[MOAB-dev] r2707 - in MOAB/trunk/tools: iMesh iMesh/SIDL	iMesh/SIDL/mserver mbperf
    kraftche at cae.wisc.edu
    Thu Mar 12 16:26:05 CDT 2009
Author: kraftche
Date: 2009-03-12 16:26:05 -0500 (Thu, 12 Mar 2009)
New Revision: 2707
Modified:
   MOAB/trunk/tools/iMesh/SIDL/iBase.sidl
   MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl
   MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
   MOAB/trunk/tools/iMesh/iBase.h
   MOAB/trunk/tools/iMesh/iMesh.h
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
   MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
   MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp
Log:
iMesh updates
Modified: MOAB/trunk/tools/iMesh/SIDL/iBase.sidl
--- MOAB/trunk/tools/iMesh/SIDL/iBase.sidl	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/iMesh/SIDL/iBase.sidl	2009-03-12 21:26:05 UTC (rev 2707)
@@ -28,8 +28,7 @@
    enum StorageOrder {
       BLOCKED,
-      INTERLEAVED,
-      UNDETERMINED
+      INTERLEAVED
    enum CreationStatus {
Modified: MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl
--- MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl	2009-03-12 21:26:05 UTC (rev 2707)
@@ -100,17 +100,9 @@
                         out int entity_handles_size) throws iBase.Error;
       void getVtxArrCoords( in array<opaque> vertex_handles,
                             in int vertex_handles_size,
-                            inout StorageOrder storage_order,
+                            in StorageOrder storage_order,
                             inout array<double> coords,
                             out int coords_size) throws iBase.Error;
-      void getAdjEntities( in opaque entity_set,
-                           in EntityType entity_type_requestor,
-                           in EntityTopology entity_topology_requestor,
-                           in EntityType entity_type_requested,
-                           inout array<opaque> adj_entity_handles,
-                           out int adj_entity_handles_size,
-                           inout array<int> offset,
-                           out int offset_size) throws iBase.Error;
       void getAdjEntIndices( in opaque entity_set_handle,
@@ -235,8 +227,8 @@
    interface Modify extends Mesh {
       // single entities
-      void setVtxCoords( in opaque vertex_handle,
-                         in double x, in double y, in double z) throws iBase.Error;
+      void setVtxCoord( in opaque vertex_handle,
+                        in double x, in double y, in double z) throws iBase.Error;
       void createVtx( in double x, in double y, in double z,
                          out opaque new_vertex_handle) throws iBase.Error;
       void createEnt( in EntityTopology new_entity_topology,
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc	2009-03-12 21:26:05 UTC (rev 2707)
@@ -1539,7 +1539,7 @@
 iMesh_SIDL::MeshSidl_impl::getVtxArrCoords (
   /* in */ ::sidl::array<void*> vertex_handles,
   /* in */ int32_t vertex_handles_size,
-  /* inout */ ::iBase::StorageOrder& storage_order,
+  /* in */ ::iBase::StorageOrder storage_order,
   /* inout */ ::sidl::array<double>& coords,
   /* out */ int32_t& coords_size )
 throw (
@@ -1551,7 +1551,7 @@
   iMesh_getVtxArrCoords (imeshInstance,
                          TEMP_TYPED_ARRAY_IN(iBase_EntityHandle, vertex_handles),
-                         (int*)&storage_order,
+                         storage_order,
                          TEMP_ARRAY_INOUT(coords), &imeshError);
   PROCESS_ERROR;
@@ -1561,43 +1561,6 @@
- * Method:  getAdjEntities[]
-void
-iMesh_SIDL::MeshSidl_impl::getAdjEntities (
-  /* in */ void* entity_set,
-  /* in */ ::iBase::EntityType entity_type_requestor,
-  /* in */ ::iMesh::EntityTopology entity_topology_requestor,
-  /* in */ ::iBase::EntityType entity_type_requested,
-  /* inout */ ::sidl::array<void*>& adj_entity_handles,
-  /* out */ int32_t& adj_entity_handles_size,
-  /* inout */ ::sidl::array<int32_t>& offset,
-  /* out */ int32_t& offset_size )
-throw (
-  ::iBase::Error
-  // DO-NOT-DELETE splicer.begin(iMesh_SIDL.MeshSidl.getAdjEntities)
-  // Insert-Code-Here {iMesh_SIDL.MeshSidl.getAdjEntities} (getAdjEntities method)
-  CREATE_TEMP_EH_ARRAY(adj_entity_handles);
-  CREATE_TEMP_ARRAY(int32_t, offset);
-  iMesh_getAdjEntities (imeshInstance, reinterpret_cast<iBase_EntitySetHandle>(entity_set),
-                        (iBase_EntityType)entity_type_requestor,
-                        (iMesh_EntityTopology)entity_topology_requestor,
-                        (iBase_EntityType)entity_type_requested,
-                        TEMP_ARRAY_INOUT(adj_entity_handles),
-                        TEMP_ARRAY_INOUT(offset),
-                        &imeshError);
-  PROCESS_ERROR;
-  ASSIGN_TYPED_ARRAY(void*, adj_entity_handles);
-  ASSIGN_TYPED_ARRAY(int32_t, offset);
-  // DO-NOT-DELETE splicer.end(iMesh_SIDL.MeshSidl.getAdjEntities)
  * Method:  getAdjEntIndices[]
 void
@@ -2025,10 +1988,10 @@
- * Method:  setVtxCoords[]
+ * Method:  setVtxCoord[]
 void
-iMesh_SIDL::MeshSidl_impl::setVtxCoords (
+iMesh_SIDL::MeshSidl_impl::setVtxCoord (
   /* in */ void* vertex_handle,
   /* in */ double x,
   /* in */ double y,
@@ -2036,13 +1999,12 @@
 throw (
   ::iBase::Error
-  // DO-NOT-DELETE splicer.begin(iMesh_SIDL.MeshSidl.setVtxCoords)
-  // Insert-Code-Here {iMesh_SIDL.MeshSidl.setVtxCoords} (setVtxCoords method)
-  iMesh_setVtxCoords (imeshInstance,
-                      reinterpret_cast<iBase_EntityHandle>(vertex_handle),
-                      x, y, z, &imeshError);
+  // DO-NOT-DELETE splicer.begin(iMesh_SIDL.MeshSidl.setVtxCoord)
+  iMesh_setVtxCoord (imeshInstance,
+                     reinterpret_cast<iBase_EntityHandle>(vertex_handle),
+                     x, y, z, &imeshError);
   PROCESS_ERROR;
-  // DO-NOT-DELETE splicer.end(iMesh_SIDL.MeshSidl.setVtxCoords)
+  // DO-NOT-DELETE splicer.end(iMesh_SIDL.MeshSidl.setVtxCoord)
@@ -2257,4 +2219,3 @@
 // DO-NOT-DELETE splicer.end(iMesh_SIDL.MeshSidl._misc)
Modified: MOAB/trunk/tools/iMesh/iBase.h
--- MOAB/trunk/tools/iMesh/iBase.h	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/iMesh/iBase.h	2009-03-12 21:26:05 UTC (rev 2707)
@@ -114,8 +114,7 @@
   enum iBase_StorageOrder {
     iBase_BLOCKED,
-    iBase_INTERLEAVED,
-    iBase_UNDETERMINED
+    iBase_INTERLEAVED
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/iMesh/iMesh.h	2009-03-12 21:26:05 UTC (rev 2707)
@@ -383,56 +383,13 @@
   void iMesh_getVtxArrCoords(iMesh_Instance instance,
                              /*in*/ const iBase_EntityHandle* vertex_handles,
                              /*in*/ const int vertex_handles_size,
-                             /*inout*/ int* storage_order,
+                             /*in*/ int storage_order,
                              /*inout*/ double** coords,
                              /*inout*/ int* coords_allocated,
                              /*out*/ int* coords_size,
                              /*out*/ int *err);
-    /**\brief  Get entities adjacent to those of requested type/topology in set or instance
-     * Get entities adjacent to those of requested type/topology in set or
-     * instance.
-     * If adjacencies for all entities of specified type or
-     * topology are desired, specify iMesh_ALL_TOPOLOGIES or iBase_ALL_TYPES,
-     * respectively.  Types and topologies input to this function must be values
-     * in the iBase_EntityType or iBase_EntityTopology enumerations, respectively.
-     * \em offset[i] stores index of first adjacent entity to entity \em i from
-     * mesh or set.
-     * \param instance iMesh instance handle
-     * \param entity_set_handle Entity set whose adjacent entities are requested
-     *        (root set indicates whole mesh)
-     * \param entity_type_requestor Return entities adjacent to entities of this
-     *        type
-     * \param entity_topology_requestor Return entities adjacent to entities of
-     *        this topology
-     * \param entity_type_requested Return adjacent entities of this type
-     * \param *adj_entity_handles Pointer to array of adjacent entity handles
-     *        returned from function
-     * \param *adj_entity_handles_allocated Pointer to allocated size of
-     *        adj_entity_handles array
-     * \param *adj_entity_handles_size Pointer to occupied size of
-     * \param *offset Pointer to array of offsets returned from function
-     * \param *offset_allocated Pointer to allocated size of offset array
-     * \param *offset_size Pointer to occupied size of offset array
-     * \param *err Pointer to error type returned from function
-  void iMesh_getAdjEntities(iMesh_Instance instance,
-                            /*in*/ const iBase_EntitySetHandle entity_set_handle,
-                            /*in*/ const int entity_type_requestor,
-                            /*in*/ const int entity_topology_requestor,
-                            /*in*/ const int entity_type_requested,
-                            /*inout*/ iBase_EntityHandle** adj_entity_handles,
-                            /*inout*/ int* adj_entity_handles_allocated,
-                            /*out*/ int* adj_entity_handles_size,
-                            /*inout*/ int** offset,
-                            /*inout*/ int* offset_allocated,
-                            /*out*/ int* offset_size,
-                            /*out*/ int *err);
     /**\brief Initialize an array iterator over specified entity type, topology, and
      *        size
@@ -1418,11 +1375,11 @@
      * \param z z coordinate being set
-  void iMesh_setVtxCoords(iMesh_Instance instance,
-                          /*in*/ iBase_EntityHandle vertex_handle,
-                          /*in*/ const double x, /*in*/ const double y,
-                          /*in*/ const double z,
+  void iMesh_setVtxCoord(iMesh_Instance instance,
+                         /*in*/ iBase_EntityHandle vertex_handle,
+                         /*in*/ const double x, /*in*/ const double y,
+                         /*in*/ const double z,
+                         /*out*/ int *err);
     /**\brief  Create a new vertex at specified coordinates
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-03-12 21:26:05 UTC (rev 2707)
@@ -446,200 +446,6 @@
     RETURN(iBase_SUCCESS);
-  void iMesh_getAllVtxCoords (iMesh_Instance instance,
-                              /*inout*/ double** coordinates,
-                              /*inout*/ int* coordinates_allocated,
-                              /*out*/ int* coordinates_size,
-                              /*inout*/ int** in_entity_set,
-                              /*inout*/ int* in_entity_set_allocated,
-                              /*out*/ int* in_entity_set_size,
-                              /*inout*/ int* storage_order, int *err)
-    MBEntityHandle in_set = ENTITY_HANDLE(entity_set_handle);
-      // get all the entities then vertices
-    MBRange entities, vertices;
-    MBErrorCode result = MBI->get_entities_by_handle(in_set, entities, false);
-    if (MB_SUCCESS != result) {
-      std::string msg("iMesh_entitysetGetVertexCoordinates: getting entities didn't succeed, "
-                      "with error type: ");
-      msg += MBI->get_error_string(result);
-      iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
-      RETURN(iBase_ERROR_MAP[result]);
-      // remove any sets
-    entities.erase(entities.lower_bound(MBENTITYSET),
-                   entities.upper_bound(MBENTITYSET));
-      // get all the vertices
-    result = MBI->get_adjacencies(entities, 0, false, vertices,
-                                  MBInterface::UNION);
-      std::string msg("iMesh_entitysetGetVertexCoordinates: getting vertices didn't succeed, "
-      // now get all the coordinates
-    CHECK_SIZE(*coordinates, *coordinates_allocated,
-               (int)(3*vertices.size()), double, iBase_MEMORY_ALLOCATION_FAILED);
-    CHECK_SIZE(*in_entity_set, *in_entity_set_allocated,
-               (int)vertices.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
-      // coords will come back interleaved by default
-    MBRange::iterator vit;
-    if (*storage_order == iBase_INTERLEAVED || *storage_order == iBase_UNDETERMINED) {
-      result = MBI->get_coords(vertices, *coordinates);
-      *storage_order = iBase_INTERLEAVED;
-    else {
-      double *dum_coords = new double[3*vertices.size()];
-      result = MBI->get_coords(vertices, dum_coords);
-      if (MB_SUCCESS == result) {
-        unsigned int offset = vertices.size();
-        for (unsigned int i= 0; i < offset; i++) {
-          (*coordinates)[i]= dum_coords[3*i];
-          (*coordinates)[offset+i] = dum_coords[3*i+1];
-          (*coordinates)[2*offset+i] = dum_coords[3*i+2];
-      delete [] dum_coords;
-      std::string msg("iMesh_entitysetGetVertexCoordinates: problem getting vertex coords, "
-      // now fill the in_entity_set array
-    MBRange::iterator endr = entities.end();
-    int i;
-    for (i = 0, vit = vertices.begin(); vit != vertices.end(); vit++, i++) {
-      if (0 == in_set || entities.find(*vit) != endr)
-        (*in_entity_set)[i] = 1;
-      else
-        (*in_entity_set)[i] = 0;
-    *coordinates_size = 3*vertices.size();
-    *in_entity_set_size = vertices.size();
-    RETURN(iBase_SUCCESS);
-  void iMesh_getVtxCoordIndex (iMesh_Instance instance,
-                               /*in*/ const int requested_entity_type,
-                               /*in*/ const int requested_entity_topology,
-                               /*in*/ const int entity_adjacency_type,
-                               /*inout*/ int** index,
-                               /*inout*/ int* index_allocated,
-                               /*out*/ int* index_size,
-                               /*inout*/  int** entity_topologies,
-                               /*inout*/ int* entity_topologies_allocated,
-                               /*out*/ int* entity_topologies_size, int *err)
-    MBEntityType req_type = mb_topology_table[requested_entity_topology];
-    int req_dimension = (req_type != MBMAXTYPE ? (int) requested_entity_type : -1);
-    MBTag pos_tag = 0;
-    MBRange req_entities;
-    int num_verts;
-      iMesh_tag_set_vertices(instance, in_set,
-                             req_dimension, req_type,
-                             pos_tag, req_entities, num_verts, err);
-      RETURN(iMesh_LAST_ERROR.error_type);
-      // doesn't make sense for vertices, so remove them
-    if (-1 == req_dimension && MBI->type_from_handle(*req_entities.begin()) == MBVERTEX)
-      req_entities = req_entities.subtract(req_entities.subset_by_type(MBVERTEX));
-    if (0 == pos_tag || req_entities.empty()) {
-      *offset_size = 0;
-      *index_size = 0;
-      *entity_topologies_size = 0;
-      // now get the connectivity; get it all in one vector before setting indices, so that
-      // we can check size of or allocate index vector; but, we can check and allocate
-      // count vector
-    const MBEntityHandle *tmp_connect;
-    int num_connect;
-    std::vector<MBEntityHandle> connect;
-    CHECK_SIZE(*offset, *offset_allocated,
-               (int)(req_entities.size()+1), int, iBase_MEMORY_ALLOCATION_FAILED);
-    CHECK_SIZE(*entity_topologies, *entity_topologies_allocated,
-               (int)req_entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
-    MBRange::iterator ent_it;
-    int curr_offset = 0;
-    int i;
-    for (ent_it = req_entities.begin(), i = 0; ent_it != req_entities.end();
-         ent_it++, i++) {
-      MBErrorCode result = MBI->get_connectivity(*ent_it, tmp_connect, num_connect);
-        std::string msg("iMesh_getVtxCoordIndex: couldn't get connectivity, with error type: ");
-      std::copy(tmp_connect, tmp_connect+num_connect, std::back_inserter(connect));
-      MBEntityType this_type = MBI->type_from_handle(*ent_it);
-      (*entity_topologies)[i] = tstt_topology_table[this_type];
-      (*offset)[i] = curr_offset;
-      curr_offset += num_connect;
-      // set the last offset too
-      // now check size of, allocate, and assign index vector
-    CHECK_SIZE(*index, *index_allocated,
-               (int)connect.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
-      // get the tags all at once, it's more efficient
-    result = MBI->tag_get_data(pos_tag, &connect[0],
-                               connect.size(), *index);
-      std::string msg("iMesh_getVtxCoordIndex: couldn't get index tag, with error type: ");
-      // don't need the tag any more
-    result = MBI->tag_delete(pos_tag);
-      std::string msg("iMesh_getVtxCoordIndex: error deleting tag, with error type: ");
-    *offset_size = req_entities.size() + 1;
-    *entity_topologies_size = req_entities.size();
-    *index_size = connect.size();
   void iMesh_getEntities(iMesh_Instance instance,
                          /*in*/ const int entity_type,
@@ -658,7 +464,7 @@
   void iMesh_getVtxArrCoords (iMesh_Instance instance,
+                              /*inout*/ int storage_order,
                               /*out*/ int* coords_size, int *err)
@@ -670,10 +476,9 @@
     MBErrorCode result;
+    if (storage_order == iBase_INTERLEAVED) {
       result = MBI->get_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles),
                                vertex_handles_size, *coords);
     else {
@@ -707,122 +512,6 @@
-                            /*inout*/ int* offset_size,
-                            /*out*/ int *err)
-    MBRange entities;
-    MBEntityType requestor_type = mb_topology_table[entity_topology_requestor];
-    MBErrorCode result;
-    if (entity_type_requestor == iBase_ALL_TYPES &&
-        entity_topology_requestor == iMesh_ALL_TOPOLOGIES )
-      result = MBI->get_entities_by_handle( in_set, entities );
-    else if (requestor_type == MBMAXTYPE)
-      result = MBI->get_entities_by_dimension
-        (in_set, entity_type_requestor, entities);
-    else if (entity_topology_requestor == iMesh_SEPTAHEDRON)
-      result = MB_SUCCESS;  // MOAB doesn't do septahedrons, so there are never any of them.
-    else
-      result = MBI->get_entities_by_type(in_set, requestor_type, entities);
-    if (result != MB_SUCCESS) {
-      std::string msg("iMesh_getAdjEntities: ERROR getting requestor entities in entityset, "
-    int num_entities = entities.size();
-    if (num_entities == 0)
-      *adj_entity_handles_size = *offset_size = 0;
-      // first, count the number of adjacent entities we'll have
-    int num_sub = 0;
-    int to_dim = entity_type_requested;
-    if (to_dim == 0) {
-      const MBEntityHandle *connect;
-      int num_connect;
-      for (MBRange::const_iterator rit = entities.lower_bound(MBEDGE); rit != entities.end(); rit++) {
-        result = MBI->get_connectivity(*rit, connect, num_connect);
-        if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
-        num_sub += num_connect;
-    else {
-      MBRange tmp_adjs;
-      for (MBRange::iterator rit = entities.begin(); rit != entities.end(); rit++) {
-        result = MBI->get_adjacencies(&(*rit), 1, to_dim, false, tmp_adjs);
-        num_sub += tmp_adjs.size();
-        tmp_adjs.clear();
-      // allocate enough space for those adjacent entities
-    CHECK_SIZE(*adj_entity_handles, *adj_entity_handles_allocated,
-               num_sub, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
-               (int)entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
-      // now iterate over entities
-    num_sub = 0;
-    int i = 0;
-    std::vector<MBEntityHandle> adj_ents;
-    for (MBRange::iterator rit = entities.begin(); rit != endr; rit++) {
-      adj_ents.clear();
-      (*offset)[i] = num_sub;
-      if (to_dim == 0 && MBI->type_from_handle(*rit) == MBVERTEX) {
-        i++;
-        continue;
-      result = MBI->get_adjacencies(&(*rit), 1, (int)entity_type_requested, false,
-                                    adj_ents);
-        std::string msg("iMesh_getAdjEntities: ERROR getting adjacencies of requested entities, "
-      for (std::vector<MBEntityHandle>::iterator vit = adj_ents.begin();
-           vit != adj_ents.end(); vit++) {
-        (*adj_entity_handles)[num_sub] = (iBase_EntityHandle)*vit;
-        num_sub++;
-      i++;
-    *adj_entity_handles_size = num_sub;
-    *offset_size = entities.size();
  * Method:  initEntArrIter[]
@@ -2234,10 +1923,10 @@
-  void iMesh_setVtxCoords (iMesh_Instance instance,
-                           /*in*/ const double z, int *err)
+  void iMesh_setVtxCoord (iMesh_Instance instance,
+                          /*in*/ const double z, int *err)
     const double xyz[3] = {x, y, z};
@@ -2716,7 +2405,7 @@
     int dum = 3;
     iMesh_getVtxArrCoords(instance,
-                          &vertex_handle, 1, &order,
+                          &vertex_handle, 1, order,
                           &tmp_xyz, &dum, &dum, err);
     if (iBase_SUCCESS == *err) {
       *x = xyz[0]; *y = xyz[1]; *z = xyz[2];
Modified: MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
--- MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp	2009-03-12 21:26:05 UTC (rev 2707)
@@ -361,30 +361,17 @@
         // but will have correct size on subsequent ones
       sidl::array<double> dum_coords;
       int dum_coords_size = 0;
-      iBase::StorageOrder order = iBase::StorageOrder_UNDETERMINED;
-      mesh.getVtxArrCoords(dum_connect, dum_connect_size, order,
+      mesh.getVtxArrCoords(dum_connect, dum_connect_size, iBase::StorageOrder_INTERLEAVED,
                            dum_coords, dum_coords_size);
       assert(24 == dum_coords_size && ARRAY_SIZE(dum_coords) == 24);
       double *dum_coords_ptr = ARRAY_PTR(dum_coords, double);
       double centroid[3] = {0.0, 0.0, 0.0};
-      if (order == iBase::StorageOrder_BLOCKED) {
-        for (int j = 0; j < 8; j++) {
-          centroid[0] += dum_coords_ptr[j];
-          centroid[1] += dum_coords_ptr[8+j];
-          centroid[2] += dum_coords_ptr[16+j];
-          centroid[0] += dum_coords.get(j);
-          centroid[1] += dum_coords.get(8+j);
-          centroid[2] += dum_coords.get(16+j);
+      for (int j = 0; j < 8; j++) {
+        centroid[0] += dum_coords_ptr[3*j];
+        centroid[1] += dum_coords_ptr[3*j+1];
+        centroid[2] += dum_coords_ptr[3*j+2];
-      else {
-          centroid[0] += dum_coords_ptr[3*j];
-          centroid[1] += dum_coords_ptr[3*j+1];
-          centroid[2] += dum_coords_ptr[3*j+2];
   } catch (iBase::Error err) {
     cerr << "Problem getting connectivity or vertex coords." << endl;
Modified: MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp
--- MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp	2009-03-12 21:25:26 UTC (rev 2706)
+++ MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp	2009-03-12 21:26:05 UTC (rev 2707)
@@ -287,27 +287,17 @@
     if (iBase_SUCCESS == success) {
         // get vertex coordinates; ; will allocate space on 1st iteration,
-      int order = iBase_UNDETERMINED;
       iMesh_getVtxArrCoords(mesh, dum_connect, dum_connect_size,
-                            &order,
+                            iBase_INTERLEAVED,
                             &dum_coords, &dum_coords_allocated,
                             &dum_coords_size, &success);
-      if (order == iBase_BLOCKED) {
-          centroid[0] += dum_coords[j];
-          centroid[1] += dum_coords[8+j];
-          centroid[2] += dum_coords[16+j];
+        centroid[0] += dum_coords[3*j];
+        centroid[1] += dum_coords[3*j+1];
+        centroid[2] += dum_coords[3*j+2];
-      else {
-          centroid[0] += dum_coords[3*j];
-          centroid[1] += dum_coords[3*j+1];
-          centroid[2] += dum_coords[3*j+2];
     if (iBase_SUCCESS != success) {
