[MOAB-dev] r2556 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jan 16 16:41:31 CST 2009
Author: kraftche
Date: 2009-01-16 16:41:31 -0600 (Fri, 16 Jan 2009)
New Revision: 2556
Modified:
   MOAB/trunk/GeomTopoTool.cpp
   MOAB/trunk/GeomTopoTool.hpp
Log:
- Add utility functions to GeomTopoTool to get/set surface-volume relative sense
- In GeomTopoTool::restore_topology(), store surface-volume relative sense
Modified: MOAB/trunk/GeomTopoTool.cpp
--- MOAB/trunk/GeomTopoTool.cpp	2009-01-15 22:55:03 UTC (rev 2555)
+++ MOAB/trunk/GeomTopoTool.cpp	2009-01-16 22:41:31 UTC (rev 2556)
@@ -17,8 +17,78 @@
 #include "MBRange.hpp"
 #include "MBTagConventions.hpp"
 #include "MBInterface.hpp"
+#include "MBCN.hpp"
+#include "MBInternals.hpp"
 #include <assert.h>
+#include <iostream>
+// Tag name used for saving sense of faces in volumes.
+// We assume that the surface occurs in at most two volumes.
+// Code will error out if more than two volumes per surface.
+// The tag data is a pair of tag handles, representing the
+// forward and reverse volumes, respectively.  If a surface
+// is non-manifold in a single volume, the same volume will
+// be listed for both the forward and reverse slots.
+const char GEOM_SENSE_TAG_NAME[] = "GEOM_SENSE_2";
+MBErrorCode GeomTopoTool::set_sense( MBEntityHandle surface,
+                                     MBEntityHandle volume,
+                                     bool forward )
+  MBErrorCode rval;
+  if (!sense2Tag) {
+    rval = mdbImpl->tag_create( GEOM_SENSE_TAG_NAME, 2*sizeof(MBEntityHandle),
+                           MB_TAG_SPARSE, MB_TYPE_HANDLE,
+                           sense2Tag, 0, true );
+    if (MB_SUCCESS != rval)
+      return rval;
+  MBEntityHandle sense_data[2] = {0,0};
+  rval = mdbImpl->tag_get_data( sense2Tag, &surface, 1, sense_data );
+  if (MB_TAG_NOT_FOUND != rval && MB_SUCCESS != rval)
+    return MB_FAILURE;
+  if (sense_data[!forward] == volume)
+    return MB_SUCCESS;
+  else if (sense_data[!forward])
+    return MB_MULTIPLE_ENTITIES_FOUND;
+  sense_data[!forward] = volume;
+  return mdbImpl->tag_set_data( sense2Tag, &surface, 1, sense_data );
+MBErrorCode GeomTopoTool::get_sense( MBEntityHandle surface,
+                                     bool& forward )
+  MBErrorCode rval;
+  if (!sense2Tag) {
+    rval = mdbImpl->tag_get_handle( GEOM_SENSE_TAG_NAME, sense2Tag );
+    if (MB_SUCCESS != rval) {
+      sense2Tag = 0;
+    return rval;
+  if (sense_data[0] == volume)
+    forward = true;
+  else if (sense_data[1] == volume)
+    forward = false;
+  else
+    return MB_ENTITY_NOT_FOUND;
     //! Restore parent/child links between GEOM_TOPO mesh sets
 MBErrorCode GeomTopoTool::restore_topology()
@@ -101,6 +171,32 @@
         result = mdbImpl->add_parent_child(*pit, *d_it);
         if (MB_SUCCESS != result) return result;
+        // store surface senses
+      if (dim != 2)
+        continue;
+      const MBEntityHandle *conn3, *conn2;
+      int len3, len2, err, num, sense, offset;
+      for (size_t i = 0; i < parents.size(); ++i) {
+        result = mdbImpl->get_connectivity( dp1ents[i], conn3, len3, true );
+        if (MB_SUCCESS != result) return result;
+        result = mdbImpl->get_connectivity( dents.front(), conn2, len2, true );
+        assert(len2 <= 4);
+        err = MBCN::SideNumber( TYPE_FROM_HANDLE(dp1ents[i]), conn3,
+                                conn2, len2, dim, num, sense, offset );
+        if (err)
+        result = set_sense( *d_it, parents[i], sense == 1 );
+        if (MB_MULTIPLE_ENTITIES_FOUND == result) {
+          std::cerr << "Warning: Multiple volumes use surface with same sense." << std::endl
+                    << "         Some geometric sense data lost." << std::endl;
+        else if (MB_SUCCESS != result) {
+          return result;
       // now delete owner tag on this dimension, automatically removes tag data
Modified: MOAB/trunk/GeomTopoTool.hpp
--- MOAB/trunk/GeomTopoTool.hpp	2009-01-15 22:55:03 UTC (rev 2555)
+++ MOAB/trunk/GeomTopoTool.hpp	2009-01-16 22:41:31 UTC (rev 2556)
@@ -23,15 +23,28 @@
 class GeomTopoTool
 public:
-  GeomTopoTool(MBInterface *impl) : mdbImpl(impl) {}
+  GeomTopoTool(MBInterface *impl) : mdbImpl(impl), sense2Tag(0) {}
   ~GeomTopoTool() {}
   MBErrorCode restore_topology();
+    //! Store sense of surface relative to volume.
+    //!\return MB_MULTIPLE_ENTITIES_FOUND if surface already has a forward volume.
+    //!        MB_SUCCESS if successful
+    //!        otherwise whatever internal error code occured.
+  MBErrorCode set_sense( MBEntityHandle surface,
+                         bool forward );
+  MBErrorCode get_sense( MBEntityHandle surface,
+                         bool& forward );
 private:
   MBInterface *mdbImpl;
+  MBTag sense2Tag;
     //! compute vertices inclusive and put on tag on sets in geom_sets
   MBErrorCode construct_vertex_ranges(const MBRange &geom_sets,
