[MOAB-dev] Possible bug in 2-D quadratic elements
Tim Tautges tautges at mcs.anl.gov
Wed Jan 14 06:55:29 CST 2009
> It shouldn't.  But it appears that the problem is more complicated that I
> had at first thought.  Apparently the version of MOAB you are using is
> always returning the higher-order nodes from getEntArrAdj (regardless of any
> setting.)  I don't know if the MOAB behavior has changed or if someone has
> modified your copy of MOAB.  So the problem you are seeing is a bug rather
> than an API issue.  I'm looking into this right now.  So far the problem
> appears to be that the 'cub' file reader in MOAB looses the higher-order
> nodes on the edges of face elements (thus 5 nodes for a quad9.)
Sigh, I was afraid of that.  Thanks for looking into that Jason.
- tim
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
