[MOAB-dev] MOAB check for *AMD64* failed.
Nightly Test
kraftche at cae.wisc.edu
Sun Mar 15 02:01:38 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
Making check in .
make[1]: Entering directory `/home/jason/moab/test/AMD64'
make moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test mbcn_test kd_tree_tool kd_tree_time
make[2]: Entering directory `/home/jason/moab/test/AMD64'
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -I/home/jason/cgm/test/cubit/../trunk -I/home/jason/cgm/test/cubit/../trunk/util -I/home/jason/cgm/test/cubit/util -I/home/jason/cgm/test/cubit/../trunk/init -I/home/jason/cgm/test/cubit/init -I/home/jason/cgm/test/cubit/../trunk/geom -I/home/jason/cgm/test/cubit/geom -I/home/jason/cgm/test/cubit/../trunk/geom/ACIS -I/home/jason/cgm/test/cubit/../trunk/geom/virtual -I/home/jason/cgm/test/cubit/../trunk/geom/facet -I/home/jason/cgm/test/cubit/../trunk/geom/facetbool -I/home/jason/cgm/test/cubit/../trunk/geom/Cholla -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DTEMPLATE_DEFS_INCLUDED -I/home/jason/cgm/test/cubit/../trunk -I/home/jason/cgm/test/cubit/../trunk/util -I/home/jason/cgm/test/cubit/util -I/home/jason/cgm/test/cubit/../trunk/init -I/home/jason/cgm/test/cubit/init -I/home/jason/cgm/test!
/cubit/../trunk/geom -I/home/jason/cgm/test/cubit/geom -I/home/jason/cgm/test/cubit/../trunk/geom/ACIS -I/home/jason/cgm/test/cubit/../trunk/geom/virtual -I/home/jason/cgm/test/cubit/../trunk/geom/facet -I/home/jason/cgm/test/cubit/../trunk/geom/facetbool -I/home/jason/cgm/test/cubit/../trunk/geom/Cholla -DCGM -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBTest.o -MD -MP -MF .deps/MBTest.Tpo -c -o MBTest.o ../src/MBTest.cpp
mv -f .deps/MBTest.Tpo .deps/MBTest.Po
/bin/sh ./libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -o moab_test MBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o moab_test MBTest.o ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm
/usr/bin/ld: warning: libvtkMPEG2Encode.so.5.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libvtkexpat.so.5.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libvtkjpeg.so.5.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libvtkpng.so.5.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libvtktiff.so.5.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libvtkzlib.so.5.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libgtcAttrib.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaAVis.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaAWarp.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaASurf.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaALops.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaABlend.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaACIS.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libSpaBase.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmesquite_1_1_3.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libverdict112.so, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libg2c.so.0, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libstdc++.so.5, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, may conflict with libstdc++.so.6
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_STITCH::max_tol() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `typeinfo for Mesquite::QualityMetric'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_loops(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::first() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `vtable for Mesquite::InstructionQueue'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_detect_short_edges(ENTITY*, ENTITY_LIST&, double, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator|(SPAbox const&, SPAbox const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::from_tolerant_owner(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_entity_refinement(ENTITY*, REFINEMENT*, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::ConjugateGradient::set_patch_type(Mesquite::PatchData::PatchType, Mesquite::MsqError&, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_tet_quality'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_edges(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `write_real(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_loop_type(LOOP*, loop_type&, int*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_clean_wire(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `skin_options::set_closed(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::lose()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_remove_face(FACE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_boolean(BODY*, BODY*, BOOL_TYPE, NDBOOL_KEEP, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `read_string(char*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_offset_body(BODY*, double, SPAposition, SPAposition, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_INTCOED::face() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_quad_jacobian'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `constant_law::constant_law(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_indexed_polyedge(int, int, void*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `error_harden'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `logging_opt_on()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_logging(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::set_geometry(SURFACE*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_err_mess(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::replace_owner_geometry(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::copy_scan(ENTITY_LIST&, SCAN_TYPE, int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::InstructionQueue::InstructionQueue()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_del_entity(ENTITY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::lop_change_owner()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::set_coedge(COEDGE*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::save_global_mesh_output(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_ray_test_body(SPAposition const&, SPAunit_vector const&, double, int, BODY*, ENTITY_LIST&, double*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::MsqError::error_message() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::attach_pattern_attrib(pattern*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_STITCH_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_create_refinement(REFINEMENT*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::SPAbox(SPAposition const&, SPAposition const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::backup()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::set_pattern(pattern*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_VERTEX(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::QualityMetric::evaluate_vertex(Mesquite::PatchData&, Mesquite::MsqVertex*, double&, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_minor_version()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAinterval::mid_pt() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `VERTEX_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_detect_sliver_faces(ENTITY*, ENTITY_LIST&, double, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_booleans()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAinterval::operator>>(double) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::check_applicable_format_entity(ENTITY*, ENTITY*&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_offsetting()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_chamfer_vertex(VERTEX*, double, EDGE*, double, EDGE*, double, EDGE*, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `METHOD_TABLE::~METHOD_TABLE()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::lookup(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_entity_entity_distance(ENTITY*, ENTITY*, SPAposition&, SPAposition&, double&, param_info&, param_info&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_force_simplify_to_cone(FACE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::pattern_copyable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::param_range()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `rotate_transf(double, SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `vtable for Mesquite::MsqError'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::operator|=(SPAbox const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_subclasses'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::is_use_counted() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sheet_thicken(BODY*, double, int, SPAposition, SPAposition, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_cmp'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `entity_ver_box_container::get_ver_box() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_fafa_int(FACE*, FACE*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_hex_jacobian'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `APOINT::APOINT(double, double, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_EDGE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sg_body_to_1d(BODY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_rsfe'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::TerminationCriterion::TerminationCriterion()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `spaacis_api_errmod'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_global_node(int, EDGE*, SPAposition const&, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_default_refinement(REFINEMENT*&, AF_SURF_MODE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_ptent_rel(APOINT*, ENTITY*, point_entity_rel*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_point_in_face(SPAposition const&, FACE*, SPAtransf const&, point_face_containment&, SPApar_pos const&, int, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `REFINEMENT::set_adjust_mode(AF_ADJUST_MODE)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `f_clos'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_SIMPLIFY_FACE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_split_periodic_faces(ENTITY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_wsfe'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_force_simplify_to_plane(FACE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SIMPLIFY::set_do_simplify(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_GEN_SPLINE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator*(SPAvector const&, SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_auto_heal(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SHELL_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAvector::is_zero(double) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_blend_edges_pos_rad(ENTITY_LIST const&, int, SPAposition*, double*, double*, double*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `write_int(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_unhook_face(FACE*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAresabs'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_trans_edge(EDGE*, SPAtransf const&, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_coordinate_polygon_node(int, int, SPApar_pos const&, SPAposition const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::get_all_patterns(VOID_LIST&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPHERE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::set_search_order(MESH_MANAGER_SEARCH_ORDER)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LOOP::set_bound(SPAbox*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::FeasibleNewton::FeasibleNewton(Mesquite::ObjectiveFunction*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_face(FACE*, check_status_list*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::~sweep_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::reverse_owner()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::start_coordinate_polygon(int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `read_real()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::set_use_count(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `option_header::set(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_set_geombuild_opt_callback(void (*)(BODY*))'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_draft_angle(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `terminate_base()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_save_entity_list(_IO_FILE*, int, ENTITY_LIST const&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_STITCH::min_tol() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_ed_inters_to_ents(EDGE*, curve_curve_int*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::end_param() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::QualityMetric::compute_element_analytical_gradient(Mesquite::PatchData&, Mesquite::MsqMeshEntity*, Mesquite::MsqVertex**, Mesquite::Vector3D*, int, double&, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `gvertex::is_kind(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_ents(SPAposition const&, SPAunit_vector const&, double, int, BODY*, ENTITY_LIST&, double*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::add(ENTITY*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAtransf::translation() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_sharped_options::set()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_start_modeller(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::unhook()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::sweep_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LOOP::LOOP(COEDGE*, LOOP*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LOOP::next(PAT_NEXT_TYPE) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::SPAbox(SPAbox const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_imprint(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::length(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_error_mark()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_tweak_faces(int, FACE**, SURFACE**, int*, SPAposition, SPAposition, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `scale_transf(double, double, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_ewire(int, EDGE**, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_face_u_iso(double, FACE*, SPAtransf const&, ENTITY_LIST*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `insanity_list::data()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_quad_quality'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_edge(EDGE*, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `tensor::zero()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::next(PAT_NEXT_TYPE) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::copy_owner(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::LPtoPTemplate::~LPtoPTemplate()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_reverse_wire(WIRE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_point_in_body(SPAposition const&, BODY*, point_containment&, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator-(SPAinterval const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_geombuild_options::set()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator==(SPAinterval const&, SPAinterval const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_force_simplify_to_torus(FACE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_FACE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_lopt_ops()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_torus(double, double, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `entity_box_container::set_box(ENTITY*, SPAbox*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_tri_scaled_jacobian'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_CURVE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_local_ops()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::ENTITY_LIST()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `mass_props::get_volume() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_indexed_polyedge(int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_facet_entity(ENTITY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_embed_wire_in_faces(BODY*, BODY*, ENTITY_LIST*, double, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_force_simplify_to_cylinder(FACE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_curve_arc_3curve(entity_with_ray const&, entity_with_ray const&, entity_with_ray const&, int, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_SIMPLIFY_FACE::tol() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_face_removal()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_body_mass_props(BODY*, mass_props&, mass_props_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `i_indx'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `skin_options::set_periodic(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::start_shareable_indexed_polygon(int, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_net_wires(int, BODY**, int, BODY**, BODY*&, int, int, double, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_vertices(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_loft_faces(FACE*, double, FACE*, double, BODY*&, int, int, int, int, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_to_face(surface*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_EDGE(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_wsfi'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_face_nu_nv_isolines(int, int, FACE*, SPAtransf const&, ENTITY_LIST*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::reannounce_counts(int, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sweep_with_options(ENTITY*, SPAvector const&, sweep_options*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `vtable for Mesquite::QualityMetric'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_leaf_attrib(ENTITY const*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_mk_ed_line(SPAposition const&, SPAposition const&, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LOOP_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_blend_edges(ENTITY_LIST&, double, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::copy_pattern_down(ENTITY*) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::MsqHessian::~MsqHessian()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `lop_options::set_repair_self_int(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SHELL::wire() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_tri_quality'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_imprint_complete(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_edge_indices(ENTITY*, void*, void*, void*, void*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_selective_boolean_stage2(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::abort_mesh_output(ENTITY*, ENTITY*, ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::QualityMetric::evaluate_element(Mesquite::PatchData&, Mesquite::MsqMeshEntity*, double&, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::UntangleBetaQualityMetric::UntangleBetaQualityMetric(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_tri_area'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `curve_curve_int::~curve_curve_int()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `tolerant_stitch_options::tolerant_stitch_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE::wire() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::start_param() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_stitch_analyze(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sweep_with_options(ENTITY*, double, sweep_options*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAtransf::inverse() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_constructors()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_global_node(int, VERTEX*, SPAposition const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::remove_pattern()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_err_ident(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_GEOMBUILD::check(bhl_anal_geometry_results*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SIMPLIFY_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::set_loop(LOOP*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_SURFACE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `outcome::operator=(outcome const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_indexed_polyedge(int, int, ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_find_cls_ptto_face(SPAposition const&, FACE*, SPAposition&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_global_node(int, FACE*, SPAposition const&, SPApar_pos const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_stop_modeller()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `BODY_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::SPAbox()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_bb_begin(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::move(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `REFINEMENT::set_normal_tol(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_chamfer_edges(ENTITY_LIST&, double, double, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_lopt_ops()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_mk_ed_cubic(int, SPAposition const*, SPAunit_vector const&, SPAunit_vector const&, double, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::bulletin_no_change_vf(ENTITY const*, int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ERROR_ENTITY_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::ENTITY_LIST(ENTITY_LIST const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAtransf::affine() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_single_node_at_singularity() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_isospline_options::set()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_find_vertex(BODY*, SPAposition const&, VERTEX*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::is_pattern_child() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_boolean_start(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::high() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_which_side(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sweep_with_options(ENTITY*, ENTITY*, sweep_options*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `message_module::message_code(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `STRAIGHT::STRAIGHT(SPAposition const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `set_global_error_info(error_info*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_booleans()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SHELL::SHELL(FACE*, SUBSHELL*, SHELL*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::identity(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_lumps(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_combine_body(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::param_range() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_spface(SPAposition const&, double, SPAunit_vector const&, SPAunit_vector const&, double, double, double, double, FACE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_simplify_options::set_do_curve_simplification(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_stitch(BODY*, ENTITY_LIST&, stitch_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_file_info(unsigned long, FileInfo const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_lump_box(LUMP*, SPAtransf const*, int, SPAbox*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_chamfer_vertices(ENTITY_LIST&, double, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::add()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_subtract(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `PLANE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_offset_faces(int, FACE**, double, SPAposition, SPAposition, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `cross_surface(curve const&, surface const&, pcurve const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_tet_jacobian'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_coedge_pointers_on_polyedges()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator-(SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::lookup(ENTITY const*) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_body_to_1d(BODY*, int, ENTITY_LIST const&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_end_body_for_healing(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_COEDGE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_add_generic_named_attribute(ENTITY*, char const*, int, split_action, merge_action, trans_action, copy_action, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_hex_volume'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_rsle'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `reflect_transf(SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_PARAMETRIC_LENGTH_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_faces(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_spline()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_covering()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_generic_attributes()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_reverse_face(FACE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAinterval::length() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `CONE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_coordinate_polygons()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_entity_extrema(ENTITY_LIST&, int, SPAvector*, SPAposition&, param_info&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `e_wsfe'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `lop_options::~lop_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::TerminationCriterion::set_culling_type(Mesquite::TerminationCriterion::TCType, double, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_healing()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `TORUS_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `curve::subset(SPAinterval const&) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `write_string(char const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::remove(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::set_sense(int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_euler_ops()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::operator=(ENTITY const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_body_box(BODY*, SPAtransf const*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_copy_entity_contents(ENTITY*, ENTITY*&, SPAtransf const&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE::shell() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_delent(ENTITY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_VERTEX_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_mk_ed_ellipse(SPAposition const&, SPAunit_vector const&, SPAvector const&, double, double, double, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::remove_from_pattern()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `update_from_bb()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::remove(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `time_'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::IdealWeightInverseMeanRatio::IdealWeightInverseMeanRatio(Mesquite::MsqError&, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_local_ops()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `extend_curve(curve&, SPAinterval const&, int, extension_info&, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_set_tri_normal_func'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_healing()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_ct_copy_cell(CELL*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_CELL(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::QualityMetric::compute_element_analytical_hessian(Mesquite::PatchData&, Mesquite::MsqMeshEntity*, Mesquite::MsqVertex**, Mesquite::Vector3D*, Mesquite::Matrix3D*, int, double&, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `G77_system_0'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::ConjugateGradient::ConjugateGradient(Mesquite::ObjectiveFunction*, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::~ENTITY_LIST()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_degenerate_triangles() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_mark_faceted_faces(int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `insanity_list::next()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_set_stitch_opt_callback(void (*)(BODY*))'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FileInfo::set_units(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_counts()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_set_bhl_log_file(_IO_FILE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_dbl_option(char const*, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::MsqError::push(char const*, char const*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_approx_counts()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::roll_notify(BULLETIN_TYPE, ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_spline(spline const&, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator&(SPAinterval const&, SPAinterval const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_offset_face(FACE*, double, FACE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ACISExceptionCheck(char const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FileInfo::FileInfo()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `outcome::outcome(outcome const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_copy_entity(ENTITY*, ENTITY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `e_rsle'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::end_coordinate_polygon(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_curve_spline(int, SPAposition const*, SPAunit_vector const*, SPAunit_vector const*, EDGE*&, int, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_prism(double, double, double, int, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `BODY::lump() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `acis_allocate'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_boolean_chop_body(BODY*, BODY*, int, BODY*&, BODY*&, NDBOOL_KEEP, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_offset_planar_wire(BODY*, law*, law*, SPAunit_vector const&, BODY*&, int, int, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_edfa_int(EDGE*, FACE*, ENTITY_LIST*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::TerminationCriterion::add_criterion_type_with_int(Mesquite::TerminationCriterion::TCType, int, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_make_tolerant(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `normalise(SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_hex_quality'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_planar_wire(WIRE*, SPAposition&, SPAunit_vector&, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_closed_wire(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_steps(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_force_simplify_to_sphere(FACE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::geometry() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::start_shareable_coordinate_polygon(int, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_ISOSPLINE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::end_global_mesh_output(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `debug_file_ptr'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sg_point_in_edge(SPAposition const&, EDGE const*, SPAtransf const&, ENTITY*&, SPAparameter&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_reset_bhl_log_file()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_loops(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_covering()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sg_split_edge_at_vertex(EDGE*, VERTEX*, ENTITY_LIST&, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAtransf::SPAtransf(SPAtransf const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_edge(EDGE*, check_status_list*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_rsfi'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_curve_arc_center_edge(SPAposition const&, SPAposition const&, SPAposition const&, SPAunit_vector const*, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_cover_wires(BODY*, surface const&, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::split_owner(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_frustum(double, double, double, double, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::is_deepcopyable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::MsqError::Setter::set(char const*, Mesquite::MsqError::ErrorCode)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator+(SPAposition const&, SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `WIRE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::SPAbox(SPAinterval const&, SPAinterval const&, SPAinterval const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `WIRE::body() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAinterval::SPAinterval(double, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_apply_transf(ENTITY*, SPAtransf const&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `WIRE::next(PAT_NEXT_TYPE) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_selective_boolean_stage1(BODY*, BODY*, generic_graph*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_face_loops(FACE*, int*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SIMPLIFY::set_tol(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `e_wsfi'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::to_tolerant_owner(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `VERTEX::add_edge(EDGE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::fix_common(ENTITY**, SCAN_TYPE)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_project_curve_to_surface(curve const&, SPAinterval const&, surface const&, curve*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::ATTRIB(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `mass_props_options::mass_props_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_stitch(BODY*, BODY*, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_mk_ed_conic(SPAposition const&, SPAunit_vector const&, SPAposition const&, SPAunit_vector const&, double, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sw_face_vec(FACE*, int, SPAvector const&, double, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::save_begin(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_attrib(ENTITY const*, int, int, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_reset_boxes(ENTITY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_analyze_body(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SHARP_EDGE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_entity_point_distance(ENTITY*, SPAposition&, SPAposition&, double&, param_info&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_lumps(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_body_to_2d(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_EDGE::new_geometry() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_sphere(double, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `PLANE::PLANE(SPAposition const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sweep_with_options(ENTITY*, SPAposition const&, SPAvector const&, sweep_options*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::copy_common(ENTITY_LIST&, ATTRIB const*, pointer_map*, int, SCAN_TYPE)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `same_vector(SPAvector const&, SPAvector const&, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_mesh_manager(MESH_MANAGER*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_wsle'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `skin_options::~skin_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_cover_wire_loops(ENTITY_LIST&, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `f_back'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_remove_generic_named_attribute(ENTITY*, char const*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_unstitch_nonmani(BODY*, BODY*&, BODY*&, BODY*&, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `insanity_list::count(_etype)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_warnings(int*&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_simplify_entity(ENTITY*&, simplify_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_generic_attributes()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::trans_owner_list(SPAtransf const&, ENTITY_LIST&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_aggr_simplify(BODY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sys_error(int, error_info*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_euler_ops()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_bb_end(outcome&, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_indexed_polynode_with_data()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `e_rsfe'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SHELL::next(PAT_NEXT_TYPE) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::mid() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::coedge(FACE*) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_face_removal()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_coedges(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `BODY::BODY(WIRE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_indexed_polynode(ENTITY*, int, int, void*, double const&, SPApar_pos const&, SPAposition const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::FACE()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_LOOP_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_blending()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_global_indexed_polygons()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::LPtoPTemplate::LPtoPTemplate(Mesquite::QualityMetric*, short, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_wire_start_position(ENTITY*, SPAposition&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_remove_faces(int, FACE**, SPAposition, SPAposition, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::call_method(METHOD_ID const&, METHOD_ARGS const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE::end() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `BODY::wire() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `outcome::~outcome()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_sweep_angle(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_skinning()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_ewires(int, EDGE**, int&, BODY**&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_indexed_polynode(ENTITY*, int, int, void*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_tet_volume'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `print_warnerr_mess(char const*, int, _IO_FILE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_offsetting()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `entity_with_ray::entity_with_ray(ENTITY*, SPAposition const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FileInfo::~FileInfo()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_coedges(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_copy'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::SmartLaplacianSmoother::SmartLaplacianSmoother(Mesquite::ObjectiveFunction*, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::remove_pattern_global(pattern*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `debug_entity(ENTITY const*, _IO_FILE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_list_ff_ints(int, FACE**, ENTITY_LIST*, int&, _IO_FILE*, int, FACE**, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_BODY(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LIST_ENTRY_DELETED'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `acis_interrupted'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_trface(SPAposition const&, SPAunit_vector const&, double, double, SPAposition const&, double, double, double, double, FACE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAposition::operator-=(SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_shelling()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `scale_transf(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `generic_graph::get_vertices(int&) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `write_id_level(char const*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `VERTEX::edge(int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAinterval::negate()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_save_version(int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::InstructionQueue::set_master_quality_improver(Mesquite::QualityImprover*, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `error_end'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_find_named_attribute(ENTITY*, char const*, ATTRIB_GEN_NAME*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_FACE::is_discontinuous()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_skinning()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_stitch_auto(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_option(char const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_STITCH::set_max_tol(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_edge_grading_on_face(FACE*, REFINEMENT*, double&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_faces(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::use_count() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `f_rew'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_cnface(SPAposition const&, SPAunit_vector const&, SPAvector const&, double, double, double, double, double, double, FACE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `read_int()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_move_faces(int, FACE**, SPAtransf const&, SPAposition, SPAposition, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `error_begin'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `mass_props::mass_props()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_duplicate_indexed_nodes_at_singularities()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_int_option(char const*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_ray_test_ents(SPAposition const&, SPAunit_vector const&, double, int, int, ENTITY**, ENTITY_LIST&, double*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_blending()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::restore_common()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ELLIPSE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_trim_curve(entity_with_ray const&, SPAposition const*, entity_with_ray const*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `exact_stitch_options::exact_stitch_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_intersectors()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::start_param()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `make_curve(curve const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `TRANSFORM::TRANSFORM(SPAtransf const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_default_refinement(REFINEMENT*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::remove_from_pattern_list()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `VERTEX::VERTEX(APOINT*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_init_body_for_healing(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator&&(SPAbox const&, SPAbox const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::pattern_compatible() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::warp_owner(law*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::moveable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_entity(ENTITY const*, ENTITY_LIST*, _IO_FILE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::FACE(LOOP*, FACE*, SURFACE*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::QualityMetric::change_metric_type(Mesquite::QualityMetric::MetricType, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_shells(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_face_box(FACE*, SPAtransf const*, int, SPAbox*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SHELL::face() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::check_applicable_refinement(ENTITY*, AF_SURF_MODE, REFINEMENT*&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `vtable for Mesquite::FeasibleNewton'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_loop_external(LOOP*, int*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_owner_transf(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::MESH_MANAGER()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `G77_etime_0'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `insanity_data::get_ent() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_GEOMBUILD_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::trans_owner(SPAtransf const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `mass_props::get_centroid() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `edge_entity_rel::lose()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_kernel()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `set_merge_method(char const*, void (*)(ATTRIB_GEN_NAME*, ENTITY*, int))'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `do_lio'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_quad_area'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `copy_single_entity(ENTITY*, ENTITY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAunit_vector::SPAunit_vector(double, double, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `insanity_data::get_message()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_vertices(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_intersectors()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_sweeping()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::query_search_order()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_wire_self_inters(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_ent_area(ENTITY*, double, double&, double&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_precount_of_global_indexed_polygons()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::set_bound(SPAbox*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::need_edge_indices()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `NULL_REF'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_set_tri_size'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::clear()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `BODY::set_lump(LUMP*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::SmartLaplacianSmoother::~SmartLaplacianSmoother()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_close_to_axis(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator-(SPAposition const&, SPAposition const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_kernel()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_initialize_shelling()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `CURVE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `STRAIGHT_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::~MESH_MANAGER()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LUMP::LUMP(SHELL*, LUMP*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_ENT_GEOMBUILD_FACE::new_geometry() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE::COEDGE(EDGE*, int, COEDGE*, COEDGE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LUMP::set_next(LUMP*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAtransf::SPAtransf()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_next_attrib(ATTRIB const*, int, int, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `translate_transf(SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `make_surface(surface const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::EDGE(VERTEX*, VERTEX*, CURVE*, int, EDGE_cvty, SPAinterval const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_clean_entity(ENTITY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::loop() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::fixup_copy(ATTRIB*) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_point_version()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_copy_body(BODY*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_inter_ed_ed(EDGE*, EDGE*, curve_curve_int*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_TEDGE(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_constructors()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `PLANE::PLANE(plane const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `point_in_face(SPAposition const&, FACE*, SPAtransf const&, SPApar_pos const&, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_facet_curve(curve const&, double, double, double, int, int&, SPAposition*, double*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `find_aggr_geombuild(BODY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::set_param_range(SPAinterval const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sw_face_norm(FACE*, int, double, double, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `plane::plane(SPAposition const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `error_info::add()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SIMPLIFY::num_final_splines() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SIMPLIFY::num_input_splines() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE::loop() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LOOP::set_next(LOOP*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::debug_ent(_IO_FILE*) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_slice(BODY*, BODY*, SPAunit_vector const&, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_GTC_NAME_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::save_end(ENTITY_LIST&) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_update_intersection(FACE*, SPAtransf const&, FACE*, SPAtransf const&, int, EDGE**, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_separate_body(BODY*, int&, BODY**&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `base_configuration::base_configuration()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `REFINEMENT::set_surface_tol(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_restore_entity_list(_IO_FILE*, int, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `BODY::BODY(LUMP*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `angle_between(SPAvector const&, SPAvector const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `METHOD_TABLE::add(METHOD_ID const&, int (*)(void*, METHOD_ARGS const&))'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_skin_wires(int, BODY**, BODY*&, skin_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `lop_options::lop_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_intersect_curves(EDGE*, EDGE*, int, curve_curve_int*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_reverse_body(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_face_v_iso(double, FACE*, SPAtransf const&, ENTITY_LIST*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `f_inqu'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::owner() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `plane::eval(SPApar_pos const&, SPAposition&, SPAvector*, SPAvector*) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::TerminationCriterion::add_criterion_type_with_double(Mesquite::TerminationCriterion::TCType, double, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_simplify_auto(BODY*, hh_simplify_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::deletable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::InstructionQueue::run_instructions(Mesquite::Mesh*, Mesquite::MeshDomain*, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::ConjugateGradient::~ConjugateGradient()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `tolerant_stitch_options::set_max_stitch_tol(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `typeinfo for MESH_MANAGER'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_set_str_option(char const*, char const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_tweak_faces(int, FACE**, SURFACE**, int*, SPAposition const&, SPAposition const&, lop_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `mass_props_options::set_level(mass_props_level)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::count() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_gap_type(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `APOINT::APOINT(SPAposition const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `skin_options::set_solid(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `plane::~plane()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `HISTORY_STREAM::set_max_states_to_keep(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPLINE_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `REFINEMENT::set_grid_mode(AF_GRID_MODE)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `distance_to_point(SPAposition const&, SPAposition const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `tolerant_stitch_options::~tolerant_stitch_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SHELL::first_face() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `is_closed_solid_body(ENTITY const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_entity_entity_touch(ENTITY*, ENTITY*, int&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAresfit'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::full_size(SizeAccumulator&, int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_ANALYTIC_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_wire_end_position(ENTITY*, SPAposition&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_wire(BODY*, int, SPAposition*, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::end_param()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `e_wsle'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_postprocess(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::QualityMetric::compute_vertex_analytical_gradient(Mesquite::PatchData&, Mesquite::MsqVertex&, Mesquite::MsqVertex**, Mesquite::Vector3D*, int, double&, Mesquite::MsqError&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_combine_edges(EDGE*, EDGE*, EDGE*&, _IO_FILE*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator-(SPAposition const&, SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `Mesquite::MsqError::~MsqError()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `s_cat'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_SIMPLIFY::tol() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `do_fio'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::set_end(VERTEX*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_major_version()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::next() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_curve_arc_3pt(SPAposition const&, SPAposition const&, SPAposition const&, int, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_sweeping()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::announce_polygon_model_face(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `acis_discard'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_selectively_intersect(int, FACE**, FACE**, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `outcome::outcome(int, error_info*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `typeinfo for ATTRIB'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_simplify_options::hh_simplify_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator*(SPAposition const&, SPAtransf const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_get_shells(ENTITY*, ENTITY_LIST&, PAT_NEXT_TYPE, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `skin_options::skin_options()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `vtable for Mesquite::IdealWeightInverseMeanRatio'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_get_bad_edges(BODY*, ENTITY_LIST&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `operator/(SPAvector const&, double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAresnor'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_change_body_trans(BODY*, TRANSFORM*, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::operator[](int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `restore_def::~restore_def()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `COEDGE::start() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_edge_box(EDGE*, SPAtransf const*, int, SPAbox*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LUMP_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_set_tet_size'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_loft_coedges(int, Loft_Connected_Coedge_List*, BODY*&, int, int, int, int, int, int, int, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `f_open'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_terminate_spline()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_geombuild_auto(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `entity_box_container::get_box() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_edge_from_curve(curve const*, EDGE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_intersect(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `z_axis'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::begin_global_mesh_output(ENTITY*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::replace_owner(ENTITY*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `REFINEMENT::set_triang_mode(AF_TRIANG_MODE)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_check_entity(ENTITY const*, insanity_list*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `METHOD_TABLE::find(METHOD_ID const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::copyable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `get_face_trans(FACE*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LUMP::shell() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `EDGE::set_start(VERTEX*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::merge_owner(ENTITY*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_STITCH::set_min_tol(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::apply_transform(SPAtransf const&, ENTITY_LIST&, int, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_set_hex_size'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `v_set_quad_size'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `WIRE::shell() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `e_rsfi'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::next_face() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_cuboid(double, double, double, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAposition::operator+=(SPAvector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_edent_rel(EDGE*, ENTITY*, edge_entity_rel*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FileInfo::set_product_id(char const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_HH_AGGR_STITCH::set_do_stitch(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB_GTC_TYPE'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::save_common(ENTITY_LIST&) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_stitch(ENTITY_LIST const&, ENTITY_LIST&, ENTITY_LIST&, stitch_options*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_body_mass_pr(BODY*, SPAposition const&, SPAunit_vector const&, int, double, double&, SPAposition&, tensor&, double*, SPAunit_vector*, double&, double, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `hh_set_simplify_opt_callback(void (*)(BODY*))'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY::debug_scheme(_IO_FILE*, int) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `SPAbox::low() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `restore_def::restore_def(restore_def*&, char const*, int&, ENTITY* (*)(), restore_def* const*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `initialize_base(base_configuration*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `error_info::remove()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `sweep_options::set_rigid(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `generic_graph::number_of_vertices() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_sheet_from_ff(int, FACE**, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_make_pyramid(double, double, double, double, int, BODY*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `set_logging(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `FACE::set_next(FACE*, int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::duplicatable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `REFINEMENT::set_max_edge_length(double)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `vtable for Mesquite::VertexMover'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::init() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::~ATTRIB()'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `MESH_MANAGER::end_indexed_polygon(int)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ENTITY_LIST::iteration_count() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_cover_wire(WIRE*, surface const&, FACE*&, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `coordinate_transf(SPAposition const&, SPAunit_vector const&, SPAunit_vector const&)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `ATTRIB::savable() const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_preprocess(BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_unite(BODY*, BODY*, AcisOptions*)'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `LUMP::next(PAT_NEXT_TYPE) const'
/opt/cubit-10.2-amd64/bin/libcubiti19.so: undefined reference to `api_hh_simplify_analyze(BODY*, AcisOptions*)'
collect2: ld returned 1 exit status
make[2]: *** [moab_test] Error 1
make[2]: Leaving directory `/home/jason/moab/test/AMD64'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/moab/test/AMD64'
make: *** [check-recursive] Error 1
