[MOAB-dev] r2639 - MOAB/trunk
janehu at mcs.anl.gov
Wed Feb 11 14:26:15 CST 2009
Author: janehu
Date: 2009-02-11 14:26:15 -0600 (Wed, 11 Feb 2009)
New Revision: 2639
Modified:
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/ReadNCDF.hpp
Log:
Updated function to update DB coordinates based on input exodus file. Assumed that DB was created through reading initial exodus file.
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-02-11 18:13:16 UTC (rev 2638)
+++ MOAB/trunk/ReadNCDF.cpp 2009-02-11 20:26:15 UTC (rev 2639)
@@ -25,6 +25,7 @@
#include <string>
#include <assert.h>
#include <stdio.h>
+#include <cmath>
#include "MBCN.hpp"
#include "MBRange.hpp"
@@ -429,10 +430,10 @@
MBErrorCode ReadNCDF::load_file(const char *exodus_file_name,
- MBEntityHandle& file_set,
- const FileOptions&,
- const int *blocks_to_load,
- const int num_blocks)
+ MBEntityHandle& file_set,
+ const FileOptions&,
+ const int *blocks_to_load,
+ const int num_blocks)
MBErrorCode status;
@@ -444,6 +445,7 @@
reset();
bool previously_loaded = false;
std::string filename( exodus_file_name );
+ exodusFile = filename;
status = check_file_status(filename, previously_loaded);
if (MB_SUCCESS != status)
return status;
@@ -1925,6 +1927,16 @@
//currently support 'sum'
//destination shows where to store the updated info, currently assume it is
//stored in the same database by replacing the old info.
+ //Assumptions:
+ //Since the exodus_file will not have a node_num_map, so the strategies are following, this is expected to be very slow.
+ //1. Assume the num_el_blk's in both DB and update exodus file are the same.
+ //2. Assume num_el_in_blk1...num_el_in_blk(num_el_blk) numbers are matching, may in
+ //different order. example: num_el_in_blk11 = num_el_in_blk22 && num_el_in_blk12 =
+ //num_el_in_blk21.
+ //3. In DB file, get node_num_map
+ //4. Match DB file's node_num_map, and the exodus file's node_num_map.
+ //5. Replace coord[0][n] with coordx[m]+vals_nod_var1(time_step, m) for all directions.
MBErrorCode rval;
std::string s;
rval = opts.get_str_option("tdata", s );
@@ -1936,11 +1948,66 @@
std::vector< std::string > tokens;
tokenize(s, tokens,",");
+ //1. check for time step to find the match time
+ int time_step = 1;
+ if(tokens.size() > 1 && !tokens[1].empty())
+ const char* time_s = tokens[1].c_str();
+ char* endptr;
+ long int pval = strtol( time_s, &endptr, 0 );
+ std::string end = endptr;
+ if (!end.empty()) // syntax error
+ return MB_TYPE_OUT_OF_RANGE;
+ // check for overflow (parsing long int, returning int)
+ time_step = pval;
+ if (pval != (long int)time_step)
+ if(time_step <= 0)
+ //2. check for the operations, currently support sum.
+ const char* op;
+ if(tokens.size() > 2 && !tokens[2].empty())
+ op = tokens[2].c_str();
- // 0. Check for previously read file.
+ //a. Deal with DB file first: get the node_num_map.
+ assert(NULL != ncFile);
+ int* ptr1 = new int [numberNodes_loading];
+ int varid = -1;
+ int cstatus = nc_inq_varid (ncFile->id(), "node_num_map", &varid);
+ if (cstatus == NC_NOERR && varid != -1) {
+ NcVar *temp_var = ncFile->get_var("node_num_map");
+ NcBool status = temp_var->get(ptr1, numberNodes_loading);
+ if (0 == status) {
+ readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
+ delete [] ptr1;
+ return MB_FAILURE;
+ std::vector<double*> arrays(3);
+ arrays[0] = new double[numberNodes_loading];
+ arrays[1] = new double[numberNodes_loading];
+ if( numberDimensions_loading == 3 )
+ arrays[2] = new double[numberNodes_loading];
+ for (int i = 0; i < numberNodes_loading; i++)
+ arrays[0][i] = 0.0;
+ arrays[1][i] = 0.0;
+ arrays[2][i] = 0.0;
+ // b. read in the node_num_map and coords from the input exodus file.
reset();
+ ncFile = NULL;
rval = check_file_status(filename, previously_loaded);
if (MB_SUCCESS != rval)
return rval;
@@ -1949,87 +2016,36 @@
if (! strcmp (tokens[0].c_str(), "coord") || ! strcmp (tokens[0].c_str() ,"COORD"))
- //1. check for time step to find the match time
- int time_step = 1;
- if(tokens.size() > 1 && !tokens[1].empty())
- const char* time_s = tokens[1].c_str();
- char* endptr;
- long int pval = strtol( time_s, &endptr, 0 );
- std::string end = endptr;
- if (!end.empty()) // syntax error
- return MB_TYPE_OUT_OF_RANGE;
+ //read in the node_num_map .
+ int* ptr2 = new int [numberNodes_loading];
- // check for overflow (parsing long int, returning int)
- time_step = pval;
- if (pval != (long int)time_step)
- if(time_step <= 0)
- //2. check for the operations, currently support sum.
- std::string op;
- if(tokens.size() > 2 && !tokens[2].empty())
- op = tokens[2].c_str();
- //3. match the node_num_map.
- int* ptr1 = new int [numberNodes_loading];
- int* ptr2 ;
- int varid = -1;
- int cstatus = nc_inq_varid (ncFile->id(), "node_num_map", &varid);
+ varid = -1;
+ cstatus = nc_inq_varid (ncFile->id(), "node_num_map", &varid);
- NcBool status = temp_var->get(ptr1, numberNodes_loading);
+ NcBool status = temp_var->get(ptr2, numberNodes_loading);
if (0 == status) {
- delete [] ptr1;
+ delete [] ptr2;
return MB_FAILURE;
- MBRange range(MB_START_ID+vertexOffset,
- MB_START_ID+vertexOffset+numberNodes_loading-1);
- //get the existing db's node map
- MBErrorCode error = mdbImpl->tag_get_data(mGlobalIdTag,
- range, ptr2);
- if (MB_SUCCESS != error)
- readMeshIface->report_error("ReadNCDF:: Problem getting node global ids.");
- //read in the coordinates from the database.
- MBEntityHandle node_handle = 0;
- std::vector<double*> arrays, orig_coords, deform_arrays ;
- double* array1 = new double [numberNodes_loading];
- double* array2 = new double [numberNodes_loading];
- double* array3 = new double [numberNodes_loading];
- double* array4 = new double [numberNodes_loading];
- double* array5 = new double [numberNodes_loading];
- double* array6 = new double [numberNodes_loading];
- deform_arrays.push_back(array1);
- deform_arrays.push_back(array2);
- deform_arrays.push_back(array3);
- orig_coords.push_back(array4);
- orig_coords.push_back(array5);
- orig_coords.push_back(array6);
- readMeshIface->get_node_arrays(3, numberNodes_loading,
- MB_START_ID, node_handle, arrays);
- //read in the original coordinates from the exodus file
- NcVar *coord1 = ncFile->get_var("coordx");
- NcVar *coord2 = ncFile->get_var("coordy");
- NcVar *coord3;
- if(numberDimensions_loading == 3)
- coord3 = ncFile->get_var("coordz");
- if (NULL == coord1 || !coord1->is_valid() ||
- NULL == coord2 || !coord2->is_valid() ||
- (numberDimensions_loading == 3 && (NULL == coord3 || !coord3->is_valid())) ) {
- readMeshIface->report_error("MBCN:: Problem getting coords variable.");
- return MB_FAILURE;
+ // read in the deformations.
+ std::vector<double*> deformed_arrays(3) ;
+ std::vector<double*> orig_coords(3) ;
+ deformed_arrays[0] = new double [numberNodes_loading];
+ deformed_arrays[1] = new double [numberNodes_loading];
+ deformed_arrays[2] = NULL;
+ orig_coords[0] = new double [numberNodes_loading];
+ orig_coords[1] = new double [numberNodes_loading];
+ orig_coords[2] = NULL;
+ deformed_arrays[2] = new double [numberNodes_loading];
+ orig_coords[2] = new double [numberNodes_loading];
- // read in the deformation from the exodus file
NcVar *coordx = ncFile->get_var("vals_nod_var1");
NcVar *coordy = ncFile->get_var("vals_nod_var2");
NcVar *coordz;
@@ -2039,55 +2055,93 @@
NULL == coordy || !coordy->is_valid() ||
(numberDimensions_loading == 3 && (NULL == coordz || !coordz->is_valid())) ) {
+ do_delete(ptr1, ptr2, deformed_arrays, orig_coords, arrays);
return MB_FAILURE;
- NcBool status = coord1->get(orig_coords[0], 1, numberNodes_loading);
+ NcBool status = coordx->set_cur(time_step-1, 0);
if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting x coord array.");
+ readMeshIface->report_error("MBCN:: Problem getting x deformation array.");
return MB_FAILURE;
- status = coord2->get(orig_coords[1], 1, numberNodes_loading);
+ status = coordx->get(deformed_arrays[0], 1, numberNodes_loading);
if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting y coord array.");
return MB_FAILURE;
+ status = coordy->set_cur(time_step-1, 0);
+ readMeshIface->report_error("MBCN:: Problem getting y deformation array.");
+ status = coordy->get(deformed_arrays[1], 1, numberNodes_loading);
if (numberDimensions_loading == 3 )
- status = coord3->get(orig_coords[2], 1, numberNodes_loading);
+ status = coordz->set_cur(time_step-1, 0);
if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting z coord array.");
+ readMeshIface->report_error("MBCN:: Problem getting z deformation array.");
return MB_FAILURE;
+ status = coordz->get(deformed_arrays[2], 1,numberNodes_loading);
- status = coordx->get(deform_arrays[0], 1, numberNodes_loading);
+ NcVar *coord1 = ncFile->get_var("coordx");
+ NcVar *coord2 = ncFile->get_var("coordy");
+ NcVar *coord3;
+ if(numberDimensions_loading == 3)
+ coord3 = ncFile->get_var("coordz");
+ if (NULL == coord1 || !coord1->is_valid() ||
+ NULL == coord2 || !coord2->is_valid() ||
+ (numberDimensions_loading == 3 && (NULL == coord3 || !coord3->is_valid())) ) {
+ readMeshIface->report_error("MBCN:: Problem getting coords variable.");
+ status = coord1->get(orig_coords[0], numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
- status = coordy->get(deform_arrays[1], 1, numberNodes_loading);
+ status = coord2->get(orig_coords[1], numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
- status = coordz->get(deform_arrays[2], 1, numberNodes_loading);
+ status = coord3->get(orig_coords[2], numberNodes_loading);
if (0 == status) {
return MB_FAILURE;
- //do operations on all coordinates.
+ //c. match node_num_map for DB and exodus file.
for(int node_num = 0; node_num < numberNodes_loading; )
NcBool found = 0;
int node_index1, num_of_nodes;
for(int i = 0; i < numberNodes_loading; i++)
- if(ptr1[i] == ptr2[node_num])
+ if(ptr1[node_num] == ptr2[i])
//i is the index on the exodus file which matches the (node_num+1)th
//node in the node map of existing DB.
@@ -2099,41 +2153,124 @@
if(!found)
readMeshIface->report_error("MBCN:: node maps do not match.");
return MB_FAILURE;
- int offset = (time_step-1) * numberNodes_loading;
for(int j = 1;j <= numberNodes_loading ; j++)
//j is the number of nodes to be sequentially matched
- if(op == "sum")
+ if(! strcmp (op, "sum") || !strcmp (op, " sum"))
- arrays[0][node_num + j - 1] = orig_coords[0][node_index1+j-1] + deform_arrays[0][offset+node_index1+j-1];
- arrays[1][node_num + j - 1] = orig_coords[1][node_index1+j-1] + deform_arrays[0][offset+node_index1+j-1];
- arrays[2][node_num + j - 1] = orig_coords[2][node_index1+j-1] + deform_arrays[0][offset+node_index1+j-1];
+ arrays[0][node_num + j - 1] = orig_coords[0][node_index1 + j-1] +
+ deformed_arrays[0][node_index1 + j-1] ;
+ arrays[1][node_num + j - 1] = orig_coords[1][node_index1 + j-1] +
+ deformed_arrays[1][node_index1+j-1] ;
+ if(numberDimensions_loading == 3 )
+ arrays[2][node_num + j - 1] = orig_coords[2][node_index1+j-1] +
+ deformed_arrays[2][node_index1+j-1] ;
- if(ptr1[node_index1+j] != ptr2[node_num +j])
+ if(ptr1[node_index1+j] != ptr2[node_num +j])
num_of_nodes = j;
break;
node_num += num_of_nodes;
- delete [] ptr1;
- delete [] array1;
- delete [] array2;
- delete [] array3;
- delete [] array4;
- delete [] array5;
- delete [] array6;
+ ncFile = new NcFile(exodusFile.c_str(), NcFile::Write);
+ if (NULL == ncFile || !ncFile->is_valid())
+ readMeshIface->report_error("MBCN:: problem opening Netcdf/Exodus II file %s",exodus_file_name);
+ NcVar *coords = ncFile->get_var("coord");
+ if (NULL == coords || !coords->is_valid()) {
+ status = coords->put(arrays[0], 1, numberNodes_loading);
+ readMeshIface->report_error("MBCN:: Problem saving x coord array.");
+ status = coords->set_cur(1, 0);
+ readMeshIface->report_error("MBCN:: Problem getting y coord array.");
+ status = coords->put(arrays[1], 1, numberNodes_loading);
+ readMeshIface->report_error("MBCN:: Problem saving y coord array.");
+ if (numberDimensions_loading == 3 )
+ status = coords->set_cur(2, 0);
+ status = coords->put(arrays[2], 1, numberNodes_loading);
+ readMeshIface->report_error("MBCN:: Problem saving z coord array.");
+ delete ptr2;
+ delete [] deformed_arrays[0];
+ delete [] deformed_arrays[1];
+ delete [] orig_coords[0];
+ delete [] orig_coords[1];
+ delete [] deformed_arrays[2];
+ delete [] orig_coords[2];
} //if token[0] == "coord"
+ delete ptr1;
+ delete [] arrays[0];
+ delete [] arrays[1];
+ delete [] arrays[2];
return MB_SUCCESS;
+void ReadNCDF::do_delete(int *ptr1, int *ptr2,
+ std::vector<double*> deformed_arrays,
+ std::vector<double*> orig_coords ,
+ std::vector<double*> arrays)
+ delete ptr1;
+ delete ptr2;
void ReadNCDF::tokenize( const std::string& str,
std::vector<std::string>& tokens,
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp 2009-02-11 18:13:16 UTC (rev 2638)
+++ MOAB/trunk/ReadNCDF.hpp 2009-02-11 20:26:15 UTC (rev 2639)
@@ -92,6 +92,11 @@
void reset();
+ void do_delete(int *ptr1, int *ptr2,
+ std::vector<double*> array);
//! read the header from the ExoII file
MBErrorCode read_exodus_header(const char *exodus_file_name);
