[MOAB-dev] r2603 - in MOAB/trunk/tools/iMesh: . SIDL SIDL/mserver
kraftche at mcs.anl.gov
Fri Jan 30 09:42:40 CST 2009
Author: kraftche
Date: 2009-01-30 09:42:34 -0600 (Fri, 30 Jan 2009)
New Revision: 2603
Modified:
MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl
MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
MOAB/trunk/tools/iMesh/iMesh.h
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
o Add missing implementation of iMesh_setGeometricDimension
o Remove in_entity_set argument from iMesh_getAdjEntities
Modified: MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl
--- MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl 2009-01-29 23:10:13 UTC (rev 2602)
+++ MOAB/trunk/tools/iMesh/SIDL/iMesh.sidl 2009-01-30 15:42:34 UTC (rev 2603)
@@ -110,9 +110,7 @@
inout array<opaque> adj_entity_handles,
out int adj_entity_handles_size,
inout array<int> offset,
- out int offset_size,
- inout array<int> in_entity_set,
- out int in_entity_set_size) throws iBase.Error;
+ out int offset_size) throws iBase.Error;
void getAdjEntIndices( in opaque entity_set_handle,
in EntityType entity_type_requestor,
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc 2009-01-29 23:10:13 UTC (rev 2602)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc 2009-01-30 15:42:34 UTC (rev 2603)
@@ -3,15 +3,15 @@
// Symbol: iMesh_SIDL.MeshSidl-v0.2
// Symbol Type: class
// Babel Version: 0.10.10
-// sidl Created: 20090120 19:02:01 CST
-// Generated: 20090120 19:02:03 CST
+// sidl Created: 20090130 09:34:06 CST
+// Generated: 20090130 09:34:08 CST
// Description: Server-side implementation for iMesh_SIDL.MeshSidl
// WARNING: Automatically generated; only changes within splicers preserved
// babel-version = 0.10.10
// source-line = 5
-// source-url = file:/home/jason/moab/newimesh/src/tools/iMesh/SIDL/iMesh_SIDL.sidl
+// source-url = file:/home/jason/moab/clean/sidl/tools/iMesh/SIDL/../../../../src/tools/iMesh/SIDL/iMesh_SIDL.sidl
#include "iMesh_SIDL_MeshSidl_Impl.hh"
@@ -1575,10 +1575,7 @@
/* in */ ::iBase::EntityType entity_type_requested,
/* inout */ ::sidl::array<void*>& adj_entity_handles,
/* out */ int32_t& adj_entity_handles_size,
- /* inout */ ::sidl::array<int32_t>& offset,
- /* out */ int32_t& offset_size,
- /* inout */ ::sidl::array<int32_t>& in_entity_set,
- /* out */ int32_t& in_entity_set_size )
+ /* inout */ ::sidl::array<int32_t>& offset )
throw (
::iBase::Error
@@ -1587,7 +1584,6 @@
CREATE_TEMP_EH_ARRAY(adj_entity_handles);
CREATE_TEMP_ARRAY(int32_t, offset);
- CREATE_TEMP_ARRAY(int32_t, in_entity_set);
iMesh_getAdjEntities (imeshInstance, reinterpret_cast<iBase_EntitySetHandle>(entity_set),
(iBase_EntityType)entity_type_requestor,
@@ -1595,13 +1591,12 @@
(iBase_EntityType)entity_type_requested,
TEMP_ARRAY_INOUT(adj_entity_handles),
TEMP_ARRAY_INOUT(offset),
- TEMP_ARRAY_INOUT(in_entity_set), &imeshError);
+ &imeshError);
PROCESS_ERROR;
ASSIGN_TYPED_ARRAY(void*, adj_entity_handles);
ASSIGN_TYPED_ARRAY(int32_t, offset);
- ASSIGN_TYPED_ARRAY(int32_t, in_entity_set);
// DO-NOT-DELETE splicer.end(iMesh_SIDL.MeshSidl.getAdjEntities)
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h 2009-01-29 23:10:13 UTC (rev 2602)
+++ MOAB/trunk/tools/iMesh/iMesh.h 2009-01-30 15:42:34 UTC (rev 2603)
@@ -393,10 +393,9 @@
/**\brief Get entities adjacent to those of requested type/topology in set or instance
* Get entities adjacent to those of requested type/topology in set or
- * instance. If set is specified, also returns whether each adjacent entity
- * is in the set ((*in_entity_set)[i]=1 indicates that adjacent entity
- * (*adj_entity_handles)[i] is in the specified set). If adjacencies for
- * all entities of specified type or
+ * instance.
+ * If adjacencies for all entities of specified type or
* topology are desired, specify iMesh_ALL_TOPOLOGIES or iBase_ALL_TYPES,
* respectively. Types and topologies input to this function must be values
* in the iBase_EntityType or iBase_EntityTopology enumerations, respectively.
@@ -419,12 +418,6 @@
* \param *offset Pointer to array of offsets returned from function
* \param *offset_allocated Pointer to allocated size of offset array
* \param *offset_size Pointer to occupied size of offset array
- * \param *in_entity_set Pointer to array of in_entity_set returned
- * from function
- * \param *in_entity_set_allocated Pointer to allocated size of
- * in_entity_set array
- * \param *in_entity_set_size Pointer to occupied size of in_entity_set
- * array
* \param *err Pointer to error type returned from function
void iMesh_getAdjEntities(iMesh_Instance instance,
@@ -438,9 +431,6 @@
/*inout*/ int** offset,
/*inout*/ int* offset_allocated,
/*out*/ int* offset_size,
- /*inout*/ int** in_entity_set,
- /*inout*/ int* in_entity_set_allocated,
- /*out*/ int* in_entity_set_size,
/*out*/ int *err);
/**\brief Initialize an array iterator over specified entity type, topology, and
@@ -604,8 +594,8 @@
* \param instance iMesh instance for this call
* \param entity_handles Entities from which adjacencies are requested
* \param entity_handles_size Number of entities whose adjacencies are requested
- * \param bridge_dimension Bridge dimension for 2nd order adjacencies
- * \param to_dimension Dimension of adjacent entities returned
+ * \param bridge_entity_type Type of bridge entity for 2nd order adjacencies
+ * \param requested_entity_type Type of adjacent entities returned
* \param adj_entity_handles Adjacent entities
* \param adj_entity_handles_allocated Allocated size of returned array
* \param adj_entity_handles_size Occupied size of returned array
@@ -618,7 +608,7 @@
void iMesh_getEntArr2ndAdj( iMesh_Instance instance,
iBase_EntityHandle const* entity_handles,
int entity_handles_size,
- int order_adjacent_key,
+ int bridge_entity_type,
int requested_entity_type,
iBase_EntityHandle** adj_entity_handles,
int* adj_entity_handles_allocated,
@@ -870,8 +860,8 @@
void iMesh_isEntContained(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle containing_entity_set,
- /*in*/ const iBase_EntityHandle contained_entity,
+ /*in*/ iBase_EntitySetHandle containing_entity_set,
+ /*in*/ iBase_EntityHandle contained_entity,
/*out*/ int *is_contained,
/*out*/ int *err);
@@ -1967,8 +1957,8 @@
* specified "to" dimension.
* \param entity_handle Entity from which adjacencies are requested
* \param adjacent_entities Adjacent entities
* \param adjacent_entities_allocated Allocated size of returned array
* \param adjacent_entities_size Occupied size of returned array
@@ -1976,7 +1966,7 @@
void iMesh_getEnt2ndAdj( iMesh_Instance instance,
iBase_EntityHandle entity_handle,
iBase_EntityHandle** adjacent_entities,
int* adjacent_entities_allocated,
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-01-29 23:10:13 UTC (rev 2602)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-01-30 15:42:34 UTC (rev 2603)
@@ -375,6 +375,13 @@
RETURN(iBase_SUCCESS);
+ void iMesh_setGeometricDimension(iMesh_Instance instance,
+ int geom_dim, int *err)
+ MBErrorCode rval = MBI->set_dimension(geom_dim);
+ RETURN((MB_SUCCESS == rval ? iBase_SUCCESS : iBase_FAILURE));
void iMesh_getDfltStorage(iMesh_Instance instance,
int *order, int *err)
@@ -710,10 +717,8 @@
/*out*/ int* adj_entity_handles_size,
- /*out*/ int* offset_size,
- /*out*/ int* in_entity_set_size, int *err)
+ /*inout*/ int* offset_size,
+ /*out*/ int *err)
MBEntityHandle in_set = ENTITY_HANDLE(entity_set_handle);
MBRange entities;
@@ -743,7 +748,7 @@
if (num_entities == 0)
- *adj_entity_handles_size = *offset_size = *in_entity_set_size = 0;
+ *adj_entity_handles_size = *offset_size = 0;
RETURN(iBase_ERROR_MAP[result]);
@@ -778,9 +783,6 @@
CHECK_SIZE(*offset, *offset_allocated,
(int)entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
- CHECK_SIZE(*in_entity_set, *in_entity_set_allocated,
- num_sub, int, iBase_MEMORY_ALLOCATION_FAILED);
// now iterate over entities
num_sub = 0;
int i = 0;
@@ -809,11 +811,6 @@
for (std::vector<MBEntityHandle>::iterator vit = adj_ents.begin();
vit != adj_ents.end(); vit++) {
(*adj_entity_handles)[num_sub] = (iBase_EntityHandle)*vit;
- if (0 == in_set || entities.find(*vit) != endr)
- (*in_entity_set)[num_sub] = 1;
- else
- (*in_entity_set)[num_sub] = 0;
num_sub++;
@@ -822,8 +819,7 @@
*adj_entity_handles_size = num_sub;
*offset_size = entities.size();
- *in_entity_set_size = num_sub;
