[MOAB-dev] r2666 - MOAB/trunk
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Feb 26 18:24:58 CST 2009
Author: kraftche
Date: 2009-02-26 18:24:58 -0600 (Thu, 26 Feb 2009)
New Revision: 2666
Modified:
   MOAB/trunk/MBSkinner.cpp
Log:
fix skinner bugs
Modified: MOAB/trunk/MBSkinner.cpp
--- MOAB/trunk/MBSkinner.cpp	2009-02-26 22:24:14 UTC (rev 2665)
+++ MOAB/trunk/MBSkinner.cpp	2009-02-27 00:24:58 UTC (rev 2666)
@@ -455,7 +455,7 @@
     if( type != tmp_type )
       continue;
-    result = thisMB->get_connectivity(*jter, tmp, num_verts);
+    result = thisMB->get_connectivity(*jter, tmp, num_verts, true);
     assert(MB_SUCCESS == result && num_verts >= num_nodes);
     if(connectivity_match(conn, tmp, num_verts, direct))
@@ -657,7 +657,8 @@
     assert(MB_SUCCESS == result);
     // add node handles to boundary_node range
-    std::copy(conn.begin(), conn.end(), mb_range_inserter(boundary_nodes));
+    std::copy(conn.begin(), conn.begin()+MBCN::VerticesPerEntity(type),
+              mb_range_inserter(boundary_nodes));
     type = thisMB->type_from_handle(*iter);
