[MOAB-dev] r2527 - MOAB/trunk/tools/iMesh
Jason Kraftcheck kraftche at cae.wisc.edu
Fri Jan 9 16:53:51 CST 2009
The correct log message for this checkin should have been:
  significantly speed up iMesh_getEntArrAdj by eliminating the use
  of a temporary std::vector for results
  fix bug where iMesh_getEntArrAdj breaks for structured mesh
MOAB repo ddoesn't have pre-revprop-change hook, so I cannot correct the
actual log message.
- jason
kraftche at mcs.anl.gov wrote:
> Author: kraftche
> Date: 2009-01-09 16:44:12 -0600 (Fri, 09 Jan 2009)
> New Revision: 2527
> Modified:
>    MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
> Log:
> Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
> --- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-01-09 21:10:42 UTC (rev 2526)
> +++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-01-09 22:44:12 UTC (rev 2527)
> @@ -986,11 +986,22 @@
>      int* off_iter = *offset;
>      int prev_off = 0;
> -    std::vector<MBEntityHandle> all_adj_ents;
> +    std::vector<MBEntityHandle> conn_storage;
>      std::vector<MBEntityHandle> adj_ents;
>      const MBEntityHandle *connect;
>      int num_connect;
> +    MBEntityHandle* array = reinterpret_cast<MBEntityHandle*>(*adjacentEntityHandles);
> +    int array_alloc = *adjacentEntityHandles_allocated;
> +    const bool allocated_array = !array || !array_alloc;
> +    if (allocated_array) {
> +      array_alloc = 2 * entity_handles_size;
> +      array = (MBEntityHandle*)malloc(array_alloc*sizeof(MBEntityHandle));
> +      if (!array) {
> +        RETURN(iBase_MEMORY_ALLOCATION_FAILED);
>      for ( ; entity_iter != entity_end; ++entity_iter)
>        *off_iter = prev_off;
> @@ -998,27 +1009,25 @@
>        if (iBase_VERTEX == entity_type_requested &&
>            TYPE_FROM_HANDLE(*entity_iter) != MBPOLYHEDRON) {
> -        result = MBI->get_connectivity(*entity_iter, connect, num_connect);
> +        result = MBI->get_connectivity(*entity_iter, connect, num_connect, true, &conn_storage);
>          if (MB_SUCCESS != result) {
>            iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
>            RETURN(iBase_ERROR_MAP[result]);
> -        std::copy(connect, connect+num_connect, std::back_inserter(all_adj_ents));
> -        prev_off += num_connect;
>        else if (iBase_ALL_TYPES == entity_type_requested) {
> +        adj_ents.clear();
>          for (int dim = 0; dim < 4; ++dim) {
>            if (MBCN::Dimension(TYPE_FROM_HANDLE(*entity_iter)) == dim)
>              continue;
> -          adj_ents.clear();
>            result = MBI->get_adjacencies( entity_iter, 1, dim, false, adj_ents );
> -          std::copy(adj_ents.begin(), adj_ents.end(), std::back_inserter(all_adj_ents));
> -          prev_off += adj_ents.size();
> +        connect = &adj_ents[0];
> +        num_connect = adj_ents.size();
>        else {
>          adj_ents.clear();
> @@ -1028,19 +1037,39 @@
> +      if (prev_off + num_connect <= array_alloc) {
> +        std::copy(connect, connect+num_connect, array+prev_off);
> +      else if (allocated_array) {
> +        array_alloc *= 2;
> +        array = (MBEntityHandle*)realloc( array, array_alloc*sizeof(MBEntityHandle) );
> +        if (!array) {
> +      // else do nothing.  Will catch error later when comparing
> +      //  occupied to allocated sizes.  Continue here because
> +      //  must pass back required size.
> +      prev_off += num_connect;
> +    *offset_size = entity_handles_size+1;
> +    *adjacentEntityHandles_size = prev_off;
> -    CHECK_SIZE(*adjacentEntityHandles, *adjacentEntityHandles_allocated,
> -               (int)all_adj_ents.size(),
> -               iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
> -    memcpy(*adjacentEntityHandles, &all_adj_ents[0], sizeof(MBEntityHandle) * all_adj_ents.size() );
> +    if (*adjacentEntityHandles_size > array_alloc) {
> +      RETURN(iBase_BAD_ARRAY_SIZE);
> +      *adjacentEntityHandles = reinterpret_cast<iBase_EntityHandle*>(array);
> +      *adjacentEntityHandles_allocated = array_alloc;
> -    *adjacentEntityHandles_size = all_adj_ents.size();
> -    *offset_size = entity_handles_size+1;
>      RETURN(iBase_SUCCESS);
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
