[MOAB-dev] r2620 - in MOAB/trunk: . tools/dagmc
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Mon Feb  2 14:20:44 CST 2009
This code looks broken.  You do things like "if(!tokens[2].empty())" without
ever checking that the 'tokens' vector contains 3 strings.  If I pass in
"tdata=coords", then your tokenize function will put only the one string in
the vector, and your code will read off the end of the underlying array
trying to access non-existent string instances at indices 1, 2, and 3.
Also, rather than doing '! strcmp (tokens[0].c_str(), "coord")', you can do
'tokens[0] == "coord"'.
- jason
janehu at mcs.anl.gov wrote:
> Author: janehu
> Date: 2009-02-02 14:05:32 -0600 (Mon, 02 Feb 2009)
> New Revision: 2620
> Modified:
>    MOAB/trunk/ReadNCDF.cpp
>    MOAB/trunk/ReadNCDF.hpp
>    MOAB/trunk/tools/dagmc/main.cc
> Log:
> Added an update function for existing DB to update coordinates forthe deformed mesh.
> Modified: MOAB/trunk/ReadNCDF.cpp
> --- MOAB/trunk/ReadNCDF.cpp	2009-01-31 01:29:18 UTC (rev 2619)
> +++ MOAB/trunk/ReadNCDF.cpp	2009-02-02 20:05:32 UTC (rev 2620)
> @@ -24,6 +24,7 @@
>  #include <time.h>
>  #include <string>
>  #include <assert.h>
> +#include <list>
>  #include <stdio.h>
>  #include "MBCN.hpp"
> @@ -34,6 +35,7 @@
>  #include "MBInternals.hpp"
>  #include "MBReadUtilIface.hpp"
>  #include "exodus_order.h"
> +#include "FileOptions.hpp"
>  #define INS_ID(stringvar, prefix, id) \
>            sprintf(stringvar, prefix, id)
> @@ -1012,14 +1014,13 @@
>        readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
>        delete [] ptr;
>        return MB_FAILURE;
> -      MBRange range(MB_START_ID+vertexOffset,
> -                    MB_START_ID+vertexOffset+numberNodes_loading-1);
> -      MBErrorCode error = mdbImpl->tag_set_data(mGlobalIdTag,
> -                                                range, &ptr[0]);
> -      if (MB_SUCCESS != error)
> -        readMeshIface->report_error("ReadNCDF:: Problem setting node global ids.");
> +    MBRange range(MB_START_ID+vertexOffset,
> +                  MB_START_ID+vertexOffset+numberNodes_loading-1);
> +    MBErrorCode error = mdbImpl->tag_set_data(mGlobalIdTag,
> +                                              range, &ptr[0]);
> +    if (MB_SUCCESS != error)
> +      readMeshIface->report_error("ReadNCDF:: Problem setting node global ids.");
>    delete [] ptr;
> @@ -1889,8 +1890,8 @@
>  MBErrorCode ReadNCDF::read_qa_string(char *temp_string,
> -                                       int record_number,
> -                                       int record_position)
> +                                     int record_number,
> +                                     int record_position)
>    NcVar *temp_var = ncFile->get_var("qa_records");
>    if (NULL == temp_var || !temp_var->is_valid()) {
> @@ -1912,3 +1913,194 @@
>    return MB_SUCCESS;
> +MBErrorCode ReadNCDF::update(const char *exodus_file_name, FileOptions& opts)
> +  //Function : updating current database from new exodus_file.
> +  //Creator:   Jane Hu
> +  //opts is currently designed as following
> +  //tdata = <var_name>[, time][,op][,destination]
> +  //where var_name show the tag name to be updated, this version just take
> +  //coord.
> +  //time is the optional, and it gives time step of the each of the mesh
> +  //info in exodus file.
> +  //op is the operation that is going to be performed on the var_name info.
> +  //currently support 'copy' and 'sum'
> +  //destination shows where to store the updated info, currently assume it is
> +  //stored in the same database by replacing the old info.
> +  MBErrorCode rval;
> +  std::string s;
> +  rval = opts.get_str_option("tdata", s );
> +  if(MB_SUCCESS != rval)
> +    readMeshIface->report_error("MBCN:: Problem reading file options.");
> +    return MB_FAILURE;
> +  std::vector< std::string > tokens;
> +  tokenize(s, tokens,",");
> +  std::string filename( exodus_file_name );
> +  // 0. Check for previously read file.
> +  reset();
> +  bool previously_loaded = false;
> +  rval = check_file_status(filename, previously_loaded);
> +  if (MB_SUCCESS != rval)
> +    return rval;
> +  read_exodus_header(exodus_file_name);
> +  if (! strcmp (tokens[0].c_str(), "coord") || ! strcmp (tokens[0].c_str() ,"COORD"))
> +    //1. check for time step to find the match time
> +    int time_step = 1;
> +    if(!tokens[1].empty())
> +      const char* time_s = tokens[1].c_str();
> +      char* endptr;
> +      long int pval = strtol( time_s, &endptr, 0 );
> +      std::string end = endptr;
> +      if (!end.empty()) // syntax error
> +        return MB_TYPE_OUT_OF_RANGE;
> +      // check for overflow (parsing long int, returning int)
> +      time_step = pval;
> +      if (pval != (long int)time_step)
> +    //2. check for the operations, they can be copy or sum.
> +    const char *op;
> +    if(!tokens[2].empty())
> +      op = tokens[2].c_str();
> +    if(!(!strcmp(op, "copy") || !strcmp( op ,"sum")))
> +    //3. match the node_num_map.
> +    int*    ptr1 = new int [numberNodes_loading];
> +    int*    ptr2 ;
> +    int varid = -1;
> +    int cstatus = nc_inq_varid (ncFile->id(), "node_num_map", &varid);
> +    if (cstatus == NC_NOERR && varid != -1) {
> +      NcVar *temp_var = ncFile->get_var("node_num_map");
> +      NcBool status = temp_var->get(ptr1, numberNodes_loading);
> +      if (0 == status) {
> +        readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
> +        delete [] ptr1;
> +      //get the existing db's node map
> +      MBErrorCode error = mdbImpl->tag_get_data(mGlobalIdTag,
> +                                              range, ptr2);
> +        readMeshIface->report_error("ReadNCDF:: Problem getting node global ids.");
> +    //read in the coordinates from the database.
> +    MBEntityHandle node_handle = 0;
> +    std::vector<double*> arrays, arrays_DB;
> +    readMeshIface->get_node_arrays(3, numberNodes_loading,
> +      MB_START_ID, node_handle, arrays);
> +    // read in the coordinates from the exodus file
> +    NcVar *coords = ncFile->get_var("coord");
> +    if (NULL == coords || !coords->is_valid()) {
> +      readMeshIface->report_error("MBCN:: Problem getting coords variable.");
> +    if(!strcmp(op ,"sum"))
> +      //record the DB coords.
> +        MB_START_ID, node_handle, arrays_DB);
> +    //do operations on all coordinates.
> +    for(int node_num = 0; node_num < numberNodes_loading; )
> +      NcBool found = 0;
> +      int node_index2, num_of_nodes;
> +      for(int i = 0; i < numberNodes_loading; i++)
> +        if(ptr2[i] == ptr1[node_num])
> +        //i is the index on the exodus file which matches the (node_num+1)th
> +        //node in the node map of existing DB.
> +          found = 1;
> +          node_index2 = i;
> +          break;
> +      if(!found)
> +        readMeshIface->report_error("MBCN:: node maps do not match.");
> +      for(int j = 1; ; j++)//j is the number of nodes to be sequentially matched
> +        if(ptr2[node_index2+j] != ptr1[node_num +j])
> +          num_of_nodes = j;
> +          break;
> +      NcBool status = coords->get(arrays[0], node_index2+1, num_of_nodes);
> +        readMeshIface->report_error("MBCN:: Problem getting x coord array.");
> +      status = coords->set_cur(1, 0);
> +        readMeshIface->report_error("MBCN:: Problem getting y coord array.");
> +      status = coords->get(arrays[1], node_index2+1, num_of_nodes);
> +      if (numberDimensions_loading == 3 )
> +        status = coords->set_cur(2, 0);
> +          readMeshIface->report_error("MBCN:: Problem getting z coord array.");
> +        status = coords->get(arrays[2], node_index2+1, num_of_nodes);
> +      node_num += num_of_nodes;
> +    delete [] ptr1;
> +      for(int i = 0 ; i < numberNodes_loading; i++)
> +        arrays[0][i] += arrays_DB[0][i];
> +        arrays[1][i] += arrays_DB[1][i];
> +        arrays[2][i] += arrays_DB[2][i];
> +  } //if token[0] == "coord"
> +void ReadNCDF::tokenize( const std::string& str,
> +                         std::vector<std::string>& tokens,
> +                         char* delimiters )
> +  std::string::size_type last = str.find_first_not_of( delimiters, 0 );
> +  std::string::size_type pos  = str.find_first_of( delimiters, last );
> +  while (std::string::npos != pos && std::string::npos != last) {
> +    tokens.push_back( str.substr( last, pos - last ) );
> +    last = str.find_first_not_of( delimiters, pos );
> +    pos  = str.find_first_of( delimiters, last );
> Modified: MOAB/trunk/ReadNCDF.hpp
> --- MOAB/trunk/ReadNCDF.hpp	2009-01-31 01:29:18 UTC (rev 2619)
> +++ MOAB/trunk/ReadNCDF.hpp	2009-02-02 20:05:32 UTC (rev 2620)
> @@ -64,6 +64,10 @@
>    static MBReaderIface* factory( MBInterface* );
> +  static void tokenize( const std::string& str,
> +                      char* delimiters );
>      //! load an ExoII file
>    MBErrorCode load_file(const char *exodus_file_name,
>                           MBEntityHandle& file_set,
> @@ -77,6 +81,9 @@
>     //! Destructor
>    virtual ~ReadNCDF();
> +  //update the coords for deformed mesh according to FileOptions
> +  MBErrorCode update(const char *exodus_file_name, FileOptions& opts);
>  private:
>    MBReadUtilIface* readMeshIface;
> Modified: MOAB/trunk/tools/dagmc/main.cc
> --- MOAB/trunk/tools/dagmc/main.cc	2009-01-31 01:29:18 UTC (rev 2619)
> +++ MOAB/trunk/tools/dagmc/main.cc	2009-02-02 20:05:32 UTC (rev 2620)
> @@ -4,6 +4,8 @@
>  #include "MBCore.hpp"
>  #include "cgm2moab.hpp"
>  #include "cubfile.h"
> +#include "Tqdcfr.hpp"
>  #define GF_CUBIT_FILE_TYPE    "CUBIT"
>  #define GF_STEP_FILE_TYPE     "STEP"
> @@ -158,10 +160,17 @@
>        exit(2);
> -    int rval = cub_file_type( cub_file, tmp_file, CUB_FILE_ACIS );
> +    MBCore *my_impl = new MBCore();
> +    Tqdcfr *my_tqd = new Tqdcfr(my_impl);
> +    MBEntityHandle file_set;
> +    FileOptions opts(NULL);
> +    MBErrorCode result = my_tqd->load_file(input_name, file_set, opts, 0, 0);
> +    int rvalue = cub_file_type( cub_file, tmp_file, CUB_FILE_ACIS );
>      fclose( cub_file );
>      fclose( tmp_file );
> -    if (rval) {
> +    if (rvalue) {
>        remove( temp_name );
>        free( temp_name );
>        exit(2);
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
