[MOAB-dev] r2571 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Jan 26 12:14:32 CST 2009
Author: kraftche
Date: 2009-01-26 12:14:32 -0600 (Mon, 26 Jan 2009)
New Revision: 2571
Modified:
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
   MOAB/trunk/tools/iMesh/iMesh_extensions.h
Log:
s/iBase_EntityHandle/iBase_EntitySetHandle/
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-01-24 19:32:45 UTC (rev 2570)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-01-26 18:14:32 UTC (rev 2571)
@@ -3149,7 +3149,7 @@
                                  /*in*/ const char * const *tag_vals,
                                  /*in*/ const int num_tags_vals,
                                  /*in*/ const int recursive,
-                                 /*out*/ iBase_EntityHandle** set_handles,
+                                 /*out*/ iBase_EntitySetHandle** set_handles,
                                  /*out*/ int* set_handles_allocated,
                                  /*out*/ int* set_handles_size,
                                  /*out*/ int *err)
@@ -3171,7 +3171,7 @@
     CHECK_SIZE(*set_handles, *set_handles_allocated,
-               (int)out_entities.size(), iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+               (int)out_entities.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
     std::copy(out_entities.begin(), out_entities.end(), ((MBEntityHandle*) *set_handles));
Modified: MOAB/trunk/tools/iMesh/iMesh_extensions.h
--- MOAB/trunk/tools/iMesh/iMesh_extensions.h	2009-01-24 19:32:45 UTC (rev 2570)
+++ MOAB/trunk/tools/iMesh/iMesh_extensions.h	2009-01-26 18:14:32 UTC (rev 2571)
@@ -140,7 +140,7 @@
                                  /*out*/ int *err);
