[MOAB-dev] r2679 - in MOAB/trunk: . test
    kraftche at cae.wisc.edu
    Wed Mar  4 08:41:56 CST 2009
Author: kraftche
Date: 2009-03-04 08:41:56 -0600 (Wed, 04 Mar 2009)
New Revision: 2679
Added:
   MOAB/trunk/test/ho_test.cub
   MOAB/trunk/test/test.cub
Removed:
   MOAB/trunk/ho_test.cub
   MOAB/trunk/test.cub
Modified:
   MOAB/trunk/Makefile.am
   MOAB/trunk/cub_file_test.cc
   MOAB/trunk/test/Makefile.am
Log:
move test input files to test/ dir and include them in tarball
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-03-03 21:08:46 UTC (rev 2678)
+++ MOAB/trunk/Makefile.am	2009-03-04 14:41:56 UTC (rev 2679)
@@ -359,8 +359,6 @@
 mbcn_test_SOURCES = MBCN.hpp MBCN.cpp mbcn_test.cc
 mbcn_test_CPPFLAGS = -DSRCDIR=$(srcdir)  # define anything to work around build issue
-EXTRA_DIST = test.cub
 # Other files to clean up (e.g. output from tests)
 MOSTLYCLEANFILES = dumped_acis.sat tree.h5m
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc	2009-03-03 21:08:46 UTC (rev 2678)
+++ MOAB/trunk/cub_file_test.cc	2009-03-04 14:41:56 UTC (rev 2679)
@@ -76,11 +76,11 @@
  * adjacent corner vertices of the element.
 #ifdef SRCDIR
-static const char input_file_1[] = STRINGIFY(SRCDIR) "/test.cub";
-static const char ho_file[] = STRINGIFY(SRCDIR) "/ho_test.cub";
+static const char input_file_1[] = STRINGIFY(SRCDIR) "/test/test.cub";
+static const char ho_file[] = STRINGIFY(SRCDIR) "/test/ho_test.cub";
 #else
-static const char input_file_1[] = "test.cub";
-static const char ho_file[] = "ho_test.cub";
+static const char input_file_1[] = "test/test.cub";
+static const char ho_file[] = "test/ho_test.cub";
 #endif
 void read_file( MBInterface& moab,
Deleted: MOAB/trunk/ho_test.cub
(Binary files differ)
Modified: MOAB/trunk/test/Makefile.am
--- MOAB/trunk/test/Makefile.am	2009-03-03 21:08:46 UTC (rev 2678)
+++ MOAB/trunk/test/Makefile.am	2009-03-04 14:41:56 UTC (rev 2679)
@@ -23,7 +23,10 @@
               testquad-cyl.g \
               testquad.g \
               testtet.g \
-	      v3_dodec.h5m
+	      v3_dodec.h5m \
+              ho_test.g \
+              test.cub \
+              ho_test.cub
 CLEANFILES = mb_big_test.g \
              cell1.gen \
Copied: MOAB/trunk/test/ho_test.cub (from rev 2678, MOAB/trunk/ho_test.cub)
Property changes on: MOAB/trunk/test/ho_test.cub
___________________________________________________________________
   + application/octet-stream
Copied: MOAB/trunk/test/test.cub (from rev 2678, MOAB/trunk/test.cub)
Property changes on: MOAB/trunk/test/test.cub
   + application/x-cubit
Deleted: MOAB/trunk/test.cub
