[MOAB-dev] r2085 - MOAB/trunk
tautges at mcs.anl.gov
Tue Sep 23 23:14:56 CDT 2008
Author: tautges
Date: 2008-09-23 23:14:56 -0500 (Tue, 23 Sep 2008)
New Revision: 2085
Modified:
MOAB/trunk/MBTest.cpp
Log:
Committing a test which will break the meshset test. Jason, you'll need to look at this one, looks like an off-by-one type of error in both range and vector sets.
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2008-09-23 20:17:15 UTC (rev 2084)
+++ MOAB/trunk/MBTest.cpp 2008-09-24 04:14:56 UTC (rev 2085)
@@ -1359,6 +1359,36 @@
result = check_esets(MB, start_num_sets + MBENTITYSET - MBEDGE + 4);
if (MB_SUCCESS != result) return result;
+ //-------------Misc tests--------------
+ MBEntityHandle temp_ms3;
+ result = MB->create_meshset(flags, temp_ms3);
+ if(result != MB_SUCCESS )
+ return result;
+ MBEntityHandle handle_array[] = {1, 2, 3, 4, 5, 7, 8, 9, 10};
+ //add ents to set
+ result = MB->add_entities( temp_ms3, handle_array,
+ sizeof(handle_array)/sizeof(MBEntityHandle));
+ return result;
+ // try adding again
+ return result;
+ int num_ents;
+ result = MB->get_number_entities_by_handle(temp_ms3, num_ents);
+ if(result != MB_SUCCESS ) return result;
+ else if (num_ents != sizeof(handle_array)/sizeof(MBEntityHandle))
+ return MB_FAILURE;
+ return result;
return MB_SUCCESS;
