[MOAB-dev] r2655 - MOAB/trunk/tools
    kraftche at cae.wisc.edu
    Tue Feb 24 10:52:13 CST 2009
Author: kraftche
Date: 2009-02-24 10:52:13 -0600 (Tue, 24 Feb 2009)
New Revision: 2655
Added:
   MOAB/trunk/tools/README.mbconvert
   MOAB/trunk/tools/README.mbskin
   MOAB/trunk/tools/README.mbsurfplot
Removed:
   MOAB/trunk/tools/README.mvconvert
   MOAB/trunk/tools/README.skin
   MOAB/trunk/tools/README.surfplot
Modified:
   MOAB/trunk/tools/Makefile.am
Log:
install README files for simple tools
Modified: MOAB/trunk/tools/Makefile.am
--- MOAB/trunk/tools/Makefile.am	2009-02-24 16:35:42 UTC (rev 2654)
+++ MOAB/trunk/tools/Makefile.am	2009-02-24 16:52:13 UTC (rev 2655)
@@ -4,34 +4,42 @@
 LDADD = $(top_builddir)/libMOAB.la
 bin_PROGRAMS =
 dist_man1_MANS =
+doc_DATA =
 if ENABLE_mbconvert
   bin_PROGRAMS += mbconvert
   dist_man1_MANS += mbconvert.man
+  doc_DATA += README.mbconvert
 endif
 if ENABLE_hexmodops
   bin_PROGRAMS += hexmodops
+  doc_DATA += README.hexmodops
 endif
 if ENABLE_mbsize
   bin_PROGRAMS += mbsize
+  doc_DATA += README.mbsize
 endif
 if ENABLE_mbskin
   bin_PROGRAMS += mbskin
+  doc_DATA += README.mbskin
 endif
 if ENABLE_mbtagprop
   bin_PROGRAMS += mbtagprop
+  doc_DATA += README.mbtagprop
 endif
 if ENABLE_spheredecomp
   bin_PROGRAMS += spheredecomp
+  doc_DATA += README.spheredecomp
 endif
 if ENABLE_mbsurfplot
   bin_PROGRAMS += mbsurfplot
+  doc_DATA += README.mbsurfplot
 endif
 if ENABLE_gsets
Copied: MOAB/trunk/tools/README.mbconvert (from rev 2653, MOAB/trunk/tools/README.mvconvert)
--- MOAB/trunk/tools/README.mbconvert	                        (rev 0)
+++ MOAB/trunk/tools/README.mbconvert	2009-02-24 16:52:13 UTC (rev 2655)
@@ -0,0 +1 @@
+See mbconvert.man in this directory.
Copied: MOAB/trunk/tools/README.mbskin (from rev 2653, MOAB/trunk/tools/README.skin)
--- MOAB/trunk/tools/README.mbskin	                        (rev 0)
+++ MOAB/trunk/tools/README.mbskin	2009-02-24 16:52:13 UTC (rev 2655)
@@ -0,0 +1,15 @@
+This is a utility for generating input files for testing Mesquite
+(MESh QUality Improvement Toolkit).  The CL arguments to the utilty
+are a single input file and a single outpute file.  The utility
+does the following:
+  o Read input file
+  o Find the set of all elements of the highest dimension
+    (e.g. all volume elements if there are any, otherwise
+     all face elements.)
+  o Generate the skin of that set of elements.
+  o Create an integer tag named "fixed"
+  o Set the tag to zero on all interior vertices and one
+    on all vertices in the skin of the mesh
+  o Write out the set of elements
Copied: MOAB/trunk/tools/README.mbsurfplot (from rev 2653, MOAB/trunk/tools/README.surfplot)
--- MOAB/trunk/tools/README.mbsurfplot	                        (rev 0)
+++ MOAB/trunk/tools/README.mbsurfplot	2009-02-24 16:52:13 UTC (rev 2655)
@@ -0,0 +1,10 @@
+This utility plots the mesh of a single geometric surface projected to
+a plane.  The output file is written to stdout.
+Usage:
+surfplot [-g|-p] <Surface_ID> <input_file>
+-g           -  Write GNU Plot data file (default).
+-p           -  Write encapsulated postscript file
+-s           -  Write an SVG file
+<Surface_ID> -  ID of surface containing mesh to export.
+<input_file> -  Mesh file to read.
Deleted: MOAB/trunk/tools/README.mvconvert
--- MOAB/trunk/tools/README.mvconvert	2009-02-24 16:35:42 UTC (rev 2654)
+++ MOAB/trunk/tools/README.mvconvert	2009-02-24 16:52:13 UTC (rev 2655)
@@ -1 +0,0 @@
-See mbconvert.man in this directory.
Deleted: MOAB/trunk/tools/README.skin
--- MOAB/trunk/tools/README.skin	2009-02-24 16:35:42 UTC (rev 2654)
+++ MOAB/trunk/tools/README.skin	2009-02-24 16:52:13 UTC (rev 2655)
@@ -1,15 +0,0 @@
-This is a utility for generating input files for testing Mesquite
-(MESh QUality Improvement Toolkit).  The CL arguments to the utilty
-are a single input file and a single outpute file.  The utility
-does the following:
-  o Read input file
-  o Find the set of all elements of the highest dimension
-    (e.g. all volume elements if there are any, otherwise
-     all face elements.)
-  o Generate the skin of that set of elements.
-  o Create an integer tag named "fixed"
-  o Set the tag to zero on all interior vertices and one
-    on all vertices in the skin of the mesh
-  o Write out the set of elements
Deleted: MOAB/trunk/tools/README.surfplot
--- MOAB/trunk/tools/README.surfplot	2009-02-24 16:35:42 UTC (rev 2654)
+++ MOAB/trunk/tools/README.surfplot	2009-02-24 16:52:13 UTC (rev 2655)
@@ -1,10 +0,0 @@
-This utility plots the mesh of a single geometric surface projected to
-a plane.  The output file is written to stdout.
-Usage:
-surfplot [-g|-p] <Surface_ID> <input_file>
--g           -  Write GNU Plot data file (default).
--p           -  Write encapsulated postscript file
--s           -  Write an SVG file
-<Surface_ID> -  ID of surface containing mesh to export.
-<input_file> -  Mesh file to read.
