[MOAB-dev] r2086 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Sep 24 09:58:33 CDT 2008
Author: kraftche
Date: 2008-09-24 09:58:33 -0500 (Wed, 24 Sep 2008)
New Revision: 2086
Modified:
MOAB/trunk/MBMeshSet.cpp
MOAB/trunk/MBTest.cpp
Log:
o Fix bug in insertion routine for set-based mesh sets where the set
contents were corrupted when an input range of handles ended with
the same value as a range of handles in the set.
o Fix new regression test for above bug: expected number of values in
meshset depends on whether or not the MESHSET_SET flag is set during
creation.
Modified: MOAB/trunk/MBMeshSet.cpp
--- MOAB/trunk/MBMeshSet.cpp 2008-09-24 04:14:56 UTC (rev 2085)
+++ MOAB/trunk/MBMeshSet.cpp 2008-09-24 14:58:33 UTC (rev 2086)
@@ -479,9 +479,9 @@
// discard any input blocks already in the set
for (; i != end && i->second <= list_write[1]; ++i);
- if (i == end) {
+ if (i == end || i->first > list_write[1]+1) {
list_write += 2;
- break;
+ continue;
// merge subsequent blocks in meshset
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2008-09-24 04:14:56 UTC (rev 2085)
+++ MOAB/trunk/MBTest.cpp 2008-09-24 14:58:33 UTC (rev 2086)
@@ -1366,29 +1366,26 @@
return result;
MBEntityHandle handle_array[] = {1, 2, 3, 4, 5, 7, 8, 9, 10};
+ const int num_handle = sizeof(handle_array)/sizeof(handle_array[0]);
//add ents to set
- result = MB->add_entities( temp_ms3, handle_array,
- sizeof(handle_array)/sizeof(MBEntityHandle));
+ result = MB->add_entities( temp_ms3, handle_array, num_handle );
if(result != MB_SUCCESS )
return result;
// try adding again
return result;
int num_ents;
result = MB->get_number_entities_by_handle(temp_ms3, num_ents);
- if(result != MB_SUCCESS ) return result;
- else if (num_ents != sizeof(handle_array)/sizeof(MBEntityHandle))
+ if(result != MB_SUCCESS )
+ return result;
+ int num_expected = (flags & MESHSET_SET) ? num_handle : 2*num_handle;
+ if (num_ents != num_expected)
return MB_FAILURE;
- return result;
return MB_SUCCESS;
