygen program is installed])
+AC_HELP_STRING([--disable-doxygen],[Do not generate API documentation (default)])],
+ [ENABLE_DOXYGEN="$enableval"],[ENABLE_DOXYGEN=no] )
+if test "x$ENABLE_DOXYGEN" = "xyes"; then
+ AC_PATH_PROG( [DOXYGEN], [doxygen], [no] )
+elif test "x$ENABLE_DOXYGEN" != "xno"; then
+ AC_PATH_PROG( [DOXYGEN], [doxygen], [no], [$ENABLE_DOXYGEN] )
+fi
+if test "x$ENABLE_DOXYGEN" != "xno"; then
+ if test "x$DOXYGEN" = "xno"; then
+ AC_MSG_ERROR("Doxygen executable not found.")
+ fi
+fi
+AC_SUBST([DOXYGEN])
+AM_CONDITIONAL([ENABLE_DOXYGEN],[test "x$ENABLE_DOXYGEN" != "xno"])
+# Optional Tools
+ # Define a macro to avoid typing this for each individual tool
+ # Usage: MB_OPTIOANL_TOOL( name, default )
+ # name - name of option
+ # default - yes/no, $ENABLE_TOOLS overrides this if set
+ # Actions:
+ # sets ENABLE_${tool} to 'yes' or 'no'
+ # creates ENABLE_${tool} automake conditional
+AC_DEFUN([MB_OPTIONAL_TOOL],[
+ mb_default_$1=$2
+ if test "x" != "x$ENABLE_TOOLS"; then
+ mb_default_$1="$ENABLE_TOOLS"
+ fi
+ AC_ARG_ENABLE( [$1],
+[AC_HELP_STRING([--enable-$1],[Build tool: $1])
+AC_HELP_STRING([--disable-$1],[Don't build $1])],
+ [ENABLE_$1=$enableval
+DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-$1=\"${enableval}\""
+],[ENABLE_$1=${mb_default_$1}] )
+ AM_CONDITIONAL([ENABLE_$1],[test "x${ENABLE_$1}" != "xno"])
+ AC_MSG_CHECKING([if $1 is to be built])
+ AC_MSG_RESULT([${ENABLE_$1}])
+ # The default for all tools
+AC_ARG_ENABLE( [tools], [
+AC_HELP_STRING([--enable-tools],[Build all tools by default])
+AC_HELP_STRING([--disable-tools],[Disable all tools by default])],
+ [ENABLE_TOOLS=$enableval],[ENABLE_TOOLS=] )
+ # Individual tools
+MB_OPTIONAL_TOOL([mbconvert], [yes])
+MB_OPTIONAL_TOOL([hexmodops], [yes])
+MB_OPTIONAL_TOOL([mbchaco], [no] )
+MB_OPTIONAL_TOOL([mbperf], [yes])
+MB_OPTIONAL_TOOL([qvdual], [no] )
+MB_OPTIONAL_TOOL([mbsize], [yes])
+MB_OPTIONAL_TOOL([mbskin], [yes])
+MB_OPTIONAL_TOOL([mbtagprop], [yes])
+MB_OPTIONAL_TOOL([mcnpmit], [no])
+MB_OPTIONAL_TOOL([mbcoupler], [$ENABLE_mcnpmit] )
+MB_OPTIONAL_TOOL([spheredecomp], [yes])
+MB_OPTIONAL_TOOL([mbsurfplot], [yes])
+MB_OPTIONAL_TOOL([mbzoltan], [no] )
+MB_OPTIONAL_TOOL([dagmc], [yes])
+MB_OPTIONAL_TOOL([gsets], [yes])
+# iMesh
+AC_ARG_ENABLE( [imesh],
+[AC_HELP_STRING([--enable-imesh(=nofortran)],[Build iMesh interface. If optional
+'nofortran' argument is given, support for FORTRAN name mangling will be disabled.])
+AC_HELP_STRING([--disable-imesh],[Don't build support for iMesh interface.])],
+[DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-imesh=\"${enableval}\""],
+[enableval=yes] )
+case $enableval in
+ yes)
+ ENABLE_imesh=yes
+ nofortran|NoFortran|noFORTRAN|NoFORTRAN|Nofortran)
+ ENABLE_imesh=yes
+ no)
+ ENABLE_imesh=no
+ AC_MSG_ERROR([Invalid argument to --enable-imesh : $enableval])
+esac
+AC_MSG_CHECKING([if iMesh support is to be built])
+AC_MSG_RESULT([$ENABLE_imesh])
+AM_CONDITIONAL([ENABLE_imesh],[test "xyes" == "x$ENABLE_imesh"])
+# Zoltan
+if test $ENABLE_mbzoltan = yes; then
+ if test "x$WITH_MPI" = "xno"; then
+ AC_MSG_ERROR([--enable-mbzoltan requires MPI, try specifying --with-mpi])
+ fi
+ ZOLTAN_LIB_FLAGS=
+ ZOLTAN_INC_FLAGS=
+ ZOLTAN_LIBS=
+ ZOLTAN_ARCH=
+ ZOLTAN_DIR=
+ AC_ARG_WITH( [zoltan],
+ [AC_HELP_STRING([--with-zoltan=DIR],[Specify Zoltan build directory])],
+ [if test "xyes" = "$withval"; then
+ AC_MSG_WARN([Ingoring --with-zoltan flag w/out value])
+ elif test -d $withval/$include; then
+ ZOLTAN_INC_FLAGS="$ZOLTAN_INC_FLAGS -I$withval/include"
+ ZOLTAN_DIR="$withval"
+ else
+ AC_MSG_ERROR("$withval/include : not a directory")
+ fi
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-zoltan=\"${withval}\""
+ AC_ARG_WITH([zoltan-arch],
+ [AC_HELP_STRING([--with-zoltan-arch=OS],[Specify zoltan architecture])],
+ [if test "xyes" = "x$withval"; then
+ AC_MSG_ERROR([--with-zoltan-arch flag requires a value])
+ elif test "x" = "x$ZOLTAN_DIR"; then
+ AC_MSG_WARN([Ingoring --with-zoltan-arch without --with-zoltan])
+ elif test -d "$ZOLTAN_DIR/Obj_$withval"; then
+ ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$ZOLTAN_DIR/Obj_$withval"
+ else
+ AC_MSG_ERROR("$ZOLTAN_DIR/Obj_$withval : not a directory")
+ fi],
+ [if test "x" != "x$ZOLTAN_DIR"; then
+ AC_MSG_WARN([Expect --with-zoltan-arch with --with-zoltan])
+ if test -d $ZOLTAN_DIR/lib; then
+ AC_MSG_WARN("Guessing '$ZOLTAN_DIR/lib'")
+ ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$ZOLTAN_DIR/lib"
+ else
+ # if only one Obj_$ARCH dir, then us it
+ found=no
+ for dir in $ZOLTAN_DIR/Obj_*; do
+ if test -d $dir; then
+ if test "xyes" = "x$found"; then
+ AC_MSG_ERROR("Multiple Zoltan Obj_$ARCH dirs. --with-zoltan-arch required.")
+ fi
+ ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$dir"
+ found=yes
+ fi
+ done
+ if test "xno" = "x$found"; then
+ AC_MSG_ERROR('No Zoltan Obj_$ARCH dir found. --with-zoltan-arch required.')
+ fi
+ fi
+ fi
+ AC_ARG_WITH([parmetis],
+ [AC_HELP_STRING([--with-parmetis=DIR],
+ [Directory containing Parmetis library for Zoltan])],
+ AC_MSG_WARN([Ingoring --with-parmetis flag w/out value])
+ elif test -d "$withval"; then
+ ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$withval"
+ else
+ AC_MSG_ERROR("$withval: not a directory")
+ fi]
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-parmetis=\"${withval}\""
+ old_CPPFLAGS="$CPPFLAGS"
+ CPPFLAGS="$CPPFLAGS $ZOLTAN_INC_FLAGS -DMPICH_IGNORE_CXX_SEEK"
+ AC_LANG_PUSH([C++])
+ AC_CHECK_HEADER([zoltan_cpp.h],[],[AC_MSG_ERROR("mbzoltan requires zoltan")])
+ AC_LANG_POP([C++])
+ CPPFLAGS="$old_CPPFLAGS"
+ LDFLAGS="$LDFLAGS $ZOLTAN_LIB_FLAGS"
+ AC_CHECK_LIB([zoltan],[Zoltan_LB_Partition],[ZOLTAN_LIBS='-lzoltan'],
+ [unset ac_cv_lib_zoltan_Zoltan_LB_Partition
+ [ZOLTAN_LIBS="-lzoltan -lparmetis -lmetis"],
+ [AC_MSG_ERROR("mbzoltan requires zoltan")],
+ [-lparmetis -lmetis])])
+ AC_SUBST(ZOLTAN_LIBS)
+ AC_SUBST(ZOLTAN_LIB_FLAGS)
+ AC_SUBST(ZOLTAN_INC_FLAGS)
+fi
+# Chaco
+if test $ENABLE_mbchaco = yes; then
+ AC_ARG_WITH(chaco,
+ [AC_HELP_STRING([--with-chaco=DIR], [Specify directory containing chaco source and library])],
+ [CHACO_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-chaco=\"${withval}\""
+ ], [CHACO_DIR=])
+ case "x$CHACO_DIR" in
+ xno|x)
+ CHACO_MISSING=yes
+ xyes)
+ AC_MSG_ERROR([--with-chaco requires and argument])
+ esac
+ if ! test -d "$CHACO_DIR"; then
+ AC_MSG_WARN([$CHACO_DIR : not a directory.])
+ fi
+ AC_CHECK_FILES([${CHACO_DIR}/code/main/defs.h ${CHACO_DIR}/code/main/params.h],
+ [], [AC_MSG_WARN([$CHACO_DIR : not a valid chaco source]); CHACO_MISSING=yes])
+ old_LIBS="$LIBS"
+ LIBS="-L${CHACO_DIR}/code"
+ AC_CHECK_LIB([chaco],[read_params],[],
+ [AC_MSG_WARN([Could not find libchaco in ${CHACO_DIR}/code]); CHACO_MISSING=yes],
+ [-lm])
+ CHACO_INCLUDES="-I${CHACO_DIR}/code/main"
+ LIBS="$old_LIBS"
+ CHACO_LIBS="-L${CHACO_DIR}/code -lchaco -lm"
+ AC_SUBST(CHACO_LIBS)
+ AC_SUBST(CHACO_INCLUDES)
+fi
+# qvdual
+GRAPHVIZ_MISSING=no
+X_MISSING=no
+VTK_MISSING=no
+QT_MISSING=no
+if test $ENABLE_qvdual = yes; then
+# GraphViz
+ AC_ARG_WITH([graphviz],
+ [AC_HELP_STRING([--with-graphviz=DIR], [Specify directory containing GraphViz])],
+ [GRAPH_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-graphviz=\"${withval}\""
+ ],[GRAPH_DIR=])
+ case "x$GRAPH_DIR" in
+ xno)
+ GRAPHVIZ_MISSING=yes
+ xyes|x)
+ GRAPH_INC_DIR=
+ GRAPH_DIR=
+ for dir in /usr /usr/local; do
+ if test "x" = "x$GRAPH_DIR"; then
+ AC_CHECK_FILE([${dir}/include/graphviz/gvc.h],[GRAPH_DIR="$dir"])
+ fi
+ done
+ AC_MSG_CHECKING([for GraphViz include dir])
+ if test "x" != x"$GRAPH_DIR"; then
+ GRAPH_INC_DIR="-I${GRAPH_DIR}/include/graphviz"
+ fi
+ AC_MSG_RESULT([$GRAPH_INC_DIR])
+ AC_MSG_CHECKING([for GraphViz library dir])
+ GRAPH_LIB_DIR=
+ for dir in ${GRAPH_DIR}/lib64/graphviz ${GRAPH_DIR}/lib/graphviz /usr/lib64/graphviz /usr/lib/graphviz /usr/local/lib64/graphviz /usr/local/lib/graphviz /lib64/graphviz /lib/graphviz; do
+ if test "x" = "x$GRAPH_LIB_DIR"; then
+ GRAPH_LIB_DIR=-L$dir
+ fi
+ fi
+ done
+ AC_MSG_RESULT([$GRAPH_LIB_DIR])
+ x?*)
+ GRAPH_INC_DIR=
+ for dir in ${GRAPH_DIR}/include/graphviz ${GRAPH_DIR}/include ${GRAPH_DIR}; do
+ if test "x" = "x$GRAPH_INC_DIR"; then
+ AC_CHECK_FILE([${dir}/gvc.h],[GRAPH_INC_DIR="-I$dir"])
+ fi
+ done
+ if test "x" = x"$GRAPH_INC_DIR"; then
+ AC_MSG_RESULT([no])
+ else
+ fi
+ GRAPH_LIB_DIR=
+ for dir in ${GRAPH_DIR}/lib/graphviz ${GRAPH_DIR}/lib ${GRAPH_DIR}; do
+ fi
+ fi
+ done
+ if test "x" = x"$GRAPH_LIB_DIR"; then
+ else
+ fi
+ esac
+ GRAPH_LIBS="$GRAPH_LIB_DIR -lgvc -lgraph"
+ old_CXXFLAGS="$CXXFLAGS"
+ CXXFLAGS="$GRAPH_INC_DIR"
+ CPPFLAGS="$GRAPH_INC_DIR"
+ old_LIBS="$LIBS"
+ LIBS=$GRAPH_LIBS
+ AC_CHECK_HEADERS([gvc.h],[],[AC_MSG_WARN([Missing GraphViz header]); GRAPHVIZ_MISSING=yes])
+ AC_CHECK_LIB([gvc],[gvContext],[],[AC_MSG_WARN([Cannot find GraphViz library: -lgraph]); GRAPHVIZ_MISSING=yes])
+ LIBS="$old_LIBS"
+ CXXFLAGS="$old_CXXFLAGS"
+# X
+ AC_PATH_X
+ AC_PATH_XTRA
+ if test "xyes" = "x$no_x"; then
+ X_MISSING=yes
+ fi
+# VTK
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ AC_ARG_WITH([vtk],
+ [AC_HELP_STRING([--with-vtk=DIR], [Specify directory containing VTK])],
+ [VTK_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-vtk=\"${withval}\""
+ ],[VTK_DIR=])
+ VTK_INCLUDES=
+ case "x$VTK_DIR" in
+ xno)
+ VTK_MISSING=yes
+ xyes|x)
+ VTK_LIB_DIR=
+ VTK_INC_DIR=
+ for dir in /usr/include/vtk /usr/local/include/vtk /include/vtk /usr/include/vtk-5.0; do
+ if test "x" = "x$VTK_INC_DIR"; then
+ AC_CHECK_FILE([${dir}/vtkRenderer.h],[VTK_INC_DIR="-I$dir"])
+ fi
+ done
+ if test x = x"$VTK_INC_DIR"; then
+ AC_CHECK_HEADER([vtkRenderer.h],[],
+ [VTK_MISSING=yes])
+ else
+ VTK_INCLUDES="$VTK_INC_DIR"
+ fi
+ old_LIBS="$LIBS"
+ for dir in /usr/lib/vtk /usr/lib /usr/bin /usr; do
+ if test "x" = "x$VTK_LIB_DIR"; then
+ LIBS="$old_LIBS -L$dir"
+ unset ac_cv_lib_vtkCommon
+ unset ac_cv_lib_vtkCommon_main
+ AC_HAVE_LIBRARY([vtkCommon],[VTK_LIB_DIR=$dir])
+ fi
+ done
+ VTK_MISSING=yes
+ fi
+ LIBS="$old_LIBS"
+ x?*)
+ VTK_LIB_DIR=
+ VTK_INC_DIR=
+ for dir in ${VTK_DIR}/include/vtk ${VTK_DIR}/include/vtk/Rendering ${VTK_DIR}/include ${VTK_DIR}; do
+ fi
+ done
+ # Check for non-installed VTK source
+ AC_CHECK_FILE([${VTK_DIR}/Rendering/vtkRenderer.h],[
+ for subdir in . Common Filtering GenericFiltering Graphics Hybrid Imaging Parallel Patented Rendering Utilities Utilities/vtkexpat Utilities/expat Utilities/DICOMParser Utilties/vtkpng Utilities/vtkzlib Utilities/freetype/include/freetype Wrapping; do
+ AC_MSG_CHECKING([for directory ${VTK_DIR}/$subdir])
+ if test -d ${VTK_DIR}/$subdir; then
+ VTK_INC_DIR="$VTK_INC_DIR -I${VTK_DIR}/$subdir"
+ AC_MSG_RESULT([yes])
+ else
+ fi
+ done
+ ],[VTK_MISSING=yes]
+ fi
+ old_LIBS="$LIBS"
+ for dir in ${VTK_DIR}/lib/vtk ${VTK_DIR}/lib ${VTK_DIR}/bin ${VTK_DIR}; do
+ fi
+ done
+ VTK_MISSING=yes
+ fi
+ LIBS="$old_LIBS"
+ esac
+dnl Define a function that checks for the existence of a library
+dnl and if it exists, prepends the corresponding link flag to a
+dnl sepecified variable
+dnl Arguments:
+dnl - The library name
+dnl - The name of the variable to which to prepend the library link flag
+dnl - List of extra libraries required for link test
+dnl - Optional library path linker argument (e.g. -L/opt/foo)
+ AC_DEFUN([SNL_CHECK_LIB_LIST],[
+ old_LIBS="$LIBS"
+ LIBS="$4 ${$2} $old_LIBS"
+ AC_HAVE_LIBRARY([$1],[$2="-l$1 ${$2}"],[],[$3])
+ LIBS="$old_LIBS"
+ # These are ordered such that a given library depends only on those libraries
+ # that preceed it in the list.
+ SNL_CHECK_LIB_LIST([pthread],[vtk_sys_libs])
+ SNL_CHECK_LIB_LIST([dl], [vtk_sys_libs])
+ SNL_CHECK_LIB_LIST([m], [vtk_sys_libs])
+ SNL_CHECK_LIB_LIST([gcc], [vtk_sys_libs])
+ x_libs_arg="$X_EXTRA_LIBS -lX11 $X_PRE_LIBS"
+ SNL_CHECK_LIB_LIST([Xext],[vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ SNL_CHECK_LIB_LIST([ICE], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ SNL_CHECK_LIB_LIST([SM], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ SNL_CHECK_LIB_LIST([Xt], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ SNL_CHECK_LIB_LIST([GL], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ SNL_CHECK_LIB_LIST([GLU], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ vtk_libs_arg="-L$x_libraries $vtk_x_libs $X_EXTRA_LIBS -lX11 $X_PRE_LIBS $vtk_sys_libs"
+ SNL_CHECK_LIB_LIST([vtksys], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkCommon], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkDICOMParser],[vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkfreetype], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkexpat], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkzlib], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkpng], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkjpeg], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtktiff], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkftgl], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkFiltering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkImaging], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([verdict], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkGraphics], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkNetCDF], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkexoIIc], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkmetaio], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkIO], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkRendering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkParallel], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkHybrid], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([QVTK], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ # Make sure we found at least vtkCommon and vtkRendering
+ if ! echo "x $vtk_libs" | grep lvtkCommon >/dev/null; then
+ AC_MSG_WARN("VTK library 'vtkCommon' not found.")
+ VTK_MISSING=yes
+ fi
+ if ! echo "x $vtk_libs" | grep lvtkRendering >/dev/null; then
+ AC_MSG_WARN("VTK library 'vtkRendering' not found.")
+ VTK_MISSING=yes
+ fi
+ AC_LANG_RESTORE
+# QT
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ AC_ARG_VAR([QTDIR],[QT installation directory])
+ if test x"$QTDIR" = x; then
+ search_path="$PATH"
+ qlibdir=
+ incdir=
+ for dir in /usr/include/qt3 /usr/local/include/qt3 /include/qt3; do
+ if test x = x${incdir}; then
+ incdir=-I$dir
+ fi
+ fi
+ done
+ else
+ search_path="${QTDIR}/bin"
+ qlibdir="-L${QTDIR}/lib"
+ incdir="-I${QTDIR}/include"
+ fi
+ AC_PATH_PROG([MOC],[moc],[],[$search_path])
+ if test x = x"$MOC";then
+ AC_MSG_WARN([Cannot find moc (Qt meta object compiler)])
+ QT_MISSING=yes
+ fi
+ AC_SUBST(MOC)
+ AC_PATH_PROG([UIC],[uic],[],[$search_path])
+ if test x = x"$UIC";then
+ AC_MSG_WARN([Cannot find uic (Qt user interface compiler)])
+ QT_MISSING=yes
+ fi
+ AC_SUBST(UIC)
+ CXXFLAGS="$incdir"
+ CPPFLAGS="$incdir"
+ AC_CHECK_HEADERS([qlineedit.h qevent.h qapplication.h \
+ qwidget.h qtimer.h qpixmap.h qwidgetplugin.h \
+ qobject.h qmetaobject.h],[],
+ [QT_MISSING=yes])
+ QT_INCLUDES="$incdir"
+ old_LIBS="$LIBS"
+ LIBS="$LIBS $qlibdir"
+ # Cannot use AC_HAVE_LIBRARY for qt-mt because of
+ # autoconf bug with libraries that have a '-' in their name.
+ #AC_HAVE_LIBRARY([qt-mt],[QT_LIBS="$qlibdir -lqt-mt"],[
+ AC_MSG_CHECKING([for main in -lqt-mt])
+ QT_LIBS="$qlibdir -lqt-mt"
+ AC_TRY_LINK_FUNC(main,[AC_MSG_RESULT([yes])],[
+ LIBS="$old_LIBS $qlibdir"
+ AC_HAVE_LIBRARY([qt],[QT_LIBS="$qlibdir -lqt"],[
+ QT_MISSING=yes
+ LIBS="$old_LIBS"
+# X/VTK/QT
+ dnl Merge lists of libraries
+ dnl Arguments
+ dnl - name of output variable
+ dnl - first list
+ dnl - second list
+ AC_DEFUN([SNL_MERGE_LISTS],[
+ $1="$2"
+ # Reverse list two
+ for item3 in $3; do
+ found=no
+ for item2 in $2; do
+ if test "x$item2" = "x$item3"; then found=yes; fi
+ done
+ if test "$found" = "no"; then $1="${$1} $item3"; fi
+ done
+ $1="${$1} $2"
+ SNL_MERGE_LISTS([XLIBS_tmp],[$X_EXTRA_LIBS -lX11 $X_PRE_LIBS],[$vtk_x_libs])
+ SNL_MERGE_LISTS([XLIBS],[$vtk_sys_libs],[$XLIBS_tmp])
+ QVDUAL_LIBS="$LIBS $GRAPH_LIBS -L$VTK_LIB_DIR $vtk_libs $QT_LIBS $XLIBS"
+ QVDUAL_INCLUDES="$GRAPH_INC_DIR $VTK_INCLUDES $QT_INCLUDES"
+ AC_SUBST(VTK_LIB_DIR)
+ AC_SUBST(QVDUAL_LIBS)
+ AC_SUBST(QVDUAL_INCLUDES)
+fi
+# CGM
+if test $ENABLE_dagmc = yes; then
+ AC_ARG_WITH(cgm,
+ [AC_HELP_STRING([--with-cgm=DIR], [Specify directory containing CGM])],
+ [CGM_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cgm=\"${withval}\""
+ ], [CGM_DIR=])
+ case "x$CGM_DIR" in
+ xno|x)
+ CGM_MISSING=yes
+ xyes)
+ AC_MSG_ERROR([--with-cgm requires an argument])
+ if ! test -d "$CGM_DIR"; then
+ AC_MSG_WARN([$CGM_DIR : not a directory.])
+ fi
+ CGM_MISSING=no
+ CGM_MAKE=
+ AC_CHECK_FILE([${CGM_DIR}/lib/cgm.make],
+ [CGM_MAKE="${CGM_DIR}/lib/cgm.make";
+ DEFINES="$DEFINES -DCGM"],
+ [AC_CHECK_FILE([${CGM_DIR}/cgm.make],
+ [CGM_MAKE="${CGM_DIR}/cgm.make";
+ [AC_MSG_WARN([$CGM_DIR : not a configured CGM]);
+ CGM_MISSING=yes])
+ esac
+ if test "x$CGM_MISSING" = "xno"; then
+ CGM_CONFIG_OPTIONS="include $CGM_MAKE"
+ AC_MSG_CHECKING([Checking for GeometryQueryTool::ray_fire(RefFace*,...)])
+ old_LIBS="$LIBS"
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_DEFINES], [CPPFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_INCLUDES],[CPPFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LTFLAGS], [LDFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LDFLAGS], [LDFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LIBS], [LIBS="$make_val $libs"])
+ AC_LINK_IFELSE(
+ [AC_LANG_PROGRAM([#include "GeometryQueryTool.hpp"
+ #include "CubitVector.hpp"],
+ [CubitVector a,b;
+ DLIList<double> c;
+ GeometryQueryTool::instance()->fire_ray((RefFace*)0, a, b, c );
+ [MOAB_CGM_DEFINES="-DHAVE_CGM_FIRE_RAY"; AC_MSG_RESULT(yes)],
+ [AC_MSG_RESULT(no)])
+ LIBS="$old_LIBS"
+ fi
+ AC_SUBST(MOAB_CGM_DEFINES)
+ AC_SUBST(CGM_DIR)
+ AC_SUBST(CGM_CONFIG_OPTIONS)
+ DAGMC_CONFIG_OPTIONS="include \${MOAB_LIBDIR}/dagmc.make"
+ AC_SUBST(DAGMC_CONFIG_OPTIONS)
+fi
+AM_CONDITIONAL( HAVE_CGM, [test "x$CGM_MISSING" = "xno"] )
+# iMesh Babel
+if test "x$ENABLE_imesh" = "xyes"; then
+ AC_ARG_WITH(babel,
+ [AC_HELP_STRING([--with-babel=DIR], [Specify directory containing babel])],
+ [BABEL_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-babel=\"${withval}\""
+ ], [BABEL_DIR=no])
+ case "x$BABEL_DIR" in
+ xno)
+ BABEL_DIR=
+ USE_BABEL=no
+ xyes|x)
+ BABEL_DIR=/usr/local
+ AC_CHECK_FILE([${BABEL_DIR}/bin/babel], [USE_BABEL=yes], [USE_BABEL=no])
+ esac
+ AC_SUBST(BABEL_DIR)
+ AC_SUBST(USE_BABEL)
+else
+ USE_BABEL=no
+fi
+AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"])
+# Output Files
+AC_SUBST([INCLUDES])
+AC_SUBST([DEFINES])
+AC_SUBST([AM_CPPFLAGS])
+AC_SUBST([AM_LDFLAGS])
+AC_SUBST([AM_CXXFLAGS])
+AC_SUBST([AM_CFLAGS])
+AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
+AC_ARG_VAR([FC], [FORTRAN compiler command])
+AC_CONFIG_HEADERS([config.h])
+AC_CONFIG_HEADERS([MBVersion.h])
+AC_CONFIG_HEADERS([MBEntityHandle.h])
+AC_CONFIG_HEADERS([MBCN_FCDefs.h])
+AC_CONFIG_FILES([Makefile
+ moab.make
+ testdir.h
+ parallel/Makefile
+ mhdf/Makefile
+ test/Makefile
+ test/h5file/Makefile
+ test/dual/Makefile
+ test/obb/Makefile
+ test/perf/Makefile
+ tools/Makefile
+ tools/iMesh/Makefile
+ tools/iMesh/iMesh-Defs.inc
+ tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
+ tools/iMesh/SIDL/Makefile
+ tools/iMesh/SIDL/common.make
+ tools/mbperf/Makefile
+ tools/mbchaco/Makefile
+ tools/mbcoupler/Makefile
+ tools/mbzoltan/Config.moab
+ tools/mbzoltan/Makefile
+ tools/mcnpmit/Makefile
+ tools/qvdual/Makefile
+ tools/dagmc/Makefile
+ tools/dagmc/dagmc.make
+ doc/Makefile
+ doxygen/Makefile
+AC_OUTPUT
+AC_MSG_RESULT([C: $CC $CFLAGS $CPPFLAGS])
+AC_MSG_RESULT([C++: $CXX $CXXFLAGS $CPPFLAGS])
+AC_MSG_RESULT([Fortran: $FC $FCFLAGS])
+if test "x$GRAPHVIZ_MISSING" = "xyes"; then
+ AC_MSG_WARN([Could not find GraphViz library. Build will FAIL!!! Try \"--with-graphviz=DIR\"])
+fi
+if test "x$X_MISSING" = "xyes"; then
+ AC_MSG_WARN([Cound not find X client. Build will FAIL!!!])
+else
+ if test "x$QT_MISSING" = "xyes"; then
+ AC_MSG_WARN([Cound not find QT. Build will FAIL!!! Try setting \"QTDIR\"])
+ fi
+ if test "x$VTK_MISSING" = "xyes"; then
+ AC_MSG_WARN([Count not find VTK. Build will FAIL!!! Try \"--with-VTK=DIR\"])
+ fi
+fi
+if test "x$HAVE_HDF5" = "xno"; then
+ AC_MSG_WARN([
+* MOAB has been configured w/out the HDF5 library.
+* Support for native file format is disabled!
+fi
+if test "x$HAVE_NETCDF" = "xno"; then
+ AC_MSG_WARN([
+* MOAB has been configured w/out the NetCDF library.
+* Support for ExodusII/Genesis and other file formats is disabled!
+fi
Property changes on: MOAB/trunk/configure.ac
___________________________________________________________________
+ Author Date Id Revision
+ native
Deleted: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2009-03-17 12:03:39 UTC (rev 2719)
+++ MOAB/trunk/configure.in 2009-03-17 13:37:01 UTC (rev 2720)
@@ -1,972 +0,0 @@
-# Standard Stuff
-AC_INIT(MOAB, 3.99)
-AC_CONFIG_MACRO_DIR([m4])
-AC_CANONICAL_SYSTEM
-AM_INIT_AUTOMAKE
-AC_PROG_SED
-EXTRA_GNU_FLAGS='-Wall -pipe -pedantic'
-SNL_CHECK_COMPILERS
-AM_CONDITIONAL(PARALLEL,[test "x$WITH_MPI" != "xno"])
-LIBS="-lm"
-AC_PROG_LN_S
-AC_PROG_MAKE_SET
-AC_DISABLE_SHARED
-AC_PROG_LIBTOOL
-AC_CHECK_PROG([ZCAT],[gunzip],[gunzip -c],[])
-AC_CHECK_PROG([ZCAT],[gzip],[gzip -cd],[])
-AC_CHECK_PROG([ZCAT],[zcat],[zcat],[])
-if test "x" = "x$ZCAT"; then
- AC_MSG_WARN([[Cannot run tests: no way to uncompress input files.]])
-fi
-AC_SUBST([ZCAT])
-AM_CONDITIONAL([HAVE_ZCAT],[test "x" = "x$ZCAT"])
-SNL_TEMPLATE_SPECIALIZATION
-SNL_TEMPLATE_FUNC_SPECIALIZATION
-DEFINES="$DEFINES $TEMPLATE_SPECIALIZATION $TEMPLATE_FUNC_SPECIALIZATION"
-if test "x" != "x$FC"; then
- AC_FC_WRAPPERS
-fi
-# Version Stuff
-AC_DEFINE(MB_VERSION,["AC_PACKAGE_VERSION"],[MOAB Version])
-VERSION_MAJOR=`expr AC_PACKAGE_VERSION : '\([[0-9]]*\)'`
-VERSION_MINOR=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.\([[0-9]]*\)'`
-VERSION_PATCH=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.[[0-9]]*\.\(.*\)'`
-test "x" != "x$VERSION_MAJOR" || AC_MSG_ERROR("Invalid version string: AC_PACKAGE_VERSION")
-test "x" != "x$VERSION_MINOR" || AC_MSG_ERROR("Invalid version string: AC_PACKAGE_VERSION")
-AC_DEFINE_UNQUOTED(MB_VERSION_MAJOR,$VERSION_MAJOR,[MOAB Major Version])
-AC_DEFINE_UNQUOTED(MB_VERSION_MINOR,$VERSION_MINOR,[MOAB Minor Version])
-if test "x" != "x$VERSION_PATCH"; then
- AC_DEFINE_UNQUOTED(MB_VERSION_PATCH,$VERSION_PATCH,[MOAB Patch Level])
- VERSION_STRING="AC_PACKAGE_STRING"
-elif test $VERSION_MINOR -eq 99; then
- VERSION_STRING="AC_PACKAGE_STRING (Alpha)"
-else
- VERSION_STRING="AC_PACKAGE_STRING (Beta)"
-fi
-AC_DEFINE_UNQUOTED(MB_VERSION_STRING,"${VERSION_STRING}",[MOAB Version String])
-# Extract libtool config
-ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [MOAB_CXX_LINKFLAGS])
-ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [MOAB_CXX_LIBS])
-AC_SUBST(MOAB_CXX_LINKFLAGS)
-AC_SUBST(MOAB_CXX_LIBS)
-# HANDLE SIZE
-AC_CHECK_HEADER([inttypes.h], [AC_DEFINE(MOAB_HAVE_INTTYPES_H, [], [MOAB qualified HAVE_INTTYPES_H]) ])
-AC_CHECK_HEADER([stdint.h], [AC_DEFINE(MOAB_HAVE_STDINT_H, [], [MOAB qualified HAVE_STDINT_H]) ])
-AC_CHECK_HEADER([sys/types.h],[AC_DEFINE(MOAB_HAVE_SYS_TYPES_H, [], [MOAB qualified HAVE_SYS_TYPES_H])])
-AC_CHECK_HEADER([stddef.h], [AC_DEFINE(MOAB_HAVE_STDDEF_H, [], [MOAB qualified HAVE_STDDEF_H]) ])
-AC_CHECK_HEADER([stdlib.h], [AC_DEFINE(MOAB_HAVE_STDLIB_H, [], [MOAB qualified HAVE_STDLIB_H]) ])
-AC_ARG_ENABLE([64bit-handles],
- [AC_HELP_STRING([--enable-64bit-handles],[Force MBEntityHandle to be 64 bits])],
- [AC_CHECK_TYPE([uint64_t],
- [AC_DEFINE(MOAB_FORCE_64_BIT_HANDLES,[],[Use int64_t for handles])
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-64bit-handles"],
- [AC_MSG_ERROR([Platform does not have uint64_t. Cannot force 64-bit handles])])
-AC_ARG_ENABLE([32bit-handles],
- [AC_HELP_STRING([--enable-32bit-handles],[Force MBEntityHandle to be 32 bits])],
- [AC_CHECK_TYPE([uint32_t],
- [AC_DEFINE(MOAB_FORCE_32_BIT_HANDLES,[],[Use int32_t for handles])
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-32bit-handles"],
- [AC_MSG_ERROR([Platform does not have uint32_t. Cannot force 32-bit handles])])
-if test "x$HANDLE_TYPE" = "x"; then
- AC_CHECK_TYPE([size_t],
- [AC_DEFINE(MOAB_HAVE_SIZE_T,[],[System provides size_t typedef])],
- [AC_MSG_WARN([size_t not defined, assuming sizeof(void*) == sizeof(long)])]
- AC_CHECK_TYPE([ptrdiff_t],
- [AC_DEFINE(MOAB_HAVE_PTRDIFF_T,[],[System provides ptrdiff_t typedef])],
- [AC_MSG_WARN([ptrdiff_t not defined, assuming sizeof(void*) == sizeof(long)])]
-fi
-# System Headers
-AC_CHECK_HEADER([ieeefp.h],[DEFINES="$DEFINES -DHAVE_IEEEFP_H"] )
-if test "xyes" = "x$enable_debug"; then
- AC_CHECK_HEADER( [valgrind/memcheck.h], [CPPFLAGS="$CPPFLAGS -DVALGRIND"] )
-fi
-# BOOST OPTIONS
-dnl SNL_CHECK_BOOST( [boost/pool/object_pool.hpp] )
-MK_CHECK_UNORDERED_MAP([CPPFLAGS="$CPPFLAGS -DUNORDERED_MAP_NS=$result -DHAVE_UNORDERED_MAP=${incdir}unordered_map"])
-# MPI OPTIONS
-AC_ARG_VAR(MPIEXEC,[Program to use to run parallel tests (default: mpiexec or mpirun)])
-AC_ARG_VAR(MPIEXEC_NP,[Command line flag to specify number of processors to use (default: -np)])
-AC_ARG_VAR(NP,[Number of processors to on which to run parallel tests (default: 2)])
-if test "x$WITH_MPI" != "xno"; then
- DEFINES="$DEFINES -DUSE_MPI"
- AC_CHECK_HEADER([mpi.h],[],[AC_MSG_ERROR([mpi.h not found or not working])])
- AC_MSG_CHECKING([If -DMPICH_IGNORE_CXX_SEEK is necessary])
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_PREPROC_IFELSE([AC_LANG_PROGRAM( [[#include <stdio.h>
- #include <mpi.h>]],[])],
- [AC_MSG_RESULT([no])],
- [save_CPPFLAGS="$CPPFLAGS"
- CPPFLAGS="$CPPFLAGS -DMPICH_IGNORE_CXX_SEEK"
- [AC_MSG_RESULT([yes]); AM_CPPFLAGS="$AM_CPPLFLAGS -DMPICH_IGNORE_CXX_SEEK" ],
- [AC_MSG_ERROR([mpi.h is not usable])]),
- CPPFLAGS="$save_CPPFLAGS"])
- AC_LANG_RESTORE
- if test "x$MPIEXEC" = "x"; then
- if test "x$WITH_MPI" != "xyes"; then
- AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true],[${WITH_MPI}:${WITH_MPI}/bin])
- else
- AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true])
- fi
- fi
- if test "x$MPIEXEC_NP" = "x"; then
- MPIEXEC_NP="-np"
- fi
- if test "x$NP" = "x"; then
- NP=2
- fi
-fi
-AM_CONDITIONAL(USE_MPI, [test "xno" != "x$WITH_MPI"])
-AM_CONDITIONAL(USE_MPIEXEC, [test "x$MPIEXEC" != "xtrue"])
-# HDF5 OPTIONS
-SNL_CHECK_HDF5
-if test "xno" = "x$HAVE_HDF5"; then
- AC_MSG_WARN([Support for native HDF5 file format disabled])
-else
- DEFINES="$DEFINES -DHDF5_FILE"
-fi
-AM_CONDITIONAL(HDF5_FILE, [test "xno" != "x$HAVE_HDF5"])
-AM_CPPFLAGS="$HDF5_CPPFLAGS $AM_CPPFLAGS"
-AM_LDFLAGS="$HDF5_LDFLAGS $AM_LDFLAGS"
-AC_SUBST(HDF5_LIBS)
-HAVE_HDF5_PARALLEL=no
-if test "xno" != "x$HAVE_HDF5"; then
- if test "xno" != "x$WITH_MPI"; then
- old_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
- AC_CHECK_LIB( [hdf5], [H5Pset_fapl_mpio], [HAVE_HDF5_PARALLEL=yes],
- [AC_MSG_WARN("libhdf5 library does not include parallel support. Parallel HDF5 I/O disabled")],
- [$HDF5_LIBS]
- LDFLAGS="$old_LDFLAGS"
- fi
-fi
-AM_CONDITIONAL(PARALLEL_HDF5, [test "xno" != "x$HAVE_HDF5_PARALLEL"])
-if test "xno" != "x$HAVE_HDF5_PARALLEL"; then
- DEFINES="$DEFINES -DHDF5_PARALLEL"
-fi
-# NetCDF OPTIONS
-SNL_CHECK_NETCDF
-if test "xno" = "x$HAVE_NETCDF"; then
- AC_MSG_WARN([Support for ExodusII file format disabled])
- NETCDF_LIBS=
-else
- DEFINES="$DEFINES -DNETCDF_FILE"
- NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"
-fi
-AM_CONDITIONAL(NETCDF_FILE, [test "xno" != "x$HAVE_NETCDF"])
-AM_CPPFLAGS="$NETCDF_CPPFLAGS $AM_CPPFLAGS"
-AM_LDFLAGS="$NETCDF_LDFLAGS $AM_LDFLAGS"
-AC_SUBST(NETCDF_LIBS)
-# Documentation
-AC_ARG_ENABLE([doxygen],
-[AC_HELP_STRING([[--enable-doxygen(=DIR)]],[Specify directory where Doxygen program is installed])
-AC_HELP_STRING([--disable-doxygen],[Do not generate API documentation (default)])],
- [ENABLE_DOXYGEN="$enableval"],[ENABLE_DOXYGEN=no] )
-if test "x$ENABLE_DOXYGEN" = "xyes"; then
- AC_PATH_PROG( [DOXYGEN], [doxygen], [no] )
-elif test "x$ENABLE_DOXYGEN" != "xno"; then
- AC_PATH_PROG( [DOXYGEN], [doxygen], [no], [$ENABLE_DOXYGEN] )
-fi
-if test "x$ENABLE_DOXYGEN" != "xno"; then
- if test "x$DOXYGEN" = "xno"; then
- AC_MSG_ERROR("Doxygen executable not found.")
- fi
-fi
-AC_SUBST([DOXYGEN])
-AM_CONDITIONAL([ENABLE_DOXYGEN],[test "x$ENABLE_DOXYGEN" != "xno"])
-# Optional Tools
- # Define a macro to avoid typing this for each individual tool
- # Usage: MB_OPTIOANL_TOOL( name, default )
- # name - name of option
- # default - yes/no, $ENABLE_TOOLS overrides this if set
- # Actions:
- # sets ENABLE_${tool} to 'yes' or 'no'
- # creates ENABLE_${tool} automake conditional
-AC_DEFUN([MB_OPTIONAL_TOOL],[
- mb_default_$1=$2
- if test "x" != "x$ENABLE_TOOLS"; then
- mb_default_$1="$ENABLE_TOOLS"
- fi
- AC_ARG_ENABLE( [$1],
-[AC_HELP_STRING([--enable-$1],[Build tool: $1])
-AC_HELP_STRING([--disable-$1],[Don't build $1])],
- [ENABLE_$1=$enableval
-DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-$1=\"${enableval}\""
-],[ENABLE_$1=${mb_default_$1}] )
- AM_CONDITIONAL([ENABLE_$1],[test "x${ENABLE_$1}" != "xno"])
- AC_MSG_CHECKING([if $1 is to be built])
- AC_MSG_RESULT([${ENABLE_$1}])
- # The default for all tools
-AC_ARG_ENABLE( [tools], [
-AC_HELP_STRING([--enable-tools],[Build all tools by default])
-AC_HELP_STRING([--disable-tools],[Disable all tools by default])],
- [ENABLE_TOOLS=$enableval],[ENABLE_TOOLS=] )
- # Individual tools
-MB_OPTIONAL_TOOL([mbconvert], [yes])
-MB_OPTIONAL_TOOL([hexmodops], [yes])
-MB_OPTIONAL_TOOL([mbchaco], [no] )
-MB_OPTIONAL_TOOL([mbperf], [yes])
-MB_OPTIONAL_TOOL([qvdual], [no] )
-MB_OPTIONAL_TOOL([mbsize], [yes])
-MB_OPTIONAL_TOOL([mbskin], [yes])
-MB_OPTIONAL_TOOL([mbtagprop], [yes])
-MB_OPTIONAL_TOOL([mcnpmit], [no])
-MB_OPTIONAL_TOOL([mbcoupler], [$ENABLE_mcnpmit] )
-MB_OPTIONAL_TOOL([spheredecomp], [yes])
-MB_OPTIONAL_TOOL([mbsurfplot], [yes])
-MB_OPTIONAL_TOOL([mbzoltan], [no] )
-MB_OPTIONAL_TOOL([dagmc], [yes])
-MB_OPTIONAL_TOOL([gsets], [yes])
-# iMesh
-AC_ARG_ENABLE( [imesh],
-[AC_HELP_STRING([--enable-imesh(=nofortran)],[Build iMesh interface. If optional
-'nofortran' argument is given, support for FORTRAN name mangling will be disabled.])
-AC_HELP_STRING([--disable-imesh],[Don't build support for iMesh interface.])],
-[DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-imesh=\"${enableval}\""],
-[enableval=yes] )
-case $enableval in
- yes)
- ENABLE_imesh=yes
- nofortran|NoFortran|noFORTRAN|NoFORTRAN|Nofortran)
- ENABLE_imesh=yes
- no)
- ENABLE_imesh=no
- AC_MSG_ERROR([Invalid argument to --enable-imesh : $enableval])
-esac
-AC_MSG_CHECKING([if iMesh support is to be built])
-AC_MSG_RESULT([$ENABLE_imesh])
-AM_CONDITIONAL([ENABLE_imesh],[test "xyes" == "x$ENABLE_imesh"])
-# Zoltan
-if test $ENABLE_mbzoltan = yes; then
- if test "x$WITH_MPI" = "xno"; then
- AC_MSG_ERROR([--enable-mbzoltan requires MPI, try specifying --with-mpi])
- fi
- ZOLTAN_LIB_FLAGS=
- ZOLTAN_INC_FLAGS=
- ZOLTAN_LIBS=
- ZOLTAN_ARCH=
- ZOLTAN_DIR=
- AC_ARG_WITH( [zoltan],
- [AC_HELP_STRING([--with-zoltan=DIR],[Specify Zoltan build directory])],
- [if test "xyes" = "$withval"; then
- AC_MSG_WARN([Ingoring --with-zoltan flag w/out value])
- elif test -d $withval/$include; then
- ZOLTAN_INC_FLAGS="$ZOLTAN_INC_FLAGS -I$withval/include"
- ZOLTAN_DIR="$withval"
- else
- AC_MSG_ERROR("$withval/include : not a directory")
- fi
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-zoltan=\"${withval}\""
- AC_ARG_WITH([zoltan-arch],
- [AC_HELP_STRING([--with-zoltan-arch=OS],[Specify zoltan architecture])],
- [if test "xyes" = "x$withval"; then
- AC_MSG_ERROR([--with-zoltan-arch flag requires a value])
- elif test "x" = "x$ZOLTAN_DIR"; then
- AC_MSG_WARN([Ingoring --with-zoltan-arch without --with-zoltan])
- elif test -d "$ZOLTAN_DIR/Obj_$withval"; then
- ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$ZOLTAN_DIR/Obj_$withval"
- else
- AC_MSG_ERROR("$ZOLTAN_DIR/Obj_$withval : not a directory")
- fi],
- [if test "x" != "x$ZOLTAN_DIR"; then
- AC_MSG_WARN([Expect --with-zoltan-arch with --with-zoltan])
- if test -d $ZOLTAN_DIR/lib; then
- AC_MSG_WARN("Guessing '$ZOLTAN_DIR/lib'")
- ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$ZOLTAN_DIR/lib"
- else
- # if only one Obj_$ARCH dir, then us it
- found=no
- for dir in $ZOLTAN_DIR/Obj_*; do
- if test -d $dir; then
- if test "xyes" = "x$found"; then
- AC_MSG_ERROR("Multiple Zoltan Obj_$ARCH dirs. --with-zoltan-arch required.")
- fi
- ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$dir"
- found=yes
- fi
- done
- if test "xno" = "x$found"; then
- AC_MSG_ERROR('No Zoltan Obj_$ARCH dir found. --with-zoltan-arch required.')
- fi
- fi
- fi
- AC_ARG_WITH([parmetis],
- [AC_HELP_STRING([--with-parmetis=DIR],
- [Directory containing Parmetis library for Zoltan])],
- AC_MSG_WARN([Ingoring --with-parmetis flag w/out value])
- elif test -d "$withval"; then
- ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$withval"
- else
- AC_MSG_ERROR("$withval: not a directory")
- fi]
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-parmetis=\"${withval}\""
- old_CPPFLAGS="$CPPFLAGS"
- CPPFLAGS="$CPPFLAGS $ZOLTAN_INC_FLAGS -DMPICH_IGNORE_CXX_SEEK"
- AC_LANG_PUSH([C++])
- AC_CHECK_HEADER([zoltan_cpp.h],[],[AC_MSG_ERROR("mbzoltan requires zoltan")])
- AC_LANG_POP([C++])
- CPPFLAGS="$old_CPPFLAGS"
- LDFLAGS="$LDFLAGS $ZOLTAN_LIB_FLAGS"
- AC_CHECK_LIB([zoltan],[Zoltan_LB_Partition],[ZOLTAN_LIBS='-lzoltan'],
- [unset ac_cv_lib_zoltan_Zoltan_LB_Partition
- [ZOLTAN_LIBS="-lzoltan -lparmetis -lmetis"],
- [AC_MSG_ERROR("mbzoltan requires zoltan")],
- [-lparmetis -lmetis])])
- AC_SUBST(ZOLTAN_LIBS)
- AC_SUBST(ZOLTAN_LIB_FLAGS)
- AC_SUBST(ZOLTAN_INC_FLAGS)
-fi
-# Chaco
-if test $ENABLE_mbchaco = yes; then
- AC_ARG_WITH(chaco,
- [AC_HELP_STRING([--with-chaco=DIR], [Specify directory containing chaco source and library])],
- [CHACO_DIR=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-chaco=\"${withval}\""
- ], [CHACO_DIR=])
- case "x$CHACO_DIR" in
- xno|x)
- CHACO_MISSING=yes
- xyes)
- AC_MSG_ERROR([--with-chaco requires and argument])
- esac
- if ! test -d "$CHACO_DIR"; then
- AC_MSG_WARN([$CHACO_DIR : not a directory.])
- fi
- AC_CHECK_FILES([${CHACO_DIR}/code/main/defs.h ${CHACO_DIR}/code/main/params.h],
- [], [AC_MSG_WARN([$CHACO_DIR : not a valid chaco source]); CHACO_MISSING=yes])
- old_LIBS="$LIBS"
- LIBS="-L${CHACO_DIR}/code"
- AC_CHECK_LIB([chaco],[read_params],[],
- [AC_MSG_WARN([Could not find libchaco in ${CHACO_DIR}/code]); CHACO_MISSING=yes],
- [-lm])
- CHACO_INCLUDES="-I${CHACO_DIR}/code/main"
- LIBS="$old_LIBS"
- CHACO_LIBS="-L${CHACO_DIR}/code -lchaco -lm"
- AC_SUBST(CHACO_LIBS)
- AC_SUBST(CHACO_INCLUDES)
-fi
-# qvdual
-GRAPHVIZ_MISSING=no
-X_MISSING=no
-VTK_MISSING=no
-QT_MISSING=no
-if test $ENABLE_qvdual = yes; then
-# GraphViz
- AC_ARG_WITH([graphviz],
- [AC_HELP_STRING([--with-graphviz=DIR], [Specify directory containing GraphViz])],
- [GRAPH_DIR=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-graphviz=\"${withval}\""
- ],[GRAPH_DIR=])
- case "x$GRAPH_DIR" in
- xno)
- GRAPHVIZ_MISSING=yes
- xyes|x)
- GRAPH_INC_DIR=
- GRAPH_DIR=
- for dir in /usr /usr/local; do
- if test "x" = "x$GRAPH_DIR"; then
- AC_CHECK_FILE([${dir}/include/graphviz/gvc.h],[GRAPH_DIR="$dir"])
- fi
- done
- AC_MSG_CHECKING([for GraphViz include dir])
- if test "x" != x"$GRAPH_DIR"; then
- GRAPH_INC_DIR="-I${GRAPH_DIR}/include/graphviz"
- fi
- AC_MSG_RESULT([$GRAPH_INC_DIR])
- AC_MSG_CHECKING([for GraphViz library dir])
- GRAPH_LIB_DIR=
- for dir in ${GRAPH_DIR}/lib64/graphviz ${GRAPH_DIR}/lib/graphviz /usr/lib64/graphviz /usr/lib/graphviz /usr/local/lib64/graphviz /usr/local/lib/graphviz /lib64/graphviz /lib/graphviz; do
- if test "x" = "x$GRAPH_LIB_DIR"; then
- GRAPH_LIB_DIR=-L$dir
- fi
- fi
- done
- AC_MSG_RESULT([$GRAPH_LIB_DIR])
- x?*)
- GRAPH_INC_DIR=
- for dir in ${GRAPH_DIR}/include/graphviz ${GRAPH_DIR}/include ${GRAPH_DIR}; do
- if test "x" = "x$GRAPH_INC_DIR"; then
- AC_CHECK_FILE([${dir}/gvc.h],[GRAPH_INC_DIR="-I$dir"])
- fi
- done
- if test "x" = x"$GRAPH_INC_DIR"; then
- AC_MSG_RESULT([no])
- else
- fi
- GRAPH_LIB_DIR=
- for dir in ${GRAPH_DIR}/lib/graphviz ${GRAPH_DIR}/lib ${GRAPH_DIR}; do
- fi
- fi
- done
- if test "x" = x"$GRAPH_LIB_DIR"; then
- else
- fi
- esac
- GRAPH_LIBS="$GRAPH_LIB_DIR -lgvc -lgraph"
- old_CXXFLAGS="$CXXFLAGS"
- CXXFLAGS="$GRAPH_INC_DIR"
- CPPFLAGS="$GRAPH_INC_DIR"
- old_LIBS="$LIBS"
- LIBS=$GRAPH_LIBS
- AC_CHECK_HEADERS([gvc.h],[],[AC_MSG_WARN([Missing GraphViz header]); GRAPHVIZ_MISSING=yes])
- AC_CHECK_LIB([gvc],[gvContext],[],[AC_MSG_WARN([Cannot find GraphViz library: -lgraph]); GRAPHVIZ_MISSING=yes])
- LIBS="$old_LIBS"
- CXXFLAGS="$old_CXXFLAGS"
-# X
- AC_PATH_X
- AC_PATH_XTRA
- if test "xyes" = "x$no_x"; then
- X_MISSING=yes
- fi
-# VTK
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_ARG_WITH([vtk],
- [AC_HELP_STRING([--with-vtk=DIR], [Specify directory containing VTK])],
- [VTK_DIR=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-vtk=\"${withval}\""
- ],[VTK_DIR=])
- VTK_INCLUDES=
- case "x$VTK_DIR" in
- xno)
- VTK_MISSING=yes
- xyes|x)
- VTK_LIB_DIR=
- VTK_INC_DIR=
- for dir in /usr/include/vtk /usr/local/include/vtk /include/vtk /usr/include/vtk-5.0; do
- if test "x" = "x$VTK_INC_DIR"; then
- AC_CHECK_FILE([${dir}/vtkRenderer.h],[VTK_INC_DIR="-I$dir"])
- fi
- done
- if test x = x"$VTK_INC_DIR"; then
- AC_CHECK_HEADER([vtkRenderer.h],[],
- [VTK_MISSING=yes])
- else
- VTK_INCLUDES="$VTK_INC_DIR"
- fi
- old_LIBS="$LIBS"
- for dir in /usr/lib/vtk /usr/lib /usr/bin /usr; do
- if test "x" = "x$VTK_LIB_DIR"; then
- LIBS="$old_LIBS -L$dir"
- unset ac_cv_lib_vtkCommon
- unset ac_cv_lib_vtkCommon_main
- AC_HAVE_LIBRARY([vtkCommon],[VTK_LIB_DIR=$dir])
- fi
- done
- VTK_MISSING=yes
- fi
- LIBS="$old_LIBS"
- x?*)
- VTK_LIB_DIR=
- VTK_INC_DIR=
- for dir in ${VTK_DIR}/include/vtk ${VTK_DIR}/include/vtk/Rendering ${VTK_DIR}/include ${VTK_DIR}; do
- fi
- done
- # Check for non-installed VTK source
- AC_CHECK_FILE([${VTK_DIR}/Rendering/vtkRenderer.h],[
- for subdir in . Common Filtering GenericFiltering Graphics Hybrid Imaging Parallel Patented Rendering Utilities Utilities/vtkexpat Utilities/expat Utilities/DICOMParser Utilties/vtkpng Utilities/vtkzlib Utilities/freetype/include/freetype Wrapping; do
- AC_MSG_CHECKING([for directory ${VTK_DIR}/$subdir])
- if test -d ${VTK_DIR}/$subdir; then
- VTK_INC_DIR="$VTK_INC_DIR -I${VTK_DIR}/$subdir"
- AC_MSG_RESULT([yes])
- else
- fi
- done
- ],[VTK_MISSING=yes]
- fi
- old_LIBS="$LIBS"
- for dir in ${VTK_DIR}/lib/vtk ${VTK_DIR}/lib ${VTK_DIR}/bin ${VTK_DIR}; do
- fi
- done
- VTK_MISSING=yes
- fi
- LIBS="$old_LIBS"
- esac
-dnl Define a function that checks for the existence of a library
-dnl and if it exists, prepends the corresponding link flag to a
-dnl sepecified variable
-dnl Arguments:
-dnl - The library name
-dnl - The name of the variable to which to prepend the library link flag
-dnl - List of extra libraries required for link test
-dnl - Optional library path linker argument (e.g. -L/opt/foo)
- AC_DEFUN([SNL_CHECK_LIB_LIST],[
- old_LIBS="$LIBS"
- LIBS="$4 ${$2} $old_LIBS"
- AC_HAVE_LIBRARY([$1],[$2="-l$1 ${$2}"],[],[$3])
- LIBS="$old_LIBS"
- # These are ordered such that a given library depends only on those libraries
- # that preceed it in the list.
- SNL_CHECK_LIB_LIST([pthread],[vtk_sys_libs])
- SNL_CHECK_LIB_LIST([dl], [vtk_sys_libs])
- SNL_CHECK_LIB_LIST([m], [vtk_sys_libs])
- SNL_CHECK_LIB_LIST([gcc], [vtk_sys_libs])
- x_libs_arg="$X_EXTRA_LIBS -lX11 $X_PRE_LIBS"
- SNL_CHECK_LIB_LIST([Xext],[vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([ICE], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([SM], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([Xt], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([GL], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([GLU], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- vtk_libs_arg="-L$x_libraries $vtk_x_libs $X_EXTRA_LIBS -lX11 $X_PRE_LIBS $vtk_sys_libs"
- SNL_CHECK_LIB_LIST([vtksys], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkCommon], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkDICOMParser],[vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkfreetype], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkexpat], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkzlib], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkpng], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkjpeg], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtktiff], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkftgl], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkFiltering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkImaging], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([verdict], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkGraphics], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkNetCDF], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkexoIIc], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkmetaio], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkIO], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkRendering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkParallel], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkHybrid], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([QVTK], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- # Make sure we found at least vtkCommon and vtkRendering
- if ! echo "x $vtk_libs" | grep lvtkCommon >/dev/null; then
- AC_MSG_WARN("VTK library 'vtkCommon' not found.")
- VTK_MISSING=yes
- fi
- if ! echo "x $vtk_libs" | grep lvtkRendering >/dev/null; then
- AC_MSG_WARN("VTK library 'vtkRendering' not found.")
- VTK_MISSING=yes
- fi
- AC_LANG_RESTORE
-# QT
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_ARG_VAR([QTDIR],[QT installation directory])
- if test x"$QTDIR" = x; then
- search_path="$PATH"
- qlibdir=
- incdir=
- for dir in /usr/include/qt3 /usr/local/include/qt3 /include/qt3; do
- if test x = x${incdir}; then
- incdir=-I$dir
- fi
- fi
- done
- else
- search_path="${QTDIR}/bin"
- qlibdir="-L${QTDIR}/lib"
- incdir="-I${QTDIR}/include"
- fi
- AC_PATH_PROG([MOC],[moc],[],[$search_path])
- if test x = x"$MOC";then
- AC_MSG_WARN([Cannot find moc (Qt meta object compiler)])
- QT_MISSING=yes
- fi
- AC_SUBST(MOC)
- AC_PATH_PROG([UIC],[uic],[],[$search_path])
- if test x = x"$UIC";then
- AC_MSG_WARN([Cannot find uic (Qt user interface compiler)])
- QT_MISSING=yes
- fi
- AC_SUBST(UIC)
- CXXFLAGS="$incdir"
- CPPFLAGS="$incdir"
- AC_CHECK_HEADERS([qlineedit.h qevent.h qapplication.h \
- qwidget.h qtimer.h qpixmap.h qwidgetplugin.h \
- qobject.h qmetaobject.h],[],
- [QT_MISSING=yes])
- QT_INCLUDES="$incdir"
- old_LIBS="$LIBS"
- LIBS="$LIBS $qlibdir"
- # Cannot use AC_HAVE_LIBRARY for qt-mt because of
- # autoconf bug with libraries that have a '-' in their name.
- #AC_HAVE_LIBRARY([qt-mt],[QT_LIBS="$qlibdir -lqt-mt"],[
- AC_MSG_CHECKING([for main in -lqt-mt])
- QT_LIBS="$qlibdir -lqt-mt"
- AC_TRY_LINK_FUNC(main,[AC_MSG_RESULT([yes])],[
- LIBS="$old_LIBS $qlibdir"
- AC_HAVE_LIBRARY([qt],[QT_LIBS="$qlibdir -lqt"],[
- QT_MISSING=yes
- LIBS="$old_LIBS"
-# X/VTK/QT
- dnl Merge lists of libraries
- dnl Arguments
- dnl - name of output variable
- dnl - first list
- dnl - second list
- AC_DEFUN([SNL_MERGE_LISTS],[
- $1="$2"
- # Reverse list two
- for item3 in $3; do
- found=no
- for item2 in $2; do
- if test "x$item2" = "x$item3"; then found=yes; fi
- done
- if test "$found" = "no"; then $1="${$1} $item3"; fi
- done
- $1="${$1} $2"
- SNL_MERGE_LISTS([XLIBS_tmp],[$X_EXTRA_LIBS -lX11 $X_PRE_LIBS],[$vtk_x_libs])
- SNL_MERGE_LISTS([XLIBS],[$vtk_sys_libs],[$XLIBS_tmp])
- QVDUAL_LIBS="$LIBS $GRAPH_LIBS -L$VTK_LIB_DIR $vtk_libs $QT_LIBS $XLIBS"
- QVDUAL_INCLUDES="$GRAPH_INC_DIR $VTK_INCLUDES $QT_INCLUDES"
- AC_SUBST(VTK_LIB_DIR)
- AC_SUBST(QVDUAL_LIBS)
- AC_SUBST(QVDUAL_INCLUDES)
-fi
-# CGM
-if test $ENABLE_dagmc = yes; then
- AC_ARG_WITH(cgm,
- [AC_HELP_STRING([--with-cgm=DIR], [Specify directory containing CGM])],
- [CGM_DIR=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cgm=\"${withval}\""
- ], [CGM_DIR=])
- case "x$CGM_DIR" in
- xno|x)
- CGM_MISSING=yes
- xyes)
- AC_MSG_ERROR([--with-cgm requires an argument])
- if ! test -d "$CGM_DIR"; then
- AC_MSG_WARN([$CGM_DIR : not a directory.])
- fi
- CGM_MISSING=no
- CGM_MAKE=
- AC_CHECK_FILE([${CGM_DIR}/lib/cgm.make],
- [CGM_MAKE="${CGM_DIR}/lib/cgm.make";
- DEFINES="$DEFINES -DCGM"],
- [AC_CHECK_FILE([${CGM_DIR}/cgm.make],
- [CGM_MAKE="${CGM_DIR}/cgm.make";
- [AC_MSG_WARN([$CGM_DIR : not a configured CGM]);
- CGM_MISSING=yes])
- esac
- if test "x$CGM_MISSING" = "xno"; then
- CGM_CONFIG_OPTIONS="include $CGM_MAKE"
- AC_MSG_CHECKING([Checking for GeometryQueryTool::ray_fire(RefFace*,...)])
- old_LIBS="$LIBS"
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_DEFINES], [CPPFLAGS="$CPPFLAGS $make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_INCLUDES],[CPPFLAGS="$CPPFLAGS $make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LTFLAGS], [LDFLAGS="$CPPFLAGS $make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LDFLAGS], [LDFLAGS="$CPPFLAGS $make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LIBS], [LIBS="$make_val $libs"])
- AC_LINK_IFELSE(
- [AC_LANG_PROGRAM([#include "GeometryQueryTool.hpp"
- #include "CubitVector.hpp"],
- [CubitVector a,b;
- DLIList<double> c;
- GeometryQueryTool::instance()->fire_ray((RefFace*)0, a, b, c );
- [MOAB_CGM_DEFINES="-DHAVE_CGM_FIRE_RAY"; AC_MSG_RESULT(yes)],
- [AC_MSG_RESULT(no)])
- LIBS="$old_LIBS"
- fi
- AC_SUBST(MOAB_CGM_DEFINES)
- AC_SUBST(CGM_DIR)
- AC_SUBST(CGM_CONFIG_OPTIONS)
- DAGMC_CONFIG_OPTIONS="include \${MOAB_LIBDIR}/dagmc.make"
- AC_SUBST(DAGMC_CONFIG_OPTIONS)
-fi
-AM_CONDITIONAL( HAVE_CGM, [test "x$CGM_MISSING" = "xno"] )
-# iMesh Babel
-if test "x$ENABLE_imesh" = "xyes"; then
- AC_ARG_WITH(babel,
- [AC_HELP_STRING([--with-babel=DIR], [Specify directory containing babel])],
- [BABEL_DIR=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-babel=\"${withval}\""
- ], [BABEL_DIR=no])
- case "x$BABEL_DIR" in
- xno)
- BABEL_DIR=
- USE_BABEL=no
- xyes|x)
- BABEL_DIR=/usr/local
- AC_CHECK_FILE([${BABEL_DIR}/bin/babel], [USE_BABEL=yes], [USE_BABEL=no])
- esac
- AC_SUBST(BABEL_DIR)
- AC_SUBST(USE_BABEL)
-else
- USE_BABEL=no
-fi
-AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"])
-# Output Files
-AC_SUBST([INCLUDES])
-AC_SUBST([DEFINES])
-AC_SUBST([AM_CPPFLAGS])
-AC_SUBST([AM_LDFLAGS])
-AC_SUBST([AM_CXXFLAGS])
-AC_SUBST([AM_CFLAGS])
-AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
-AC_ARG_VAR([FC], [FORTRAN compiler command])
-AC_CONFIG_HEADERS([config.h])
-AC_CONFIG_HEADERS([MBVersion.h])
-AC_CONFIG_HEADERS([MBEntityHandle.h])
-AC_CONFIG_HEADERS([MBCN_FCDefs.h])
-AC_CONFIG_FILES([Makefile
- moab.make
- testdir.h
- parallel/Makefile
- mhdf/Makefile
- test/Makefile
- test/h5file/Makefile
- test/dual/Makefile
- test/obb/Makefile
- test/perf/Makefile
- tools/Makefile
- tools/iMesh/Makefile
- tools/iMesh/iMesh-Defs.inc
- tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
- tools/iMesh/SIDL/Makefile
- tools/iMesh/SIDL/common.make
- tools/mbperf/Makefile
- tools/mbchaco/Makefile
- tools/mbcoupler/Makefile
- tools/mbzoltan/Config.moab
- tools/mbzoltan/Makefile
- tools/mcnpmit/Makefile
- tools/qvdual/Makefile
- tools/dagmc/Makefile
- tools/dagmc/dagmc.make
- doc/Makefile
- doxygen/Makefile
-AC_OUTPUT
-AC_MSG_RESULT([C: $CC $CFLAGS $CPPFLAGS])
-AC_MSG_RESULT([C++: $CXX $CXXFLAGS $CPPFLAGS])
-AC_MSG_RESULT([Fortran: $FC $FCFLAGS])
-if test "x$GRAPHVIZ_MISSING" = "xyes"; then
- AC_MSG_WARN([Could not find GraphViz library. Build will FAIL!!! Try \"--with-graphviz=DIR\"])
-fi
-if test "x$X_MISSING" = "xyes"; then
- AC_MSG_WARN([Cound not find X client. Build will FAIL!!!])
-else
- if test "x$QT_MISSING" = "xyes"; then
- AC_MSG_WARN([Cound not find QT. Build will FAIL!!! Try setting \"QTDIR\"])
- fi
- if test "x$VTK_MISSING" = "xyes"; then
- AC_MSG_WARN([Count not find VTK. Build will FAIL!!! Try \"--with-VTK=DIR\"])
- fi
-fi
-if test "x$HAVE_HDF5" = "xno"; then
- AC_MSG_WARN([
-* MOAB has been configured w/out the HDF5 library.
-* Support for native file format is disabled!
-fi
-if test "x$HAVE_NETCDF" = "xno"; then
- AC_MSG_WARN([
-* MOAB has been configured w/out the NetCDF library.
-* Support for ExodusII/Genesis and other file formats is disabled!
-fi
