[MOAB-dev] r2673 - in MOAB/trunk: . tools/dagmc
tautges at mcs.anl.gov
Mon Mar 2 21:11:25 CST 2009
Author: tautges
Date: 2009-03-02 21:11:25 -0600 (Mon, 02 Mar 2009)
New Revision: 2673
Added:
MOAB/trunk/tools/dagmc/ray_fire_test.cc
Modified:
MOAB/trunk/MBOrientedBoxTreeTool.cpp
MOAB/trunk/MBOrientedBoxTreeTool.hpp
MOAB/trunk/tools/dagmc/DagMC.hpp
MOAB/trunk/tools/dagmc/Makefile.am
Log:
Adding a ray fire test for timing calls to ray tracing through dagmc.
Adding another function to MBOrientedBoxTreeTool for passing back tree
stats instead of just printing them.
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp 2009-03-02 19:45:22 UTC (rev 2672)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp 2009-03-03 03:11:25 UTC (rev 2673)
@@ -1665,6 +1665,47 @@
//#define WW <<std::setw(10)<<std::fixed<<
#define WE <<std::setw(10)<<
#define WW WE
+MBErrorCode MBOrientedBoxTreeTool::stats( MBEntityHandle set,
+ unsigned &total_entities,
+ double &rv,
+ double &tot_node_volume,
+ double &tot_to_root_volume,
+ unsigned &tree_height,
+ unsigned &node_count,
+ unsigned &num_leaves)
+ StatData d;
+ MBErrorCode rval;
+ unsigned i;
+ MBCartVect total_dim;
+ rval = recursive_stats( this, instance, set, 0, d, total_entities, total_dim );
+ if (MB_SUCCESS != rval)
+ return rval;
+ tree_height = d.leaf_depth.size();
+ unsigned min_leaf_depth = tree_height;
+ num_leaves = 0;
+ unsigned max_leaf_per_depth = 0;
+ double sum_leaf_depth = 0, sqr_leaf_depth = 0;
+ for (i = 0; i < d.leaf_depth.size(); ++i) {
+ unsigned val = d.leaf_depth[i];
+ num_leaves += val;
+ sum_leaf_depth += (double)val*i;
+ sqr_leaf_depth += (double)val*i*i;
+ if (val && i < min_leaf_depth)
+ min_leaf_depth = i;
+ if (max_leaf_per_depth < val)
+ max_leaf_per_depth = val;
+ rv = total_dim[0]*total_dim[1]*total_dim[2];
+ tot_node_volume = d.vol.sum;
+ tot_to_root_volume = d.vol.sum/rv;
+ node_count = d.count;
+ return MB_SUCCESS;
MBErrorCode MBOrientedBoxTreeTool::stats( MBEntityHandle set, std::ostream& s )
StatData d;
Modified: MOAB/trunk/MBOrientedBoxTreeTool.hpp
--- MOAB/trunk/MBOrientedBoxTreeTool.hpp 2009-03-02 19:45:22 UTC (rev 2672)
+++ MOAB/trunk/MBOrientedBoxTreeTool.hpp 2009-03-03 03:11:25 UTC (rev 2673)
@@ -280,6 +280,27 @@
MBErrorCode stats( MBEntityHandle tree_root_set, std::ostream& stream );
+ /**\brief Get tree statistics
+ * Get summary stats. describing tree
+ * \param set Root of tree for which data is requested
+ * \param total_entities Entities in tree
+ * \param root_volume Total volume of root box
+ * \param tot_node_volume Total volume in all nodes
+ * \param tot_to_root_volume Ratio of total / root volume
+ * \param tree_height Maximum height of tree, from root to leaf
+ * \param node_count Number of nodes in tree
+ * \param num_leaves Number of leaf nodes in tree
+ MBErrorCode stats( MBEntityHandle set,
+ unsigned &entities_in_tree,
+ double &root_volume,
+ unsigned &num_leaves);
/** \brief Implement this and pass instance to preorder_traverse
* This interface may be implemented and an instance passed to
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2009-03-02 19:45:22 UTC (rev 2672)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2009-03-03 03:11:25 UTC (rev 2673)
@@ -140,6 +140,9 @@
MBErrorCode getobb(MBEntityHandle volume, double center[3],
double axis1[3], double axis2[3], double axis3[3]);
+ // get the root of the obbtree for a given entity
+ MBErrorCode get_root(MBEntityHandle vol_or_surf, MBEntityHandle &root);
int get_entity_id(MBEntityHandle this_ent);
// Get the instance of MOAB used by functions in this file.
@@ -297,5 +300,13 @@
return entHandles[dimension][index];
+inline MBErrorCode DagMC::get_root(MBEntityHandle vol_or_surf, MBEntityHandle &root)
+ unsigned int index = vol_or_surf - setOffset;
+ root = (index < rootSets.size() ? rootSets[index] : 0);
+ return (root ? MB_SUCCESS : MB_INDEX_OUT_OF_RANGE);
#endif
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am 2009-03-02 19:45:22 UTC (rev 2672)
+++ MOAB/trunk/tools/dagmc/Makefile.am 2009-03-03 03:11:25 UTC (rev 2673)
@@ -35,7 +35,7 @@
cfg_DATA = dagmc.make
TESTS = test_geom
-check_PROGRAMS = $(TESTS) pt_vol_test
+check_PROGRAMS = $(TESTS) pt_vol_test ray_fire_test
test_geom_SOURCES = test_geom.cc
cub2h5m_SOURCES = cub2h5m.cc
test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
@@ -44,4 +44,7 @@
pt_vol_test_SOURCES = pt_vol_test.cc
pt_vol_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
+ray_fire_test_SOURCES = ray_fire_test.cc
+ray_fire_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
Added: MOAB/trunk/tools/dagmc/ray_fire_test.cc
--- MOAB/trunk/tools/dagmc/ray_fire_test.cc (rev 0)
+++ MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-03-03 03:11:25 UTC (rev 2673)
@@ -0,0 +1,169 @@
+#include "MBInterface.hpp"
+#include "MBCore.hpp"
+#include "DagMC.hpp"
+#include "MBTagConventions.hpp"
+#include <vector>
+#include <iostream>
+#include <math.h>
+#include <unistd.h>
+#include <limits>
+#include <fcntl.h>
+#include <stdio.h>
+#include <cstdlib>
+#include <cfloat>
+#if !defined(_MSC_VER) && !defined(__MINGW32__)
+#include <sys/resource.h>
+#endif
+#ifdef SOLARIS
+extern "C" int getrusage(int, struct rusage *);
+#ifndef RUSAGE_SELF
+#include </usr/ucbinclude/sys/rusage.h>
+#endif
+#endif
+#define CHKERR if (MB_SUCCESS != rval) return rval
+void get_time_mem(double &tot_time, double &user_time,
+ double &sys_time, double &tot_mem);
+int main( int argc, char* argv[] )
+ MBErrorCode rval;
+ if (argc < 3) {
+ std::cerr << "Usage: " << argv[0] << " <mesh_filename> "
+ << " <facet_tol> <#calls> " << std::endl;
+ return 1;
+ char* filename = argv[1];
+ double tol = atof(argv[2]);
+ int ncalls = atoi(argv[3]);
+ DagMC& dagmc = *DagMC::instance();
+ rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0, tol);
+ if (MB_SUCCESS != rval) {
+ std::cerr << "Failed to initialize DagMC." << std::endl;
+ return 2;
+ MBEntityHandle vol = dagmc.entity_by_index(3, 1);
+ if (0 == vol) {
+ std::cerr << "Problem getting first volume." << std::endl;
+ return 2;
+ double ttime1, utime1, stime1, tmem1, ttime2, utime2, stime2, tmem2;
+ get_time_mem(ttime1, utime1, stime1, tmem1);
+ // initialize random number generator using ttime1
+ srand((unsigned int) ttime1);
+ double denom = 1.0 / ((double) RAND_MAX);
+ double u, v, w, normal, dist;
+ MBEntityHandle nsurf;
+ for (int i = 0; i < ncalls; i++) {
+ u = denom * rand();
+ v = denom * rand();
+ w = denom * rand();
+ normal = 1.0 / (u*u + v*v + w*w);
+ u *= normal;
+ v *= normal;
+ w *= normal;
+ dagmc.ray_fire(vol, 0, 1, u, v, w, 0.0, 0.0, 0.0, DBL_MAX,
+ dist, nsurf);
+ get_time_mem(ttime2, utime2, stime2, tmem1);
+ double timewith = ttime2 - ttime1;
+ // now without ray fire call, to subtract out overhead
+ u *= normal;
+ v *= normal;
+ w *= normal;
+ get_time_mem(ttime1, utime1, stime1, tmem2);
+ double timewithout = ttime1 - ttime2;
+ MBEntityHandle root;
+ MBErrorCode result = dagmc.get_root(vol, root);
+ if (MB_SUCCESS != result) {
+ std::cerr << "Trouble getting tree stats." << std::endl;
+ return 2;
+ unsigned int entities_in_tree, tree_height, node_count, num_leaves;
+ double root_volume, tot_node_volume, tot_to_root_volume;
+ dagmc.obb_tree()->stats(root, entities_in_tree, root_volume, tot_node_volume,
+ tot_to_root_volume, tree_height, node_count, num_leaves);
+ std::cout << "Gross time per call, net time per call, memory = "
+ << timewith/ncalls << " " << (timewith - timewithout)/ncalls
+ << " " << tmem2 << std::endl;
+ std::cout << "Tree stats: facets, tree_height, num_leaves = "
+ << entities_in_tree << " " << tree_height << " " << num_leaves << std::endl;
+ return 0;
+ struct rusage r_usage;
+ getrusage(RUSAGE_SELF, &r_usage);
+ user_time = (double)r_usage.ru_utime.tv_sec +
+ ((double)r_usage.ru_utime.tv_usec/1.e6);
+ sys_time = (double)r_usage.ru_stime.tv_sec +
+ ((double)r_usage.ru_stime.tv_usec/1.e6);
+ tot_time = user_time + sys_time;
+ tot_mem = 0;
+ if (0 != r_usage.ru_maxrss) {
+ tot_mem = r_usage.ru_idrss;
+ else {
+ // this machine doesn't return rss - try going to /proc
+ // print the file name to open
+ char file_str[4096], dum_str[4096];
+ int file_ptr = -1, file_len;
+ file_ptr = open("/proc/self/stat", O_RDONLY);
+ file_len = read(file_ptr, file_str, sizeof(file_str)-1);
+ if (file_len == 0) return;
+ close(file_ptr);
+ file_str[file_len] = '\0';
+ // read the preceeding fields and the ones we really want...
+ int dum_int;
+ unsigned int dum_uint, vm_size, rss;
+ int num_fields = sscanf(file_str,
+ "%d " // pid
+ "%s " // comm
+ "%c " // state
+ "%d %d %d %d %d " // ppid, pgrp, session, tty, tpgid
+ "%u %u %u %u %u " // flags, minflt, cminflt, majflt, cmajflt
+ "%d %d %d %d %d %d " // utime, stime, cutime, cstime, counter, priority
+ "%u %u " // timeout, itrealvalue
+ "%d " // starttime
+ "%u %u", // vsize, rss
+ &dum_int,
+ dum_str,
+ dum_str,
+ &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
+ &dum_uint, &dum_uint, &dum_uint, &dum_uint, &dum_uint,
+ &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
+ &dum_int,
+ &vm_size, &rss);
+ if (num_fields == 24)
+ tot_mem = ((double)vm_size);
