[MOAB-dev] Possible bug in 2-D quadratic elements
Wollaber, Allan B.
awollaber at anl.gov
Thu Jan 15 09:18:21 CST 2009
Jason,
Awesome.
We have been using HEX27 elements but it should be little trouble for me
to reorder the connectivity (the UNIC-internal mapping differs from MOAB
anyway).
Thanks!
- Allan
-----Original Message-----
From: Jason Kraftcheck [mailto:kraftche at cae.wisc.edu]
Sent: Wednesday, January 14, 2009 5:59 PM
To: Wollaber, Allan B.
Cc: moab-dev at mcs.anl.gov; Smith, Micheal A.; Tautges, Timothy J.
Subject: Re: [MOAB-dev] Possible bug in 2-D quadratic elements
The current version of MOAB now has the following relevant changes:
o Remove "HIGHER_ORDER_ADJ" option for iMesh_newMesh
o Restore previous iMesh_getEntArrAdj behavior: return full
connectivity list for higher-order elements
o Fix bug reading in higher-order face elements from CUB files.
o Fix incorrect connectivity order for tet8, tet14, and hex27
elements read from CUB files.
The last item above may be an issue if you are working with those
element types (volume elements with mid-face nodes.) MOAB's node
ordering is not the same as PATRAN or ExodusII for many higher-order
element types. The CUB file reader was previously storing hex27
connectivity in the PATRAN rather than MOAB order. Further, it was
storing tet8 and tet14 connectivity in an order that was neither
PATRAN/Exodus nor MOAB (some internal Cubit ordering
apparently.)
- jason
Wollaber, Allan B. wrote:
> Jason,
> I had forgotten that I called both "iMesh_newMesh" and "iMesh_load".
> Thanks for clearing that up.
> I think we can rule out that someone has modified my local copy of
> MOAB, since I installed it locally (in my home directory) using
> autoreconf around mid-December.
> Let me know what you find out, or if I can do anything useful while
> you figure out what's going on from your side.
> Thanks,
> - Allan
> Sent: Tuesday, January 13, 2009 4:11 PM
>> Jason,
>> Thank you for your prompt reply.
>> Actually, I never call "iMesh_createMesh", and I can't find this
>> function in any of the header files. I'm working out of the trunk of
>> MOAB (grep -ir createmesh *). Do you possibly mean "iMesh_newMesh"?
>> I
> Yes, I meant the latter. Apologies for any confusion.
>> would prefer to just use "iMesh_load", since I am just loading the
>> mesh directly from the CUBIT file. Would it be necessary to create a
>> new mesh instance and copy in the mesh loaded from CUBIT to achieve
>> this? If so, I'm actually not sure how best to do that. Is there a
>> "copy constructor" somewhere?
> You need to call iMesh_newMesh to create the "iMesh_instance" object
> which is later passed to iMesh_load. The name "newMesh" is a bit
> misleading, as it doesn't create a mesh (new or otherwise), but rather
> an instance of the database.
>> Also, will using this setting affect the success I've had thus far
>> with the quadratic 3-D elements? It is only the 2-D elements that
>> I've
>> had trouble with.
> It shouldn't. But it appears that the problem is more complicated
> that I had at first thought. Apparently the version of MOAB you are
> using is always returning the higher-order nodes from getEntArrAdj
> (regardless of any
> setting.) I don't know if the MOAB behavior has changed or if someone
> has modified your copy of MOAB. So the problem you are seeing is a
> bug rather than an API issue. I'm looking into this right now. So
> far the problem appears to be that the 'cub' file reader in MOAB
> looses the higher-order nodes on the edges of face elements (thus 5
> nodes for a
> quad9.)
> - jason
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo
Emerson
