[MOAB-dev] r2612 - in MOAB/trunk: . cmake tools/iMesh
kraftche at mcs.anl.gov
Fri Jan 30 14:37:42 CST 2009
Author: kraftche
Date: 2009-01-30 14:37:42 -0600 (Fri, 30 Jan 2009)
New Revision: 2612
Added:
MOAB/trunk/cmake/ITAPSFortranMangling.cmake
MOAB/trunk/tools/iMesh/CMakeLists.txt
Modified:
MOAB/trunk/CMakeLists.txt
Log:
Fix CMake build:
- do not try to build refiner or mbcoupler unless parallel support is enabled
- build iMesh C bindings
- auto-generate iMesh *_protos.h
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2009-01-30 19:38:21 UTC (rev 2611)
+++ MOAB/trunk/CMakeLists.txt 2009-01-30 20:37:42 UTC (rev 2612)
@@ -239,11 +239,11 @@
${MOAB_LIB_SRCS}
- add_subdirectory( refiner )
- include_directories( ${MOAB_SOURCE_DIR}/refiner )
- target_link_libraries( MOAB
- MOABrefiner
+ if ( MOAB_USE_MPI AND MPI_FOUND )
+ add_subdirectory( refiner )
+ include_directories( ${MOAB_SOURCE_DIR}/refiner )
+ target_link_libraries( MOAB MOABrefiner )
+ endif ( MOAB_USE_MPI AND MPI_FOUND )
if ( MOAB_USE_HDF AND HDF5_FOUND )
@@ -254,9 +254,7 @@
add_subdirectory( parallel )
- MOABpar
+ target_link_libraries( MOAB MOABpar )
if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
@@ -280,13 +278,14 @@
endif ( MOAB_BUILD_DAGMC )
# MBCoupler
- if ( MOAB_BUILD_MBCOUPLER )
+ if ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
add_subdirectory( tools/mbcoupler )
- endif ( MOAB_BUILD_MBCOUPLER )
+ endif ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
# iMesh Babel
if ( MOAB_BUILD_IMESH )
option( MOAB_IMESH_FORTRAN "Should MOAB include iMesh FORTRAN bindings?" OFF )
+ add_subdirectory( tools/iMesh )
endif ( MOAB_BUILD_IMESH )
if ( MOAB_IMESH_FORTRAN )
@@ -295,6 +294,7 @@
# to macros which can be used from C to call FORTRAN.
#include( ${MOAB_SOURCE_DIR}/cmake/FortranCallingConvention.cmake)
endif ( MOAB_IMESH_FORTRAN )
include( ${MOAB_SOURCE_DIR}/cmake/AutoconfHeader.cmake )
# Define some more variables so they will be substituted properly in the autoconf files.
Added: MOAB/trunk/cmake/ITAPSFortranMangling.cmake
--- MOAB/trunk/cmake/ITAPSFortranMangling.cmake (rev 0)
+++ MOAB/trunk/cmake/ITAPSFortranMangling.cmake 2009-01-30 20:37:42 UTC (rev 2612)
@@ -0,0 +1,16 @@
+# Generate GNU autoconf-style Fortran name mangling for ITAPS headers
+# MACRO ( itaps_fortran_mangle input_file output_file prefix )
+SET( match_expr "^[ \\t]*void[ \\t]+${prefix}_([a-z][_a-zA-Z0-9]*)[ \\t]*\\(.*$" )
+FILE( STRINGS ${input_file} data REGEX ${match_expr} )
+FILE( WRITE ${output_file} "#include \"MBCN_FCDefs.h\"\n#ifdef FC_FUNC_\n\n" )
+FOREACH( line ${data} )
+ STRING(REGEX REPLACE ${match_expr} "${prefix}_\\1" func ${line})
+ STRING(TOUPPER ${func} upper)
+ STRING(TOLOWER ${func} lower)
+ FILE( APPEND ${output_file} "#define ${func} FC_FUNC_( ${upper}, ${lower} )\n" )
+ENDFOREACH( line )
+FILE( APPEND ${output_file} "\n#endif\n" )
+# ENDMACRO( itaps_fortran_mangle )
Added: MOAB/trunk/tools/iMesh/CMakeLists.txt
--- MOAB/trunk/tools/iMesh/CMakeLists.txt (rev 0)
+++ MOAB/trunk/tools/iMesh/CMakeLists.txt 2009-01-30 20:37:42 UTC (rev 2612)
@@ -0,0 +1,60 @@
+# Generate Fortran name mangling headers
+ADD_CUSTOM_COMMAND(
+ OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/iMesh_protos.h
+ COMMAND ${CMAKE_COMMAND}
+ -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMesh.h
+ -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMesh_protos.h
+ -Dprefix:STRING=iMesh
+ -P ${CMAKE_SOURCE_DIR}/cmake/ITAPSFortranMangling.cmake
+ DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/iMesh.h
+ OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/iMesh_extensions_protos.h
+ -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMesh_extensions.h
+ -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMesh_extensions_protos.h
+ DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/iMesh_extensions.h
+ OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h
+ -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMeshP.h
+ -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h
+ -Dprefix:STRING=iMeshP
+ DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/iMeshP.h
+set ( MOAB_IMESH_SRCS
+ iMesh_MOAB.cpp
+ ${CMAKE_CURRENT_BINARY_DIR}/iMesh_protos.h
+ ${CMAKE_CURRENT_BINARY_DIR}/iMesh_extensions_protos.h
+ ${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h )
+if ( MOAB_USE_MPI AND MPI_FOUND )
+ LIST ( APPEND MOAB_IMESH_SRCS
+ iMeshP_MOAB.cpp
+endif ( MOAB_USE_MPI AND MPI_FOUND )
+include_directories( ${CMAKE_SOURCE_DIR}
+ ${CMAKE_BINARY_DIR}
+ ${CMAKE_SOURCE_DIR}/parallel
+ ${CMAKE_BINARY_DIR}/parallel
+ ${CMAKE_CURRENT_SOURCE_DIR}
+set_source_files_properties(
+ ${MOAB_IMESH_SRCS}
+ COMPILE_FLAGS "${MOAB_DEFINES}"
+add_library( iMesh
