[MOAB-dev] r2541 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Jan 13 21:27:34 CST 2009
Author: kraftche
Date: 2009-01-13 21:27:34 -0600 (Tue, 13 Jan 2009)
New Revision: 2541
Added:
MOAB/trunk/hex27.cub
MOAB/trunk/quad9.cub
Modified:
MOAB/trunk/Makefile.am
MOAB/trunk/cub_file_test.cc
Log:
add unit tests for reading higher-order elements from cub files
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2009-01-14 03:20:31 UTC (rev 2540)
+++ MOAB/trunk/Makefile.am 2009-01-14 03:27:34 UTC (rev 2541)
@@ -347,7 +347,7 @@
cub_file_test_DEPENDENCIES = $(tag_test_LDADD)
-EXTRA_DIST = test.cub
+EXTRA_DIST = test.cub quad9.cub hex27.cub
# Other files to clean up (e.g. output from tests)
MOSTLYCLEANFILES = dumped_acis.sat tree.h5m
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc 2009-01-14 03:20:31 UTC (rev 2540)
+++ MOAB/trunk/cub_file_test.cc 2009-01-14 03:27:34 UTC (rev 2541)
@@ -68,8 +68,12 @@
#ifdef SRCDIR
static const char input_file_1[] = STRINGIFY(SRCDIR) "/test.cub";
+static const char quad9_file[] = STRINGIFY(SRCDIR) "/quad9.cub";
+static const char hex27_file[] = STRINGIFY(SRCDIR) "/hex27.cub";
#else
static const char input_file_1[] = "test.cub";
+static const char quad9_file[] = "quad9.cub";
+static const char hex27_file[] = "hex27.cub";
#endif
void read_file( MBInterface& moab,
@@ -96,6 +100,10 @@
void test_file_set();
+void test_quad9();
+void test_hex27();
int main()
int result = 0;
@@ -110,6 +118,8 @@
result += RUN_TEST(test_side_sets);
result += RUN_TEST(test_node_sets);
result += RUN_TEST(test_file_set);
+ result += RUN_TEST(test_hex27);
+ result += RUN_TEST(test_quad9);
return result;
@@ -787,3 +797,187 @@
CHECK( exp == act );
+static int q9_idx_from_coord( double coord )
+ // 10x10 element grid has 21 vertices in each direction,
+ // equally spaced in [-5,5].
+ return (int)round( 2*coord + 10 );
+void test_quad9()
+ MBErrorCode rval;
+ MBCore mb_impl;
+ MBInterface& mb = mb_impl;
+ read_file( mb, quad9_file );
+ // we're expecting a 10x10 element grid in the xy plane.
+ MBEntityHandle verts[21][21], quads[10][10];
+ memset( verts, 0, sizeof(verts) );
+ memset( quads, 0, sizeof(quads) );
+ // get all quads
+ MBRange range;
+ rval = mb.get_entities_by_type( 0, MBQUAD, range );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)(10*10), range.size() );
+ // for each quad
+ for (MBRange::iterator i = range.begin(); i != range.end(); ++i) {
+ // get connectivity
+ const MBEntityHandle* conn = 0;
+ int conn_len = 0;
+ rval = mb.get_connectivity( *i, conn, conn_len, false );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 9, conn_len );
+ // translate connectivity to indices into vertex grid
+ double coords[3*9];
+ rval = mb.get_coords( conn, 9, coords ); CHECK_ERR(rval);
+ int x[9], y[9];
+ for (int j = 0; j < 9; ++j) {
+ x[j] = q9_idx_from_coord( coords[3*j] );
+ y[j] = q9_idx_from_coord( coords[3*j+1] );
+ CHECK_REAL_EQUAL( 0.0, coords[3*j+2], 1e-12 );
+ CHECK( 0 <= x[j] && x[j] <= 20 );
+ CHECK( 0 <= y[j] && y[j] <= 20 );
+ // calculate element location from mid-node location
+ int ex = (x[8]-1)/2;
+ int ey = (y[8]-1)/2;
+ CHECK_EQUAL( (MBEntityHandle)0, quads[ex][ey] );
+ quads[ex][ey] = *i;
+ // check each vertex
+ bool seen[3][3] = { {false, false, false},
+ {false, false, false},
+ {false, false, false} };
+ // check for duplicate vertices
+ if (verts[x[j]][y[j]] == 0)
+ verts[x[j]][y[j]] = conn[j];
+ else {
+ CHECK_EQUAL( verts[x[j]][y[j]], conn[j] );
+ // check that vertices have correct coordinates
+ int sx = x[j] - x[8] + 1;
+ int sy = y[j] - y[8] + 1;
+ CHECK( 0 <= sx && sx <= 2 );
+ CHECK( 0 <= sy && sy <= 2 );
+ seen[sx][sy] = true;
+ CHECK( seen[0][0] );
+ CHECK( seen[0][1] );
+ CHECK( seen[0][2] );
+ CHECK( seen[1][0] );
+ CHECK( seen[1][1] );
+ CHECK( seen[1][2] );
+ CHECK( seen[2][0] );
+ CHECK( seen[2][1] );
+ CHECK( seen[2][2] );
+ // check that we saw all the elements and vertices we expected to
+ for (int i = 0; i < 21; ++i)
+ for (int j = 0; j < 21; ++j)
+ CHECK( verts[i][j] != 0 );
+ for (int i = 0; i < 10; ++i)
+ for (int j = 0; j < 10; ++j)
+ CHECK( quads[i][j] != 0 );
+static int h27_idx_from_coord( double coord )
+ // 2x2 element grid has 7 vertices in each direction,
+ // equally spaced in [-1,1].
+ return (int)round( 2*coord + 2 );
+void test_hex27()
+ MBErrorCode rval;
+ MBCore mb_impl;
+ read_file( mb, hex27_file );
+ // we're expecting a 2x2x2 element grid
+ MBEntityHandle verts[5][5][5], hexes[2][2][2];
+ memset( hexes, 0, sizeof(hexes) );
+ // get all hexes
+ MBRange range;
+ rval = mb.get_entities_by_type( 0, MBHEX, range );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)(2*2*2), range.size() );
+ // for each quad
+ int conn_len = 0;
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 27, conn_len );
+ double coords[3*27];
+ rval = mb.get_coords( conn, 27, coords ); CHECK_ERR(rval);
+ int x[27], y[27], z[27];
+ for (int j = 0; j < 27; ++j) {
+ x[j] = h27_idx_from_coord( coords[3*j] );
+ y[j] = h27_idx_from_coord( coords[3*j+1] );
+ z[j] = h27_idx_from_coord( coords[3*j+2] );
+ CHECK( 0 <= x[j] && x[j] <= 4 );
+ CHECK( 0 <= y[j] && y[j] <= 4 );
+ CHECK( 0 <= z[j] && z[j] <= 4 );
+ int ex = (x[20]-1)/2;
+ int ey = (y[20]-1)/2;
+ int ez = (z[20]-1)/2;
+ CHECK_EQUAL( (MBEntityHandle)0, hexes[ex][ey][ez] );
+ hexes[ex][ey][ez] = *i;
+ bool seen[3][3][3];
+ std::fill( &seen[0][0][0], &seen[0][0][0] + 3*3*3, false );
+ if (verts[x[j]][y[j]][z[j]] == 0)
+ verts[x[j]][y[j]][z[j]] = conn[j];
+ else {
+ CHECK_EQUAL( verts[x[j]][y[j]][z[j]], conn[j] );
+ int sx = x[j] - x[20] + 1;
+ int sy = y[j] - y[20] + 1;
+ int sz = z[j] - z[20] + 1;
+ CHECK( 0 <= sz && sz <= 2 );
+ seen[sx][sy][sz] = true;
+ for (int k = 0; k < 3; ++k)
+ for (int l = 0; l < 3; ++l)
+ for (int m = 0; m < 3; ++m)
+ CHECK( seen[k][l][m] );
+ for (int i = 0; i < 5; ++i)
+ for (int j = 0; j < 5; ++j)
+ for (int k = 0; k < 5; ++k)
+ CHECK( verts[i][j][k] != 0 );
+ for (int i = 0; i < 2; ++i)
+ for (int j = 0; j < 2; ++j)
+ for (int k = 0; k < 2; ++k)
+ CHECK( hexes[i][j][k] != 0 );
Added: MOAB/trunk/hex27.cub
(Binary files differ)
Property changes on: MOAB/trunk/hex27.cub
___________________________________________________________________
+ application/octet-stream
Added: MOAB/trunk/quad9.cub
Property changes on: MOAB/trunk/quad9.cub
