[MOAB-dev] r2510 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Jan 6 15:43:42 CST 2009
Author: kraftche
Date: 2009-01-06 15:43:42 -0600 (Tue, 06 Jan 2009)
New Revision: 2510
Modified:
MOAB/trunk/MBAdaptiveKDTree.cpp
MOAB/trunk/MBAdaptiveKDTree.hpp
MOAB/trunk/MBBSPTree.cpp
MOAB/trunk/MBBSPTree.hpp
MOAB/trunk/MBOrientedBoxTreeTool.cpp
MOAB/trunk/MBOrientedBoxTreeTool.hpp
Log:
add option to delete created trees when tool is deleted
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp 2009-01-06 21:19:07 UTC (rev 2509)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp 2009-01-06 21:43:42 UTC (rev 2510)
@@ -116,8 +116,15 @@
return rval;
-MBAdaptiveKDTree::MBAdaptiveKDTree( MBInterface* mb, const char* tagname_in, unsigned set_flags )
- : mbInstance(mb), meshSetFlags(set_flags)
+MBAdaptiveKDTree::MBAdaptiveKDTree( MBInterface* mb, const char* tagname, unsigned set_flags )
+ : mbInstance(mb), meshSetFlags(set_flags), cleanUpTrees(false)
+{ init(tagname); }
+MBAdaptiveKDTree::MBAdaptiveKDTree( MBInterface* mb, bool clean_up, const char* tagname, unsigned set_flags )
+ : mbInstance(mb), meshSetFlags(set_flags), cleanUpTrees(clean_up)
+{ init(tagname); }
+void MBAdaptiveKDTree::init( const char* tagname_in )
const char* tagname = tagname_in ? tagname_in : MB_AD_KD_TREE_DEFAULT_TAG_NAME;
std::vector<MBTag> ctl;
@@ -176,6 +183,23 @@
#endif
+MBAdaptiveKDTree::~MBAdaptiveKDTree()
+ if (!cleanUpTrees)
+ return;
+ while (!createdTrees.empty()) {
+ MBEntityHandle tree = createdTrees.back();
+ // make sure this is a tree (rather than some other, stale handle)
+ const void* data_ptr = 0;
+ MBErrorCode rval = moab()->tag_get_data( rootTag, &tree, 1, &data_ptr );
+ if (MB_SUCCESS == rval)
+ rval = delete_tree( tree );
+ if (MB_SUCCESS != rval)
+ createdTrees.pop_back();
MBErrorCode MBAdaptiveKDTree::set_split_plane( MBEntityHandle entity,
const Plane& plane )
@@ -229,6 +253,7 @@
return rval;
+ createdTrees.push_back( root_handle );
return MB_SUCCESS;
@@ -237,6 +262,10 @@
MBErrorCode rval;
std::vector<MBEntityHandle> children, dead_sets, current_sets;
+ createdTrees.erase(
+ std::remove( createdTrees.begin(), createdTrees.end(), root_handle ),
+ createdTrees.end() );
current_sets.push_back( root_handle );
while (!current_sets.empty()) {
MBEntityHandle set = current_sets.back();
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp 2009-01-06 21:19:07 UTC (rev 2509)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp 2009-01-06 21:43:42 UTC (rev 2510)
@@ -38,6 +38,8 @@
MBInterface* mbInstance;
MBTag planeTag, axisTag, rootTag;
unsigned meshSetFlags;
+ bool cleanUpTrees;
+ std::vector<MBEntityHandle> createdTrees;
public:
@@ -45,6 +47,13 @@
const char* tagname = 0,
unsigned meshset_creation_flags = MESHSET_SET );
+ MBAdaptiveKDTree( MBInterface* iface,
+ bool destroy_created_trees,
+ const char* tagname = 0,
+ unsigned meshset_creation_flags = MESHSET_SET );
+ ~MBAdaptiveKDTree();
//! Enumeriate split plane directions
enum Axis { X = 0, Y = 1, Z = 2 };
@@ -227,6 +236,8 @@
private:
+ void init( const char* tagname );
/**\brief find a triangle near the input point */
MBErrorCode find_close_triangle( MBEntityHandle root,
const double from_point[3],
Modified: MOAB/trunk/MBBSPTree.cpp
--- MOAB/trunk/MBBSPTree.cpp 2009-01-06 21:19:07 UTC (rev 2509)
+++ MOAB/trunk/MBBSPTree.cpp 2009-01-06 21:43:42 UTC (rev 2510)
@@ -85,29 +85,54 @@
return true;
-MBBSPTree::MBBSPTree( MBInterface* mb,
- const char* tagname,
- unsigned set_flags )
+MBErrorCode MBBSPTree::init_tags( const char* tagname )
- MBErrorCode rval;
if (!tagname)
tagname = MB_BSP_TREE_DEFAULT_TAG_NAME;
std::string rootname(tagname);
rootname += "_box";
- rval = mb->tag_create( tagname, 4*sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE, planeTag, 0, true );
+ MBErrorCode rval = moab()->tag_create( tagname, 4*sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE, planeTag, 0, true );
planeTag = 0;
- rval = mb->tag_create( rootname.c_str(), 24*sizeof(double), MB_TAG_SPARSE, MB_TYPE_DOUBLE, rootTag, 0, true );
+ else
+ rval = moab()->tag_create( rootname.c_str(), 24*sizeof(double), MB_TAG_SPARSE, MB_TYPE_DOUBLE, rootTag, 0, true );
rootTag = 0;
+ return rval;
+MBBSPTree::MBBSPTree( MBInterface* mb,
+ const char* tagname,
+ unsigned set_flags )
+{ init_tags( tagname ); }
+ : mbInstance(mb), meshSetFlags(set_flags), cleanUpTrees(destroy_created_trees)
+MBBSPTree::~MBBSPTree()
+ return;
MBErrorCode MBBSPTree::set_split_plane( MBEntityHandle node, const Plane& p )
// check for unit-length normal
@@ -174,6 +199,7 @@
return rval;
return MB_SUCCESS;
@@ -208,6 +234,9 @@
return rval;
return moab()->delete_entities( &dead_sets[0], dead_sets.size() );
Modified: MOAB/trunk/MBBSPTree.hpp
--- MOAB/trunk/MBBSPTree.hpp 2009-01-06 21:19:07 UTC (rev 2509)
+++ MOAB/trunk/MBBSPTree.hpp 2009-01-06 21:43:42 UTC (rev 2510)
@@ -38,7 +38,11 @@
MBTag planeTag, rootTag;
+ MBErrorCode init_tags( const char* tagname = 0 );
public:
static double epsilon() { return 1e-6; }
@@ -46,7 +50,14 @@
MBBSPTree( MBInterface* iface,
+ MBBSPTree( MBInterface* iface,
+ ~MBBSPTree();
/**\brief struct to store a plane
* If plane is defined as Ax+By+Cz+D=0, then
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp 2009-01-06 21:19:07 UTC (rev 2509)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp 2009-01-06 21:43:42 UTC (rev 2510)
@@ -45,8 +45,9 @@
MBOrientedBoxTreeTool::Op::~Op() {}
MBOrientedBoxTreeTool::MBOrientedBoxTreeTool( MBInterface* i,
- const char* tag_name )
- : instance( i )
+ const char* tag_name,
+ bool destroy_created_trees )
+ : instance( i ), cleanUpTrees(destroy_created_trees)
if (!tag_name)
tag_name = DEFAULT_TAG_NAME;
@@ -55,6 +56,23 @@
tagHandle = 0;
+MBOrientedBoxTreeTool::~MBOrientedBoxTreeTool()
+ return;
+ MBErrorCode rval = instance->tag_get_data( tagHandle, &tree, 1, &data_ptr );
MBOrientedBoxTreeTool::Settings::Settings()
: max_leaf_entities( 8 ),
max_depth( 0 ),
@@ -148,8 +166,18 @@
return rval;
- return build_sets( data, set_handle_out, 0,
- settings ? *settings : Settings() );
+ MBErrorCode result = build_sets( data, set_handle_out, 0,
+ settings ? *settings : Settings() );
+ if (MB_SUCCESS != result)
+ return result;
+ for (MBRange::reverse_iterator i = sets.rbegin(); i != sets.rend(); ++i) {
+ std::remove( createdTrees.begin(), createdTrees.end(), *i ),
+ createdTrees.push_back( set_handle_out );
+ return MB_SUCCESS;
@@ -287,6 +315,7 @@
{ delete_tree( set ); return rval; }
+ createdTrees.push_back( set );
return MB_SUCCESS;
@@ -428,6 +457,9 @@
return rval;
+ std::remove( createdTrees.begin(), createdTrees.end(), set ),
children.insert( children.begin(), set );
return instance->delete_entities( &children[0], children.size() );
Modified: MOAB/trunk/MBOrientedBoxTreeTool.hpp
--- MOAB/trunk/MBOrientedBoxTreeTool.hpp 2009-01-06 21:19:07 UTC (rev 2509)
+++ MOAB/trunk/MBOrientedBoxTreeTool.hpp 2009-01-06 21:43:42 UTC (rev 2510)
@@ -85,8 +85,11 @@
- const char* tag_name = 0 ) ;
+ const char* tag_name = 0,
+ bool destroy_created_trees = false ) ;
+ ~MBOrientedBoxTreeTool();
/**\brief Build oriented bounding box tree
* Build an oriented bounding box tree.
@@ -336,6 +339,9 @@
MBInterface* instance;
MBTag tagHandle;
#endif
