[MOAB-dev] r2624 - MOAB/trunk
janehu at mcs.anl.gov
Tue Feb 3 11:42:41 CST 2009
Author: janehu
Date: 2009-02-03 11:42:41 -0600 (Tue, 03 Feb 2009)
New Revision: 2624
Modified:
MOAB/trunk/ReadNCDF.cpp
Log:
Modified update function for Paul's exodus file with time_step. It's clear the format is to keep original coordinates, while each time_step shows the deformation on each direction. So removed the op in the tdata because we know it's going to do sum instead of copy.
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-02-03 15:50:57 UTC (rev 2623)
+++ MOAB/trunk/ReadNCDF.cpp 2009-02-03 17:42:41 UTC (rev 2624)
@@ -1918,13 +1918,13 @@
//Function : updating current database from new exodus_file.
//Creator: Jane Hu
//opts is currently designed as following
- //tdata = <var_name>[, time][,op][,destination]
+ //tdata = <var_name>[, time][,destination]
+ //Since deformed mesh will have original coordx, coordy and coordz, and at each
+ //time_step, a deformation on each direction, so update will sum them to get the new coords
//where var_name show the tag name to be updated, this version just takes
//coord.
//time is the optional, and it gives time step of each of the mesh
//info in exodus file.
- //op is the operation that is going to be performed on the var_name info.
- //currently support 'copy' and 'sum'
//destination shows where to store the updated info, currently assume it is
//stored in the same database by replacing the old info.
MBErrorCode rval;
@@ -1968,15 +1968,7 @@
return MB_TYPE_OUT_OF_RANGE;
- //2. check for the operations, they can be copy or sum.
- const char *op = "" ;
- if(tokens.size() > 2 && !tokens[2].empty())
- op = tokens[2].c_str();
- if(!(!strcmp(op, "copy") || !strcmp( op ,"sum")))
- return MB_TYPE_OUT_OF_RANGE;
- //3. match the node_num_map.
+ //2. match the node_num_map.
int* ptr1 = new int [numberNodes_loading];
int* ptr2 ;
@@ -2001,24 +1993,30 @@
//read in the coordinates from the database.
MBEntityHandle node_handle = 0;
- std::vector<double*> arrays, arrays_DB;
+ std::vector<double*> arrays, deform_arrays ;
+ double* array1 = new double [numberNodes_loading];
+ double* array2 = new double [numberNodes_loading];
+ double* array3 = new double [numberNodes_loading];
+ deform_arrays.push_back(array1);
+ deform_arrays.push_back(array2);
+ deform_arrays.push_back(array3);
readMeshIface->get_node_arrays(3, numberNodes_loading,
MB_START_ID, node_handle, arrays);
// read in the coordinates from the exodus file
- NcVar *coords = ncFile->get_var("coord");
- if (NULL == coords || !coords->is_valid()) {
+ NcVar *coordx = ncFile->get_var("vals_nod_var1");
+ NcVar *coordy = ncFile->get_var("vals_nod_var2");
+ NcVar *coordz;
+ if(numberDimensions_loading == 3)
+ ncFile->get_var("vals_nod_var3");
+ if (NULL == coordx || !coordx->is_valid() ||
+ NULL == coordy || !coordy->is_valid() ||
+ (numberDimensions_loading == 3 && (NULL == coordz || !coordz->is_valid())) ) {
readMeshIface->report_error("MBCN:: Problem getting coords variable.");
return MB_FAILURE;
- if(!strcmp(op ,"sum"))
- //record the DB coords.
- readMeshIface->get_node_arrays(3, numberNodes_loading,
- MB_START_ID, node_handle, arrays_DB);
//do operations on all coordinates.
for(int node_num = 0; node_num < numberNodes_loading; )
@@ -2048,47 +2046,39 @@
num_of_nodes = j;
break;
- NcBool status = coords->get(arrays[0], node_index1+1, num_of_nodes);
+ int offset = time_step * numberNodes_loading;
+ NcBool status = coordx->get(deform_arrays[0], offset+node_index1+1, num_of_nodes);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting x coord array.");
return MB_FAILURE;
- status = coords->set_cur(1, 0);
+ status = coordy->get(deform_arrays[1], offset+node_index1+1, num_of_nodes);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting y coord array.");
return MB_FAILURE;
- status = coords->get(arrays[1], node_index1+1, num_of_nodes);
- if (0 == status) {
- readMeshIface->report_error("MBCN:: Problem getting y coord array.");
- return MB_FAILURE;
if (numberDimensions_loading == 3 )
- status = coords->set_cur(2, 0);
+ status = coordz->get(deform_arrays[2], offset+node_index1+1, num_of_nodes);
if (0 == status) {
readMeshIface->report_error("MBCN:: Problem getting z coord array.");
return MB_FAILURE;
- status = coords->get(arrays[2], node_index1+1, num_of_nodes);
- readMeshIface->report_error("MBCN:: Problem getting z coord array.");
node_num += num_of_nodes;
- delete [] ptr1;
+ for(int i = 0; i < numberNodes_loading; i++)
- for(int i = 0 ; i < numberNodes_loading; i++)
- arrays[0][i] += arrays_DB[0][i];
- arrays[1][i] += arrays_DB[1][i];
- arrays[2][i] += arrays_DB[2][i];
+ arrays[0][i] += deform_arrays[0][i];
+ arrays[1][i] += deform_arrays[1][i];
+ arrays[2][i] += deform_arrays[2][i];
+ delete [] ptr1;
+ delete [] array1;
+ delete [] array2;
+ delete [] array3;
} //if token[0] == "coord"
