[MOAB-dev] r2543 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Jan 13 21:31:32 CST 2009
Author: kraftche
Date: 2009-01-13 21:31:32 -0600 (Tue, 13 Jan 2009)
New Revision: 2543
Modified:
MOAB/trunk/Tqdcfr.cpp
Log:
Try to fix reading of higher-order elements for which the complete connectivty
list is not stored explicitly (tri6, tri7, quad8, quad9, and perhaps cubit
FullHex and FullTet elements with higher-order nodes).
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2009-01-14 03:28:39 UTC (rev 2542)
+++ MOAB/trunk/Tqdcfr.cpp 2009-01-14 03:31:32 UTC (rev 2543)
@@ -22,6 +22,7 @@
#include "MBCN.hpp"
#include "MBInternals.hpp"
#include "FileOptions.hpp"
+#include "HigherOrderFactory.hpp"
#ifdef USE_MPI
#include "mpi.h"
@@ -758,7 +759,27 @@
if (MB_SUCCESS != result) return result;
- return MB_SUCCESS;
+ // Put additional higher-order nodes into element connectivity list.
+ // Cubit saves full connectivity list only for NodeHex and NodeTet
+ // elements. Other element types will only have the corners and
+ // the mid-element node if there is one. Need to reconsturct additional
+ // connectivity entries from mid-nodes of adjacent lower-order entities.
+ int node_per_elem = cub_elem_num_verts[blockh->blockElemType];
+ if (MBCN::VerticesPerEntity(blockh->blockEntityType) == node_per_elem)
+ return MB_SUCCESS;
+ // Can't use MBInterface::convert_entities because block could contain
+ // both entity sets and entities. convert_entities will fail if block
+ // contains an entity set, but we still need to call it on any elements
+ // directly in the block (rather than a geometry subset). So bypass
+ // MBInterface and call HOFactory directly with an MBRange of entities.
+ MBRange entities;
+ mdbImpl->get_entities_by_type( blockh->setHandle, blockh->blockEntityType, entities, true );
+ int mid_nodes[4];
+ MBCN::HasMidNodes( blockh->blockEntityType, node_per_elem, mid_nodes );
+ HigherOrderFactory ho_fact( dynamic_cast<MBCore*>(mdbImpl), 0 );
+ return ho_fact.convert( entities, !!mid_nodes[1], !!mid_nodes[2], !!mid_nodes[3] );
MBErrorCode Tqdcfr::read_group(const unsigned int group_index,
