[MOAB-dev] r2625 - MOAB/trunk
janehu at mcs.anl.gov
Tue Feb 3 12:41:10 CST 2009
Author: janehu
Date: 2009-02-03 12:41:10 -0600 (Tue, 03 Feb 2009)
New Revision: 2625
Modified:
MOAB/trunk/ReadNCDF.cpp
Log:
Added back op as one of the tdata options per design request.
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-02-03 17:42:41 UTC (rev 2624)
+++ MOAB/trunk/ReadNCDF.cpp 2009-02-03 18:41:10 UTC (rev 2625)
@@ -1918,13 +1918,13 @@
//Function : updating current database from new exodus_file.
//Creator: Jane Hu
//opts is currently designed as following
- //tdata = <var_name>[, time][,destination]
- //Since deformed mesh will have original coordx, coordy and coordz, and at each
- //time_step, a deformation on each direction, so update will sum them to get the new coords
+ //tdata = <var_name>[, time][,op][,destination]
//where var_name show the tag name to be updated, this version just takes
//coord.
//time is the optional, and it gives time step of each of the mesh
//info in exodus file.
+ //op is the operation that is going to be performed on the var_name info.
+ //currently support 'sum'
//destination shows where to store the updated info, currently assume it is
//stored in the same database by replacing the old info.
MBErrorCode rval;
@@ -1968,7 +1968,12 @@
return MB_TYPE_OUT_OF_RANGE;
- //2. match the node_num_map.
+ //2. check for the operations, currently support sum.
+ const char *op = "" ;
+ if(tokens.size() > 2 && !tokens[2].empty())
+ op = tokens[2].c_str();
+ //3. match the node_num_map.
int* ptr1 = new int [numberNodes_loading];
int* ptr2 ;
@@ -2049,31 +2054,37 @@
int offset = time_step * numberNodes_loading;
- NcBool status = coordx->get(deform_arrays[0], offset+node_index1+1, num_of_nodes);
- if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting x coord array.");
- return MB_FAILURE;
- status = coordy->get(deform_arrays[1], offset+node_index1+1, num_of_nodes);
- readMeshIface->report_error("MBCN:: Problem getting y coord array.");
- if (numberDimensions_loading == 3 )
+ if(op == "sum")
- status = coordz->get(deform_arrays[2], offset+node_index1+1, num_of_nodes);
+ NcBool status = coordx->get(deform_arrays[0], offset+node_index1+1, num_of_nodes);
if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting z coord array.");
+ readMeshIface->report_error("MBCN:: Problem getting x coord array.");
return MB_FAILURE;
+ status = coordy->get(deform_arrays[1], offset+node_index1+1, num_of_nodes);
+ if (0 == status) {
+ readMeshIface->report_error("MBCN:: Problem getting y coord array.");
+ return MB_FAILURE;
+ if (numberDimensions_loading == 3 )
+ status = coordz->get(deform_arrays[2], offset+node_index1+1, num_of_nodes);
+ readMeshIface->report_error("MBCN:: Problem getting z coord array.");
node_num += num_of_nodes;
- for(int i = 0; i < numberNodes_loading; i++)
+ if(op == "sum")
- arrays[0][i] += deform_arrays[0][i];
- arrays[1][i] += deform_arrays[1][i];
- arrays[2][i] += deform_arrays[2][i];
+ for(int i = 0; i < numberNodes_loading; i++)
+ arrays[0][i] += deform_arrays[0][i];
+ arrays[1][i] += deform_arrays[1][i];
+ arrays[2][i] += deform_arrays[2][i];
delete [] ptr1;
delete [] array1;
