[MOAB-dev] r2643 - MOAB/trunk
janehu at mcs.anl.gov
Mon Feb 16 15:10:57 CST 2009
Author: janehu
Date: 2009-02-16 15:10:57 -0600 (Mon, 16 Feb 2009)
New Revision: 2643
Modified:
MOAB/trunk/ReadNCDF.cpp
Log:
Updated to be able to update the coordinates on copy of the DB exodus file as defined in the FileOption::destination, and keep the original coordinates if the node map are not matching.
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-02-13 15:44:10 UTC (rev 2642)
+++ MOAB/trunk/ReadNCDF.cpp 2009-02-16 21:10:57 UTC (rev 2643)
@@ -1926,9 +1926,10 @@
//op is the operation that is going to be performed on the var_name info.
//currently support 'sum'
//destination shows where to store the updated info, currently assume it is
- //stored in the same database by replacing the old info.
+ //stored in the same database by replacing the old info if there's no input
+ //for destination, or the destination data is given in exodus format and just
+ //need to update the coordinates.
//Assumptions:
- //Since the exodus_file will not have a node_num_map, so the strategies are following, this is expected to be very slow.
//1. Assume the num_el_blk's in both DB and update exodus file are the same.
//2. Assume num_el_in_blk1...num_el_in_blk(num_el_blk) numbers are matching, may in
//different order. example: num_el_in_blk11 = num_el_in_blk22 && num_el_in_blk12 =
@@ -1974,6 +1975,13 @@
std::string filename( exodus_file_name );
+ //3. check for destination, current only generates exodus file
+ const char* des ;
+ if(tokens.size() > 3 && !tokens[3].empty())
+ des = tokens[3].c_str();
+ else
+ des = "";
//a. Deal with DB file first: get the node_num_map.
assert(NULL != ncFile);
int* ptr1 = new int [numberNodes_loading];
@@ -1996,14 +2004,56 @@
if( numberDimensions_loading == 3 )
arrays[2] = new double[numberNodes_loading];
- for (int i = 0; i < numberNodes_loading; i++)
+ //get original nodal coordinates, in case of not matching in node id's,
+ //those coordinate will be kept.
+ NcVar *coord = ncFile->get_var("coord");
+ if (NULL == coord || !coord->is_valid() )
- arrays[0][i] = 0.0;
- arrays[1][i] = 0.0;
- if( numberDimensions_loading == 3 )
- arrays[2][i] = 0.0;
+ readMeshIface->report_error("MBCN:: Problem getting coords variable.");
+ do_delete(ptr1, NULL, NULL, NULL, arrays);
+ return MB_FAILURE;
+ NcBool status = coord->get(arrays[0], 1, numberNodes_loading);
+ if (0 == status) {
+ readMeshIface->report_error("MBCN:: Problem getting x coord array.");
+ status = coord->set_cur(1, 0);
+ readMeshIface->report_error("MBCN:: Problem getting x deformation array.");
+ status = coord->get(arrays[1], 1, numberNodes_loading);
+ readMeshIface->report_error("MBCN:: Problem getting y coord array.");
+ if (numberDimensions_loading == 3 )
+ status = coord->set_cur(2, 0);
+ status = coord->get(arrays[2], 1, numberNodes_loading);
+ readMeshIface->report_error("MBCN:: Problem getting z coord array.");
+ //remember the original numberNodes_loading, the later one is expected to
+ //be larger than this one.
+ const int init_numberNodes = numberNodes_loading;
// b. read in the node_num_map and coords from the input exodus file.
reset();
bool previously_loaded = false;
@@ -2026,7 +2076,7 @@
NcBool status = temp_var->get(ptr2, numberNodes_loading);
if (0 == status) {
readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
- delete [] ptr2;
+ do_delete(ptr1, ptr2, NULL, NULL, arrays);
return MB_FAILURE;
@@ -2055,32 +2105,32 @@
NULL == coordy || !coordy->is_valid() ||
(numberDimensions_loading == 3 && (NULL == coordz || !coordz->is_valid())) ) {
- do_delete(ptr1, ptr2, deformed_arrays, orig_coords, arrays);
+ do_delete(ptr1, ptr2, &deformed_arrays, &orig_coords, arrays);
return MB_FAILURE;
- NcBool status = coordx->set_cur(time_step-1, 0);
+ status = coordx->set_cur(time_step-1, 0);
if (0 == status) {
return MB_FAILURE;
status = coordx->get(deformed_arrays[0], 1, numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
status = coordy->set_cur(time_step-1, 0);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting y deformation array.");
return MB_FAILURE;
status = coordy->get(deformed_arrays[1], 1, numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
@@ -2088,13 +2138,13 @@
status = coordz->set_cur(time_step-1, 0);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting z deformation array.");
return MB_FAILURE;
status = coordz->get(deformed_arrays[2], 1,numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
@@ -2108,20 +2158,20 @@
NULL == coord2 || !coord2->is_valid() ||
(numberDimensions_loading == 3 && (NULL == coord3 || !coord3->is_valid())) ) {
return MB_FAILURE;
status = coord1->get(orig_coords[0], numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
status = coord2->get(orig_coords[1], numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
@@ -2129,13 +2179,13 @@
status = coord3->get(orig_coords[2], numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
//c. match node_num_map for DB and exodus file.
- for(int node_num = 0; node_num < numberNodes_loading; )
+ for(int node_num = 0; node_num < init_numberNodes; )
NcBool found = 0;
int node_index1, num_of_nodes;
@@ -2152,11 +2202,10 @@
if(!found)
- readMeshIface->report_error("MBCN:: node maps do not match.");
- return MB_FAILURE;
+ node_num++;
+ continue;
for(int j = 1;j <= numberNodes_loading ; j++)
//j is the number of nodes to be sequentially matched
@@ -2181,38 +2230,52 @@
node_num += num_of_nodes;
- ncFile = new NcFile(exodusFile.c_str(), NcFile::Write);
+ if(strcmp (des, ""))
+ std::string destinate(des);
+ if(destinate.substr(0,1) == " ")
+ destinate = destinate.substr(1);
+ ncFile = new NcFile(destinate.c_str(), NcFile::Write);
+ if (NULL == ncFile || !ncFile->is_valid())
+ readMeshIface->report_error("MBCN:: problem opening Netcdf/Exodus II file %s", des);
+ else
+ ncFile = new NcFile(exodusFile.c_str(), NcFile::Write);
+ readMeshIface->report_error("MBCN:: problem opening Netcdf/Exodus II file %s", exodusFile.c_str());
- readMeshIface->report_error("MBCN:: problem opening Netcdf/Exodus II file %s",exodus_file_name);
return MB_FAILURE;
NcVar *coords = ncFile->get_var("coord");
if (NULL == coords || !coords->is_valid()) {
return MB_FAILURE;
- status = coords->put(arrays[0], 1, numberNodes_loading);
+ status = coords->put(arrays[0], 1, init_numberNodes);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem saving x coord array.");
return MB_FAILURE;
status = coords->set_cur(1, 0);
if (0 == status) {
return MB_FAILURE;
- status = coords->put(arrays[1], 1, numberNodes_loading);
+ status = coords->put(arrays[1], 1, init_numberNodes);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem saving y coord array.");
return MB_FAILURE;
@@ -2221,14 +2284,14 @@
status = coords->set_cur(2, 0);
if (0 == status) {
return MB_FAILURE;
- status = coords->put(arrays[2], 1, numberNodes_loading);
+ status = coords->put(arrays[2], 1, init_numberNodes);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem saving z coord array.");
return MB_FAILURE;
@@ -2252,23 +2315,32 @@
void ReadNCDF::do_delete(int *ptr1, int *ptr2,
- std::vector<double*> deformed_arrays,
- std::vector<double*> orig_coords ,
+ std::vector<double*>* deformed_arrays,
+ std::vector<double*>* orig_coords ,
std::vector<double*> arrays)
delete ptr1;
- delete ptr2;
+ if(ptr2)
+ delete ptr2;
delete [] arrays[0];
delete [] arrays[1];
- delete [] deformed_arrays[0];
- delete [] deformed_arrays[1];
- delete [] orig_coords[0];
- delete [] orig_coords[1];
+ if(deformed_arrays)
+ delete [] (*deformed_arrays)[0];
+ delete [] (*deformed_arrays)[1];
+ if(orig_coords)
+ delete [] (*orig_coords)[0];
+ delete [] (*orig_coords)[1];
if(numberDimensions_loading == 3 )
delete [] arrays[2];
- delete [] deformed_arrays[2];
- delete [] orig_coords[2];
+ delete [] (*deformed_arrays)[2];
+ if(orig_coords)
+ delete [] (*orig_coords)[2];
