[MOAB-dev] r2628 - MOAB/trunk
    kraftche at mcs.anl.gov
    Wed Feb  4 13:17:18 CST 2009
Author: kraftche
Date: 2009-02-04 13:17:18 -0600 (Wed, 04 Feb 2009)
New Revision: 2628
Modified:
   MOAB/trunk/ReadNCDF.cpp
   MOAB/trunk/ReadNCDF.hpp
Log:
Fix bugs indicated by compiler warnings:
  - passing string literal as char*
  - comparison of char*'s with ==
  - no return value from function
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp	2009-02-03 21:48:54 UTC (rev 2627)
+++ MOAB/trunk/ReadNCDF.cpp	2009-02-04 19:17:18 UTC (rev 2628)
@@ -1971,7 +1971,7 @@
     //2. check for the operations, currently support sum.
-    const char *op = "" ;
+    std::stirng op;
     if(tokens.size() > 2 && !tokens[2].empty())
       op = tokens[2].c_str();
@@ -2093,11 +2093,13 @@
     delete [] array2;
     delete [] array3;
   } //if token[0] == "coord"
+  return MB_SUCCESS;
 void ReadNCDF::tokenize( const std::string& str,
                          std::vector<std::string>& tokens,
-                         char* delimiters )
+                         const char* delimiters )
   std::string::size_type last = str.find_first_not_of( delimiters, 0 );
   std::string::size_type pos  = str.find_first_of( delimiters, last );
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp	2009-02-03 21:48:54 UTC (rev 2627)
+++ MOAB/trunk/ReadNCDF.hpp	2009-02-04 19:17:18 UTC (rev 2628)
@@ -65,8 +65,8 @@
   static MBReaderIface* factory( MBInterface* );
   static void tokenize( const std::string& str,
-                      std::vector<std::string>& tokens,
-                      char* delimiters );
+                        std::vector<std::string>& tokens,
+                        const char* delimiters );
     //! load an ExoII file
   MBErrorCode load_file(const char *exodus_file_name,
