[MOAB-dev] r2699 - MOAB/trunk/tools/dagmc
tautges at mcs.anl.gov
Wed Mar 11 12:26:40 CDT 2009
Author: tautges
Date: 2009-03-11 12:26:39 -0500 (Wed, 11 Mar 2009)
New Revision: 2699
Modified:
MOAB/trunk/tools/dagmc/ray_fire_test.cc
Log:
Adding input parameters to limit azimuthal location and direction
of ray, and changing to polar coordinates to reduce # calls to random
number generator.
Modified: MOAB/trunk/tools/dagmc/ray_fire_test.cc
--- MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-03-11 15:03:29 UTC (rev 2698)
+++ MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-03-11 17:26:39 UTC (rev 2699)
@@ -28,14 +28,14 @@
void get_time_mem(double &tot_time, double &user_time,
double &sys_time, double &tot_mem);
-#define RNDVEC(u, v, w) \
- {u = 2.0 * (denom * rand() - 0.5); \
- v = 2.0 * (denom * rand() - 0.5); \
- w = 2.0 * (denom * rand() - 0.5); \
- double normal = 1.0 / (u*u + v*v + w*w); \
- u *= normal; \
- v *= normal; \
- w *= normal;}
+#define RNDVEC(u, v, w, az) \
+ double theta = denom * az * rand(); \
+ double phi = denomPI * rand(); \
+ u = cos(theta)*sin(phi); \
+ v = sin(theta)*sin(phi); \
+ z = cos(phi);\
int main( int argc, char* argv[] )
@@ -43,7 +43,7 @@
if (argc < 6) {
std::cerr << "Usage: " << argv[0] << " [-f] <filename> "
- << " <facet_tol> <source_rad> <vol_index> <#calls> " << std::endl;
+ << " <facet_tol> <source_rad> <vol_index> <#calls> [<location_az>] [<direction_az>]" << std::endl;
std::cerr << "-f: report full tree statistics" << std::endl;
std::cerr << "filename: mesh or geometry filename" << std::endl;
std::cerr << "facet_tol: facet tolerance" << std::endl;
@@ -51,9 +51,15 @@
std::cerr << " otherwise, ray at radius and random angle, pointed in random direction;" << std::endl;
std::cerr << "vol_index: index of the volume at which to fire rays" << std::endl;
std::cerr << "#calls: # iterations of ray-tracing loop" << std::endl;
+ std::cerr << "location_az: if present, ray location is limited to between +-<azimuthal_limit> degrees" << std::endl;
+ std::cerr << "direction_az: if present, ray direction is limited to between +-<azimuthal_limit> degrees" << std::endl;
return 1;
+ const double PI = acos(-1.0);
+ double denom = 1.0 / ((double) RAND_MAX);
+ double denomPI = PI * denom;
double facet_tol;
int ncalls;
bool full = false;
@@ -68,7 +74,12 @@
double rad = atof(argv[i++]);
int vol_idx = atoi(argv[i++]);
ncalls = atoi(argv[i++]);
+ double location_az = 2.0 * PI / 180.0, direction_az = location_az;
+ if (i < argc) location_az = atof(argv[i++]) * PI / 180.0;
+ if (i < argc) direction_az = atof(argv[i++]) * PI / 180.0;
DagMC& dagmc = *DagMC::instance();
rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0, facet_tol);
if (MB_SUCCESS != rval) {
@@ -87,19 +98,18 @@
// initialize random number generator using ttime1
srand((unsigned int) ttime1);
- double denom = 1.0 / ((double) RAND_MAX);
double x, y, z, u, v, w, dist;
MBEntityHandle nsurf;
for (int j = 0; j < ncalls; j++) {
- RNDVEC(u, v, w);
+ RNDVEC(u, v, w, location_az);
x = -u*rad;
y = -v*rad;
z = -w*rad;
if (rad >= 0.0) {
- RNDVEC(u, v, w);
+ RNDVEC(u, v, w, direction_az);
dagmc.ray_fire(vol, 0, 1, u, v, w, x, y, z, DBL_MAX,
@@ -110,14 +120,14 @@
// now without ray fire call, to subtract out overhead
- RNDVEC(u, v, w);
x = -u*rad;
y = -v*rad;
z = -w*rad;
if (rad >= 0.0) {
- RNDVEC(u, v, w);
