[MOAB-dev] r2646 - MOAB/trunk
janehu at mcs.anl.gov
Wed Feb 18 14:51:53 CST 2009
Author: janehu
Date: 2009-02-18 14:51:53 -0600 (Wed, 18 Feb 2009)
New Revision: 2646
Modified:
MOAB/trunk/ReadNCDF.cpp
Log:
Added a call to update function in load_file; simplified the calls by using smart pointer type data instead of manually arrange each memory allocation/deallocation; changed the option 'sum' to 'set' based on the nature of operation as Jason suggested.
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-02-18 20:51:31 UTC (rev 2645)
+++ MOAB/trunk/ReadNCDF.cpp 2009-02-18 20:51:53 UTC (rev 2646)
@@ -431,7 +431,7 @@
MBErrorCode ReadNCDF::load_file(const char *exodus_file_name,
MBEntityHandle& file_set,
- const FileOptions&,
+ const FileOptions& opts,
const int *blocks_to_load,
const int num_blocks)
@@ -441,6 +441,13 @@
// this function directs the reading of an exoii file, but doesn't do any of
// the actual work
+ //See if opts has tdata.
+ MBErrorCode rval;
+ std::string s;
+ rval = opts.get_str_option("tdata", s );
+ if(MB_SUCCESS == rval && !s.empty())
+ return update(exodus_file_name, opts);
// 0. Check for previously read file.
reset();
bool previously_loaded = false;
@@ -1913,7 +1920,8 @@
return MB_SUCCESS;
-MBErrorCode ReadNCDF::update(const char *exodus_file_name, FileOptions& opts)
+MBErrorCode ReadNCDF::update(const char *exodus_file_name,
+ const FileOptions& opts)
//Function : updating current database from new exodus_file.
//Creator: Jane Hu
@@ -1924,7 +1932,7 @@
//time is the optional, and it gives time step of each of the mesh
//info in exodus file. It start from 1.
//op is the operation that is going to be performed on the var_name info.
- //currently support 'sum'
+ //currently support 'set'
//destination shows where to store the updated info, currently assume it is
//stored in the same database by replacing the old info if there's no input
//for destination, or the destination data is given in exodus format and just
@@ -1991,35 +1999,29 @@
read_exodus_header(exodus_file_name);
//read in the node_num_map .
- int* ptr2 = new int [numberNodes_loading];
+ std::vector<int> ptr(numberNodes_loading);
int varid = -1;
int cstatus = nc_inq_varid (ncFile->id(), "node_num_map", &varid);
if (cstatus == NC_NOERR && varid != -1) {
NcVar *temp_var = ncFile->get_var("node_num_map");
- NcBool status = temp_var->get(ptr2, numberNodes_loading);
+ NcBool status = temp_var->get(&ptr[0], numberNodes_loading);
if (0 == status) {
readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
- do_delete( ptr2, NULL, NULL);
return MB_FAILURE;
// read in the deformations.
- std::vector<double*> deformed_arrays(3) ;
- std::vector<double*> orig_coords(3) ;
- deformed_arrays[0] = new double [numberNodes_loading];
- deformed_arrays[1] = new double [numberNodes_loading];
- deformed_arrays[2] = NULL;
- orig_coords[0] = new double [numberNodes_loading];
- orig_coords[1] = new double [numberNodes_loading];
- orig_coords[2] = NULL;
- if( numberDimensions_loading == 3 )
- deformed_arrays[2] = new double [numberNodes_loading];
- orig_coords[2] = new double [numberNodes_loading];
+ std::vector< std::vector<double> > deformed_arrays(3) ;
+ std::vector< std::vector<double> > orig_coords(3) ;
+ deformed_arrays[0].reserve(numberNodes_loading);
+ deformed_arrays[1].reserve(numberNodes_loading);
+ deformed_arrays[2].reserve(numberNodes_loading);
+ orig_coords[0].reserve(numberNodes_loading);
+ orig_coords[1].reserve(numberNodes_loading);
+ orig_coords[2].reserve(numberNodes_loading);
NcVar *coordx = ncFile->get_var("vals_nod_var1");
NcVar *coordy = ncFile->get_var("vals_nod_var2");
NcVar *coordz;
@@ -2029,32 +2031,27 @@
NULL == coordy || !coordy->is_valid() ||
(numberDimensions_loading == 3 && (NULL == coordz || !coordz->is_valid())) ) {
readMeshIface->report_error("MBCN:: Problem getting coords variable.");
- do_delete( ptr2, &deformed_arrays, &orig_coords);
return MB_FAILURE;
NcBool status = coordx->set_cur(time_step-1, 0);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting x deformation array.");
return MB_FAILURE;
- status = coordx->get(deformed_arrays[0], 1, numberNodes_loading);
+ status = coordx->get(&deformed_arrays[0][0], 1, numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
status = coordy->set_cur(time_step-1, 0);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting y deformation array.");
- do_delete(ptr2, &deformed_arrays, &orig_coords);
return MB_FAILURE;
- status = coordy->get(deformed_arrays[1], 1, numberNodes_loading);
+ status = coordy->get(&deformed_arrays[1][0], 1, numberNodes_loading);
if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting y deformation array.");
+ readMeshIface->report_error("MBCN:: Problem getting y deformation array.");
return MB_FAILURE;
if (numberDimensions_loading == 3 )
@@ -2062,13 +2059,11 @@
status = coordz->set_cur(time_step-1, 0);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting z deformation array.");
return MB_FAILURE;
- status = coordz->get(deformed_arrays[2], 1,numberNodes_loading);
+ status = coordz->get(&deformed_arrays[2][0], 1,numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
@@ -2082,94 +2077,68 @@
NULL == coord2 || !coord2->is_valid() ||
(numberDimensions_loading == 3 && (NULL == coord3 || !coord3->is_valid())) ) {
return MB_FAILURE;
- status = coord1->get(orig_coords[0], numberNodes_loading);
+ status = coord1->get(&orig_coords[0][0], numberNodes_loading);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting x coord array.");
return MB_FAILURE;
- status = coord2->get(orig_coords[1], numberNodes_loading);
+ status = coord2->get(&orig_coords[1][0], numberNodes_loading);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting y coord array.");
return MB_FAILURE;
- status = coord3->get(orig_coords[2], numberNodes_loading);
+ status = coord3->get(&orig_coords[2][0], numberNodes_loading);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting z coord array.");
return MB_FAILURE;
//b. Deal with DB file : get node info. according to node_num_map.
+ if (tokens[0] != "coord" && tokens[0] != "COORD")
+ return MB_NOT_IMPLEMENTED;
+ if( strcmp (op, "set") && strcmp (op, " set"))
MBTag *globalId = &mGlobalIdTag;
MBEntityHandle entity_h = 0;
+ MBRange entities;
for(int i = 0; i < numberNodes_loading; i++)
- int id = ptr2[i];
+ int id = ptr[i];
void * data[1] = {&id};
- MBRange entities;
+ double coords[3] = {0, 0, 0};
+ //check for coords.
+ if(!entities.empty())
+ mdbImpl->get_coords(entities, coords);
+ entities.clear();
mdbImpl->get_entities_by_type_and_tag(entity_h, MBVERTEX, globalId, data, 1, entities);
if(entities.empty())
continue;
else if(entities.size() > 1)
readMeshIface->report_error("ReadNCDF:: Multiple nodes share the same id.");
return MB_FAILURE;
- if (! strcmp (tokens[0].c_str(), "coord") ||
- ! strcmp (tokens[0].c_str() ,"COORD"))
- //update the coordinates for this entity.
- double coords[3] = {0, 0, 0};
- if(! strcmp (op, "sum") || !strcmp (op, " sum"))
- coords[0] = orig_coords[0][i] + deformed_arrays[0][i];
- coords[1] = orig_coords[1][i] + deformed_arrays[1][i];
- if(numberDimensions_loading == 3 )
- coords[2] = orig_coords[2][i] + deformed_arrays[2][i];
- mdbImpl->set_coords(entities, coords);
+ //update the coordinates for this entity.
+ coords[0] = orig_coords[0][i] + deformed_arrays[0][i];
+ coords[1] = orig_coords[1][i] + deformed_arrays[1][i];
+ if(numberDimensions_loading == 3 )
+ coords[2] = orig_coords[2][i] + deformed_arrays[2][i];
+ mdbImpl->set_coords(entities, coords);
return MB_SUCCESS;
-void ReadNCDF::do_delete( int *ptr,
- std::vector<double*>* deformed_arrays,
- std::vector<double*>* orig_coords )
- if(ptr)
- delete ptr;
- if(deformed_arrays)
- delete [] (*deformed_arrays)[0];
- delete [] (*deformed_arrays)[1];
- if(orig_coords)
- delete [] (*orig_coords)[0];
- delete [] (*orig_coords)[1];
- delete [] (*deformed_arrays)[2];
- if(orig_coords)
- delete [] (*orig_coords)[2];
void ReadNCDF::tokenize( const std::string& str,
std::vector<std::string>& tokens,
const char* delimiters )
