[MOAB-dev] r2630 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Wed Feb 4 13:18:34 CST 2009
Author: kraftche
Date: 2009-02-04 13:18:34 -0600 (Wed, 04 Feb 2009)
New Revision: 2630
Modified:
MOAB/trunk/tools/iMesh/iMesh.h
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
fix const-ness issues. note: diverges from current offical interface
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h 2009-02-04 19:18:04 UTC (rev 2629)
+++ MOAB/trunk/tools/iMesh/iMesh.h 2009-02-04 19:18:34 UTC (rev 2630)
@@ -799,7 +799,7 @@
* \param *err Pointer to error type returned from function
void iMesh_addEntArrToSet(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle* entity_handles,
+ /*in*/ const iBase_EntityHandle* entity_handles,
/*in*/ int entity_handles_size,
/*in*/ iBase_EntitySetHandle entity_set,
/*out*/ int *err);
@@ -815,7 +815,7 @@
void iMesh_rmvEntArrFromSet(iMesh_Instance instance,
/*out*/ int *err);
@@ -1045,7 +1045,7 @@
void iMesh_setVtxArrCoords(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle* vertex_handles,
+ /*in*/ const iBase_EntityHandle* vertex_handles,
/*in*/ const int vertex_handles_size,
/*in*/ const int storage_order,
/*in*/ const double* new_coords,
@@ -1128,7 +1128,7 @@
void iMesh_deleteEntArr(iMesh_Instance instance,
/*in*/ const int entity_handles_size,
/*out*/ int *err);
@@ -1579,7 +1579,7 @@
void iMesh_setArrData(iMesh_Instance instance,
/*in*/ const iBase_TagHandle tag_handle,
/*in*/ const char* tag_values,
@@ -1598,7 +1598,7 @@
void iMesh_setIntArrData(iMesh_Instance instance,
/*in*/ const int* tag_values,
@@ -1617,7 +1617,7 @@
void iMesh_setDblArrData(iMesh_Instance instance,
/*in*/ const double* tag_values,
@@ -1637,7 +1637,7 @@
void iMesh_setEHArrData(iMesh_Instance instance,
/*in*/ const iBase_EntityHandle* tag_values,
@@ -1654,7 +1654,7 @@
void iMesh_rmvArrTag(iMesh_Instance instance,
/*out*/ int *err);
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-02-04 19:18:04 UTC (rev 2629)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-02-04 19:18:34 UTC (rev 2630)
@@ -1389,7 +1389,7 @@
int *err)
@@ -1416,7 +1416,7 @@
/*in*/ iBase_EntitySetHandle entity_set, int *err)
@@ -1699,7 +1699,7 @@
void iMesh_setVtxArrCoords (iMesh_Instance instance,
@@ -1707,11 +1707,11 @@
MBErrorCode result = MB_SUCCESS, tmp_result;
if (storage_order == iBase_INTERLEAVED) {
- result = MBI->set_coords(HANDLE_ARRAY_PTR(vertex_handles),
+ result = MBI->set_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles),
vertex_handles_size, new_coords);
else {
- MBEntityHandle *verts = HANDLE_ARRAY_PTR(vertex_handles);
+ const MBEntityHandle *verts = CONST_HANDLE_ARRAY_PTR(vertex_handles);
double dummy[3];
for (int i = 0; i < vertex_handles_size; i++) {
dummy[0] = new_coords[i]; dummy[1] = new_coords[vertex_handles_size+i];
@@ -1842,14 +1842,14 @@
/*in*/ const int entity_handles_size, int *err)
if (0 == entity_handles_size) {
RETURN(iBase_SUCCESS);
- MBErrorCode result = MBI->delete_entities(HANDLE_ARRAY_PTR(entity_handles),
+ MBErrorCode result = MBI->delete_entities(CONST_HANDLE_ARRAY_PTR(entity_handles),
entity_handles_size);
if (MB_SUCCESS != result)
iMesh_processError(iBase_ERROR_MAP[result], "iMesh_deleteEntArr: trouble deleting entities.");
@@ -2420,7 +2420,7 @@
void iMesh_setArrData (iMesh_Instance instance,
@@ -2431,7 +2431,7 @@
MBErrorCode result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
- HANDLE_ARRAY_PTR(entity_handles),
+ CONST_HANDLE_ARRAY_PTR(entity_handles),
tag_values);
if (MB_SUCCESS != result) {
@@ -2444,7 +2444,7 @@
void iMesh_setIntArrData (iMesh_Instance instance,
@@ -2457,7 +2457,7 @@
void iMesh_setDblArrData (iMesh_Instance instance,
@@ -2470,7 +2470,7 @@
void iMesh_setBoolArrData (iMesh_Instance instance,
/*in*/ const bool* tag_values,
@@ -2483,7 +2483,7 @@
void iMesh_setEHArrData (iMesh_Instance instance,
@@ -2496,12 +2496,12 @@
void iMesh_rmvArrTag (iMesh_Instance instance,
/*in*/ const iBase_TagHandle tag_handle, int *err)
MBErrorCode result = MBI->tag_delete_data(TAG_HANDLE(tag_handle),
// don't check return; this tag may have never been set on the entity
