[MOAB-dev] r2533 - MOAB/trunk/test/perf
kraftche at mcs.anl.gov
Mon Jan 12 14:00:44 CST 2009
Author: kraftche
Date: 2009-01-12 14:00:44 -0600 (Mon, 12 Jan 2009)
New Revision: 2533
Added:
MOAB/trunk/test/perf/adj_time.cpp
Modified:
MOAB/trunk/test/perf/Makefile.am
Log:
add simple performance tests of adjacency queries
Modified: MOAB/trunk/test/perf/Makefile.am
--- MOAB/trunk/test/perf/Makefile.am 2009-01-12 20:00:25 UTC (rev 2532)
+++ MOAB/trunk/test/perf/Makefile.am 2009-01-12 20:00:44 UTC (rev 2533)
@@ -7,8 +7,9 @@
LDADD = $(top_builddir)/libMOAB.la
-check_PROGRAMS = perf seqperf
+check_PROGRAMS = perf seqperf adj_time
perf_SOURCES = perf.cpp
seqperf_SOURCES = seqperf.cpp
+adj_time_SOURCES = adj_time.cpp
Added: MOAB/trunk/test/perf/adj_time.cpp
--- MOAB/trunk/test/perf/adj_time.cpp (rev 0)
+++ MOAB/trunk/test/perf/adj_time.cpp 2009-01-12 20:00:44 UTC (rev 2533)
@@ -0,0 +1,74 @@
+#include "MBCore.hpp"
+#include "MBRange.hpp"
+#include <iostream>
+#include <assert.h>
+#include <time.h>
+#define STRINGIFY_(X) #X
+#define STRINGIFY(X) STRINGIFY_(X)
+#ifndef SRCDIR
+# define SRCDIR .
+#endif
+const char* default_input_file = "../mb_big_test.g";
+int main()
+ MBErrorCode rval;
+ MBCore moab;
+ MBInterface& mb = moab;
+ // load test file
+ MBEntityHandle set;
+ rval = mb.load_file( default_input_file, set );
+ if (MB_SUCCESS != rval) {
+ std::cerr << default_input_file <<": failed to load file." << std::endl;
+ return 1;
+ // get all region elements
+ MBRange vols;
+ rval = mb.get_entities_by_dimension( 0, 3, vols );
+ return 2;
+ if (vols.empty())
+ return 1;
+ // create internal face elements
+ MBRange faces;
+ rval = mb.get_adjacencies( vols, 2, true, faces, MBInterface::UNION );
+ return 2;
+ assert(faces.size() > vols.size());
+ // time query of all adjacent volumes
+ std::vector<MBEntityHandle> adj;
+ clock_t t_0 = clock();
+ for (MBRange::iterator i = faces.begin(); i != faces.end(); ++i) {
+ adj.clear();
+ rval = mb.get_adjacencies( &*i, 1, 3, false, adj );
+ return 2;
+ assert( adj.size() == 1 || adj.size() == 2 );
+ clock_t t_up = clock() - t_0;
+ std::cout << "Querying of volumes for " << faces.size() << " faces: "
+ << t_up/(double)CLOCKS_PER_SEC << " seconds" << std::endl;
+ // time downward adjacency query from volumes to faces
+ t_0 = clock();
+ for (MBRange::iterator i = vols.begin(); i != vols.end(); ++i) {
+ adj.clear();
+ rval = mb.get_adjacencies( &*i, 1, 1, false, adj );
+ return 2;
+ assert( adj.size() > 3 );
+ clock_t t_down = clock() - t_0;
+ std::cout << "Querying of faces for " << vols.size() << " volumes: "
+ << t_down/(double)CLOCKS_PER_SEC << " seconds" << std::endl;
+ return 0;
