[MOAB-dev] r2702 - MOAB/trunk
jiangtao_ma at yahoo.com
Wed Mar 11 14:08:28 CDT 2009
Author: janehu
Date: 2009-03-11 14:08:28 -0500 (Wed, 11 Mar 2009)
New Revision: 2702
Added:
MOAB/trunk/ReadCGM.cpp
MOAB/trunk/ReadCGM.hpp
Modified:
MOAB/trunk/MBReaderWriterSet.cpp
MOAB/trunk/Makefile.am
Log:
Added ReadCGM file for load_file of sat, step or brep type of files to moab.
Modified: MOAB/trunk/MBReaderWriterSet.cpp
--- MOAB/trunk/MBReaderWriterSet.cpp 2009-03-11 18:58:14 UTC (rev 2701)
+++ MOAB/trunk/MBReaderWriterSet.cpp 2009-03-11 19:08:28 UTC (rev 2702)
@@ -27,6 +27,7 @@
#include "ReadSms.hpp"
#include "Tqdcfr.hpp"
#include "ReadTetGen.hpp"
+#include "ReadCGM.hpp"
#include "WriteAns.hpp"
#include "WriteVtk.hpp"
@@ -78,6 +79,9 @@
register_factory( Tqdcfr::factory, NULL, "Cubit", "cub", "CUBIT" );
+ const char* cgm_sufxs[] = {"stp", "step", "brep", "occ", "sat" };
+ register_factory( ReadCGM::factory, NULL, "CGM", cgm_sufxs, "CGM");
#ifdef NETCDF_FILE
register_factory( NULL, WriteSLAC::factory, "SLAC", "slac", "SLAC" );
#endif
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2009-03-11 18:58:14 UTC (rev 2701)
+++ MOAB/trunk/Makefile.am 2009-03-11 19:08:28 UTC (rev 2702)
@@ -1,5 +1,8 @@
# Don't require GNU-standard files (Changelog, README, etc.)
AUTOMAKE_OPTIONS = foreign
+ at CGM_CONFIG_OPTIONS@
# Don't loose the autoconf include path
ACLOCAL_AMFLAGS = -I m4
@@ -15,7 +18,8 @@
# Things to build
-lib_LTLIBRARIES = libMOAB.la
+lib_LTLIBRARIES = libMOAB.la
TESTS = moab_test \
homxform_test \
scdseq_test \
@@ -58,12 +62,13 @@
# Conditional sources
MOAB_EXTRA_SRCS =
MOAB_EXTRA_HDRS =
if NETCDF_FILE
MOAB_EXTRA_SRCS += ReadNCDF.cpp ReadNCDF.hpp \
WriteNCDF.cpp WriteNCDF.hpp \
WriteSLAC.cpp WriteSLAC.hpp
endif
-libMOAB_la_LIBADD = $(NETCDF_LIBS) $(HDF5_LIBS)
+libMOAB_la_LIBADD = $(NETCDF_LIBS) $(HDF5_LIBS)
if HDF5_FILE
libMOAB_la_LIBADD += $(top_builddir)/mhdf/libmhdf.la
INCLUDES += -I$(srcdir)/mhdf/include
@@ -75,6 +80,14 @@
INCLUDES += -I$(srcdir)/parallel
endif
+if HAVE_CGM
+ INCLUDES += $(CGM_INCLUDES)
+ CPPFLAGS += $(CGM_CPPFLAGS) -DCGM $(MOAB_CGM_DEFINES)
+ MOAB_EXTRA_SRCS += ReadCGM.cpp ReadCGM.hpp
+ libMOAB_la_LIBADD += $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
+endif
# Automake doesn't seem to have a directory defined for
# platform-dependent data (or include) files. So put
# in $(libdir). Define a $(cfgdir) to get around automake's
Added: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp (rev 0)
+++ MOAB/trunk/ReadCGM.cpp 2009-03-11 19:08:28 UTC (rev 2702)
@@ -0,0 +1,636 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+#ifdef WIN32
+#pragma warning(disable:4786)
+#endif
+#include "GeometryQueryTool.hpp"
+#include "GeometryQueryEngine.hpp"
+#include "ModelQueryEngine.hpp"
+#include "RefEntityName.hpp"
+#include "GMem.hpp"
+#include "RefGroup.hpp"
+#include "RefVolume.hpp"
+#include "RefFace.hpp"
+#include "RefEdge.hpp"
+#include "RefVertex.hpp"
+#include "SenseEntity.hpp"
+#include "Surface.hpp"
+#include "Curve.hpp"
+#include "InitCGMA.hpp"
+#include "MBCore.hpp"
+#include "MBInterface.hpp"
+#include "MBRange.hpp"
+#include "MBTagConventions.hpp"
+#include "FileOptions.hpp"
+#include "GeomTopoTool.hpp"
+#include <stdio.h>
+#include <algorithm>
+#include <assert.h>
+#define GF_CUBIT_FILE_TYPE "CUBIT"
+#define GF_STEP_FILE_TYPE "STEP"
+#define GF_IGES_FILE_TYPE "IGES"
+#define GF_ACIS_TXT_FILE_TYPE "ACIS_SAT"
+#define GF_ACIS_BIN_FILE_TYPE "ACIS_SAB"
+#define GF_OCC_BREP_FILE_TYPE "OCC"
+MBReaderIface* ReadCGM::factory( MBInterface* iface )
+{ return new ReadCGM( iface ); }
+ReadCGM::ReadCGM(MBInterface *impl)
+ : geom_tag(0), id_tag(0), name_tag(0), category_tag(0)
+ assert(NULL != impl);
+ mdbImpl = impl;
+ myGeomTool = new GeomTopoTool(impl);
+ void* ptr = 0;
+ impl->query_interface( "MBReadUtilIface", &ptr );
+ assert(NULL != ptr);
+ readUtilIface = reinterpret_cast<MBReadUtilIface*>(ptr);
+ MBErrorCode rval;
+ // get some tag handles
+ rval = mdbImpl->tag_create( GEOM_DIMENSION_TAG_NAME, sizeof(int),
+ MB_TAG_SPARSE, MB_TYPE_INTEGER, geom_tag, 0, true );
+ assert(!rval);
+ rval = mdbImpl->tag_create( GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+ MB_TYPE_INTEGER, id_tag, 0, true );
+ assert(!rval);
+ rval = mdbImpl->tag_create( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TAG_SPARSE,
+ MB_TYPE_OPAQUE, name_tag, 0, true );
+ assert(!rval);
+ rval = mdbImpl->tag_create( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE,
+ MB_TAG_SPARSE, MB_TYPE_OPAQUE, category_tag, 0, true );
+ assert(!rval);
+ReadCGM::~ReadCGM()
+ std::string iface_name = "MBReadUtilIface";
+ mdbImpl->release_interface(iface_name, readUtilIface);
+ delete myGeomTool;
+// copy geometry into mesh database
+MBErrorCode ReadCGM::load_file(const char *cgm_file_name,
+ MBEntityHandle& file_set,
+ const FileOptions& opts,
+ const int* blocks_to_load,
+ const int num_blocks)
+ //opts, blocks_to_load and num_blocks are ignored.
+ MBErrorCode rval;
+ file_set = 0;
+ std::string filename( cgm_file_name );
+ cgmFile = filename;
+ // CGM data
+ std::map<RefEntity*,MBEntityHandle> entmap[5]; // one for each dim, and one for groups
+ std::map<RefEntity*,MBEntityHandle>::iterator ci;
+ const char geom_categories[][CATEGORY_TAG_SIZE] =
+ {"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
+ const char* const names[] = { "Vertex", "Curve", "Surface", "Volume"};
+ DLIList<RefEntity*> entlist;
+ DLIList<ModelEntity*> me_list;
+ // Initialize CGM
+ InitCGMA::initialize_cgma();
+ // Get CGM file type
+ const char* file_type = 0;
+ file_type = get_geom_file_type( cgm_file_name );
+ if (!file_type) {
+ std::cerr << cgm_file_name << " : unknown file type, try '-t'" << std::endl;
+ return MB_FAILURE;
+ else if(!strcmp(file_type ,"CUBIT"))
+ std::cerr << cgm_file_name << " : cub file are not handled here." << std::endl;
+ CubitStatus s;
+ s = GeometryQueryTool::instance()->import_solid_model( cgm_file_name, file_type );
+ if (CUBIT_SUCCESS != s) {
+ std::cerr << "Failed to read '" << cgm_file_name << "' of type '" << file_type << "'" << std::endl;
+ // create entity sets for all geometric entities
+ for (int dim = 0; dim < 4; ++dim) {
+ entlist.clean_out();
+ GeometryQueryTool::instance()->ref_entity_list( names[dim], entlist, true );
+ entlist.reset();
+ for (int i = entlist.size(); i--; ) {
+ RefEntity* ent = entlist.get_and_step();
+ MBEntityHandle handle;
+ rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
+ if (MB_SUCCESS != rval)
+ entmap[dim][ent] = handle;
+ rval = mdbImpl->tag_set_data( geom_tag, &handle, 1, &dim );
+ return rval;
+ int id = ent->id();
+ rval = mdbImpl->tag_set_data( id_tag, &handle, 1, &id );
+ return rval;
+ rval = mdbImpl->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
+ return rval;
+ // create topology for all geometric entities
+ for (int dim = 1; dim < 4; ++dim) {
+ for (ci = entmap[dim].begin(); ci != entmap[dim].end(); ++ci) {
+ ci->first->get_child_ref_entities( entlist );
+ entlist.reset();
+ MBEntityHandle h = entmap[dim-1][ent];
+ rval = mdbImpl->add_parent_child( ci->second, h );
+ // store CoFace senses
+ for (ci = entmap[2].begin(); ci != entmap[2].end(); ++ci) {
+ RefFace* face = (RefFace*)(ci->first);
+ BasicTopologyEntity *forward = 0, *reverse = 0;
+ for (SenseEntity* cf = face->get_first_sense_entity_ptr();
+ cf; cf = cf->next_on_bte()) {
+ BasicTopologyEntity* vol = cf->get_parent_basic_topology_entity_ptr();
+ if (cf->get_sense() == CUBIT_UNKNOWN ||
+ cf->get_sense() != face->get_surface_ptr()->bridge_sense()) {
+ if (reverse) {
+ std::cout << "Surface " << face->id() << " has reverse senes " <<
+ "with multiple volume " << reverse->id() << " and " <<
+ "volume " << vol->id() << std::endl;
+ reverse = vol;
+ cf->get_sense() == face->get_surface_ptr()->bridge_sense()) {
+ if (forward) {
+ std::cout << "Surface " << face->id() << " has forward senes " <<
+ "with multiple volume " << forward->id() << " and " <<
+ forward = vol;
+ if (forward) {
+ rval = myGeomTool->set_sense( ci->second, entmap[3][forward], true );
+ return rval;
+ if (reverse) {
+ rval = myGeomTool->set_sense( ci->second, entmap[3][reverse], false );
+ return rval;
+ // create entity sets for all ref groups
+ std::vector<MBTag> extra_name_tags;
+ DLIList<CubitString*> name_list;
+ GeometryQueryTool::instance()->ref_entity_list( "group", entlist );
+ entlist.reset();
+ RefEntity* grp = entlist.get_and_step();
+ name_list.clean_out();
+ RefEntityName::instance()->get_refentity_name( grp, name_list, true );
+ if (name_list.size() == 0)
+ continue;
+ name_list.reset();
+ CubitString name = *name_list.get();
+ MBEntityHandle h;
+ rval = mdbImpl->create_meshset( MESHSET_SET, h );
+ char namebuf[NAME_TAG_SIZE];
+ memset( namebuf, '\0', NAME_TAG_SIZE );
+ strncpy( namebuf, name.c_str(), NAME_TAG_SIZE - 1 );
+ if (name.length() >= (unsigned)NAME_TAG_SIZE)
+ std::cout << "WARNING: group name '" << name.c_str()
+ << "' truncated to '" << namebuf << "'" << std::endl;
+ rval = mdbImpl->tag_set_data( name_tag, &h, 1, namebuf );
+ int id = grp->id();
+ rval = mdbImpl->tag_set_data( id_tag, &h, 1, &id );
+ rval = mdbImpl->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
+ if (name_list.size() > 1) {
+ for (int j = extra_name_tags.size(); j < name_list.size(); ++j) {
+ sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
+ MBTag t;
+ rval = mdbImpl->tag_create( namebuf, NAME_TAG_SIZE, MB_TAG_SPARSE, MB_TYPE_OPAQUE, t, 0, true );
+ assert(!rval);
+ extra_name_tags.push_back(t);
+ for (int j = 0; j < name_list.size(); ++j) {
+ name = *name_list.get_and_step();
+ rval = mdbImpl->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
+ entmap[4][grp] = h;
+ // store contents for each group
+ entlist.reset();
+ for (ci = entmap[4].begin(); ci != entmap[4].end(); ++ci) {
+ RefGroup* grp = (RefGroup*)(ci->first);
+ grp->get_child_ref_entities( entlist );
+ MBRange entities;
+ while (entlist.size()) {
+ RefEntity* ent = entlist.pop();
+ int dim = ent->dimension();
+ if (dim < 0) {
+ if (entmap[4].find(ent) != entmap[4].end())
+ entities.insert( entmap[4][ent] );
+ else if (dim < 4) {
+ if (entmap[dim].find(ent) != entmap[dim].end())
+ entities.insert( entmap[dim][ent] );
+ if (!entities.empty()) {
+ rval = mdbImpl->add_entities( ci->second, entities );
+ // done with volumes and groups
+ entmap[3].clear();
+ entmap[4].clear();
+ // create geometry for all vertices and replace
+ // vertex set handles with vertex handles in map
+ for (ci = entmap[0].begin(); ci != entmap[0].end(); ++ci) {
+ CubitVector pos = dynamic_cast<RefVertex*>(ci->first)->coordinates();
+ double coords[3] = {pos.x(), pos.y(), pos.z()};
+ MBEntityHandle vh;
+ rval = mdbImpl->create_vertex( coords, vh );
+ rval = mdbImpl->add_entities( ci->second, &vh, 1 );
+ ci->second = vh;
+ // create geometry for all curves
+ GMem data;
+ for (ci = entmap[1].begin(); ci != entmap[1].end(); ++ci) {
+ RefEdge* edge = dynamic_cast<RefEdge*>(ci->first);
+ Curve* curve = edge->get_curve_ptr();
+ GeometryQueryEngine* gqe = curve->get_geometry_query_engine();
+ data.clean_out();
+ int count;
+ double faceting_tol = 0.001;
+ CubitStatus s = gqe->get_graphics( curve, count, &data, faceting_tol);
+ std::vector<CubitVector> points;
+ for (int i = 0; i < data.pointListCount; ++i)
+ points.push_back( CubitVector( data.point_list()[i].x,
+ data.point_list()[i].y,
+ data.point_list()[i].z ) );
+ // need to reverse data?
+ if (curve->bridge_sense() == CUBIT_REVERSED)
+ std::reverse( points.begin(), points.end() );
+ // check for closed curve
+ RefVertex *start_vtx, *end_vtx;
+ start_vtx = edge->start_vertex();
+ end_vtx = edge->end_vertex();
+ // Special case for point curve
+ if (points.size() < 2) {
+ if (start_vtx != end_vtx || curve->measure() > gqe->get_sme_resabs_tolerance()) {
+ std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl;
+ continue;
+ MBEntityHandle h = entmap[0][start_vtx];
+ rval = mdbImpl->add_entities( ci->second, &h, 1 );
+ continue;
+ const bool closed = (points.front() - points.back()).length() < gqe->get_sme_resabs_tolerance();
+ if (closed != (start_vtx == end_vtx)) {
+ std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve "
+ << edge->id() << std::endl;
+ // check proximity of vertices to end coordinates
+ if ((start_vtx->coordinates() - points.front()).length() > gqe->get_sme_resabs_tolerance()
+ || ( end_vtx->coordinates() - points.back() ).length() > gqe->get_sme_resabs_tolerance()) {
+ std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl;
+ // create interior points
+ std::vector<MBEntityHandle> verts, edges;
+ verts.push_back( entmap[0][start_vtx] );
+ for (size_t i = 1; i < points.size() - 1; ++i) {
+ double coords[] = { points[i].x(), points[i].y(), points[i].z() };
+ MBEntityHandle h;
+ rval = mdbImpl->create_vertex( coords, h );
+ verts.push_back( h );
+ verts.push_back( entmap[0][end_vtx] );
+ // create edges
+ for (size_t i = 0; i < verts.size()-1; ++i) {
+ MBEntityHandle h;
+ rval = mdbImpl->create_element( MBEDGE, &verts[i], 2, h );
+ edges.push_back( h );
+ // if closed, remove duplicate
+ if (verts.front() == verts.back())
+ verts.pop_back();
+ rval = mdbImpl->add_entities( ci->second, &verts[0], verts.size() );
+ rval = mdbImpl->add_entities( ci->second, &edges[0], edges.size() );
+ // create geometry for all surfaces
+ RefFace* face = dynamic_cast<RefFace*>(ci->first);
+ Surface* surf = face->get_surface_ptr();
+ GeometryQueryEngine* gqe = surf->get_geometry_query_engine();
+ data.clean_out();
+ int nt, np, nf;
+ int norm_tol = 5;
+ double faceting_tol = 0.001, len_tol = 0.0;
+ CubitStatus s = gqe->get_graphics( surf, nt, np, nf, &data,
+ norm_tol, faceting_tol, len_tol);
+ // declare array of all vertex handles
+ std::vector<MBEntityHandle> verts( data.pointListCount, 0 );
+ // get list of vertices in surface
+ me_list.clean_out();
+ ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list );
+ // for each vertex, find coincident point in facets
+ for (int i = me_list.size(); i--; ) {
+ RefVertex* vtx = dynamic_cast<RefVertex*>(me_list.get_and_step());
+ CubitVector pos = vtx->coordinates();
+ for (int j = 0; j < data.pointListCount; ++j) {
+ CubitVector vpos( data.point_list()[j].x,
+ data.point_list()[j].y,
+ data.point_list()[j].z );
+ if ((pos - vpos).length_squared() < gqe->get_sme_resabs_tolerance()*gqe->get_sme_resabs_tolerance()) {
+ if (verts[j])
+ std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
+ verts[j] = entmap[0][vtx];
+ break;
+ // now create vertices for the remaining points in the facetting
+ for (int i = 0; i < data.pointListCount; ++i) {
+ if (verts[i]) // if a geometric vertex
+ continue;
+ double coords[] = { data.point_list()[i].x,
+ data.point_list()[i].z };
+ rval = mdbImpl->create_vertex( coords, verts[i] );
+ return rval;
+ // now create facets
+ MBRange facets;
+ std::vector<MBEntityHandle> corners;
+ for (int i = 0; i < data.fListCount; i += data.facet_list()[i]+1) {
+ int* facet = data.facet_list() + i;
+ corners.resize( *facet );
+ for (int j = 1; j <= *facet; ++j) {
+ if (facet[j] >= (int)verts.size()) {
+ std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl;
+ corners[j-1] = verts[facet[j]];
+ MBEntityType type;
+ if (*facet == 3)
+ type = MBTRI;
+ else {
+ std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl;
+ if (*facet == 4)
+ type = MBQUAD;
+ else
+ type = MBPOLYGON;
+ // if (surf->bridge_sense() == CUBIT_REVERSED)
+ // std::reverse( corners.begin(), corners.end() );
+ MBEntityHandle h;
+ rval = mdbImpl->create_element( type, &corners[0], corners.size(), h );
+ facets.insert( h );
+ // add vertices and facets to surface set
+ rval = mdbImpl->add_entities( ci->second, facets );
+ MBRange init_range, loaded_range;
+ rval = mdbImpl->get_entities_by_handle(0, loaded_range);
+ if (MB_FAILURE == rval) return rval;
+ rval = mdbImpl->get_entities_by_handle(0, init_range);
+ loaded_range = loaded_range.subtract(init_range);
+ rval = mdbImpl->add_entities(mCurrentMeshHandle, loaded_range);
+ file_set = mCurrentMeshHandle;
+ return MB_SUCCESS;
+const char* ReadCGM::get_geom_file_type( const char* name )
+ FILE* file;
+ const char* result = 0;
+ file = fopen( name, "r" );
+ if (file) {
+ result = get_geom_fptr_type( file );
+ fclose( file );
+ return result;
+const char* ReadCGM::get_geom_fptr_type( FILE* file )
+ static const char* CUBIT_NAME = GF_CUBIT_FILE_TYPE;
+ static const char* STEP_NAME = GF_STEP_FILE_TYPE;
+ static const char* IGES_NAME = GF_IGES_FILE_TYPE;
+ static const char* SAT_NAME = GF_ACIS_TXT_FILE_TYPE;
+ static const char* SAB_NAME = GF_ACIS_BIN_FILE_TYPE;
+ static const char* BREP_NAME = GF_OCC_BREP_FILE_TYPE;
+ if (is_cubit_file(file))
+ return CUBIT_NAME;
+ else if (is_step_file(file))
+ return STEP_NAME;
+ else if (is_iges_file(file))
+ return IGES_NAME;
+ else if (is_acis_bin_file(file))
+ return SAB_NAME;
+ else if (is_acis_txt_file(file))
+ return SAT_NAME;
+ else if (is_occ_brep_file(file))
+ return BREP_NAME;
+ else
+ return 0;
+int ReadCGM::is_cubit_file( FILE* file )
+ unsigned char buffer[4];
+ return !fseek(file, 0, SEEK_SET) &&
+ fread(buffer, 4, 1, file) &&
+ !memcmp(buffer, "CUBE", 4);
+int ReadCGM::is_step_file( FILE* file )
+ unsigned char buffer[9];
+ fread(buffer, 9, 1, file) &&
+ !memcmp(buffer, "ISO-10303", 9);
+int ReadCGM::is_iges_file( FILE* file )
+ unsigned char buffer[10];
+ return !fseek(file, 72, SEEK_SET) &&
+ fread(buffer, 10, 1, file) &&
+ !memcmp(buffer, "S 1", 8);
+int ReadCGM::is_acis_bin_file( FILE* file )
+ char buffer[15];
+ fread(buffer, 15, 1, file) &&
+ !memcmp(buffer, "ACIS BinaryFile", 9);
+int ReadCGM::is_acis_txt_file( FILE* file )
+ char buffer[5];
+ int version, length;
+ if (fseek(file,0,SEEK_SET) ||
+ 2 != fscanf( file, "%d %*d %*d %*d %d ", &version, &length ))
+ return 0;
+ if (version < 1 || version >0xFFFF)
+ return 0;
+ // Skip appliation name
+ if (fseek(file, length, SEEK_CUR))
+ return 0;
+ // Read length of version string followed by first 5 characters
+ if (2 != fscanf(file, "%d %4s", &length, buffer))
+ return 0;
+ return !strcmp( buffer, "ACIS" );
+int ReadCGM::is_occ_brep_file( FILE* file )
+ unsigned char buffer[6];
+ fread(buffer, 6, 1, file) &&
+ !memcmp(buffer, "DBRep_", 6);
Added: MOAB/trunk/ReadCGM.hpp
--- MOAB/trunk/ReadCGM.hpp (rev 0)
+++ MOAB/trunk/ReadCGM.hpp 2009-03-11 19:08:28 UTC (rev 2702)
@@ -0,0 +1,92 @@
+// Filename : ReadCGM.hpp
+// Purpose : .sat, .step and .brep file reader
+// Special Notes : Lots of code taken from cgm2moab implementation
+// Creator : Jane Hu
+// Date : 3/09
+#ifndef READCGM_HPP
+#define READCGM_HPP
+#ifndef CGM
+#error "ReadCGM.hpp isn't supposed to be included without building CGM"
+#endif
+#include <string>
+class MBReadUtilIface;
+class GeomTopoTool;
+#include "MBReaderIface.hpp"
+class ReadCGM : public MBReaderIface
+public:
+ static MBReaderIface* factory( MBInterface* );
+ //! load an ExoII file
+ MBErrorCode load_file(const char *cgm_file_name,
+ const int num_blocks);
+ //! Constructor
+ ReadCGM(MBInterface* impl = NULL);
+ //! Destructor
+ virtual ~ReadCGM();
+private:
+ MBReadUtilIface* readUtilIface;
+ GeomTopoTool* myGeomTool;
+ const char* get_geom_file_type( const char* filename );
+ const char* get_geom_fptr_type( FILE* file );
+ int is_cubit_file( FILE* file );
+ int is_step_file( FILE* file );
+ int is_iges_file( FILE* file );
+ int is_acis_txt_file( FILE* file );
+ int is_acis_bin_file( FILE* file );
+ int is_occ_brep_file( FILE* file );
+ //------------member variables ------------//
+ //! interface instance
+ MBInterface* mdbImpl;
+ //! file name
+ std::string cgmFile;
+ //! Meshset Handle for the mesh that is currently being read
+ MBEntityHandle mCurrentMeshHandle;
+ MBTag geom_tag, id_tag, name_tag, category_tag;
+#endif
