[MOAB-dev] r2561 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jan 20 16:43:42 CST 2009
Author: kraftche
Date: 2009-01-20 16:43:42 -0600 (Tue, 20 Jan 2009)
New Revision: 2561
Modified:
   MOAB/trunk/MBReadUtilIface.hpp
   MOAB/trunk/MBWriteUtilIface.hpp
   MOAB/trunk/Makefile.am
   MOAB/trunk/ReadNCDF.cpp
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/WriteNCDF.cpp
Log:
use ExodusII ordering map to re-order connectivity for Cub and ExodusII files
Modified: MOAB/trunk/MBReadUtilIface.hpp
--- MOAB/trunk/MBReadUtilIface.hpp	2009-01-20 22:42:43 UTC (rev 2560)
+++ MOAB/trunk/MBReadUtilIface.hpp	2009-01-20 22:43:42 UTC (rev 2561)
@@ -110,6 +110,23 @@
     ) = 0;
+  /**\brief Re-order incomming element connectivity
+   * Permute the connectivity of each element such that the node
+   * order is that of MBCN rather than the target file format.
+   *\param order The permutation to use.  Must be an array of 'node_per_elem'
+   *             integers and be a permutation of the values [0..node_per_elem-1].
+   *             Such that for a single element:
+   *             mbcn_conn[order[i]] == target_conn[i]
+   *\param conn  The connectivty array to re-order
+   *\param num_elem  The number of elements in the connectivity array
+   *\param node_per_elem The number of nodes in each element's connectivity list.
+  static inline
+  void reorder( const int* order, MBEntityHandle* conn,
+                int num_elem, int node_per_elem );
     //! if an error occured when reading the mesh, report it to MOAB
     //! it makes sense to have this as long as MBInterface has a load_mesh function
   virtual MBErrorCode report_error( const std::string& error ) = 0;
@@ -131,6 +148,20 @@
                                            MBEntityType &etype) = 0;
+inline
+void MBReadUtilIface::reorder( const int* order, MBEntityHandle* conn,
+  std::vector<MBEntityHandle> elem(node_per_elem);
+  MBEntityHandle* const end = conn + num_elem*node_per_elem;
+  while (conn != end) {
+    std::copy( conn, conn+node_per_elem, elem.begin() );
+    for (int j = 0; j < node_per_elem; ++j)
+      conn[order[j]] = elem[j];
+    conn += node_per_elem;
 #endif
Modified: MOAB/trunk/MBWriteUtilIface.hpp
--- MOAB/trunk/MBWriteUtilIface.hpp	2009-01-20 22:42:43 UTC (rev 2560)
+++ MOAB/trunk/MBWriteUtilIface.hpp	2009-01-20 22:43:42 UTC (rev 2561)
@@ -283,6 +283,22 @@
                                const MBEntityHandle*& adj_array,
                                int& num_adj ) = 0;
+  /**\brief Re-order outgoing element connectivity
+   * order is that of the target file format rather than that of MBCN.
+   *             target_conn[i] == mbcn_conn[order[i]]
+  template <typename T> static inline
+  void reorder( const int* order, T* conn, int num_elem, int node_per_elem );
     //! if an error occured when reading the mesh, report it to MB
     //! it makes sense to have this as long as MBInterface has a write_mesh function
     //! \return status Return status
@@ -298,6 +314,20 @@
+template <typename T> inline
+void MBWriteUtilIface::reorder( const int* order, T* conn,
+  std::vector<T> elem(node_per_elem);
+  T* const end = conn + num_elem*node_per_elem;
+    for (int j = 0; j < node_per_elem; ++j, ++conn)
+      *conn = elem[order[j]];
 #endif
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-01-20 22:42:43 UTC (rev 2560)
+++ MOAB/trunk/Makefile.am	2009-01-20 22:43:42 UTC (rev 2561)
@@ -34,6 +34,7 @@
 	tag_test \
 	mesh_set_test \
 	cub_file_test \
+	exodus_test \
         mbcn_test
 #                 merge_test \         # input files no longer exist?
 #                 test_tag_server \    # fails
@@ -99,6 +100,7 @@
   ElementSequence.hpp \
   EntitySequence.cpp \
   EntitySequence.hpp \
+  exodus_order.hpp \
   ExoIIUtil.cpp \
   ExoIIUtil.hpp \
   FileOptions.cpp \
@@ -148,6 +150,7 @@
   MeshSetSequence.cpp \
   MeshSetSequence.hpp \
   MeshTopoUtil.cpp \
+  patran_order.h \
   PolyElementSeq.cpp \
   PolyElementSeq.hpp \
   RangeMap.hpp \
@@ -347,6 +350,10 @@
 cub_file_test_LDADD = $(top_builddir)/libMOAB.la
 cub_file_test_DEPENDENCIES = $(tag_test_LDADD)
+exodus_test_SOURCES = TestUtil.hpp exodus_test.cc
+exodus_test_LDADD = $(top_builddir)/libMOAB.la
+exodus_test_DEPENDENCIES = $(tag_test_LDADD)
 mbcn_test_SOURCES = MBCN.hpp MBCN.cpp mbcn_test.cc
 mbcn_test_CPPFLAGS = -DSRCDIR=$(srcdir)  # define anything to work around build issue
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp	2009-01-20 22:42:43 UTC (rev 2560)
+++ MOAB/trunk/ReadNCDF.cpp	2009-01-20 22:43:42 UTC (rev 2561)
@@ -33,6 +33,7 @@
 #include "MBTagConventions.hpp"
 #include "MBInternals.hpp"
 #include "MBReadUtilIface.hpp"
+#include "exodus_order.h"
 #define INS_ID(stringvar, prefix, id) \
           sprintf(stringvar, prefix, id)
@@ -789,6 +790,7 @@
   return MB_SUCCESS;
 MBErrorCode ReadNCDF::read_elements()
     // read in elements
@@ -860,12 +862,13 @@
     int verts_per_element = ExoIIUtil::VerticesPerElement[(*this_it).elemType];
     int number_nodes = (*this_it).numElements*verts_per_element;
+    const MBEntityType mb_type = ExoIIUtil::ExoIIElementMBEntity[(*this_it).elemType];
     // allocate an array to read in connectivity data
     readMeshIface->get_element_array(
         (*this_it).numElements,
         verts_per_element,
-        ExoIIUtil::ExoIIElementMBEntity[(*this_it).elemType],
+        mb_type,
         (*this_it).startExoId,
         (*this_it).startMBId,
         conn);
@@ -887,7 +890,12 @@
       if( mdbImpl->add_entities( ms_handle, new_range) != MB_SUCCESS )
         return MB_FAILURE;
+      int mid_nodes[4];
+      MBCN::HasMidNodes( mb_type, verts_per_element, mid_nodes );
+      if( mdbImpl->tag_set_data( mHasMidNodesTag, &ms_handle, 1, mid_nodes ) != MB_SUCCESS )
+        return MB_FAILURE;
     // just a check because the following code won't work if this case fails
     assert(sizeof(MBEntityHandle) >= sizeof(int));
@@ -905,9 +913,21 @@
       // Iterate backwards in case handles are larger than ints.
     for (int i = number_nodes - 1; i >= 0; --i)
+      if ((unsigned)tmp_ptr[i] >= nodesInLoadedBlocks.size()) {
+        readMeshIface->report_error( "Invalid node ID in block connectivity\n");
+        delete [] temp_string;
       nodesInLoadedBlocks[tmp_ptr[i]] = 1;
       conn[i] = static_cast<MBEntityHandle>(tmp_ptr[i]) + vertexOffset;
+    // Adjust connectivity order if necessary
+    const int* reorder = exodus_elem_order_map[mb_type][verts_per_element];
+    if (reorder)
+      MBReadUtilIface::reorder( reorder, conn, this_it->numElements, verts_per_element );
     readMeshIface->update_adjacencies((*this_it).startMBId, (*this_it).numElements,
                                       ExoIIUtil::VerticesPerElement[(*this_it).elemType], conn);
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2009-01-20 22:42:43 UTC (rev 2560)
+++ MOAB/trunk/Tqdcfr.cpp	2009-01-20 22:43:42 UTC (rev 2561)
@@ -23,6 +23,7 @@
 #include "FileOptions.hpp"
 #include "HigherOrderFactory.hpp"
 #ifdef USE_MPI
 #include "mpi.h"
@@ -87,38 +88,7 @@
 // index into the MOAB node order for the corresponding vertex
 // in the Cubit connectivity list.  Thus for a 27-node hex:
 // moab_conn[ cub_hex27_order[i] ] = cubit_conn[ i ];
-const int cub_tet8_order[] = { 0, 1, 2, 3, 4, 5, 7, 6 };
-const int cub_tet14_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 13, 12 };
-const int cub_hex27_order[] = { 0, 1, 2, 3, 4, 5, 6, 7,
-                                8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19,
-                                26, 24, 25, 23, 21, 20, 22 };
-const int* cub_all_null_order[] = { 0, 0, 0, 0, 0, 0, 0, 0, 0,
-                                    0, 0, 0, 0, 0, 0, 0, 0, 0,
-                                    0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
-const int* cub_tet_order[] = { 0, 0, 0, 0, 0, 0, 0, 0,
-                               cub_tet8_order,
-                               0, 0, 0, 0, 0,
-                               cub_tet14_order,
-                               0, 0, 0, 0, 0, 0 };
-const int* cub_hex_order[] = { 0, 0, 0, 0, 0, 0, 0, 0, 0,
-                               cub_hex27_order };
-const int** cub_elem_order_map[] = {
-  cub_all_null_order, // MBVERTEX
-  cub_all_null_order, // MBEDGE
-  cub_all_null_order, // MBTRI
-  cub_all_null_order, // MBQUAD
-  cub_all_null_order, // MBPOLYGON
-  cub_tet_order,      // MBTET
-  cub_all_null_order, // MBPYRAMID
-  cub_all_null_order, // MBPRISM
-  cub_all_null_order, // MBKNIFE
-  cub_hex_order,      // MBHEX
-  cub_all_null_order, // MBPOLYHEDRON
+const int* const* const* const cub_elem_order_map = exodus_elem_order_map;
 std::string Tqdcfr::BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET";
 std::string Tqdcfr::BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET";
Modified: MOAB/trunk/WriteNCDF.cpp
--- MOAB/trunk/WriteNCDF.cpp	2009-01-20 22:42:43 UTC (rev 2560)
+++ MOAB/trunk/WriteNCDF.cpp	2009-01-20 22:43:42 UTC (rev 2561)
@@ -43,6 +43,7 @@
 #include "ExoIIUtil.hpp"
 #include "MBWriteUtilIface.hpp"
 const int TIME_STR_LEN = 11;
@@ -881,8 +882,6 @@
   return MB_SUCCESS;
 MBErrorCode WriteNCDF::write_elementblocks(std::vector<MaterialSetData> &block_data )
@@ -929,15 +928,28 @@
     if(result != MB_SUCCESS) {
       mWriteIface->report_error("Couldn't get element array to write from.");
+      delete [] connectivity;
       return result;
+    // if necessary, convert from EXODUS to MBCN node order
+    const MBEntityType elem_type = ExoIIUtil::ExoIIElementMBEntity[block.element_type];
+    assert( block.elements.all_of_type( elem_type ) );
+    const int* reorder = exodus_elem_order_map[elem_type][block.number_nodes_per_element];
+    if (reorder)
+      MBWriteUtilIface::reorder( reorder, connectivity,
+                                 block.number_elements,
+                                 block.number_nodes_per_element );
     exodus_id += num_elem;
     char wname[80];
     INS_ID(wname, "connect%d", i+1);
     NcVar *conn = ncFile->get_var(wname);
-    if (NULL == conn) return MB_FAILURE;
+    if (NULL == conn) {
     NcBool err = conn->put(connectivity, num_elem, num_nodes_per_elem);
     if(!err)
