[MOAB-dev] MOAB check for *AMD64* failed.
Nightly Test
kraftche at cae.wisc.edu
Tue Mar 17 02:08:12 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
Making check in .
make[1]: Entering directory `/home/jason/moab/test/AMD64'
make moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test mbcn_test kd_tree_tool kd_tree_time
make[2]: Entering directory `/home/jason/moab/test/AMD64'
make[2]: `homxform_test' is up to date.
make[2]: `scdseq_test' is up to date.
make[2]: `tqdcfr' is up to date.
make[2]: `test_adj' is up to date.
make[2]: `seq_man_test' is up to date.
make[2]: `geom_util_test' is up to date.
make[2]: `xform_test' is up to date.
make[2]: `obb_test' is up to date.
make[2]: `vtk_test' is up to date.
make[2]: `adaptive_kd_tree_tests' is up to date.
make[2]: `bsp_tree_test' is up to date.
make[2]: `file_options_test' is up to date.
make[2]: `kd_tree_test' is up to date.
make[2]: `var_len_test' is up to date.
make[2]: `var_len_test_no_template' is up to date.
make[2]: `tag_test' is up to date.
make[2]: `mesh_set_test' is up to date.
make[2]: `cub_file_test' is up to date.
make[2]: `exodus_test' is up to date.
make[2]: `mbcn_test' is up to date.
make[2]: `kd_tree_tool' is up to date.
make[2]: `kd_tree_time' is up to date.
make[2]: Leaving directory `/home/jason/moab/test/AMD64'
make check-TESTS
Size of mConnMap = 10512
Size of mUpConnMap = 59904
Size of MBCN = 1
==29973== Conditional jump or move depends on uninitialised value(s)
==29973== at 0x45028B: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==29973== by 0x4505B4: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==29973== by 0x43EF19: MBCore::initialize() (MBCore.cpp:191)
==29973== by 0x43F12D: MBCore::MBCore() (MBCore.cpp:122)
==29973== by 0x40C5CB: _ZL9_run_testPF11MBErrorCodeP11MBInterfaceEPKc (MBTest.cpp:5928)
==29973== by 0x40CF11: main (MBTest.cpp:6005)
==29973==
==29973== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==29973== by 0x450087: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==29973==
==29973== Use of uninitialised value of size 8
==29973== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==29973== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==29973==
==29973== Invalid read of size 1
==29973== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==29973==
==29973== Process terminating with default action of signal 11 (SIGSEGV)
==29973== Access not within mapped region at address 0x1
MB TEST PROGRAM:
/bin/sh: line 4: 29973 Segmentation fault valgrind ${dir}$tst
FAIL: moab_test
All tests passed.
PASS: homxform_test
==31569== Conditional jump or move depends on uninitialised value(s)
==31569== at 0x435837: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==31569== by 0x435B60: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==31569== by 0x420C4D: MBCore::initialize() (MBCore.cpp:191)
==31569== by 0x420E61: MBCore::MBCore() (MBCore.cpp:122)
==31569== by 0x410EFC: main (scdseq_test.cpp:268)
==31569==
==31569== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==31569== by 0x435633: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==31569==
==31569== Use of uninitialised value of size 8
==31569== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==31569== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==31569==
==31569== Invalid read of size 1
==31569== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==31569==
==31569== Process terminating with default action of signal 11 (SIGSEGV)
==31569== Access not within mapped region at address 0x1
/bin/sh: line 4: 31569 Segmentation fault valgrind ${dir}$tst
FAIL: scdseq_test
Usage: tqdcfr <cub_file_name>
==634== Conditional jump or move depends on uninitialised value(s)
==634== at 0x44FB2F: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==634== by 0x44FE58: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==634== by 0x43F251: MBCore::initialize() (MBCore.cpp:191)
==634== by 0x43F465: MBCore::MBCore() (MBCore.cpp:122)
==634== by 0x40FD63: main (Tqdcfr.cpp:2575)
==634==
==634== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==634== by 0x44F92B: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==634==
==634== Use of uninitialised value of size 8
==634== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==634== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==634==
==634== Invalid read of size 1
==634== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==634==
==634== Process terminating with default action of signal 11 (SIGSEGV)
==634== Access not within mapped region at address 0x1
/bin/sh: line 4: 634 Segmentation fault valgrind ${dir}$tst
FAIL: tqdcfr
==3777== Conditional jump or move depends on uninitialised value(s)
==3777== at 0x42B073: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==3777== by 0x42B39C: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==3777== by 0x416665: MBCore::initialize() (MBCore.cpp:191)
==3777== by 0x416879: MBCore::MBCore() (MBCore.cpp:122)
==3777== by 0x40A562: main (test_adj.cpp:38)
==3777==
==3777== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==3777== by 0x42AE6F: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==3777==
==3777== Use of uninitialised value of size 8
==3777== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==3777== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==3777==
==3777== Invalid read of size 1
==3777== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==3777==
==3777== Process terminating with default action of signal 11 (SIGSEGV)
==3777== Access not within mapped region at address 0x1
/bin/sh: line 4: 3777 Segmentation fault valgrind ${dir}$tst
FAIL: test_adj
Running test_basic ...
Running test_lower_bound ...
Running test_upper_bound ...
Running test_find ...
Running test_get_entities ...
Running test_insert_sequence_merge ...
Running test_insert_sequence_nomerge ...
Running test_remove_sequence ...
Running test_replace_subsequence ...
Running test_erase ...
Running test_find_free_handle ...
Running test_find_free_sequence ...
Running test_is_free_sequence ...
Running regression_svn1952 ...
Running regression_svn1958 ...
Running regression_svn1960 ...
ALL TESTS PASSED
PASS: seq_man_test
Running test_box_plane_overlap ...
Running test_box_linear_elem_overlap_tri ...
Running test_box_linear_elem_overlap_tet ...
Running test_box_linear_elem_overlap_hex ...
Running test_box_tri_overlap ...
Running test_box_tet_overlap ...
Running test_box_hex_overlap ...
Running test_ray_tri_intersect ...
Running test_closest_location_on_tri ...
Running test_closest_location_on_polygon ...
Running test_segment_box_intersect ...
Running test_closest_location_on_box ...
PASS: geom_util_test
PASS: xform_test
==14812== Conditional jump or move depends on uninitialised value(s)
==14812== at 0x441F5F: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14812== by 0x442288: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14812== by 0x42876D: MBCore::initialize() (MBCore.cpp:191)
==14812== by 0x428981: MBCore::MBCore() (MBCore.cpp:122)
==14812== by 0x40C1B1: _ZL19test_build_from_triv (OBBTest.cpp:1157)
==14812== by 0x41BD7E: main (OBBTest.cpp:36)
==14812==
==14812== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14812== by 0x441D5B: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14812==
==14812== Use of uninitialised value of size 8
==14812== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14812== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14812==
==14812== Invalid read of size 1
==14812== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14812==
==14812== Process terminating with default action of signal 11 (SIGSEGV)
==14812== Access not within mapped region at address 0x1
/bin/sh: line 4: 14812 Segmentation fault valgrind ${dir}$tst
FAIL: obb_test
==14823== Conditional jump or move depends on uninitialised value(s)
==14823== at 0x432F33: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14823== by 0x43325C: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14823== by 0x41F255: MBCore::initialize() (MBCore.cpp:191)
==14823== by 0x41F469: MBCore::MBCore() (MBCore.cpp:122)
==14823== by 0x40E056: test_read_write_element(double const*, unsigned, int const*, int const*, unsigned, unsigned, unsigned, MBEntityType) (VtkTest.cpp:1017)
==14823== by 0x40E598: test_edge2() (VtkTest.cpp:192)
==14823== by 0x40E7AA: main (VtkTest.cpp:124)
==14823==
==14823== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14823== by 0x432D2F: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14823==
==14823== Use of uninitialised value of size 8
==14823== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14823== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14823==
==14823== Invalid read of size 1
==14823== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14823==
==14823== Process terminating with default action of signal 11 (SIGSEGV)
==14823== Access not within mapped region at address 0x1
Testing edge2...
/bin/sh: line 4: 14823 Segmentation fault valgrind ${dir}$tst
FAIL: vtk_test
==14830== Conditional jump or move depends on uninitialised value(s)
==14830== at 0x44ACB7: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14830== by 0x44AFE0: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14830== by 0x431D21: MBCore::initialize() (MBCore.cpp:191)
==14830== by 0x431F35: MBCore::MBCore() (MBCore.cpp:122)
==14830== by 0x40BB94: leaf_iterator_test() (adaptive_kd_tree_tests.cpp:533)
==14830== by 0x4112F8: main (adaptive_kd_tree_tests.cpp:1101)
==14830==
==14830== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14830== by 0x44AAB3: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14830==
==14830== Use of uninitialised value of size 8
==14830== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14830== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14830==
==14830== Invalid read of size 1
==14830== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14830==
==14830== Process terminating with default action of signal 11 (SIGSEGV)
==14830== Access not within mapped region at address 0x1
/bin/sh: line 4: 14830 Segmentation fault valgrind ${dir}$tst
FAIL: adaptive_kd_tree_tests
==14837== Conditional jump or move depends on uninitialised value(s)
==14837== at 0x438EAB: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14837== by 0x4391D4: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14837== by 0x4256ED: MBCore::initialize() (MBCore.cpp:191)
==14837== by 0x425901: MBCore::MBCore() (MBCore.cpp:122)
==14837== by 0x411D12: test_iterator() (bsp_tree_test.cpp:54)
==14837== by 0x412759: run_test(void (*)(), char const*) (TestUtil.hpp:292)
==14837== by 0x4127C4: main (bsp_tree_test.cpp:17)
==14837==
==14837== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14837== by 0x438CA7: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14837==
==14837== Use of uninitialised value of size 8
==14837== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14837== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== Invalid read of size 1
==14837== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14837==
==14837== at 0x7F63DF2: signal (signal.c:38)
==14837== by 0x412A6E: sighandler (TestUtil.hpp:113)
==14837== by 0x7F63F5F: (within /usr/lib/debug/libc-2.7.so)
==14837== by 0x4C22D81: strlen (mc_replace_strmem.c:242)
==14837==
==14837== at 0x7F63DF7: signal (signal.c:38)
==14837==
==14837== at 0x7F64156: sigaction (sigaction.c:38)
==14837== by 0x7F63E83: signal (signal.c:49)
==14837==
==14837== Syscall param rt_sigaction(signum) contains uninitialised byte(s)
==14837== at 0x7F64064: __libc_sigaction (sigaction.c:65)
==14837==
==14837== Syscall param rt_sigaction(act->sa_mask) points to uninitialised byte(s)
==14837== Address 0x7fefff9e0 is on thread 1's stack
==14837==
==14837== at 0x412752: run_test(void (*)(), char const*) (TestUtil.hpp:291)
==14837==
==14837== at 0x412767: run_test(void (*)(), char const*) (TestUtil.hpp:296)
==14837==
==14837== at 0x7F75963: _itoa_word (_itoa.c:195)
==14837== by 0x7F787DB: vfprintf (vfprintf.c:1559)
==14837== by 0x7F7FCA9: printf (printf.c:35)
==14837== by 0x41279A: run_test(void (*)(), char const*) (TestUtil.hpp:302)
==14837==
==14837== at 0x7F7596D: _itoa_word (_itoa.c:195)
==14837==
==14837== at 0x7F78858: vfprintf (vfprintf.c:1559)
==14837==
==14837== at 0x7F78FB0: vfprintf (vfprintf.c:1559)
==14837==
==14837== at 0x7F77DAD: vfprintf (vfprintf.c:1559)
==14837==
==14837== at 0x4C22D94: strlen (mc_replace_strmem.c:242)
==14837== by 0x41111D: test_box_iterator() (bsp_tree_test.cpp:214)
==14837== by 0x4127D6: main (bsp_tree_test.cpp:18)
==14837==
==14837== at 0x7830DFE: (within /usr/lib/libstdc++.so.6.0.10)
==14837== by 0x7830F52: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x7830E03: (within /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x7830441: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14837== by 0x7830E14: (within /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x7830446: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x783047A: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x7830E20: (within /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x4C231DA: memcpy (mc_replace_strmem.c:402)
==14837== by 0x7830E2F: (within /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x4C231E3: memcpy (mc_replace_strmem.c:77)
==14837==
==14837== at 0x4C231F8: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C23245: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C2325A: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C23260: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C23264: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C23292: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C23268: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C2326D: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x4C232AE: memcpy (mc_replace_strmem.c:402)
==14837==
==14837== at 0x7830E3B: (within /usr/lib/libstdc++.so.6.0.10)
==14837==
==14837== at 0x439F08: __gnu_cxx::__enable_if<std::__is_char<char>::__value, bool>::__type std::operator==<char>(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (basic_string.h:2165)
==14837== by 0x438497: MBReaderWriterSet::handler_from_extension(std::string const&, bool, bool) const (MBReaderWriterSet.cpp:210)
==14837== by 0x438CC1: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14837==
==14837==
==14837==
==14837==
==14837==
==14837==
==14837== by 0x4127E8: main (bsp_tree_test.cpp:19)
==14837==
==14837==
==14837==
==14837==
==14837==
==14837== by 0x4127FA: main (bsp_tree_test.cpp:20)
==14837==
==14837==
==14837==
==14837==
==14837==
==14837== by 0x41280C: main (bsp_tree_test.cpp:21)
==14837==
==14837==
==14837==
==14837==
==14837==
==14837== by 0x41281E: main (bsp_tree_test.cpp:22)
==14837==
==14837==
==14837==
==14837==
==14837==
==14837== by 0x412830: main (bsp_tree_test.cpp:23)
==14837==
==14837==
==14837==
==14837==
Running test_iterator ...
test_iterator: TERMINATED (signal 11)
Running test_box_iterator ...
test_box_iterator: TERMINATED (signal 11)
Running test_tree_create ...
test_tree_create: TERMINATED (signal 11)
Running test_box_tree_create ...
test_box_tree_create: TERMINATED (signal 11)
Running test_leaf_containing_point_bounded_tree ...
test_leaf_containing_point_bounded_tree: TERMINATED (signal 11)
Running test_leaf_containing_point_unbounded_tree ...
test_leaf_containing_point_unbounded_tree: TERMINATED (signal 11)
Running test_merge_leaf ...
test_merge_leaf: TERMINATED (signal 11)
FAIL: bsp_tree_test
PASS: file_options_test
==14850== Conditional jump or move depends on uninitialised value(s)
==14850== at 0x445C8F: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14850== by 0x445FB8: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14850== by 0x42CD0D: MBCore::initialize() (MBCore.cpp:191)
==14850== by 0x42CF21: MBCore::MBCore() (MBCore.cpp:122)
==14850== by 0x40B877: main (kd_tree_test.cpp:21)
==14850==
==14850== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14850== by 0x445A8B: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14850==
==14850== Use of uninitialised value of size 8
==14850== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14850== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14850==
==14850== Invalid read of size 1
==14850== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14850==
==14850== Process terminating with default action of signal 11 (SIGSEGV)
==14850== Access not within mapped region at address 0x1
/bin/sh: line 4: 14850 Segmentation fault valgrind ${dir}$tst
FAIL: kd_tree_test
Running test_valid_struct ...
Running test_inline ...
Running test_non_inline ...
Running test_resize_ii ...
Running test_resize_in ...
Running test_resize_ni ...
Running test_resize_nn ...
PASS: var_len_test
PASS: var_len_test_no_template
==14867== Conditional jump or move depends on uninitialised value(s)
==14867== at 0x4399F7: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14867== by 0x439D20: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14867== by 0x426971: MBCore::initialize() (MBCore.cpp:191)
==14867== by 0x426B85: MBCore::MBCore() (MBCore.cpp:122)
==14867== by 0x410DA9: test_create_tag() (TagTest.cpp:250)
==14867== by 0x415679: run_test(void (*)(), char const*) (TestUtil.hpp:292)
==14867== by 0x4156E4: main (TagTest.cpp:39)
==14867==
==14867== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14867== by 0x4397F3: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14867==
==14867== Use of uninitialised value of size 8
==14867== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14867== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== Invalid read of size 1
==14867== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14867==
==14867== at 0x7F63DF2: signal (signal.c:38)
==14867== by 0x415AE4: sighandler (TestUtil.hpp:113)
==14867== by 0x7F63F5F: (within /usr/lib/debug/libc-2.7.so)
==14867== by 0x4C22D81: strlen (mc_replace_strmem.c:242)
==14867==
==14867== at 0x7F63DF7: signal (signal.c:38)
==14867==
==14867== at 0x7F64156: sigaction (sigaction.c:38)
==14867== by 0x7F63E83: signal (signal.c:49)
==14867==
==14867== Syscall param rt_sigaction(signum) contains uninitialised byte(s)
==14867== at 0x7F64064: __libc_sigaction (sigaction.c:65)
==14867==
==14867== Syscall param rt_sigaction(act->sa_mask) points to uninitialised byte(s)
==14867== Address 0x7fefffb70 is on thread 1's stack
==14867==
==14867== at 0x415672: run_test(void (*)(), char const*) (TestUtil.hpp:291)
==14867==
==14867== at 0x415687: run_test(void (*)(), char const*) (TestUtil.hpp:296)
==14867==
==14867== at 0x7F75963: _itoa_word (_itoa.c:195)
==14867== by 0x7F787DB: vfprintf (vfprintf.c:1559)
==14867== by 0x7F7FCA9: printf (printf.c:35)
==14867== by 0x4156BA: run_test(void (*)(), char const*) (TestUtil.hpp:302)
==14867==
==14867== at 0x7F7596D: _itoa_word (_itoa.c:195)
==14867==
==14867== at 0x7F78858: vfprintf (vfprintf.c:1559)
==14867==
==14867== at 0x7F78FB0: vfprintf (vfprintf.c:1559)
==14867==
==14867== at 0x7F77DAD: vfprintf (vfprintf.c:1559)
==14867==
==14867== at 0x4C22D94: strlen (mc_replace_strmem.c:242)
==14867== by 0x410A36: test_invalid_tag_size() (TagTest.cpp:306)
==14867== by 0x4156F6: main (TagTest.cpp:40)
==14867==
==14867== at 0x7830DFE: (within /usr/lib/libstdc++.so.6.0.10)
==14867== by 0x7830F52: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x7830E03: (within /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x7830441: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14867== by 0x7830E14: (within /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x7830446: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x783047A: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x7830E20: (within /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x4C231DA: memcpy (mc_replace_strmem.c:402)
==14867== by 0x7830E2F: (within /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x4C231E3: memcpy (mc_replace_strmem.c:77)
==14867==
==14867== at 0x4C231F8: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C23245: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C2325A: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C23260: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C23264: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C23292: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C23268: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C2326D: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x4C232AE: memcpy (mc_replace_strmem.c:402)
==14867==
==14867== at 0x7830E3B: (within /usr/lib/libstdc++.so.6.0.10)
==14867==
==14867== at 0x43AA54: __gnu_cxx::__enable_if<std::__is_char<char>::__value, bool>::__type std::operator==<char>(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (basic_string.h:2165)
==14867== by 0x438FE3: MBReaderWriterSet::handler_from_extension(std::string const&, bool, bool) const (MBReaderWriterSet.cpp:210)
==14867== by 0x43980D: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x415708: main (TagTest.cpp:41)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x41571A: main (TagTest.cpp:42)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x41572C: main (TagTest.cpp:43)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x41573E: main (TagTest.cpp:44)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x415750: main (TagTest.cpp:45)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x415762: main (TagTest.cpp:46)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x415774: main (TagTest.cpp:47)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x415786: main (TagTest.cpp:48)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x415798: main (TagTest.cpp:49)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x4157AA: main (TagTest.cpp:50)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x4157BC: main (TagTest.cpp:51)
==14867==
==14867==
==14867==
==14867==
==14867==
==14867== by 0x4157CE: main (TagTest.cpp:52)
==14867==
==14867==
==14867==
==14867==
==14867== More than 100 errors detected. Subsequent errors
==14867== will still be recorded, but in less detail than before.
==14867==
==14867== by 0x4157E0: main (TagTest.cpp:53)
==14867==
==14867==
==14867== by 0x4157F2: main (TagTest.cpp:54)
==14867==
==14867==
==14867== by 0x415804: main (TagTest.cpp:55)
==14867==
==14867==
==14867== by 0x415816: main (TagTest.cpp:56)
==14867==
==14867==
==14867== by 0x415828: main (TagTest.cpp:57)
==14867==
==14867==
==14867== by 0x41583A: main (TagTest.cpp:58)
==14867==
==14867==
==14867== by 0x41584C: main (TagTest.cpp:59)
==14867==
==14867==
==14867== by 0x41585E: main (TagTest.cpp:60)
==14867==
==14867==
==14867== by 0x415870: main (TagTest.cpp:61)
==14867==
==14867==
==14867== by 0x415882: main (TagTest.cpp:62)
==14867==
==14867==
==14867== by 0x415894: main (TagTest.cpp:63)
==14867==
==14867==
==14867== by 0x4158A6: main (TagTest.cpp:64)
==14867==
Running test_create_tag ...
test_create_tag: TERMINATED (signal 11)
Running test_invalid_tag_size ...
test_invalid_tag_size: TERMINATED (signal 11)
Running test_get_set_sparse_int ...
test_get_set_sparse_int: TERMINATED (signal 11)
Running test_get_set_dense_int ...
test_get_set_dense_int: TERMINATED (signal 11)
Running test_get_set_dense_double ...
test_get_set_dense_double: TERMINATED (signal 11)
Running test_get_set_bit ...
test_get_set_bit: TERMINATED (signal 11)
Running test_get_by_tag ...
test_get_by_tag: TERMINATED (signal 11)
Running test_get_by_tag_value ...
test_get_by_tag_value: TERMINATED (signal 11)
Running test_mesh_value ...
test_mesh_value: TERMINATED (signal 11)
Running test_get_pointers_sparse ...
test_get_pointers_sparse: TERMINATED (signal 11)
Running test_get_pointers_dense ...
test_get_pointers_dense: TERMINATED (signal 11)
Running test_set_pointers_sparse ...
test_set_pointers_sparse: TERMINATED (signal 11)
Running test_set_pointers_dense ...
test_set_pointers_dense: TERMINATED (signal 11)
Running test_get_entity_tags ...
test_get_entity_tags: TERMINATED (signal 11)
Running test_delete_sparse_tag ...
test_delete_sparse_tag: TERMINATED (signal 11)
Running test_delete_dense_tag ...
test_delete_dense_tag: TERMINATED (signal 11)
Running test_delete_mesh_tag ...
test_delete_mesh_tag: TERMINATED (signal 11)
Running test_delete_sparse_data ...
test_delete_sparse_data: TERMINATED (signal 11)
Running test_delete_dense_data ...
test_delete_dense_data: TERMINATED (signal 11)
Running test_delete_bit_data ...
test_delete_bit_data: TERMINATED (signal 11)
Running test_create_variable_length_tag ...
test_create_variable_length_tag: TERMINATED (signal 11)
Running test_get_set_variable_length_sparse ...
test_get_set_variable_length_sparse: TERMINATED (signal 11)
Running test_get_set_variable_length_dense ...
test_get_set_variable_length_dense: TERMINATED (signal 11)
Running test_get_set_variable_length_mesh ...
test_get_set_variable_length_mesh: TERMINATED (signal 11)
Running regression_one_entity_by_var_tag ...
regression_one_entity_by_var_tag: TERMINATED (signal 11)
Running regression_tag_on_nonexistent_entity ...
regression_tag_on_nonexistent_entity: TERMINATED (signal 11)
FAIL: tag_test
==14874== Conditional jump or move depends on uninitialised value(s)
==14874== at 0x43FEE3: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14874== by 0x44020C: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14874== by 0x42EF95: MBCore::initialize() (MBCore.cpp:191)
==14874== by 0x42F1A9: MBCore::MBCore() (MBCore.cpp:122)
==14874== by 0x40E649: test_add_entities(unsigned) (Test_MBMeshSet.cpp:418)
==14874== by 0x4106B0: test_add_entities_ordered() (Test_MBMeshSet.cpp:49)
==14874== by 0x412755: run_test(void (*)(), char const*) (TestUtil.hpp:292)
==14874== by 0x4127C0: main (Test_MBMeshSet.cpp:103)
==14874==
==14874== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14874== by 0x43FCDF: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14874==
==14874== Use of uninitialised value of size 8
==14874== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14874== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== Invalid read of size 1
==14874== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14874==
==14874== at 0x7F63DF2: signal (signal.c:38)
==14874== by 0x412D22: sighandler (TestUtil.hpp:113)
==14874== by 0x7F63F5F: (within /usr/lib/debug/libc-2.7.so)
==14874== by 0x4C22D81: strlen (mc_replace_strmem.c:242)
==14874==
==14874== at 0x7F63DF7: signal (signal.c:38)
==14874==
==14874== at 0x7F64156: sigaction (sigaction.c:38)
==14874== by 0x7F63E83: signal (signal.c:49)
==14874==
==14874== Syscall param rt_sigaction(signum) contains uninitialised byte(s)
==14874== at 0x7F64064: __libc_sigaction (sigaction.c:65)
==14874==
==14874== Syscall param rt_sigaction(act->sa_mask) points to uninitialised byte(s)
==14874== Address 0x7fefff6b0 is on thread 1's stack
==14874==
==14874== at 0x41274E: run_test(void (*)(), char const*) (TestUtil.hpp:291)
==14874==
==14874== at 0x412763: run_test(void (*)(), char const*) (TestUtil.hpp:296)
==14874==
==14874== at 0x7F75963: _itoa_word (_itoa.c:195)
==14874== by 0x7F787DB: vfprintf (vfprintf.c:1559)
==14874== by 0x7F7FCA9: printf (printf.c:35)
==14874== by 0x412796: run_test(void (*)(), char const*) (TestUtil.hpp:302)
==14874==
==14874== at 0x7F7596D: _itoa_word (_itoa.c:195)
==14874==
==14874== at 0x7F78858: vfprintf (vfprintf.c:1559)
==14874==
==14874== at 0x7F78FB0: vfprintf (vfprintf.c:1559)
==14874==
==14874== at 0x7F77DAD: vfprintf (vfprintf.c:1559)
==14874==
==14874== at 0x4C22D94: strlen (mc_replace_strmem.c:242)
==14874== by 0x4106A0: test_add_entities_set() (Test_MBMeshSet.cpp:50)
==14874== by 0x4127D2: main (Test_MBMeshSet.cpp:104)
==14874==
==14874== at 0x7830DFE: (within /usr/lib/libstdc++.so.6.0.10)
==14874== by 0x7830F52: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x7830E03: (within /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x7830441: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14874== by 0x7830E14: (within /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x7830446: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x783047A: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x7830E20: (within /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x4C231DA: memcpy (mc_replace_strmem.c:402)
==14874== by 0x7830E2F: (within /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x4C231E3: memcpy (mc_replace_strmem.c:77)
==14874==
==14874== at 0x4C231F8: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C23245: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C2325A: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C23260: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C23264: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C23292: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C23268: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C2326D: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x4C232AE: memcpy (mc_replace_strmem.c:402)
==14874==
==14874== at 0x7830E3B: (within /usr/lib/libstdc++.so.6.0.10)
==14874==
==14874== at 0x440F40: __gnu_cxx::__enable_if<std::__is_char<char>::__value, bool>::__type std::operator==<char>(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (basic_string.h:2165)
==14874== by 0x43F4CF: MBReaderWriterSet::handler_from_extension(std::string const&, bool, bool) const (MBReaderWriterSet.cpp:210)
==14874== by 0x43FCF9: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x4127E4: main (Test_MBMeshSet.cpp:105)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x4127F6: main (Test_MBMeshSet.cpp:106)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x412808: main (Test_MBMeshSet.cpp:108)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x41281A: main (Test_MBMeshSet.cpp:109)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x41282C: main (Test_MBMeshSet.cpp:110)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x41283E: main (Test_MBMeshSet.cpp:111)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x412850: main (Test_MBMeshSet.cpp:113)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x412862: main (Test_MBMeshSet.cpp:114)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x412874: main (Test_MBMeshSet.cpp:115)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x412886: main (Test_MBMeshSet.cpp:116)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x412898: main (Test_MBMeshSet.cpp:118)
==14874==
==14874==
==14874==
==14874==
==14874==
==14874== by 0x4128AA: main (Test_MBMeshSet.cpp:119)
==14874==
==14874==
==14874==
==14874==
==14874== More than 100 errors detected. Subsequent errors
==14874== will still be recorded, but in less detail than before.
==14874==
==14874== by 0x4128BC: main (Test_MBMeshSet.cpp:120)
==14874==
==14874==
==14874== by 0x4128CE: main (Test_MBMeshSet.cpp:121)
==14874==
==14874==
==14874== by 0x4128E0: main (Test_MBMeshSet.cpp:122)
==14874==
==14874==
==14874== by 0x4128F2: main (Test_MBMeshSet.cpp:123)
==14874==
==14874==
==14874== by 0x412904: main (Test_MBMeshSet.cpp:124)
==14874==
==14874==
==14874== by 0x412916: main (Test_MBMeshSet.cpp:125)
==14874==
==14874==
==14874== by 0x412928: main (Test_MBMeshSet.cpp:127)
==14874==
==14874==
==14874== by 0x41293A: main (Test_MBMeshSet.cpp:128)
==14874==
==14874==
==14874== by 0x41294C: main (Test_MBMeshSet.cpp:129)
==14874==
==14874==
==14874== by 0x41295E: main (Test_MBMeshSet.cpp:130)
==14874==
==14874==
==14874== by 0x412970: main (Test_MBMeshSet.cpp:131)
==14874==
==14874==
==14874== by 0x412982: main (Test_MBMeshSet.cpp:132)
==14874==
==14874==
==14874== by 0x412994: main (Test_MBMeshSet.cpp:133)
==14874==
==14874==
==14874== by 0x4129A6: main (Test_MBMeshSet.cpp:134)
==14874==
==14874==
==14874== by 0x4129B8: main (Test_MBMeshSet.cpp:136)
==14874==
==14874==
==14874== by 0x4129CA: main (Test_MBMeshSet.cpp:137)
==14874==
==14874==
==14874== by 0x4129DC: main (Test_MBMeshSet.cpp:138)
==14874==
==14874==
==14874== by 0x4129EE: main (Test_MBMeshSet.cpp:139)
==14874==
==14874==
==14874== by 0x412A00: main (Test_MBMeshSet.cpp:140)
==14874==
==14874==
==14874== by 0x412A12: main (Test_MBMeshSet.cpp:141)
==14874==
==14874==
==14874== by 0x412A24: main (Test_MBMeshSet.cpp:142)
==14874==
==14874==
==14874== by 0x412A36: main (Test_MBMeshSet.cpp:143)
==14874==
==14874==
==14874== by 0x412A6C: main (Test_MBMeshSet.cpp:148)
==14874==
==14874==
==14874== by 0x412A7E: main (Test_MBMeshSet.cpp:149)
==14874==
==14874==
==14874== by 0x412A90: main (Test_MBMeshSet.cpp:150)
==14874==
==14874==
==14874== by 0x412AA2: main (Test_MBMeshSet.cpp:151)
==14874==
Running test_add_entities_ordered ...
test_add_entities_ordered: TERMINATED (signal 11)
Running test_add_entities_set ...
test_add_entities_set: TERMINATED (signal 11)
Running test_add_entities_ordered_tracking ...
test_add_entities_ordered_tracking: TERMINATED (signal 11)
Running test_add_entities_set_tracking ...
test_add_entities_set_tracking: TERMINATED (signal 11)
Running test_remove_entities_ordered ...
test_remove_entities_ordered: TERMINATED (signal 11)
Running test_remove_entities_set ...
test_remove_entities_set: TERMINATED (signal 11)
Running test_remove_entities_ordered_tracking ...
test_remove_entities_ordered_tracking: TERMINATED (signal 11)
Running test_remove_entities_set_tracking ...
test_remove_entities_set_tracking: TERMINATED (signal 11)
Running test_entities_by_type_ordered ...
test_entities_by_type_ordered: TERMINATED (signal 11)
Running test_entities_by_type_set ...
test_entities_by_type_set: TERMINATED (signal 11)
Running test_entities_by_dim_ordered ...
test_entities_by_dim_ordered: TERMINATED (signal 11)
Running test_entities_by_dim_set ...
test_entities_by_dim_set: TERMINATED (signal 11)
Running test_subtract_set_set ...
test_subtract_set_set: TERMINATED (signal 11)
Running test_subtract_set_ordered ...
test_subtract_set_ordered: TERMINATED (signal 11)
Running test_subtract_ordered_set ...
test_subtract_ordered_set: TERMINATED (signal 11)
Running test_subtract_ordered_ordered ...
test_subtract_ordered_ordered: TERMINATED (signal 11)
Running test_subtract_set_set_tracking ...
test_subtract_set_set_tracking: TERMINATED (signal 11)
Running test_subtract_set_ordered_tracking ...
test_subtract_set_ordered_tracking: TERMINATED (signal 11)
Running test_subtract_ordered_set_tracking ...
test_subtract_ordered_set_tracking: TERMINATED (signal 11)
Running test_subtract_ordered_ordered_tracking ...
test_subtract_ordered_ordered_tracking: TERMINATED (signal 11)
Running test_itersect_set_set ...
test_itersect_set_set: TERMINATED (signal 11)
Running test_itersect_set_ordered ...
test_itersect_set_ordered: TERMINATED (signal 11)
Running test_itersect_ordered_set ...
test_itersect_ordered_set: TERMINATED (signal 11)
Running test_itersect_ordered_ordered ...
test_itersect_ordered_ordered: TERMINATED (signal 11)
Running test_itersect_set_set_tracking ...
test_itersect_set_set_tracking: TERMINATED (signal 11)
Running test_itersect_set_ordered_tracking ...
test_itersect_set_ordered_tracking: TERMINATED (signal 11)
Running test_itersect_ordered_set_tracking ...
test_itersect_ordered_set_tracking: TERMINATED (signal 11)
Running test_itersect_ordered_ordered_tracking ...
test_itersect_ordered_ordered_tracking: TERMINATED (signal 11)
Running test_unite_set_set ...
test_unite_set_set: TERMINATED (signal 11)
Running test_unite_set_ordered ...
test_unite_set_ordered: TERMINATED (signal 11)
Running test_unite_ordered_set ...
test_unite_ordered_set: TERMINATED (signal 11)
Running test_unite_ordered_ordered ...
test_unite_ordered_ordered: TERMINATED (signal 11)
Running test_unite_set_set_tracking ...
test_unite_set_set_tracking: TERMINATED (signal 11)
Running test_unite_set_ordered_tracking ...
test_unite_set_ordered_tracking: TERMINATED (signal 11)
Running test_unite_ordered_set_tracking ...
test_unite_ordered_set_tracking: TERMINATED (signal 11)
Running test_unite_ordered_ordered_tracking ...
test_unite_ordered_ordered_tracking: TERMINATED (signal 11)
Running test_contains_entities_ordered ...
Running test_contains_entities_set ...
Running test_clear_ordered ...
test_clear_ordered: TERMINATED (signal 11)
Running test_clear_set ...
test_clear_set: TERMINATED (signal 11)
Running test_clear_ordered_tracking ...
test_clear_ordered_tracking: TERMINATED (signal 11)
Running test_clear_set_tracking ...
test_clear_set_tracking: TERMINATED (signal 11)
40 TESTS FAILED
FAIL: mesh_set_test
==14881== Conditional jump or move depends on uninitialised value(s)
==14881== at 0x43A66F: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14881== by 0x43A998: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14881== by 0x426D4D: MBCore::initialize() (MBCore.cpp:191)
==14881== by 0x426F61: MBCore::MBCore() (MBCore.cpp:122)
==14881== by 0x40FAE4: test_vertices() (cub_file_test.cc:241)
==14881== by 0x4101D3: run_test(void (*)(), char const*) (TestUtil.hpp:292)
==14881== by 0x41023E: main (cub_file_test.cc:150)
==14881==
==14881== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14881== by 0x43A46B: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14881==
==14881== Use of uninitialised value of size 8
==14881== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14881== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== Invalid read of size 1
==14881== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14881==
==14881== at 0x7F63DF2: signal (signal.c:38)
==14881== by 0x4105F6: sighandler (TestUtil.hpp:113)
==14881== by 0x7F63F5F: (within /usr/lib/debug/libc-2.7.so)
==14881== by 0x4C22D81: strlen (mc_replace_strmem.c:242)
==14881==
==14881== at 0x7F63DF7: signal (signal.c:38)
==14881==
==14881== at 0x7F64156: sigaction (sigaction.c:38)
==14881== by 0x7F63E83: signal (signal.c:49)
==14881==
==14881== Syscall param rt_sigaction(signum) contains uninitialised byte(s)
==14881== at 0x7F64064: __libc_sigaction (sigaction.c:65)
==14881==
==14881== Syscall param rt_sigaction(act->sa_mask) points to uninitialised byte(s)
==14881== Address 0x7fefffac0 is on thread 1's stack
==14881==
==14881== at 0x4101CC: run_test(void (*)(), char const*) (TestUtil.hpp:291)
==14881==
==14881== at 0x4101E1: run_test(void (*)(), char const*) (TestUtil.hpp:296)
==14881==
==14881== at 0x7F75963: _itoa_word (_itoa.c:195)
==14881== by 0x7F787DB: vfprintf (vfprintf.c:1559)
==14881== by 0x7F7FCA9: printf (printf.c:35)
==14881== by 0x410214: run_test(void (*)(), char const*) (TestUtil.hpp:302)
==14881==
==14881== at 0x7F7596D: _itoa_word (_itoa.c:195)
==14881==
==14881== at 0x7F78858: vfprintf (vfprintf.c:1559)
==14881==
==14881== at 0x7F78FB0: vfprintf (vfprintf.c:1559)
==14881==
==14881== at 0x7F77DAD: vfprintf (vfprintf.c:1559)
==14881==
==14881== at 0x4C22D94: strlen (mc_replace_strmem.c:242)
==14881== by 0x40F40A: test_element(char const*, MBEntityType, int, int, int const*) (cub_file_test.cc:281)
==14881== by 0x40FAC8: test_edges() (cub_file_test.cc:404)
==14881== by 0x410250: main (cub_file_test.cc:151)
==14881==
==14881== at 0x7830DFE: (within /usr/lib/libstdc++.so.6.0.10)
==14881== by 0x7830F52: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x7830E03: (within /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x7830441: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14881== by 0x7830E14: (within /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x7830446: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x783047A: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x7830E20: (within /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x4C231DA: memcpy (mc_replace_strmem.c:402)
==14881== by 0x7830E2F: (within /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x4C231E3: memcpy (mc_replace_strmem.c:77)
==14881==
==14881== at 0x4C231F8: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C23245: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C2325A: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C23260: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C23264: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C23292: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C23268: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C2326D: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x4C232AE: memcpy (mc_replace_strmem.c:402)
==14881==
==14881== at 0x7830E3B: (within /usr/lib/libstdc++.so.6.0.10)
==14881==
==14881== at 0x43B5FE: __gnu_cxx::__enable_if<std::__is_char<char>::__value, bool>::__type std::operator==<char>(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (basic_string.h:2165)
==14881== by 0x439C5B: MBReaderWriterSet::handler_from_extension(std::string const&, bool, bool) const (MBReaderWriterSet.cpp:210)
==14881== by 0x43A485: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410262: main (cub_file_test.cc:152)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410274: main (cub_file_test.cc:153)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410286: main (cub_file_test.cc:154)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410298: main (cub_file_test.cc:155)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x4102AA: main (cub_file_test.cc:156)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x4102BC: main (cub_file_test.cc:157)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x4102CE: main (cub_file_test.cc:158)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x4102E0: main (cub_file_test.cc:159)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x4102F2: main (cub_file_test.cc:160)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410304: main (cub_file_test.cc:161)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410316: main (cub_file_test.cc:162)
==14881==
==14881==
==14881==
==14881==
==14881==
==14881== by 0x410328: main (cub_file_test.cc:163)
==14881==
==14881==
==14881==
==14881==
==14881== More than 100 errors detected. Subsequent errors
==14881== will still be recorded, but in less detail than before.
==14881==
==14881== by 0x41033A: main (cub_file_test.cc:164)
==14881==
==14881==
==14881== by 0x41034C: main (cub_file_test.cc:165)
==14881==
==14881==
==14881== by 0x41035E: main (cub_file_test.cc:166)
==14881==
==14881==
==14881== by 0x410370: main (cub_file_test.cc:167)
==14881==
==14881==
==14881== by 0x410382: main (cub_file_test.cc:168)
==14881==
==14881==
==14881== by 0x410394: main (cub_file_test.cc:169)
==14881==
==14881==
==14881== by 0x4103A6: main (cub_file_test.cc:170)
==14881==
==14881==
==14881== by 0x4103B8: main (cub_file_test.cc:171)
==14881==
Running test_vertices ...
test_vertices: TERMINATED (signal 11)
Running test_edges ...
test_edges: TERMINATED (signal 11)
Running test_quads ...
test_quads: TERMINATED (signal 11)
Running test_hexes ...
test_hexes: TERMINATED (signal 11)
Running test_geometric_topology ...
test_geometric_topology: TERMINATED (signal 11)
Running test_geometric_sets ...
test_geometric_sets: TERMINATED (signal 11)
Running test_blocks ...
test_blocks: TERMINATED (signal 11)
Running test_side_sets ...
test_side_sets: TERMINATED (signal 11)
Running test_node_sets ...
test_node_sets: TERMINATED (signal 11)
Running test_file_set ...
test_file_set: TERMINATED (signal 11)
Running test_tri6 ...
test_tri6: TERMINATED (signal 11)
Running test_tri7 ...
test_tri7: TERMINATED (signal 11)
Running test_quad5 ...
test_quad5: TERMINATED (signal 11)
Running test_quad8 ...
test_quad8: TERMINATED (signal 11)
Running test_quad9 ...
test_quad9: TERMINATED (signal 11)
Running test_tet8 ...
test_tet8: TERMINATED (signal 11)
Running test_tet10 ...
test_tet10: TERMINATED (signal 11)
Running test_tet14 ...
test_tet14: TERMINATED (signal 11)
Running test_hex9 ...
test_hex9: TERMINATED (signal 11)
Running test_hex20 ...
test_hex20: TERMINATED (signal 11)
Running test_hex27 ...
test_hex27: TERMINATED (signal 11)
Running test_multiple_files ...
test_multiple_files: TERMINATED (signal 11)
FAIL: cub_file_test
==14888== Conditional jump or move depends on uninitialised value(s)
==14888== at 0x434CE7: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:122)
==14888== by 0x435010: MBReaderWriterSet::MBReaderWriterSet(MBCore*, MBError*) (MBReaderWriterSet.cpp:86)
==14888== by 0x420F41: MBCore::initialize() (MBCore.cpp:191)
==14888== by 0x421155: MBCore::MBCore() (MBCore.cpp:122)
==14888== by 0x40B93F: test_ho_elements(MBEntityType, int) (exodus_test.cc:222)
==14888== by 0x40BBB3: test_tri6() (exodus_test.cc:40)
==14888== by 0x40BCEB: run_test(void (*)(), char const*) (TestUtil.hpp:292)
==14888== by 0x40BD56: main (exodus_test.cc:59)
==14888==
==14888== at 0x7830F36: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14888== by 0x434AE3: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14888==
==14888== Use of uninitialised value of size 8
==14888== at 0x4C22D82: strlen (mc_replace_strmem.c:242)
==14888== by 0x7830F3F: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== Invalid read of size 1
==14888== Address 0x1 is not stack'd, malloc'd or (recently) free'd
==14888==
==14888== at 0x7F63DF2: signal (signal.c:38)
==14888== by 0x40C066: sighandler (TestUtil.hpp:113)
==14888== by 0x7F63F5F: (within /usr/lib/debug/libc-2.7.so)
==14888== by 0x4C22D81: strlen (mc_replace_strmem.c:242)
==14888==
==14888== at 0x7F63DF7: signal (signal.c:38)
==14888==
==14888== at 0x7F64156: sigaction (sigaction.c:38)
==14888== by 0x7F63E83: signal (signal.c:49)
==14888==
==14888== Syscall param rt_sigaction(signum) contains uninitialised byte(s)
==14888== at 0x7F64064: __libc_sigaction (sigaction.c:65)
==14888==
==14888== Syscall param rt_sigaction(act->sa_mask) points to uninitialised byte(s)
==14888== Address 0x7fefffae0 is on thread 1's stack
==14888==
==14888== at 0x40BCE4: run_test(void (*)(), char const*) (TestUtil.hpp:291)
==14888==
==14888== at 0x40BCF9: run_test(void (*)(), char const*) (TestUtil.hpp:296)
==14888==
==14888== at 0x7F75963: _itoa_word (_itoa.c:195)
==14888== by 0x7F787DB: vfprintf (vfprintf.c:1559)
==14888== by 0x7F7FCA9: printf (printf.c:35)
==14888== by 0x40BD2C: run_test(void (*)(), char const*) (TestUtil.hpp:302)
==14888==
==14888== at 0x7F7596D: _itoa_word (_itoa.c:195)
==14888==
==14888== at 0x7F78858: vfprintf (vfprintf.c:1559)
==14888==
==14888== at 0x7F78FB0: vfprintf (vfprintf.c:1559)
==14888==
==14888== at 0x7F77DAD: vfprintf (vfprintf.c:1559)
==14888==
==14888== at 0x4C22D94: strlen (mc_replace_strmem.c:242)
==14888== by 0x40BB9E: test_tri7() (exodus_test.cc:41)
==14888== by 0x40BD68: main (exodus_test.cc:60)
==14888==
==14888== at 0x7830DFE: (within /usr/lib/libstdc++.so.6.0.10)
==14888== by 0x7830F52: std::string::string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x7830E03: (within /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x7830441: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14888== by 0x7830E14: (within /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x7830446: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x783047A: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x7830E20: (within /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x4C231DA: memcpy (mc_replace_strmem.c:402)
==14888== by 0x7830E2F: (within /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x4C231E3: memcpy (mc_replace_strmem.c:77)
==14888==
==14888== at 0x4C231F8: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C23245: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C2325A: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C23260: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C23264: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C23292: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C23268: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C2326D: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x4C232AE: memcpy (mc_replace_strmem.c:402)
==14888==
==14888== at 0x7830E3B: (within /usr/lib/libstdc++.so.6.0.10)
==14888==
==14888== at 0x435C76: __gnu_cxx::__enable_if<std::__is_char<char>::__value, bool>::__type std::operator==<char>(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (basic_string.h:2165)
==14888== by 0x4342D3: MBReaderWriterSet::handler_from_extension(std::string const&, bool, bool) const (MBReaderWriterSet.cpp:210)
==14888== by 0x434AFD: MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*) (MBReaderWriterSet.cpp:124)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BD7A: main (exodus_test.cc:61)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BD8C: main (exodus_test.cc:62)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BD9E: main (exodus_test.cc:63)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BDB0: main (exodus_test.cc:64)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BDC2: main (exodus_test.cc:65)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BDD4: main (exodus_test.cc:66)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BDE6: main (exodus_test.cc:67)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BDF8: main (exodus_test.cc:68)
==14888==
==14888==
==14888==
==14888==
==14888==
==14888== by 0x40BE0A: main (exodus_test.cc:69)
==14888==
==14888==
==14888==
==14888==
FAIL: exodus_test
Running test_dimension_pair ...
Running test_type_names ...
Running test_dimension ...
Running test_vertices_per_entity ...
Running test_num_sub_entities ...
Running test_sub_entity_type_vtx ...
Running test_sub_entity_type_edge ...
Running test_sub_entity_type_tri ...
Running test_sub_entity_type_quad ...
Running test_sub_entity_type_tet ...
Running test_sub_entity_type_pyr ...
Running test_sub_entity_type_pri ...
Running test_sub_entity_type_knife ...
Running test_sub_entity_type_hex ...
Running test_sub_entity_indices_vtx ...
Running test_sub_entity_indices_edge ...
Running test_sub_entity_indices_tri ...
Running test_sub_entity_indices_quad ...
Running test_sub_entity_indices_tet ...
Running test_sub_entity_indices_pyr ...
Running test_sub_entity_indices_pri ...
Running test_sub_entity_indices_hex ...
Running test_side_number_tri ...
Running test_side_number_quad ...
Running test_side_number_tet ...
Running test_side_number_pyr ...
Running test_side_number_pri ...
Running test_side_number_hex ...
Running test_opposite_side_tri ...
Running test_opposite_side_quad ...
Running test_opposite_side_tet ...
Running test_opposite_side_hex ...
Running test_has_mid_nodes_edge ...
Running test_has_mid_nodes_tri ...
Running test_has_mid_nodes_quad ...
Running test_has_mid_nodes_tet ...
Running test_has_mid_nodes_pyr ...
Running test_has_mid_nodes_pri ...
Running test_has_mid_nodes_knife ...
Running test_has_mid_nodes_hex ...
Running test_sub_entity_nodes_tri_edges ...
Running test_sub_entity_nodes_quad_edges ...
Running test_sub_entity_nodes_tet_edges ...
Running test_sub_entity_nodes_tet_faces ...
Running test_sub_entity_nodes_pyr_edges ...
Running test_sub_entity_nodes_pyr_faces ...
Running test_sub_entity_nodes_pri_edges ...
Running test_sub_entity_nodes_pri_faces ...
Running test_sub_entity_nodes_kni_edges ...
Running test_sub_entity_nodes_kni_faces ...
Running test_sub_entity_nodes_hex_edges ...
Running test_sub_entity_nodes_hex_faces ...
Running test_ho_node_parent ...
Running test_ho_node_index ...
PASS: mbcn_test
13 of 21 tests failed
make[2]: *** [check-TESTS] Error 1
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/moab/test/AMD64'
make: *** [check-recursive] Error 1
