[MOAB-dev] r2560 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jan 20 16:42:43 CST 2009
Author: kraftche
Date: 2009-01-20 16:42:43 -0600 (Tue, 20 Jan 2009)
New Revision: 2560
Added:
   MOAB/trunk/exodus_order.h
   MOAB/trunk/patran_order.h
Log:
add maps for converting from MBCN to PATRAN or ExodusII node orderings
Added: MOAB/trunk/exodus_order.h
--- MOAB/trunk/exodus_order.h	                        (rev 0)
+++ MOAB/trunk/exodus_order.h	2009-01-20 22:42:43 UTC (rev 2560)
@@ -0,0 +1,46 @@
+#ifndef EXODUS_ORDER_HPP
+#define EXODUS_ORDER_HPP
+#include "patran_order.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Cubit writes ExodusII files with tet mid-face nodes in this order */
+static const int exodus_tet8_order[] = { 0, 1, 2, 3, 4, 5, 7, 6 };
+static const int exodus_tet9_order[] = { 0, 1, 2, 3, 8, 4, 5, 7, 6 };
+static const int exodus_tet14_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 13, 12 };
+static const int exodus_tet15_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 14, 10, 11, 13, 12 };
+static const int* exodus_tet_order[] = { 0, 0, 0, 0, 0, 0, 0, 0,
+                                  exodus_tet8_order,
+                                  exodus_tet9_order,
+                                  0, 0, 0, 0,
+                                  exodus_tet14_order,
+                                  exodus_tet15_order,
+                                  0, 0, 0, 0, 0, 0,
+                                  0, 0, 0, 0, 0, 0 };
+static const int* const* exodus_hex_order = patran_hex_order;
+static const int *const *const exodus_elem_order_map[] = {
+  patran_null_order, // MBVERTEX
+  patran_null_order, // MBEDGE
+  patran_null_order, // MBTRI
+  patran_null_order, // MBQUAD
+  patran_null_order, // MBPOLYGON
+  exodus_tet_order,  // MBTET
+  patran_null_order, // MBPYRAMID
+  patran_pri_order,  // MBPRISM
+  patran_null_order, // MBKNIFE
+  exodus_hex_order,  // MBHEX
+  patran_null_order, // MBPOLYHEDRON
+  patran_null_order
+#ifdef __cplusplus
+} // extern "C"
+#endif
+#endif
Added: MOAB/trunk/patran_order.h
--- MOAB/trunk/patran_order.h	                        (rev 0)
+++ MOAB/trunk/patran_order.h	2009-01-20 22:42:43 UTC (rev 2560)
@@ -0,0 +1,111 @@
+#ifndef PATRAN_ORDER_H
+#define PATRAN_ORDER_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Define maps that, when indexed by the PATRAN connectivity index return
+   the corresponding index in the MOAB connectivity. */
+static const int patran_tet8_order[] = { 0, 1, 2, 3, 7, 5, 6, 4 };
+static const int patran_tet9_order[] = { 0, 1, 2, 3, 8, 7, 5, 6, 4 };
+static const int patran_tet14_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 13, 11, 12, 10 };
+static const int patran_tet15_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 14, 13, 11, 12, 10 };
+static const int patran_hex14_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 12, 13, 11, 9, 8, 10 };
+static const int patran_hex15_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 14, 12, 13, 11, 9, 8, 10 };
+static const int patran_hex26_order[] = { 0, 1, 2, 3, 4, 5, 6, 7,
+                                   8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19,
+                                   24, 25, 23, 21, 20, 22 };
+static const int patran_hex27_order[] = { 0, 1, 2, 3, 4, 5, 6, 7,
+                                   26, 24, 25, 23, 21, 20, 22 };
+static const int patran_pri11_order[] = { 0, 1, 2, 3, 4, 5, 9, 10, 7, 8, 6 };
+static const int patran_pri12_order[] = { 0, 1, 2, 3, 4, 5, 11, 9, 10, 7, 8, 6 };
+static const int patran_pri20_order[] = { 0, 1, 2, 3, 4, 5,
+                                   6, 7, 8, 9, 10, 11, 12, 13, 14,
+                                   18, 19, 16, 17, 15 };
+static const int patran_pri21_order[] = { 0, 1, 2, 3, 4, 5,
+                                   20, 18, 19, 16, 17, 15 };
+/* Define list of maps for an element type, indexed by the number
+   of nodes in the element. Entries are NULL where MBCN connectivity
+   is the same as PATRAN (or the number of nodes is invalid.) */
+static const int* const patran_null_order[] = { 0, 0, 0, 0, 0, 0, 0, 0,
+                                         0, 0, 0, 0, 0, 0, 0, 0,
+                                         0 };
+static const int* const patran_tet_order[] = { 0, 0, 0, 0, 0, 0, 0, 0,
+                                        patran_tet8_order,
+                                        patran_tet9_order,
+                                        0, 0, 0, 0,
+                                        patran_tet14_order,
+                                        patran_tet15_order,
+                                        0 };
+static const int* const patran_hex_order[] = { 0, 0, 0, 0, 0, 0, 0, 0,
+                                        0, 0, 0, 0, 0, 0,
+                                        patran_hex14_order,
+                                        patran_hex15_order,
+                                        0, 0,
+                                        patran_hex26_order,
+                                        patran_hex27_order,
+                                        0, 0, 0, 0,
+                                        0 };
+static const int* const patran_pri_order[] = { 0, 0, 0, 0, 0, 0, 0, 0,
+                                        0, 0, 0,
+                                        patran_pri11_order,
+                                        patran_pri12_order,
+                                        patran_pri20_order,
+                                        patran_pri21_order,
+                                        0, 0,
+                                        0 };
+/* Define matrix of maps indexed by element topology (MBEntityType) and
+   number of nodes. Entries are NULL where MBCN connectivity
+static const int *const *const patran_elem_order_map[] = {
+  patran_tet_order,  // MBTET
+  patran_hex_order,  // MBHEX
+  patran_null_order
+#ifdef __cplusplus
+} // extern "C"
+#endif
+#endif
