[MOAB-dev] r2637 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Feb 11 12:11:49 CST 2009
Author: kraftche
Date: 2009-02-11 12:11:49 -0600 (Wed, 11 Feb 2009)
New Revision: 2637
Modified:
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/ReadNCDF.hpp
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/WriteNCDF.cpp
Log:
o Fix distFactor storage: Tqdcfr stored dist factor data as a pointer to
an array of doubles. ReadNCDF stores it as a pointer to a std::vector.
WriteNCDF expects a pointer to a std::vector. This results in a segfault
when converting a cub file to an exodus file if the cub file contains
dist factor data. Change all code to store dist factor as a variable-
length tag.
o Fix 64-bit bug where ReadNCDF declares the tag for QA data to be
sizeof(int) but stores a pointer. Convert all QA code to use
variable-length tags. Individual QA strings are separated by
NULL bytes in the tag data.
o Specify data type for tags created by ReadNCDF and WriteNCDF
o Fix a bunch of code in ReadNCDF where memory is potentially leaked when
errors are encountered.
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-02-11 18:02:28 UTC (rev 2636)
+++ MOAB/trunk/ReadNCDF.cpp 2009-02-11 18:11:49 UTC (rev 2637)
@@ -86,42 +86,61 @@
int dum_val = 0;
MBErrorCode result = impl->tag_get_handle(MATERIAL_SET_TAG_NAME, mMaterialSetTag);
if (MB_TAG_NOT_FOUND == result)
- result = impl->tag_create(MATERIAL_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mMaterialSetTag,
+ result = impl->tag_create(MATERIAL_SET_TAG_NAME,
+ sizeof(int),
+ MB_TAG_SPARSE,
+ MB_TYPE_INTEGER,
+ mMaterialSetTag,
&dum_val);
result = impl->tag_get_handle(DIRICHLET_SET_TAG_NAME, mDirichletSetTag);
- result = impl->tag_create(DIRICHLET_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mDirichletSetTag,
+ result = impl->tag_create(DIRICHLET_SET_TAG_NAME,
+ sizeof(int),
+ MB_TAG_SPARSE,
+ MB_TYPE_INTEGER,
+ mDirichletSetTag,
&dum_val);
result = impl->tag_get_handle(NEUMANN_SET_TAG_NAME, mNeumannSetTag);
- result = impl->tag_create(NEUMANN_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mNeumannSetTag,
+ result = impl->tag_create(NEUMANN_SET_TAG_NAME,
+ sizeof(int),
+ MB_TAG_SPARSE,
+ MB_TYPE_INTEGER,
+ mNeumannSetTag,
&dum_val);
result = impl->tag_get_handle(HAS_MID_NODES_TAG_NAME, mHasMidNodesTag);
if (MB_TAG_NOT_FOUND == result) {
int dum_val_array[] = {0, 0, 0, 0};
- result = impl->tag_create(HAS_MID_NODES_TAG_NAME, 4*sizeof(int), MB_TAG_SPARSE, mHasMidNodesTag,
+ result = impl->tag_create(HAS_MID_NODES_TAG_NAME,
+ 4*sizeof(int),
+ MB_TAG_SPARSE,
+ MB_TYPE_INTEGER,
+ mHasMidNodesTag,
dum_val_array);
result = impl->tag_get_handle("distFactor", mDistFactorTag);
- double dum_dbl = 0.0;
- result = impl->tag_create("distFactor", sizeof(double*), MB_TAG_SPARSE, mDistFactorTag,
- &dum_dbl);
+ result = impl->tag_create_variable_length( "distFactor",
+ MB_TAG_SPARSE,
+ MB_TYPE_DOUBLE,
+ mDistFactorTag );
result = impl->tag_get_handle("qaRecord", mQaRecordTag);
- result = impl->tag_create("qaRecord", sizeof(int), MB_TAG_SPARSE, mQaRecordTag,
- &dum_val);
+ result = impl->tag_create_variable_length( "qaRecord",
+ MB_TAG_SPARSE,
+ MB_TYPE_OPAQUE,
+ mQaRecordTag );
result = impl->tag_get_handle(GLOBAL_ID_TAG_NAME, mGlobalIdTag);
- result = impl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mGlobalIdTag,
- &dum_val);
+ result = impl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, mGlobalIdTag, &dum_val);
ncFile = NULL;
@@ -676,7 +695,8 @@
// read header information and initialize header-type block information
NcDim *temp_dim;
- char *temp_string = new char[max_str_length+1];
+ std::vector<char> temp_string_storage(max_str_length+1);
+ char *temp_string = &temp_string_storage[0];
int block_seq_id = 1;
for(; iter != end_iter; iter++, block_seq_id++ )
@@ -716,8 +736,6 @@
- delete [] temp_string;
return MB_SUCCESS;
@@ -826,7 +844,8 @@
if( mdbImpl->tag_get_data(tag_handle, &mCurrentMeshHandle, 1, &vertexOffset) != MB_SUCCESS)
return MB_FAILURE;
NcVar *temp_var;
NcAtt *temp_att;
@@ -916,7 +935,6 @@
if ((unsigned)tmp_ptr[i] >= nodesInLoadedBlocks.size()) {
readMeshIface->report_error( "Invalid node ID in block connectivity\n");
return MB_FAILURE;
nodesInLoadedBlocks[tmp_ptr[i]] = 1;
@@ -949,8 +967,6 @@
return MB_SUCCESS;
@@ -1032,20 +1048,17 @@
// read in the nodesets for the model
if(0 == numberNodeSets_loading) return MB_SUCCESS;
- int *id_array = new int[numberNodeSets_loading];
+ std::vector<int> id_array(numberNodeSets_loading);
// read in the nodeset ids
NcVar *temp_var = ncFile->get_var("ns_prop1");
if (NULL == temp_var || !temp_var->is_valid()) {
readMeshIface->report_error("MBCN:: Problem getting ns_prop1 variable.");
- delete [] id_array;
return MB_FAILURE;
- NcBool status = temp_var->get(id_array, numberNodeSets_loading);
+ NcBool status = temp_var->get(&id_array[0], numberNodeSets_loading);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting nodeset id vector.");
return MB_FAILURE;
@@ -1063,7 +1076,8 @@
std::vector<int> node_handles;
int i;
NcDim *temp_dim;
for(i = 0; i < numberNodeSets_loading; i++)
@@ -1083,14 +1097,12 @@
temp_var = ncFile->get_var(temp_string);
readMeshIface->report_error("MBCN:: Problem getting dist fact variable.");
return MB_FAILURE;
NcBool status = temp_var->get(&(temp_dist_factor_vector[0]),
number_dist_factors_in_set);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting dist factors.");
return MB_FAILURE;
@@ -1105,14 +1117,12 @@
readMeshIface->report_error("MBCN:: Problem getting nodeset node variable.");
return MB_FAILURE;
NcBool status = temp_var->get(&node_handles[0],
number_nodes_in_set);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting nodeset nodes data.");
return MB_FAILURE;
@@ -1151,7 +1161,7 @@
// TODO: could we have read it into MBEntityHandle sized array in the first place?
int j, temp;
std::vector<MBEntityHandle> nodes;
- std::vector<double> *dist_factor_vector = new std::vector<double>;
+ std::vector<double> dist_factor_vector;
for (j = 0; j < number_nodes_in_set; j++)
//see if this node is one we're currently reading in
@@ -1166,7 +1176,7 @@
if( number_dist_factors_in_set != 0)
- dist_factor_vector->push_back( temp_dist_factor_vector[j] );
+ dist_factor_vector.push_back( temp_dist_factor_vector[j] );
@@ -1191,26 +1201,30 @@
if( mdbImpl->tag_set_data(mGlobalIdTag, &ns_handle, 1, &nodeset_id ) != MB_SUCCESS )
return MB_FAILURE;
- if( !dist_factor_vector->empty() )
- if( mdbImpl->tag_set_data(mDistFactorTag, &ns_handle, 1, &dist_factor_vector ) != MB_SUCCESS )
+ if( !dist_factor_vector.empty() )
+ int size = dist_factor_vector.size() * sizeof(double);
+ const void* data = &dist_factor_vector[0];
+ if( mdbImpl->tag_set_data( mDistFactorTag, &ns_handle, 1, &data, &size ) != MB_SUCCESS )
return MB_FAILURE;
- else delete dist_factor_vector;
- else if( !dist_factor_vector->empty() )
+ else if( !dist_factor_vector.empty() )
// append dist factors to vector
+ const void* ptr = 0;
+ int size = 0;
+ if( mdbImpl->tag_get_data( mDistFactorTag, &ns_handle, 1, &ptr, &size ) != MB_SUCCESS )
+ return MB_FAILURE;
- std::vector<double> *temp_vec;
- if( mdbImpl->tag_get_data( mDistFactorTag, &ns_handle, 1, &temp_vec ) != MB_SUCCESS ||
- NULL == temp_vec)
+ size /= sizeof(double);
+ const double* data = reinterpret_cast<const double*>(ptr);
+ dist_factor_vector.reserve( dist_factor_vector.size() + size );
+ std::copy( data, data+size, std::back_inserter( dist_factor_vector ) );
+ size = dist_factor_vector.size() * sizeof(double);
+ ptr = &dist_factor_vector[0];
+ if( mdbImpl->tag_set_data( mDistFactorTag, &ns_handle, 1, &ptr, &size ) != MB_SUCCESS )
return MB_FAILURE;
- std::copy(dist_factor_vector->begin(), dist_factor_vector->end(),
- std::back_inserter( *temp_vec ) );
- delete dist_factor_vector;
// add the nodes to the meshset
@@ -1219,8 +1233,6 @@
return MB_SUCCESS;
@@ -1235,23 +1247,19 @@
return MB_SUCCESS;
// read in the sideset ids
- int *id_array = new int[numberSideSets_loading];
+ std::vector<int> id_array(numberSideSets_loading);
NcVar *temp_var = ncFile->get_var("ss_prop1");
readMeshIface->report_error("MBCN:: Problem getting ss_prop1 variable.");
return MB_FAILURE;
- NcBool status = temp_var->get(id_array, numberSideSets_loading);
+ NcBool status = temp_var->get(&id_array[0], numberSideSets_loading);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting sideset id vector.");
return MB_FAILURE;
// create a side set for each one
- int *side_list;
- int *element_list;
int number_sides_in_set;
int number_dist_factors_in_set;
@@ -1276,7 +1284,8 @@
MBRange::iterator iter, end_iter;
int i;
NcDim *temp_dim;
for(i = 0; i < numberSideSets_loading; i++)
@@ -1286,20 +1295,18 @@
GET_DIMB(temp_dim, temp_string, "num_df_ss%d", i+1, number_dist_factors_in_set);
// size new arrays and get element and side lists
- side_list = new int[number_sides_in_set];
- element_list = new int[number_sides_in_set];
+ std::vector<int> side_list(number_sides_in_set);
+ std::vector<int> element_list(number_sides_in_set);
INS_ID(temp_string, "side_ss%d", i+1);
readMeshIface->report_error("MBCN:: Problem getting sideset side variable.");
return MB_FAILURE;
- NcBool status = temp_var->get(side_list,
+ NcBool status = temp_var->get(&side_list[0],
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting sideset sides data.");
return MB_FAILURE;
@@ -1307,21 +1314,19 @@
readMeshIface->report_error("MBCN:: Problem getting sideset elem variable.");
return MB_FAILURE;
- status = temp_var->get(element_list,
+ status = temp_var->get(&element_list[0],
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting sideset elems data.");
return MB_FAILURE;
std::vector<double> temp_dist_factor_vector;
std::vector<MBEntityHandle> entities_to_add, reverse_entities;
// create the sideset entities
- if( create_ss_elements( element_list, side_list, number_sides_in_set, number_dist_factors_in_set,
+ if( create_ss_elements( &element_list[0], &side_list[0], number_sides_in_set, number_dist_factors_in_set,
entities_to_add, reverse_entities, temp_dist_factor_vector,
i+1) != MB_SUCCESS )
return MB_FAILURE;
@@ -1355,7 +1360,6 @@
if (ss_handle == 0)
return MB_FAILURE;
@@ -1401,29 +1405,22 @@
if( number_dist_factors_in_set )
//if this sideset does not already has a distribution factor array...set one
- std::vector< double > *dist_factor_vector = 0;
- mdbImpl->tag_get_data( mDistFactorTag, &ss_handle, 1, &dist_factor_vector);
- if( !dist_factor_vector )
- dist_factor_vector = new std::vector<double>;
- if( mdbImpl->tag_set_data(mDistFactorTag, &ss_handle, 1, &dist_factor_vector ) != MB_SUCCESS )
- return MB_FAILURE;
+ int size = 0;
+ if (MB_SUCCESS == mdbImpl->tag_get_data( mDistFactorTag, &ss_handle, 1, &ptr, &size )) {
+ std::copy( data, data+size, std::back_inserter( temp_dist_factor_vector ) );
- std::copy( temp_dist_factor_vector.begin(), temp_dist_factor_vector.end(),
- std::back_inserter( *dist_factor_vector ) );
+ ptr = &temp_dist_factor_vector[0];
+ size = temp_dist_factor_vector.size() * sizeof(double);
+ if (mdbImpl->tag_set_data( mDistFactorTag, &ss_handle, 1, &ptr, &size ) != MB_SUCCESS)
- delete [] side_list;
- delete [] element_list;
return MB_SUCCESS;
@@ -1444,7 +1441,8 @@
// and place this array as a tag onto the sideset meshset
std::vector<double> temp_dist_factor_vector(num_dist_factors);
NcVar *temp_var;
if( num_dist_factors )
@@ -1712,8 +1710,6 @@
return MB_SUCCESS;
@@ -1843,26 +1839,29 @@
MBErrorCode ReadNCDF::read_qa_records()
- std::vector<char*> *qa_records;
- qa_records = new std::vector<char*>;
+ std::vector<std::string> qa_records;
+ read_qa_information( qa_records );
+ std::vector<char> tag_data;
+ for (std::vector<std::string>::iterator i = qa_records.begin(); i != qa_records.end(); ++i) {
+ std::copy( i->begin(), i->end(), std::back_inserter(tag_data) );
+ tag_data.push_back( '\0' );
- read_qa_information( *qa_records );
//if there were qa_records...tag them to the mCurrentMeshHandle
- if( !qa_records->empty() )
+ if( !tag_data.empty() )
- if( mdbImpl->tag_set_data( mQaRecordTag, &mCurrentMeshHandle, 1, &qa_records ) != MB_SUCCESS ) {
- delete qa_records;
+ const void* ptr = &tag_data[0];
+ int size = tag_data.size();
+ if( mdbImpl->tag_set_data( mQaRecordTag, &mCurrentMeshHandle, 1, &ptr, &size ) != MB_SUCCESS ) {
return MB_FAILURE;
return MB_SUCCESS;
-MBErrorCode ReadNCDF::read_qa_information(std::vector<char*> &qa_record_list)
+MBErrorCode ReadNCDF::read_qa_information(std::vector<std::string> &qa_record_list)
// inquire on the genesis file to find the number of qa records
@@ -1870,19 +1869,18 @@
NcDim *temp_dim;
GET_DIM(temp_dim, "num_qa_rec", number_records);
- char *data;
+ std::vector<char> data(max_str_length+1);
for(int i = 0; i < number_records; i++)
for(int j = 0; j < 4; j++)
- data = new char[max_str_length+1];
data[max_str_length] = '\0';
- if (read_qa_string(data, i, j) != MB_SUCCESS)
+ if (read_qa_string(&data[0], i, j) != MB_SUCCESS)
return MB_FAILURE;
- qa_record_list.push_back(data);
+ qa_record_list.push_back(&data[0]);
return MB_SUCCESS;
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp 2009-02-11 18:02:28 UTC (rev 2636)
+++ MOAB/trunk/ReadNCDF.hpp 2009-02-11 18:11:49 UTC (rev 2637)
@@ -134,7 +134,7 @@
//qa record stuff
MBErrorCode read_qa_records();
- MBErrorCode read_qa_information( std::vector<char*> &qa_record_list);
+ MBErrorCode read_qa_information( std::vector<std::string> &qa_record_list);
MBErrorCode read_qa_string(char *string,
int record_number,
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2009-02-11 18:02:28 UTC (rev 2636)
+++ MOAB/trunk/Tqdcfr.cpp 2009-02-11 18:11:49 UTC (rev 2637)
@@ -590,14 +590,14 @@
// have to read dist factors
FREADD(sideseth->numDF);
MBTag distFactorTag;
- double *dum_val = NULL;
- MBErrorCode result = mdbImpl->tag_create("distFactor", sizeof(double*), MB_TAG_SPARSE,
- distFactorTag,
- &dum_val);
+ MBErrorCode result = mdbImpl->tag_create_variable_length( "distFactor",
+ MB_TAG_SPARSE,
+ MB_TYPE_DOUBLE,
+ distFactorTag );
if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
- double *dist_data = new double[ss_dfs.size()];
- memcpy(dist_data, &dbl_buf[0], sideseth->numDF*sizeof(double));
- result = mdbImpl->tag_set_data(distFactorTag, &sideseth->setHandle, 1, &dist_data);
+ const void* dist_data = &dbl_buf[0];
+ const int dist_size = sideseth->numDF * sizeof(double);
+ result = mdbImpl->tag_set_data( distFactorTag, &sideseth->setHandle, 1, &dist_data, &dist_size);
if (MB_SUCCESS != result) return result;
Modified: MOAB/trunk/WriteNCDF.cpp
--- MOAB/trunk/WriteNCDF.cpp 2009-02-11 18:02:28 UTC (rev 2636)
+++ MOAB/trunk/WriteNCDF.cpp 2009-02-11 18:11:49 UTC (rev 2637)
@@ -65,43 +65,46 @@
// initialize in case tag_get_handle fails below
//! get and cache predefined tag handles
int dum_val = 0;
- void* dum_ptr = 0;
- &dum_val);
+ result = impl->tag_create(MATERIAL_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, mMaterialSetTag, &dum_val);
- &dum_val);
+ result = impl->tag_create(DIRICHLET_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, mDirichletSetTag, &dum_val);
- &dum_val);
+ result = impl->tag_create(NEUMANN_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, mNeumannSetTag, &dum_val);
- dum_val_array);
+ result = impl->tag_create(HAS_MID_NODES_TAG_NAME, 4*sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, mHasMidNodesTag, dum_val_array);
- &dum_val);
+ MB_TAG_SPARSE,
+ MB_TYPE_DOUBLE,
+ mDistFactorTag );
- result = impl->tag_create("qaRecord", sizeof(void*), MB_TAG_SPARSE, mQaRecordTag,
- &dum_ptr);
+ MB_TAG_SPARSE,
+ MB_TYPE_OPAQUE,
+ mQaRecordTag );
- &dum_val);
impl->tag_create("WriteNCDF element mark", 1, MB_TAG_BIT, mEntityMark, NULL);
@@ -511,12 +514,16 @@
//get the tag for distribution factors
- std::vector<double> *dist_factor_vector;
+ const double *dist_factor_vector;
+ int dist_factor_size;
int has_dist_factors = 0;
- if(mdbImpl->tag_get_data(mDistFactorTag,&(*vector_iter), 1, &dist_factor_vector) == MB_SUCCESS &&
- NULL != dist_factor_vector)
+ if(mdbImpl->tag_get_data(mDistFactorTag,&(*vector_iter), 1, &ptr, &dist_factor_size) == MB_SUCCESS &&
+ dist_factor_size)
has_dist_factors = 1;
+ dist_factor_size /= sizeof(double);
+ dist_factor_vector = reinterpret_cast<const double*>(ptr);
std::vector<MBEntityHandle>::iterator iter, end_iter;
iter = node_vector.begin();
end_iter= node_vector.end();
@@ -537,7 +544,7 @@
nodeset_data.nodes.push_back( *iter );
if( has_dist_factors != 0)
- nodeset_data.node_dist_factors.push_back( (*dist_factor_vector)[j] );
+ nodeset_data.node_dist_factors.push_back( dist_factor_vector[j] );
else
nodeset_data.node_dist_factors.push_back( 1.0 );
@@ -598,17 +605,21 @@
// this is where we see if underlying element of side set element is included in output
//get the sideset-based info for distribution factors
+ const double *dist_factor_vector = 0;
+ int dist_factor_size = 0;
// initialize dist_fac_iter to get rid of compiler warning
- std::vector<double>::iterator dist_fac_iter(0);
+ const double* dist_fac_iter = 0;
bool has_dist_factors = false;
- &(sideset_data.mesh_set_handle), 1, &dist_factor_vector) == MB_SUCCESS &&
+ &(sideset_data.mesh_set_handle), 1, &ptr, &dist_factor_size) == MB_SUCCESS &&
+ dist_factor_size)
has_dist_factors = true;
- dist_fac_iter = (*dist_factor_vector).begin();
+ dist_fac_iter = dist_factor_vector;
unsigned char element_marked = 0;
