[MOAB-dev] r2566 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Sat Jan 24 11:04:00 CST 2009
Author: kraftche
Date: 2009-01-24 11:04:00 -0600 (Sat, 24 Jan 2009)
New Revision: 2566
Modified:
MOAB/trunk/tools/iMesh/testc_cbind.c
Log:
fix all gcc warnings about code not compliant with ISO C90
Modified: MOAB/trunk/tools/iMesh/testc_cbind.c
--- MOAB/trunk/tools/iMesh/testc_cbind.c 2009-01-22 21:38:53 UTC (rev 2565)
+++ MOAB/trunk/tools/iMesh/testc_cbind.c 2009-01-24 17:04:00 UTC (rev 2566)
@@ -101,7 +101,7 @@
int load_mesh_test(const char *filename, iMesh_Instance mesh)
- // load a mesh
+ /* load a mesh */
int result;
iMesh_load(mesh, root_set, filename, NULL, &result, strlen(filename), 0);
if (iBase_SUCCESS != result) {
@@ -119,10 +119,13 @@
int topology_dimension_test(iMesh_Instance mesh)
- // first get 2D entities
iBase_EntityHandle *faces = NULL;
int faces_alloc = 0, faces_size;
int result, i;
+ int *dimensions = NULL;
+ int dimensions_alloc = 0, dimensions_size;
+ /* first get 2D entities */
iMesh_getEntities(mesh, root_set, iBase_FACE,
iMesh_ALL_TOPOLOGIES,
&faces, &faces_alloc, &faces_size, &result);
@@ -131,10 +134,7 @@
return FALSE;
- // get dimensions of faces
- int *dimensions = NULL;
- int dimensions_alloc = 0, dimensions_size;
+ /* get dimensions of faces */
iMesh_getEntArrType(mesh, faces, faces_size,
&dimensions, &dimensions_alloc, &dimensions_size, &result);
@@ -147,7 +147,7 @@
return FALSE;
- // make sure all elements are 2D
+ /* make sure all elements are 2D */
for (i = 0; i < faces_size; i++) {
if (dimensions[i] != iBase_FACE) {
return FALSE;
@@ -167,22 +167,34 @@
@li Check adjacency
@li Get interior and exterior elements
-// make each topological entity vectors, check their topology
-// types, get interior and exterior faces of hexes
+/* make each topological entity vectors, check their topology */
+/* types, get interior and exterior faces of hexes */
int topology_adjacency_test(iMesh_Instance mesh)
- int result;
- iBase_EntityHandle *entity_vectors[iMesh_ALL_TOPOLOGIES] = {NULL};
+ int result, i, j, entities_alloc, entities_size, *topologies;
+ int topologies_alloc, topologies_size;
+ iBase_EntityHandle *entities, *entity_vectors[iMesh_ALL_TOPOLOGIES] = {NULL};
int entity_vectors_sizes[iMesh_ALL_TOPOLOGIES] = {0};
+ int top_j, num_tops, region_type, num_region;
+ iBase_EntityHandle *adj_faces = NULL;
+ int adj_faces_alloc = 0, adj_faces_size;
+ int *face_offsets = NULL;
+ int face_offsets_alloc = 0, face_offsets_size, face_loaded;
+ iBase_EntityHandle *adj_regions = NULL;
+ int adj_regions_alloc = 0, adj_regions_size;
+ int *region_offsets = NULL;
+ int region_offsets_alloc = 0, region_offsets_size;
+ iBase_EntityHandle *interior, *exterior;
+ int num_int = 0, num_ext = 0, found, next_offset, iter;
+ int num_faces_per_region;;
- // fill the vectors of each topology entities
- // like lines vector, polygon vector, triangle vector,
- // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
- // septahedron vectors
- int i;
+ /* fill the vectors of each topology entities */
+ /* like lines vector, polygon vector, triangle vector, */
+ /* quadrilateral, polyhedrron, tet, hex, prism, pyramid, */
+ /* septahedron vectors */
for (i = 0; i < iMesh_ALL_TOPOLOGIES; i++) {
- iBase_EntityHandle *entities = NULL;
- int entities_alloc = 0, entities_size;
+ entities = NULL;
+ entities_alloc = 0;
iMesh_getEntities(mesh, root_set, iBase_ALL_TYPES,
i, &entities, &entities_alloc,
&entities_size, &result);
@@ -192,8 +204,8 @@
if (entities_alloc > 0) {
- int *topologies = NULL;
- int topologies_alloc = 0, topologies_size;
+ topologies = NULL;
+ topologies_alloc = 0;
iMesh_getEntArrTopo(mesh, entities,
entities_alloc,
&topologies, &topologies_alloc, &topologies_size, &result);
@@ -208,11 +220,10 @@
return FALSE;
- // put entities into vectors of each topology
+ /* put entities into vectors of each topology */
entity_vectors[i] = (iBase_EntityHandle*)
malloc(entities_size*sizeof(iBase_EntityHandle));
- int j;
for (j = 0; j < entities_size; j++) {
if (topologies[j] < iMesh_POINT ||
topologies[j] >= iMesh_ALL_TOPOLOGIES)
@@ -229,10 +240,9 @@
free(entities);
- // check number of entities for each topology
- int top_j;
+ /* check number of entities for each topology */
for (top_j = 0; top_j < iMesh_ALL_TOPOLOGIES; top_j++) {
- int num_tops = 0;
+ num_tops = 0;
iMesh_getNumOfTopo(mesh, root_set, top_j, &num_tops, &result);
printf("Failed to get number of topologies in adjacencies_test.\n");
@@ -245,21 +255,20 @@
- // change if 3d topology entities are added or removed
- int region_type;
+ /* change if 3d topology entities are added or removed */
for (region_type = iMesh_TETRAHEDRON;
region_type < iMesh_ALL_TOPOLOGIES; region_type++) {
- // get all adjacent faces of regions
+ /* get all adjacent faces of regions */
iBase_EntityHandle *region_vector =
entity_vectors[region_type];
- int num_region = entity_vectors_sizes[region_type];
+ num_region = entity_vectors_sizes[region_type];
if (num_region > 0) {
- iBase_EntityHandle *adj_faces = NULL;
- int adj_faces_alloc = 0, adj_faces_size;
- int *face_offsets = NULL;
- int face_offsets_alloc = 0, face_offsets_size;
+ adj_faces = NULL;
+ adj_faces_alloc = 0;
+ face_offsets = NULL;
+ face_offsets_alloc = 0;
iMesh_getEntArrAdj(mesh, region_vector, num_region,
iBase_FACE,
@@ -277,9 +286,9 @@
return FALSE;
- int face_loaded = FALSE;
+ face_loaded = FALSE;
- // check # of faces really loaded
+ /* check # of faces really loaded */
if (region_type == iMesh_TETRAHEDRON) {
if (adj_faces_size == 4*num_region)
face_loaded = TRUE;
@@ -303,11 +312,11 @@
else
- // get all adjacent regions of adjacent faces
- iBase_EntityHandle *adj_regions = NULL;
- int adj_regions_alloc = 0, adj_regions_size;
- int *region_offsets = NULL;
- int region_offsets_alloc = 0, region_offsets_size;
+ /* get all adjacent regions of adjacent faces */
+ adj_regions = NULL;
+ adj_regions_alloc = 0;
+ region_offsets = NULL;
+ region_offsets_alloc = 0;
iMesh_getEntArrAdj(mesh, adj_faces, adj_faces_size, iBase_REGION,
&adj_regions, &adj_regions_alloc,
&adj_regions_size,
@@ -323,22 +332,18 @@
return FALSE;
- iBase_EntityHandle *interior = (iBase_EntityHandle*)
- malloc(adj_faces_size*sizeof(iBase_EntityHandle)),
- *exterior = (iBase_EntityHandle*)
- malloc(adj_faces_size*sizeof(iBase_EntityHandle));
- int num_int = 0, num_ext = 0;
+ interior = (iBase_EntityHandle*)malloc(adj_faces_size*sizeof(iBase_EntityHandle)),
+ exterior = (iBase_EntityHandle*)malloc(adj_faces_size*sizeof(iBase_EntityHandle));
+ num_int = 0; num_ext = 0;
- // find the interior faces having two adjacent regions
- int i;
+ /* find the interior faces having two adjacent regions */
for (i = 0; i < adj_faces_size; i++) {
- int next_offset = 0;
+ next_offset = 0;
if (i == adj_faces_size-1) next_offset = adj_regions_size;
else next_offset = region_offsets[i+1];
if (next_offset - region_offsets[i] == 2) {
- int found = FALSE;
- int iter;
+ found = FALSE;
for (iter = 0; iter < num_int; iter++) {
if (interior[iter] == adj_faces[i]) {
found = TRUE;
@@ -349,11 +354,10 @@
- // now remove any interior faces from the previous adjacent faces list
- // and we should be left with exterior faces
+ /* now remove any interior faces from the previous adjacent faces list */
+ /* and we should be left with exterior faces */
- int iter;
+ found = FALSE;
found = TRUE;
@@ -363,11 +367,11 @@
if (!found) exterior[num_ext++] = adj_faces[i];
- int num_faces_per_region = face_offsets[1] - face_offsets[0];
+ num_faces_per_region = face_offsets[1] - face_offsets[0];
- // check # of exterior and interior faces
- // should be #exterior_faces + 2 * #interior_faces = #faces_per_region
- // * #regions
+ /* check # of exterior and interior faces */
+ /* should be #exterior_faces + 2 * #interior_faces = #faces_per_region */
+ /* * #regions */
if (face_loaded)
if (num_ext+2*num_int !=
num_faces_per_region*num_region) {
@@ -401,14 +405,26 @@
int type = iBase_EDGE;
int result;
+ int *offsets = NULL;
+ int offsets_alloc = 0, offsets_size;
+ int *indices = NULL;
+ int indices_alloc = 0, indices_size;
+ int *topologies = NULL;
+ int topologies_alloc = 0, topologies_size;
+ int *offsets1 = NULL;
+ int offsets1_alloc = 0, offsets1_size;
+ int *entity_sets = NULL;
+ int entity_sets_alloc = 0, entity_sets_size;
+ iBase_EntityHandle *entities = NULL;
+ int entities_alloc = 0, entities_size;
for (; type < iBase_ALL_TYPES; type++) {
- int *offsets = NULL;
- int offsets_alloc = 0, offsets_size;
- int *indices = NULL;
- int indices_alloc = 0, indices_size;
+ offsets = NULL;
+ offsets_alloc = 0;
+ indices = NULL;
+ indices_alloc = 0;
iMesh_getVtxCoordIndex(mesh, root_set, type,
@@ -436,12 +452,12 @@
return FALSE;
- int *offsets1 = NULL;
- int offsets1_alloc = 0, offsets1_size;
- int *entity_sets = NULL;
- int entity_sets_alloc = 0, entity_sets_size;
+ offsets1 = NULL;
+ offsets1_alloc = 0;
+ entity_sets = NULL;
+ entity_sets_alloc = 0;
+ entities = NULL;
iMesh_getAdjEntities(mesh, root_set, type,
iMesh_ALL_TOPOLOGIES, iBase_VERTEX,
@@ -477,19 +493,52 @@
@li Check entity sets
-// helper function used to report errors in # sets
+/* helper function used to report errors in # sets */
int check_esets(iMesh_Instance mesh, const int num_sets);
int entity_sets_subtest(iMesh_Instance mesh, int is_list,
int num_iter)
- int num_type = iBase_ALL_TYPES - iBase_VERTEX;
+ int i, num_type = iBase_ALL_TYPES - iBase_VERTEX;
int num_all_entities_super = 0;
- iBase_EntitySetHandle es_array[num_type];
- int number_array[num_type];
+ iBase_EntitySetHandle es_array[iBase_ALL_TYPES - iBase_VERTEX];
+ int number_array[iBase_ALL_TYPES - iBase_VERTEX];
int ent_type = iBase_VERTEX;
- // get the number of whole mesh
+ iBase_EntitySetHandle parent_child, super_set = NULL;
+ iBase_EntitySetHandle temp_es1, temp_es2, temp_es3;
+ iBase_EntityHandle *edges = NULL, *faces = NULL,
+ *temp_entities1 = NULL, *temp_entities2 = NULL;
+ int edges_alloc = 0, faces_alloc = 0,
+ temp_entities1_alloc = 0, temp_entities2_alloc = 0;
+ int edges_size, faces_size, temp_entities1_size, temp_entities2_size;
+ int *types = NULL;
+ int types_alloc = 0, types_size;
+ int num_rest, num_regions;
+ iBase_EntityHandle *regions = NULL;
+ int regions_alloc = 0, regions_size;
+ iBase_EntityHandle *parents = NULL;
+ int parents_alloc = 0, parents_size, temp_numb, is_child;
+ iBase_EntitySetHandle *es_array1 = NULL;
+ int es_array1_alloc = 0, es_array1_size, num_super;
+ iBase_EntityHandle *all_entities = NULL;
+ int all_entities_alloc = 0, all_entities_size, k, l;
+ int *face_offsets = NULL, *face_in_sets = NULL;
+ int face_offsets_alloc = 0, face_in_sets_alloc = 0,
+ face_offsets_size, face_in_sets_size;
+ iBase_EntityHandle *hexes = NULL;
+ int hexes_alloc = 0, hexes_size;
+ iBase_EntitySetHandle hex_set;
+ iBase_EntityHandle *adj_faces1 = NULL;
+ int adj_faces1_alloc = 0, adj_faces1_size;
+ int *face_offsets1 = NULL, *face_in_sets1 = NULL;
+ int face_offsets1_alloc = 0, face_in_sets1_alloc = 0,
+ face_offsets1_size, face_in_sets1_size;
+ /* get the number of whole mesh */
int n_whole_mesh = 0;
int result;
iMesh_getNumEntSets(mesh, root_set, 1, &n_whole_mesh, &result);
@@ -498,18 +547,18 @@
return FALSE;
- // add entities to entitysets by type
+ /* add entities to entitysets by type */
for (; ent_type < num_type; ent_type++) {
- // initialize the entityset
+ /* initialize the entityset */
iMesh_createEntSet(mesh, is_list, &es_array[ent_type], &result);
printf("Problem creating entityset.\n");
return FALSE;
- // get entities by type in total "mesh"
+ /* get entities by type in total "mesh" */
+ entities = NULL;
iMesh_getEntities(mesh, root_set, ent_type,
&entities, &entities_alloc, &entities_size, &result);
@@ -523,7 +572,7 @@
return FALSE;
- // add entities into entity set
+ /* add entities into entity set */
if (0 != entities_size) {
iMesh_addEntArrToSet(mesh, entities, entities_size, es_array+ent_type, &result);
@@ -532,7 +581,7 @@
- // Check to make sure entity set really has correct number of entities in it
+ /* Check to make sure entity set really has correct number of entities in it */
iMesh_getNumOfType(mesh, es_array[ent_type], ent_type,
number_array+ent_type, &result);
@@ -541,14 +590,14 @@
return FALSE;
- // compare the number of entities by type
+ /* compare the number of entities by type */
if (number_array[ent_type] != entities_size)
printf("Number of entities by type is not correct\n");
return FALSE;
- // add to number of all entities in super set
+ /* add to number of all entities in super set */
num_all_entities_super += entities_size;
free(entities);
@@ -556,15 +605,14 @@
if (!check_esets(mesh, n_whole_mesh + num_type)) return FALSE;
- // make a super set having all entitysets
- iBase_EntitySetHandle super_set = NULL;
+ /* make a super set having all entitysets */
+ super_set = NULL;
iMesh_createEntSet(mesh, is_list, &super_set, &result);
printf("Failed to create a super set in entity_sets_test.\n");
return FALSE;
- int i;
for (i = 0; i < num_type; i++) {
iMesh_addEntSet(mesh, es_array[i], &super_set, &result);
@@ -576,9 +624,8 @@
if (!check_esets(mesh, n_whole_mesh + num_type + 1))
return FALSE;
- //----------TEST intEAN OPERATIONS----------------//
+ /*----------TEST intEAN OPERATIONS----------------*/
- iBase_EntitySetHandle temp_es1, temp_es2, temp_es3;
iMesh_createEntSet(mesh, is_list, &temp_es1, &result);
@@ -587,14 +634,11 @@
if (!check_esets(mesh, n_whole_mesh + num_type + 2)) return FALSE;
- // Subtract
- // add all EDGEs and FACEs to temp_es1
- // get all EDGE entities
- iBase_EntityHandle *edges = NULL, *faces = NULL,
- *temp_entities1 = NULL, *temp_entities2 = NULL;
- int edges_alloc = 0, faces_alloc = 0,
- temp_entities1_alloc = 0, temp_entities2_alloc = 0;
- int edges_size, faces_size, temp_entities1_size, temp_entities2_size;
+ /* Subtract */
+ /* add all EDGEs and FACEs to temp_es1 */
+ /* get all EDGE entities */
+ edges = NULL; faces = NULL; temp_entities1 = NULL; temp_entities2 = NULL;
+ edges_alloc = 0; faces_alloc = 0; temp_entities1_alloc = 0; temp_entities2_alloc = 0;
iMesh_getEntities(mesh, es_array[iBase_EDGE], iBase_EDGE,
@@ -605,14 +649,14 @@
return FALSE;
- // add EDGEs to es1
+ /* add EDGEs to es1 */
iMesh_addEntArrToSet(mesh, edges, edges_size, &temp_es1, &result);
printf("Failed to add edge entities in entity_sets_test.\n");
return FALSE;
- // get all FACE entities
+ /* get all FACE entities */
iMesh_getEntities(mesh, es_array[iBase_FACE], iBase_FACE,
@@ -621,14 +665,14 @@
return FALSE;
- // add FACEs to es1
+ /* add FACEs to es1 */
iMesh_addEntArrToSet(mesh, faces, faces_size, &temp_es1, &result);
printf("Failed to add face entities in entity_sets_test.\n");
return FALSE;
- // subtract EDGEs
+ /* subtract EDGEs */
iMesh_subtract(mesh, temp_es1, es_array[iBase_EDGE], &temp_es2, &result);
@@ -649,9 +693,9 @@
return FALSE;
- // check there's nothing but faces in face_es
- int *types = NULL;
- int types_alloc = 0, types_size;
+ /* check there's nothing but faces in face_es */
+ types = NULL;
+ types_alloc = 0;
iMesh_getEntArrType(mesh, temp_entities1, temp_entities1_size,
&types, &types_alloc, &types_size, &result);
@@ -674,18 +718,16 @@
- //------------Intersect------------
+ /*------------Intersect------------ */
- // clean out the temp_ms1
+ /* clean out the temp_ms1 */
iMesh_rmvEntArrFromSet(mesh, faces, faces_size, &temp_es1, &result);
printf("Failed to remove face entities in entity_sets_test.\n");
return FALSE;
- // check if it is really cleaned out
- int num_rest;
+ /* check if it is really cleaned out */
iMesh_getNumOfType(mesh, temp_es1, iBase_FACE, &num_rest, &result);
printf("Failed to get number of entities by type in entity_sets_test.\n");
@@ -697,22 +739,22 @@
return FALSE;
- // add EDGEs to temp es1
+ /* add EDGEs to temp es1 */
return FALSE;
- // add FACEs to temp es1
+ /* add FACEs to temp es1 */
return FALSE;
- // intersect temp_es1 with edges meshset
- // temp_ms1 entityset is altered
+ /* intersect temp_es1 with edges meshset */
+ /* temp_ms1 entityset is altered */
iMesh_intersect(mesh, temp_es1, es_array[iBase_EDGE], &temp_es2, &result);
printf("Failed to intersect in entity_sets_test.\n");
@@ -740,11 +782,11 @@
- //-------------Unite--------------
+ /*-------------Unite-------------- */
- // get all regions
- iBase_EntityHandle *regions = NULL;
- int regions_alloc = 0, regions_size;
+ /* get all regions */
+ regions = NULL;
+ regions_alloc = 0;
iMesh_createEntSet(mesh, is_list, &temp_es2, &result);
@@ -761,22 +803,21 @@
return FALSE;
- // add REGIONs to temp es2
+ /* add REGIONs to temp es2 */
iMesh_addEntArrToSet(mesh, regions, regions_size, &temp_es2, &result);
printf("Failed to add region entities in entity_sets_test.\n");
return FALSE;
- // unite temp_es1 and temp_es2
+ /* unite temp_es1 and temp_es2 */
iMesh_unite(mesh, temp_es1, temp_es2, &temp_es3, &result);
printf("Failed to unite in entity_sets_test.\n");
return FALSE;
- // perform the check
- int num_regions;
+ /* perform the check */
iMesh_getNumOfType(mesh, temp_es3, iBase_REGION, &num_regions, &result);
printf("Failed to get number of region entities by type in entity_sets_test.\n");
@@ -790,10 +831,9 @@
if (!check_esets(mesh, n_whole_mesh + num_type + 4)) return FALSE;
- //--------Test parent/child stuff in entiysets-----------
+ /*--------Test parent/child stuff in entiysets----------- */
- // Add 2 meshsets as children to another
- iBase_EntitySetHandle parent_child;
+ /* Add 2 meshsets as children to another */
iMesh_createEntSet(mesh, is_list, &parent_child, &result);
printf("Problem creating entityset in entity_sets_test.\n");
@@ -806,9 +846,9 @@
return FALSE;
- // check if parent is really added
- iBase_EntityHandle *parents = NULL;
- int parents_alloc = 0, parents_size;
+ /* check if parent is really added */
+ parents = NULL;
+ parents_alloc = 0;
iMesh_getPrnts(mesh, parent_child, 0,
&parents, &parents_alloc, &parents_size, &result);
@@ -821,8 +861,7 @@
return FALSE;
- // get the number of child entitysets
- int temp_numb;
+ /* get the number of child entitysets */
iMesh_getNumChld(mesh, es_array[iBase_VERTEX], 0, &temp_numb, &result);
printf("Problem getting number of children in entity_sets_test.\n");
@@ -834,8 +873,8 @@
return FALSE;
- // parent_child and es_array[iBase_VERTEX] should be related
- int is_child = 0;
+ /* parent_child and es_array[iBase_VERTEX] should be related */
+ is_child = 0;
iMesh_isChildOf(mesh, es_array[iBase_VERTEX], parent_child, &is_child, &result);
printf("Problem checking relation in entity_sets_test.\n");
@@ -846,7 +885,7 @@
return FALSE;
- // es_array[iBase_FACE] and es_array[iBase_REGION] are not related
+ /* es_array[iBase_FACE] and es_array[iBase_REGION] are not related */
is_child = FALSE;
iMesh_isChildOf(mesh, es_array[iBase_FACE], es_array[iBase_REGION], &is_child, &result);
@@ -860,11 +899,11 @@
if (!check_esets(mesh, n_whole_mesh + num_type + 5)) return FALSE;
- //--------test modify and query functions-----------------------------
+ /*--------test modify and query functions----------------------------- */
- // get all entity sets in super set
- iBase_EntitySetHandle *es_array1 = NULL;
- int es_array1_alloc = 0, es_array1_size;
+ /* get all entity sets in super set */
+ es_array1 = NULL;
+ es_array1_alloc = 0;
iMesh_getEntSets(mesh, super_set, 0,
&es_array1, &es_array1_alloc, &es_array1_size, &result);
@@ -872,24 +911,22 @@
return FALSE;
- int num_super;
- // get the number of entity sets in super set
+ /* get the number of entity sets in super set */
iMesh_getNumEntSets(mesh, super_set, 0, &num_super, &result);
printf("Problem to get the number of all entity sets in super set.\n");
return FALSE;
- // the number of entity sets in super set should be same
+ /* the number of entity sets in super set should be same */
if (num_super != es_array1_size) {
printf("the number of entity sets in super set should be same.\n");
return FALSE;
- // get all entities in super set
- iBase_EntityHandle *all_entities = NULL;
- int all_entities_alloc = 0, all_entities_size;
+ /* get all entities in super set */
+ all_entities = NULL;
+ all_entities_alloc = 0;
iMesh_getEntities(mesh, super_set, iBase_ALL_TYPES,
&all_entities, &all_entities_alloc, &all_entities_size, &result);
@@ -898,23 +935,21 @@
return FALSE;
- // compare the number of all entities in super set
- // NOTE: TEST COMMENTED OUT UNTIL RESOLUTION OF WHETHER GETENTITIES
- // SHOULD GET A NUM_HOPS ARGUMENT
- // if (num_all_entities_super != all_entities_size) {
- // printf("number of all entities in super set should be same.\n");
- // return FALSE;
+ /* compare the number of all entities in super set */
+ /* NOTE: TEST COMMENTED OUT UNTIL RESOLUTION OF WHETHER GETENTITIES */
+ /* SHOULD GET A NUM_HOPS ARGUMENT */
+ /* if (num_all_entities_super != all_entities_size) { */
+ /* printf("number of all entities in super set should be same.\n"); */
+ /* return FALSE; */
- // test add, remove and get all entitiy sets using super set
- // check GetAllEntitySets works recursively and dosen't return
- // multi sets
- int k;
+ /* test add, remove and get all entitiy sets using super set */
+ /* check GetAllEntitySets works recursively and dosen't return */
+ /* multi sets */
for (k = 0; k < num_super; k++) {
- // add entity sets of super set to each entity set of super set
- // make multiple child super sets
+ /* add entity sets of super set to each entity set of super set */
+ /* make multiple child super sets */
iBase_EntitySetHandle es_k = es_array1[k];
- int l;
for (l = 0; l < es_array1_size; l++) {
iMesh_addEntSet(mesh, es_array1[l], &es_k, &result);
@@ -923,14 +958,14 @@
- // add super set to each entity set
+ /* add super set to each entity set */
iMesh_addEntSet(mesh, super_set, &es_k, &result);
printf("Problem to add super set to entitysets.\n");
return FALSE;
- // add one entity sets multiple times
+ /* add one entity sets multiple times */
for (l = 0; l < 3; l++) {
iMesh_addEntSet(mesh, temp_es1, &es_k, &result);
@@ -940,12 +975,11 @@
- // get adjacent face of hexes
- int *face_offsets = NULL, *face_in_sets = NULL;
- int face_offsets_alloc = 0, face_in_sets_alloc = 0,
- face_offsets_size, face_in_sets_size;
+ /* get adjacent face of hexes */
+ adj_faces = NULL;
+ face_offsets = NULL; face_in_sets = NULL;
+ face_offsets_alloc = 0; face_in_sets_alloc = 0;
iMesh_getAdjEntities(mesh, root_set, iBase_ALL_TYPES,
iMesh_HEXAHEDRON, iBase_FACE,
@@ -957,9 +991,9 @@
return FALSE;
- // get all hexes and get faces of that hexes
- iBase_EntityHandle *hexes = NULL;
- int hexes_alloc = 0, hexes_size;
+ /* get all hexes and get faces of that hexes */
+ hexes = NULL;
+ hexes_alloc = 0;
iMesh_HEXAHEDRON, &hexes, &hexes_alloc, &hexes_size, &result);
@@ -968,7 +1002,6 @@
return FALSE;
- iBase_EntitySetHandle hex_set;
iMesh_createEntSet(mesh, FALSE, &hex_set, &result);
@@ -982,12 +1015,11 @@
return FALSE;
- // get adjacent faces of all hexes
- iBase_EntityHandle *adj_faces1 = NULL;
- int adj_faces1_alloc = 0, adj_faces1_size;
- int *face_offsets1 = NULL, *face_in_sets1 = NULL;
- int face_offsets1_alloc = 0, face_in_sets1_alloc = 0,
- face_offsets1_size, face_in_sets1_size;
+ /* get adjacent faces of all hexes */
+ adj_faces1 = NULL;
+ adj_faces1_alloc = 0;
+ face_offsets1 = NULL; face_in_sets1 = NULL;
+ face_offsets1_alloc = 0; face_in_sets1_alloc = 0;
iMesh_getAdjEntities(mesh, hex_set,
iBase_ALL_TYPES,
@@ -1000,7 +1032,7 @@
return FALSE;
- // compare number of faces
+ /* compare number of faces */
if (adj_faces_size != adj_faces1_size ||
face_offsets_size != face_offsets1_size ||
face_in_sets_size != face_in_sets1_size)
@@ -1054,13 +1086,13 @@
int entity_sets_test(iMesh_Instance mesh)
- int iter_num = 0;
- // check
+ int iter_num = 0, result;
+ /* check */
int i;
for (i = 0; i < 2; i++) {
iter_num++;
- int result = entity_sets_subtest(mesh, i, iter_num);
+ result = entity_sets_subtest(mesh, i, iter_num);
if (!result)
return result;
@@ -1075,8 +1107,18 @@
int vertex_coordinates_test(iMesh_Instance mesh)
+ double *all_coords = NULL;
+ int all_coords_alloc = 0, all_coords_size;
+ int *in_entity_set = NULL;
+ int in_entity_set_alloc = 0, in_entity_set_size;
+ int not_in_set = 0;
+ int i;
+ iBase_EntityHandle *verts = NULL;
+ int verts_alloc = 0, verts_size;
+ double *vert_coords = NULL;
+ int vert_coords_alloc = 0, vert_coords_size, num_bad;
- // check storage order
+ /* check storage order */
int result;
int this_order = iBase_UNDETERMINED;
iMesh_getDfltStorage(mesh, &this_order, &result);
@@ -1085,11 +1127,11 @@
return FALSE;
- // get the coordinates in one array
- double *all_coords = NULL;
- int all_coords_alloc = 0, all_coords_size;
- int *in_entity_set = NULL;
- int in_entity_set_alloc = 0, in_entity_set_size;
+ /* get the coordinates in one array */
+ all_coords = NULL;
+ all_coords_alloc = 0;
+ in_entity_set = NULL;
+ in_entity_set_alloc = 0;
iMesh_getAllVtxCoords(mesh, root_set,
&all_coords, &all_coords_alloc, &all_coords_size,
@@ -1100,9 +1142,8 @@
return FALSE;
- // make sure all vertices marked as being in the model
- int not_in_set = 0;
- int i;
+ /* make sure all vertices marked as being in the model */
+ not_in_set = 0;
for (i = 0; i < in_entity_set_size; i++)
if (1 != in_entity_set[i]) not_in_set++;
@@ -1112,10 +1153,10 @@
return FALSE;
- // now get the vertex coordinates from a vertex array
- // need to get the vertices in the model
- iBase_EntityHandle *verts = NULL;
- int verts_alloc = 0, verts_size;
+ /* now get the vertex coordinates from a vertex array */
+ /* need to get the vertices in the model */
+ verts = NULL;
+ verts_alloc = 0;
iMesh_getEntities(mesh, root_set, iBase_VERTEX,
iMesh_POINT, &verts, &verts_alloc, &verts_size, &result);
@@ -1123,9 +1164,9 @@
return FALSE;
- double *vert_coords = NULL;
- int vert_coords_alloc = 0, vert_coords_size;
+ vert_coords = NULL;
+ vert_coords_alloc = 0;
iMesh_getVtxArrCoords(mesh, verts, verts_size, &this_order,
&vert_coords, &vert_coords_alloc, &vert_coords_size, &result);
@@ -1134,16 +1175,16 @@
return FALSE;
- // two lists should be the same length
+ /* two lists should be the same length */
if (all_coords_size != vert_coords_size) {
printf("vertex_coordinates_test: vertex arrays different lengths.\n");
return FALSE;
- // compare the two lists, they should be the same
- int num_bad = 0;
+ /* compare the two lists, they should be the same */
+ num_bad = 0;
- // can produce an error by rounding off coordinates
+ /* can produce an error by rounding off coordinates */
for (i = 0; i < all_coords_size; i++)
if (all_coords[i] != vert_coords[i]) num_bad++;
@@ -1158,7 +1199,7 @@
free(verts);
free(vert_coords);
- // if we get here, this test was successful
+ /* if we get here, this test was successful */
return TRUE;
@@ -1169,7 +1210,12 @@
int tag_info_test(iMesh_Instance mesh)
- // Create a tag
+ char dum_name[120];
+ int dum_name_size = 120;
+ int dum_size;
+ int error = FALSE;
+ iBase_TagHandle dum_handle;
+ /* Create a tag */
int result;
iBase_TagHandle tag_handle = NULL;
const char *tag_name = "int_tag";
@@ -1181,9 +1227,7 @@
return FALSE;
- // check tag info functions
- char dum_name[120];
- int dum_name_size = 120;
+ /* check tag info functions */
iMesh_getTagName(mesh, tag_handle, dum_name, &result, dum_name_size);
printf("Couldn't get name of tag just created.\n");
@@ -1194,7 +1238,6 @@
return FALSE;
- int dum_size;
iMesh_getTagSizeBytes(mesh, tag_handle, &dum_size, &result);
printf("Couldn't get size of tag just created.\n");
@@ -1205,7 +1248,6 @@
return FALSE;
- iBase_TagHandle dum_handle;
iMesh_getTagHandle(mesh, tag_name, &dum_handle, &result, tag_name_size);
printf("Couldn't get handle of tag just created.\n");
@@ -1216,16 +1258,15 @@
return FALSE;
- // test non-forced version of tagDelete; forced version tested later,
- // when we have entities around
+ /* test non-forced version of tagDelete; forced version tested later, */
+ /* when we have entities around */
iMesh_destroyTag(mesh, tag_handle, FALSE, &result);
printf("Couldn't delete tag just created.\n");
return FALSE;
- // look for that tag, to make sure it got deleted
- int error = FALSE;
+ /* look for that tag, to make sure it got deleted */
iMesh_getTagHandle(mesh, tag_name, &tag_handle, &result, tag_name_size);
error = TRUE;
@@ -1243,8 +1284,13 @@
iBase_TagHandle *int_tag)
int result;
+ iBase_EntityHandle dum_vert = verts[0];
+ int dum_val = 11, dum_val2;
+ void *dum_val2_ptr = &dum_val2;
+ int dum_val2_alloc = sizeof(int), dum_val2_size;
- // create a tag
+ /* create a tag */
int tag_name_size = 8;
iMesh_createTag(mesh, tag_name, 1, iBase_INTEGER,
@@ -1254,12 +1300,7 @@
return FALSE;
- // put a value in the first vertex and retrieve
- iBase_EntityHandle dum_vert = verts[0];
- int dum_val = 11, dum_val2;
- void *dum_val2_ptr = &dum_val2;
- int dum_val2_alloc = sizeof(int), dum_val2_size;
+ /* put a value in the first vertex and retrieve */
iMesh_setArrData(mesh, &dum_vert, 1, *int_tag,
(const char*)(&dum_val), sizeof(iBase_EntityHandle), &result);
@@ -1280,7 +1321,7 @@
return FALSE;
- // put a value in the last vertex and retrieve
+ /* put a value in the last vertex and retrieve */
dum_val = 12;
@@ -1303,7 +1344,7 @@
return FALSE;
- // ok, the int tag test worked
+ /* ok, the int tag test worked */
return TRUE;
@@ -1313,7 +1354,12 @@
int result;
- // create a tag
+ double dum_val = 1.0e6, dum_val2;
+ int dum_val2_alloc = sizeof(double), dum_val2_size;
const char *tag_name = "double_tag";
int tag_name_size = 11;
iMesh_createTag(mesh, tag_name, 1, iBase_DOUBLE,
@@ -1323,12 +1369,7 @@
return FALSE;
- double dum_val = 1.0e6, dum_val2;
- int dum_val2_alloc = sizeof(double), dum_val2_size;
iMesh_setArrData(mesh, &dum_vert, 1, *double_tag,
(char*)(&dum_val), sizeof(double), &result);
@@ -1349,7 +1390,7 @@
return FALSE;
dum_val = 2.0e9;
@@ -1371,23 +1412,27 @@
return FALSE;
- // ok, the double tag test worked
+ /* ok, the double tag test worked */
return TRUE;
+ /* Add a struct Vertex Tag to the database */
+struct TagStruct {
+ double test_double;
+ int test_int1, test_int2;
int vertex_struct_tag_test(iMesh_Instance mesh,
iBase_EntityHandle *verts, int verts_size,
iBase_TagHandle *struct_tag)
int result;
+ struct TagStruct dum_struct = {3.0e12, 2, 3}, dum_struct2;
+ void *dum_struct2_ptr = &dum_struct2;
+ int dum_struct_alloc = sizeof(struct TagStruct), dum_struct_size;
- // Add a struct Vertex Tag to the database
- struct TagStruct {
- double test_double;
- int test_int1, test_int2;
- // create a tag
const char *tag_name = "struct_tag";
iMesh_createTag(mesh, tag_name, sizeof(struct TagStruct),
@@ -1397,13 +1442,9 @@
return FALSE;
- // careful setting the value, since tags are opaque
- struct TagStruct dum_struct = {3.0e12, 2, 3}, dum_struct2;
- void *dum_struct2_ptr = &dum_struct2;
- int dum_struct_alloc = sizeof(struct TagStruct), dum_struct_size;
+ /* careful setting the value, since tags are opaque */
iMesh_setArrData(mesh, &dum_vert, 1, *struct_tag,
(const char*) &dum_struct, sizeof(struct TagStruct), &result);
@@ -1429,7 +1470,7 @@
return FALSE;
return TRUE;
@@ -1437,10 +1478,11 @@
iBase_EntityHandle *verts, int verts_size)
int result;
+ int delete_err = FALSE;
- // test forced, unforced deletion of tags from entities
+ /* test forced, unforced deletion of tags from entities */
- // test getAlliBase_TagHandles for first entity
+ /* test getAlliBase_TagHandles for first entity */
iBase_TagHandle *all_tags = NULL;
iBase_EntityHandle dum_entity = verts[0];
int all_tags_alloc = 0, all_tags_size;
@@ -1457,7 +1499,6 @@
return FALSE;
- int delete_err = FALSE;
iMesh_destroyTag(mesh, all_tags[1], FALSE, &result);
delete_err = TRUE;
@@ -1475,7 +1516,7 @@
free(all_tags);
- // ok, we're done
+ /* ok, we're done */
return TRUE;
@@ -1483,9 +1524,12 @@
int result;
+ iBase_TagHandle int_tag, double_tag, struct_tag;
+ int int_err, double_err, struct_err, tag_delete_err;
int info_err = tag_info_test(mesh);
- // get all the vertices
+ /* get all the vertices */
@@ -1494,21 +1538,19 @@
printf("entitysetGetEntities failed in vertex_tag_test.\n");
return FALSE;
- iBase_TagHandle int_tag, double_tag, struct_tag;
- // vertex int tag
- int int_err = vertex_int_tag_test(mesh, verts, verts_size, &int_tag);
+ /* vertex int tag */
+ int_err = vertex_int_tag_test(mesh, verts, verts_size, &int_tag);
- // vertex double tag
- int double_err = vertex_double_tag_test(mesh, verts, verts_size,
+ /* vertex double tag */
+ double_err = vertex_double_tag_test(mesh, verts, verts_size,
&double_tag);
- // vertex struct tag
- int struct_err = vertex_struct_tag_test(mesh, verts, verts_size,
+ /* vertex struct tag */
+ struct_err = vertex_struct_tag_test(mesh, verts, verts_size,
&struct_tag);
- int tag_delete_err = vertex_tag_delete_test(mesh, verts, verts_size);
+ tag_delete_err = vertex_tag_delete_test(mesh, verts, verts_size);
free(verts);
@@ -1521,8 +1563,11 @@
int result;
- // create a tag
const char *tag_name = "set_int_tag";
int_tag, &result, 12);
@@ -1531,10 +1576,7 @@
return FALSE;
- // put a value in the first set and retrieve
+ /* put a value in the first set and retrieve */
iMesh_setEntSetData(mesh, sets[0], *int_tag,
(char*)(&dum_val), sizeof(int), &result);
@@ -1556,7 +1598,7 @@
return FALSE;
- // put a value in the last faces and retrieve
+ /* put a value in the last faces and retrieve */
dum_val = 12;
iMesh_setEntSetData(mesh, sets[sets_size-1], *int_tag,
@@ -1577,7 +1619,7 @@
return FALSE;
return TRUE;
@@ -1586,8 +1628,11 @@
iBase_TagHandle *double_tag)
int result;
- // create a tag
const char *tag_name = "set_double_tag";
double_tag, &result, 15);
@@ -1596,10 +1641,7 @@
return FALSE;
iMesh_setEntSetData(mesh, sets[0], *double_tag,
@@ -1621,7 +1663,7 @@
return FALSE;
dum_val = 2.0e9;
iMesh_setEntSetData(mesh, sets[sets_size-1], *double_tag,
@@ -1642,7 +1684,7 @@
return FALSE;
return TRUE;
@@ -1651,14 +1693,11 @@
int result;
- // Add a struct Tag to the database
- // create a tag
const char *tag_name = "set_struct_tag";
iMesh_createTag(mesh, tag_name, sizeof(struct TagStruct), iBase_BYTES,
struct_tag, &result, 11);
@@ -1667,12 +1706,9 @@
return FALSE;
iMesh_setEntSetData(mesh, root_set, *struct_tag,
@@ -1698,18 +1734,19 @@
return FALSE;
return TRUE;
int entityset_tag_delete_test(iMesh_Instance mesh,
iBase_EntityHandle *sets, int sets_size)
int result;
iBase_EntityHandle dum_entity = sets[0];
@@ -1726,7 +1763,6 @@
return FALSE;
delete_err = TRUE;
@@ -1744,7 +1780,7 @@
free(all_tags);
- // ok, we're done
return TRUE;
@@ -1756,8 +1792,10 @@
int entityset_tag_test(iMesh_Instance mesh)
int result;
+ int int_success, double_success, struct_success, tag_delete_success;
- // get the sets
+ /* get the sets */
iBase_EntitySetHandle *esets = NULL;
int esets_alloc = 0, esets_size;
iMesh_getEntSets(mesh, root_set, 1, &esets, &esets_alloc, &esets_size, &result);
@@ -1766,21 +1804,20 @@
return FALSE;
- // entityset int tag
- int int_success = entityset_int_tag_test(mesh, esets, esets_size,
+ /* entityset int tag */
+ int_success = entityset_int_tag_test(mesh, esets, esets_size,
&int_tag);
- // entityeset double tag
- int double_success = entityset_double_tag_test(mesh, esets, esets_size,
+ /* entityeset double tag */
+ double_success = entityset_double_tag_test(mesh, esets, esets_size,
&double_tag);
- // entityset struct tag
- int struct_success = entityset_struct_tag_test(mesh, esets, esets_size,
+ /* entityset struct tag */
+ struct_success = entityset_struct_tag_test(mesh, esets, esets_size,
&struct_tag);
- int tag_delete_success = entityset_tag_delete_test(mesh, esets, esets_size);
+ tag_delete_success = entityset_tag_delete_test(mesh, esets, esets_size);
free(esets);
@@ -1792,8 +1829,11 @@
int result;
- // create a tag
const char *tag_name = "mesh_int_tag";
@@ -1802,10 +1842,7 @@
return FALSE;
iMesh_setEntSetData(mesh, root_set, *int_tag,
@@ -1827,7 +1864,7 @@
return FALSE;
dum_val = 12;
@@ -1848,7 +1885,7 @@
return FALSE;
return TRUE;
@@ -1856,8 +1893,11 @@
int result;
- // create a tag
const char *tag_name = "mesh_double_tag";
@@ -1866,10 +1906,7 @@
return FALSE;
iMesh_setEntSetData(mesh, root_set, *double_tag,
@@ -1891,7 +1928,7 @@
return FALSE;
dum_val = 2.0e9;
@@ -1912,7 +1949,7 @@
return FALSE;
return TRUE;
@@ -1920,14 +1957,11 @@
int result;
- // create a tag
const char *tag_name = "mesh_struct_tag";
@@ -1936,12 +1970,9 @@
return FALSE;
@@ -1967,17 +1998,18 @@
return FALSE;
return TRUE;
int mesh_tag_delete_test(iMesh_Instance mesh)
int result;
iMesh_getAllEntSetTags(mesh, root_set, &all_tags, &all_tags_alloc,
@@ -1993,7 +2025,6 @@
return FALSE;
delete_err = TRUE;
@@ -2011,7 +2042,7 @@
free(all_tags);
- // ok, we're done
return TRUE;
@@ -2024,13 +2055,13 @@
int int_success = mesh_int_tag_test(mesh, &int_tag);
int double_success = mesh_double_tag_test(mesh, &double_tag);
int struct_success = mesh_struct_tag_test(mesh, &struct_tag);
int tag_delete_success = mesh_tag_delete_test(mesh);
@@ -2041,8 +2072,14 @@
int main( int argc, char *argv[] )
- // Check command line arg
+ /* Check command line arg */
const char *filename;
+ int number_tests = 0;
+ int number_tests_successful = 0;
+ int number_tests_not_implemented = 0;
+ int number_tests_failed = 0;
+ int result;
+ iMesh_Instance mesh = NULL;
if (argc == 2) {
filename = argv[1];
@@ -2055,14 +2092,8 @@
filename = DEFAULT_INPUT_FILE;
- int number_tests = 0;
- int number_tests_successful = 0;
- int number_tests_not_implemented = 0;
- int number_tests_failed = 0;
- // initialize the Mesh
- int result;
- iMesh_Instance mesh = NULL;
+ /* initialize the Mesh */
iMesh_newMesh(NULL, &mesh, &result, 0);
printf("Failed to create a mesh instance.\n");
@@ -2074,10 +2105,10 @@
return 1;
- // Print out Header information
+ /* Print out Header information */
printf("\n\nTSTT TEST PROGRAM:\n\n");
- // load_mesh test
+ /* load_mesh test */
printf(" load_mesh: ");
result = load_mesh_test(filename, mesh);
handle_error_code(result, &number_tests_failed,
@@ -2086,7 +2117,7 @@
number_tests++;
printf("\n");
- // topology_adjacency_test
+ /* topology_adjacency_test */
printf(" topology_adjacency_test: ");
result = topology_adjacency_test(mesh);
@@ -2095,7 +2126,7 @@
number_tests++;
printf("\n");
- // entity connectivity test
+ /* entity connectivity test */
printf(" entity_connectivity_test: ");
result = entity_connectivity_test(mesh);
@@ -2104,7 +2135,7 @@
number_tests++;
printf("\n");
- // vertex_coordinates_test
+ /* vertex_coordinates_test */
printf(" vertex_coordinates_test: ");
result = vertex_coordinates_test(mesh);
@@ -2113,7 +2144,7 @@
number_tests++;
printf("\n");
- // topology dimension test
+ /* topology dimension test */
printf(" topology_dimension_test: ");
result = topology_dimension_test(mesh);
@@ -2122,7 +2153,7 @@
number_tests++;
printf("\n");
- // entity sets test
+ /* entity sets test */
printf(" entity_sets_test: ");
result = entity_sets_test(mesh);
@@ -2131,7 +2162,7 @@
number_tests++;
printf("\n");
- // vertex tag test
+ /* vertex tag test */
printf(" vertex_tag_test: ");
result = vertex_tag_test(mesh);
@@ -2140,7 +2171,7 @@
number_tests++;
printf("\n");
- // entityset tag test
+ /* entityset tag test */
printf(" entityset_tag_test: ");
result = entityset_tag_test(mesh);
@@ -2149,7 +2180,7 @@
number_tests++;
printf("\n");
- // mesh tag test
+ /* mesh tag test */
printf(" mesh_tag_test: ");
result = mesh_tag_test(mesh);
@@ -2158,7 +2189,7 @@
number_tests++;
printf("\n");
- // summary
+ /* summary */
printf("\nTSTT TEST SUMMARY: \n");
@@ -2168,7 +2199,7 @@
printf(" Number Failed: %d\n", number_tests_failed);
printf("\n\n\n");
- // delete the mesh
+ /* delete the mesh */
iMesh_dtor(mesh, &result);
printf("Failed to destruct the mesh instance.\n");
