[MOAB-dev] r2716 - MOAB/trunk
jiangtao_ma at yahoo.com
Fri Mar 13 13:48:14 CDT 2009
Author: janehu
Date: 2009-03-13 13:48:13 -0500 (Fri, 13 Mar 2009)
New Revision: 2716
Modified:
MOAB/trunk/README.IO
MOAB/trunk/ReadCGM.cpp
Log:
Added option for ReadCGM into README_IO.
Modified: MOAB/trunk/README.IO
--- MOAB/trunk/README.IO 2009-03-13 16:33:25 UTC (rev 2715)
+++ MOAB/trunk/README.IO 2009-03-13 18:48:13 UTC (rev 2716)
@@ -55,6 +55,22 @@
Do not overwrite existing file.
+ FACET_DISTANCE_TOLERANCE=<D>
+Max. distance deviation between facet and geometry, default:0.001.
+ FACET_NORMAL_TOLERANCE=<N>
+Max. normal angle deviation (degrees) between facet and geometry, default:5.
+ MAX_FACET_EDGE_LENGTH=<D>
+Max. facet edge length, default:0.
+ CGM_ATTRIBS={yes|no}
+Actuation of all CGM attributes, default:no.
Parallel IO Options
Modified: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp 2009-03-13 16:33:25 UTC (rev 2715)
+++ MOAB/trunk/ReadCGM.cpp 2009-03-13 18:48:13 UTC (rev 2716)
@@ -102,68 +102,30 @@
const int num_blocks)
// blocks_to_load and num_blocks are ignored.
- //opts is currently designed as following
- //cgm_opts = [d <tol>|D] [,n <tol>|N] [,l <tol>|L] [,A|a]
- //currently attribute option is not checked.
- //-d max. distance deviation between facet and geometry
- //-D no distance tolerance
- // (default:0.001)
- //-n max. normal angle deviation (degrees) between facet and geometry
- // (default:5)
- //-N no normal tolerance
- //-l max. facet edge length
- //-L no facet edge length maximum
- // (default:0)
- //-a force actuation of all CGM attributes
- //-A disable all CGM attributes
MBErrorCode rval;
file_set = 0;
std::string filename( cgm_file_name );
cgmFile = filename;
- std::string string;
- rval = opts.get_str_option("cgm_opts", string );
- if(MB_SUCCESS != rval)
- readUtilIface->report_error("MBCN:: Problem reading file options.");
- return MB_FAILURE;
- std::vector< std::string > tokens;
- tokenize(string, tokens,",");
- int norm_tol = 5;
- double faceting_tol = 0.001, len_tol = 0.0;
+ int norm_tol, DEFAULT_NORM = 5;
+ double faceting_tol, DEFAULT_FACET_TOL = 0.001, len_tol, DEFAULT_LEN_TOL = 0.0;
bool act_att = false;
//check for the options.
- for(int i = 0 ; i < tokens.size(); i++)
- std::string opt = tokens[i];
- std::string opt_s (opt.substr(2));
- switch(opt[0])
- case('d'):
- if(opt.length() < 3)
- return MB_TYPE_OUT_OF_RANGE;
- faceting_tol = atof( opt_s.c_str() );
- break;
- case('n'):
- norm_tol = atoi( opt_s.c_str() );
- if(norm_tol < 0)
- break;
- case('l'):
- len_tol = atof( opt_s.c_str() );
- break;
- case('a'):
- act_att = true;
+ if (MB_SUCCESS != opts.get_int_option( "FACET_NORMAL_TOLERANCE", norm_tol ))
+ norm_tol = DEFAULT_NORM;
+ if (MB_SUCCESS != opts.get_real_option("FACET_DISTANCE_TOLERANCE", faceting_tol))
+ faceting_tol = DEFAULT_FACET_TOL;
+ if (MB_SUCCESS != opts.get_real_option("MAX_FACET_EDGE_LENGTH", len_tol))
+ len_tol = DEFAULT_LEN_TOL;
+ const char* name = "CGM_ATTRIBS";
+ const char* value = "yes";
+ if(MB_SUCCESS == opts.match_option(name,value))
+ act_att = true;
// CGM data
std::map<RefEntity*,MBEntityHandle> entmap[5]; // one for each dim, and one for groups
std::map<RefEntity*,MBEntityHandle>::iterator ci;
