[MOAB-dev] r2558 - in MOAB/trunk: . tools tools/gsets
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jan 16 16:45:15 CST 2009
Author: kraftche
Date: 2009-01-16 16:45:15 -0600 (Fri, 16 Jan 2009)
New Revision: 2558
Added:
   MOAB/trunk/tools/gsets/
   MOAB/trunk/tools/gsets/Makefile.am
   MOAB/trunk/tools/gsets/gsets.cc
Modified:
   MOAB/trunk/configure.in
   MOAB/trunk/tools/Makefile.am
Log:
add utility to output entity set relations as graphiz dot file
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in	2009-01-16 22:42:00 UTC (rev 2557)
+++ MOAB/trunk/configure.in	2009-01-16 22:45:15 UTC (rev 2558)
@@ -269,6 +269,7 @@
 MB_OPTIONAL_TOOL([mbsurfplot],   [yes])
 MB_OPTIONAL_TOOL([mbzoltan],     [no] )
 MB_OPTIONAL_TOOL([dagmc],        [yes])
+MB_OPTIONAL_TOOL([gsets],        [yes])
@@ -932,6 +933,7 @@
                  tools/surfplot/Makefile
                  tools/dagmc/Makefile
                  tools/dagmc/dagmc.make
+                 tools/gsets/Makefile
                  doc/Makefile
                  doxygen/Makefile
Modified: MOAB/trunk/tools/Makefile.am
--- MOAB/trunk/tools/Makefile.am	2009-01-16 22:42:00 UTC (rev 2557)
+++ MOAB/trunk/tools/Makefile.am	2009-01-16 22:45:15 UTC (rev 2558)
@@ -84,6 +84,12 @@
   imesh_DIR =
 endif
+if ENABLE_gsets
+  gsets_DIR = gsets
+else
+  gsets_DIR =
+endif
 SUBDIRS = $(imesh_DIR) \
 	  $(converter_DIR) \
           $(hexmodops_DIR) \
@@ -98,6 +104,7 @@
           $(tagprop_DIR) \
           $(spheredecomp_DIR) \
           $(mbsurfplot_DIR) \
-          $(dagmc_DIR)
+          $(dagmc_DIR) \
+          $(gsets_DIR)
 EXTRA_DIST = mbzoltan/README
Added: MOAB/trunk/tools/gsets/Makefile.am
--- MOAB/trunk/tools/gsets/Makefile.am	                        (rev 0)
+++ MOAB/trunk/tools/gsets/Makefile.am	2009-01-16 22:45:15 UTC (rev 2558)
@@ -0,0 +1,7 @@
+AUTOMAKE_OPTIONS = foreign
+DEFS = $(DEFINES)
+INCLUDES += -I$(top_srcdir) -I$(top_builddir)
+bin_PROGRAMS = mbgsets
+mbgsets_SOURCES = gsets.cc
+LDADD = $(top_builddir)/libMOAB.la
+mbgsets_DEPENDENCIES = $(top_builddir)/libMOAB.la
Added: MOAB/trunk/tools/gsets/gsets.cc
--- MOAB/trunk/tools/gsets/gsets.cc	                        (rev 0)
+++ MOAB/trunk/tools/gsets/gsets.cc	2009-01-16 22:45:15 UTC (rev 2558)
@@ -0,0 +1,284 @@
+#include <iostream>
+#include <stdlib.h>
+#include "MBRange.hpp"
+#include "MBCore.hpp"
+#include "MBTagConventions.hpp"
+#include "GeomTopoTool.hpp"
+MBTag geomTag = 0;
+MBTag blockTag = 0;
+MBTag sideTag = 0;
+MBTag nodeTag = 0;
+MBTag nameTag = 0;
+MBTag idTag = 0;
+bool printAnonSets = false;
+bool printSVSense = false;
+MBCore mb;
+GeomTopoTool geomTool(&mb);
+void usage( const char* name, bool brief = true ) {
+  std::ostream& str = brief ? std::cerr : std::cout;
+  if (!brief)
+   str << name << ": A tool to export entity set parent/child relations" << std::endl
+       << "      for use as input to graphviz" << std::endl;
+  str << "Usage: " << name << " [-a | [-g] [-m] [-n] ] <input_file>" << std::endl
+      << "       " << name << " -h" << std::endl;
+  if (brief)
+    exit(1);
+  str << "  The default behavior is equivalent to \"-gmn\"." << std::endl
+      << "  If any of the following options are used to specify which " << std::endl
+      << "  sets to output, then there are no defaults.  Only the " << std::endl
+      << "  indicated sets will be output." << std::endl
+      << "  -a  : write all sets (default is only geom, mesh, and named)" << std::endl
+      << "  -g  : write geometric topology sets" << std::endl
+      << "  -m  : write material sets and boundary condition sets" << std::endl
+      << "  -n  : write named sets" << std::endl
+      << "  -s  : label surface-volume links with sense" << std::endl
+      << "  The default link behavior is to both child links" << std::endl
+      << "  and containment with solid lines." << std::endl
+      << "  -P  : do not write child links" << std::endl
+      << "  -p  : write child links with dashed lines" << std::endl
+      << "  -C  : do not write containment links" << std::endl
+      << "  -c  : write containment links with dashed lines" << std::endl;
+  exit(0);
+enum Link { NONE = 0, SOLID, DASHED };
+void write_dot( Link contained, Link children );
+void dot_nodes( std::ostream& s, MBRange& sets_out );
+void dot_children( std::ostream& s, const MBRange& sets, bool dashed );
+void dot_contained( std::ostream& s, const MBRange& sets, bool dashed );
+int main( int argc, char* argv[] )
+  Link children = SOLID, contained = SOLID;
+  bool printGeomSets = true;
+  bool printMeshSets = true;
+  bool printNamedSets = true;
+  const char* input_file = 0;
+  bool geom_flag = false, mesh_flag = false, name_flag = false, all_flag = false;
+  bool no_more_flags = false;
+  for (int i = 1; i < argc; ++i) {
+    if (no_more_flags || argv[i][0] != '-') {
+      if (input_file)
+        usage(argv[0]);
+      input_file = argv[i];
+      continue;
+    for (int j = 1; argv[i][j]; ++j) {
+      switch (argv[i][j]) {
+        case 'a': all_flag = true; break;
+        case 'g': geom_flag = true; break;
+        case 'm': mesh_flag = true; break;
+        case 'n': name_flag = true; break;
+        case 's': printSVSense = true; break;
+        case 'P': children = NONE; break;
+        case 'p': children = DASHED; break;
+        case 'C': contained = NONE; break;
+        case 'c': contained = DASHED; break;
+        case '-': no_more_flags = true; break;
+        case 'h': usage(argv[0], false);
+        default:
+          std::cerr << "Unknown flag: '" << argv[i][j] << "'" << std::endl;
+          usage(argv[0]);
+  if (!input_file) {
+    std::cerr << "No input file specified." << std::endl;
+    usage(argv[0]);
+  if (all_flag) {
+    printGeomSets = printMeshSets = printNamedSets = printAnonSets = true;
+  else if (geom_flag || mesh_flag || name_flag) {
+    printGeomSets = geom_flag;
+    printMeshSets = mesh_flag;
+    printNamedSets = name_flag;
+  if (MB_SUCCESS != mb.load_mesh( input_file )) {
+    std::cerr << input_file << ": file read failed." << std::endl;
+    return 1;
+  MBTag t;
+  if (printGeomSets) {
+    if (MB_SUCCESS == mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, t )) {
+      geomTag = t;
+  if (printMeshSets) {
+    if (MB_SUCCESS == mb.tag_get_handle( MATERIAL_SET_TAG_NAME, t )) {
+      blockTag = t;
+    if (MB_SUCCESS == mb.tag_get_handle( DIRICHLET_SET_TAG_NAME, t )) {
+      nodeTag = t;
+    if (MB_SUCCESS == mb.tag_get_handle( NEUMANN_SET_TAG_NAME, t )) {
+      sideTag = t;
+  if (printNamedSets) {
+    if (MB_SUCCESS == mb.tag_get_handle( NAME_TAG_NAME, t )) {
+      nameTag = t;
+  if (MB_SUCCESS == mb.tag_get_handle( GLOBAL_ID_TAG_NAME, t ))
+    idTag = t;
+  write_dot( contained, children );
+  return 0;
+  MBRange sets;
+  std::cout << "digraph {" << std::endl;
+  dot_nodes( std::cout, sets );
+  std::cout << std::endl;
+  if (contained)
+    dot_contained( std::cout, sets, contained == DASHED );
+  if (children)
+    dot_children( std::cout, sets, children == DASHED );
+  std::cout << "}" << std::endl;
+void dot_get_sets( MBRange& curr_sets, MBRange& result_sets,
+                   MBTag tag, void* tag_val = 0 )
+  if (!tag)
+    return;
+  result_sets.clear();
+  mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, &tag_val, 1, result_sets );
+  result_sets = result_sets.subtract( curr_sets );
+  curr_sets.merge( result_sets );
+void dot_write_node( std::ostream& s, MBEntityHandle h,
+                     const char* label, int* id = 0 )
+  s << 's' << mb.id_from_handle(h) << " [label = \"" << label;
+  if (id)
+    s << ' ' << *id;
+  s << "\"];" << std::endl;
+void dot_write_id_nodes( std::ostream& s,
+                         const MBRange& entites,
+                         MBTag id_tag,
+                         const char* type_name )
+  int id;
+  for (MBRange::iterator i = entites.begin(); i != entites.end(); ++i)
+    if (MB_SUCCESS == mb.tag_get_data( id_tag, &*i, 1, &id ))
+      dot_write_node( s, *i, type_name, &id );
+void dot_nodes( std::ostream& s, MBRange& sets )
+  MBRange vol_sets, surf_sets, curv_sets, vert_sets;
+  MBRange block_sets, side_sets, node_sets;
+  MBRange named_sets, other_sets;
+  dot_get_sets( sets, named_sets, nameTag );
+  int dim = 3;
+  dot_get_sets( sets, vol_sets, geomTag, &dim );
+  dim = 2;
+  dot_get_sets( sets, surf_sets, geomTag, &dim );
+  dim = 1;
+  dot_get_sets( sets, curv_sets, geomTag, &dim );
+  dim = 0;
+  dot_get_sets( sets, vert_sets, geomTag, &dim );
+  dot_get_sets( sets, block_sets, blockTag );
+  dot_get_sets( sets, side_sets, sideTag );
+  dot_get_sets( sets, node_sets, nodeTag );
+  if (printAnonSets) {
+    mb.get_entities_by_type( 0, MBENTITYSET, other_sets );
+    MBRange xsect = other_sets.subtract( sets );
+    sets.swap(other_sets);
+    other_sets.swap(xsect);
+  dot_write_id_nodes( s, vol_sets , idTag, "Volume"  );
+  dot_write_id_nodes( s, surf_sets, idTag, "Surface" );
+  dot_write_id_nodes( s, curv_sets, idTag, "Curve"   );
+  dot_write_id_nodes( s, vert_sets, idTag, "Vertex"  );
+  dot_write_id_nodes( s, block_sets, blockTag, "Block" );
+  dot_write_id_nodes( s, side_sets, sideTag, "Neumann Set" );
+  dot_write_id_nodes( s, node_sets, nodeTag, "Dirichlet Set" );
+  MBRange::iterator i;
+  char name[NAME_TAG_SIZE+1];
+  for (i = named_sets.begin(); i != named_sets.end(); ++i) {
+    if (MB_SUCCESS == mb.tag_get_data( nameTag, &*i, 1, name )) {
+      name[NAME_TAG_SIZE] = '\0';
+      dot_write_node( s, *i, name );
+  for (i = other_sets.begin(); i != other_sets.end(); ++i) {
+    int id = mb.id_from_handle(*i);
+    dot_write_node( s, *i, "EntitySet ", &id );
+void dot_down_link( std::ostream& s,
+                    MBEntityHandle parent,
+                    MBEntityHandle child,
+                    bool dashed,
+                    const char* label = 0 )
+  s << 's' << mb.id_from_handle(parent) << " -> "
+    << 's' << mb.id_from_handle(child);
+  if (dashed && label)
+    s << " [style = dashed label = \"" << label << "\"]";
+  else if (dashed)
+    s << " [style = dashed]";
+  else if (label)
+    s << " [label = \"" << label << "\"]";
+  s << ';' << std::endl;
+                   const MBRange& sets,
+                   bool dashed )
+  bool forward;
+  const char *fstr = "forward", *rstr = "reverse";
+  for (MBRange::iterator i = sets.begin(); i != sets.end(); ++i) {
+    MBRange parents;
+    mb.get_parent_meshsets( *i, parents );
+    parents = parents.intersect( sets );
+    for (MBRange::iterator j = parents.begin(); j != parents.end(); ++j) {
+      const char* linklabel = 0;
+      if (printSVSense && MB_SUCCESS == geomTool.get_sense( *i, *j, forward ))
+        linklabel = forward ? fstr : rstr;
+      dot_down_link( s, *j, *i, dashed, linklabel);
+                    bool dashed )
+    MBRange contained;
+    mb.get_entities_by_type(*i, MBENTITYSET, contained );
+    contained = contained.intersect( sets );
+    for (MBRange::iterator j = contained.begin(); j != contained.end(); ++j)
+      dot_down_link( s, *i, *j, dashed );
