[MOAB-dev] r2697 - MOAB/trunk/tools/dagmc
tautges at mcs.anl.gov
Wed Mar 11 09:58:14 CDT 2009
Author: tautges
Date: 2009-03-11 09:58:14 -0500 (Wed, 11 Mar 2009)
New Revision: 2697
Modified:
MOAB/trunk/tools/dagmc/ray_fire_test.cc
Log:
Adding ability to report full tree stats; modifying outside-volume
ray directions slightly.
Modified: MOAB/trunk/tools/dagmc/ray_fire_test.cc
--- MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-03-10 20:20:16 UTC (rev 2696)
+++ MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-03-11 14:58:14 UTC (rev 2697)
@@ -28,23 +28,47 @@
void get_time_mem(double &tot_time, double &user_time,
double &sys_time, double &tot_mem);
+#define RNDVEC(u, v, w) \
+ {u = 2.0 * (denom * rand() - 0.5); \
+ v = 2.0 * (denom * rand() - 0.5); \
+ w = 2.0 * (denom * rand() - 0.5); \
+ double normal = 1.0 / (u*u + v*v + w*w); \
+ u *= normal; \
+ v *= normal; \
+ w *= normal;}
int main( int argc, char* argv[] )
MBErrorCode rval;
if (argc < 6) {
- std::cerr << "Usage: " << argv[0] << " <mesh_filename> "
+ std::cerr << "Usage: " << argv[0] << " [-f] <filename> "
<< " <facet_tol> <source_rad> <vol_index> <#calls> " << std::endl;
+ std::cerr << "-f: report full tree statistics" << std::endl;
+ std::cerr << "filename: mesh or geometry filename" << std::endl;
+ std::cerr << "facet_tol: facet tolerance" << std::endl;
+ std::cerr << "source_rad: if < 0, ray at source_rad and random angle pointed at origin;" << std::endl;
+ std::cerr << " otherwise, ray at radius and random angle, pointed in random direction;" << std::endl;
+ std::cerr << "vol_index: index of the volume at which to fire rays" << std::endl;
+ std::cerr << "#calls: # iterations of ray-tracing loop" << std::endl;
return 1;
- char* filename = argv[1];
- double facet_tol = atof(argv[2]);
- double rad = atof(argv[3]);
- int vol_idx = atoi(argv[4]);
- int ncalls = atoi(argv[5]);
+ double facet_tol;
+ int ncalls;
+ bool full = false;
+ int i = 1;
+ if (!strcmp(argv[i], "-f")) {
+ full = true;
+ i++;
+ char* filename = argv[i++];
+ facet_tol = atof(argv[i++]);
+ ncalls = atoi(argv[i++]);
+ double rad = atof(argv[i++]);
+ int vol_idx = atoi(argv[i++]);
DagMC& dagmc = *DagMC::instance();
rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0, facet_tol);
@@ -65,22 +89,20 @@
// initialize random number generator using ttime1
srand((unsigned int) ttime1);
double denom = 1.0 / ((double) RAND_MAX);
- double x, y, z, u, v, w, normal, dist;
+ double x, y, z, u, v, w, dist;
MBEntityHandle nsurf;
- for (int i = 0; i < ncalls; i++) {
- u = denom * rand();
- v = denom * rand();
- w = denom * rand();
- normal = 1.0 / (u*u + v*v + w*w);
- u *= normal;
- v *= normal;
- w *= normal;
- x = u*rad;
- y = v*rad;
- z = w*rad;
+ for (int j = 0; j < ncalls; j++) {
+ RNDVEC(u, v, w);
+ x = -u*rad;
+ y = -v*rad;
+ z = -w*rad;
+ if (rad >= 0.0) {
+ RNDVEC(u, v, w);
dagmc.ray_fire(vol, 0, 1, u, v, w, x, y, z, DBL_MAX,
dist, nsurf);
@@ -88,14 +110,16 @@
double timewith = ttime2 - ttime1;
// now without ray fire call, to subtract out overhead
- u *= normal;
- v *= normal;
- w *= normal;
+ RNDVEC(u, v, w);
+ x = -u*rad;
+ y = -v*rad;
+ z = -w*rad;
+ if (rad >= 0.0) {
+ RNDVEC(u, v, w);
get_time_mem(ttime1, utime1, stime1, tmem2);
@@ -119,6 +143,11 @@
std::cout << "Tree stats: facets, tree_height, num_leaves = "
<< entities_in_tree << " " << tree_height << " " << num_leaves << std::endl;
+ if (full) {
+ std::cout << "Tree data: " << std::endl;
+ dagmc.obb_tree()->stats(root, std::cout);
return 0;
