[MOAB-dev] r2069 - MOAB/trunk/tools/iMesh
tautges at mcs.anl.gov
Sun Sep 21 20:13:53 CDT 2008
Author: tautges
Date: 2008-09-21 20:13:52 -0500 (Sun, 21 Sep 2008)
New Revision: 2069
Modified:
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
ixed various imesh errors:
- if handle is passed into load function, fill that set
with entities read in
- in getVtxCoordIndex, get complete connectivity, not just
topological connectivity; also, don't get connectivity for
vertices
- in createEnt, removed block for creating vertices, since
this is checked for and disallowed earlier; also, implemented this
function in createEnt, rather than calling to createEntArr, so that
higher-order entities can be created
Passes make check.
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-09-19 19:44:47 UTC (rev 2068)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-09-22 01:13:52 UTC (rev 2069)
@@ -188,6 +188,8 @@
iBase_FILE_WRITE_ERROR, // MB_FILE_WRITE_ERROR,
iBase_NOT_SUPPORTED, // MB_NOT_IMPLEMENTED,
iBase_TAG_ALREADY_EXISTS, // MB_ALREADY_ALLOCATED,
+ iBase_FAILURE, // MB_VARIABLE_DATA_LENGTH,
+ iBase_FAILURE, // MB_INVALID_SIZE,
iBase_FAILURE // MB_FAILURE};
@@ -324,6 +326,14 @@
iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
+ if (handle) {
+ MBRange set_ents;
+ result = MBI->get_entities_by_handle(file_set, set_ents);
+ if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
+ result = MBI->add_entities(ENTITY_HANDLE(handle), set_ents);
// create interior edges/faces if requested
if (MBimesh->AdjTable[5] || MBimesh->AdjTable[10]) {
MBRange set_ents;
@@ -587,7 +597,7 @@
int i;
for (ent_it = req_entities.begin(), i = 0; ent_it != req_entities.end();
ent_it++, i++) {
- MBErrorCode result = MBI->get_connectivity(*ent_it, tmp_connect, num_connect, true);
+ MBErrorCode result = MBI->get_connectivity(*ent_it, tmp_connect, num_connect);
if (MB_SUCCESS != result) {
std::string msg("iMesh_getVtxCoordIndex: couldn't get connectivity, with error type: ");
msg += MBI->get_error_string(result);
@@ -754,7 +764,7 @@
const MBEntityHandle *connect;
int num_connect;
MBErrorCode result;
- for (MBRange::iterator rit = entities.begin(); rit != entities.end(); rit++) {
+ for (MBRange::const_iterator rit = entities.lower_bound(MBEDGE); rit != entities.end(); rit++) {
result = MBI->get_connectivity(*rit, connect, num_connect);
num_sub += num_connect;
@@ -789,6 +799,11 @@
for (MBRange::iterator rit = entities.begin(); rit != endr; rit++) {
adj_ents.clear();
(*offset)[i] = num_sub;
+ if (to_dim == 0 && MBI->type_from_handle(*rit) == MBVERTEX) {
+ i++;
+ continue;
result = MBI->get_adjacencies(&(*rit), 1, (int)entity_type_requested, false,
adj_ents);
@@ -1581,34 +1596,20 @@
// make the entities
MBEntityHandle *new_ents = HANDLE_ARRAY_PTR(*new_entity_handles);
- static double dum_coords[] = {0.0, 0.0, 0.0};
MBErrorCode tmp_result, result = MB_SUCCESS;
- if (this_type == MBVERTEX) {
- for (int i = 0; i < num_ents; i++) {
- tmp_result = MBI->create_vertex(dum_coords, new_ents[i]);
- if (MB_SUCCESS != tmp_result) {
- (*status)[i] = iBase_CREATION_FAILED;
- result = tmp_result;
- else
- (*status)[i] = iBase_NEW;
- else {
- tmp_result = MBI->create_element(this_type, lower_ents, num_verts,
- new_ents[i]);
- else
+ for (int i = 0; i < num_ents; i++) {
+ tmp_result = MBI->create_element(this_type, lower_ents, num_verts,
+ new_ents[i]);
+ if (MB_SUCCESS != tmp_result) {
+ (*status)[i] = iBase_CREATION_FAILED;
+ result = tmp_result;
+ else
+ (*status)[i] = iBase_NEW;
- lower_ents += num_verts;
+ lower_ents += num_verts;
@@ -2051,13 +2052,21 @@
RETURN(iBase_INVALID_ENTITY_COUNT);
- int dum = 1;
- iMesh_createEntArr(instance, new_entity_topology,
- lower_order_entity_handles,
- lower_order_entity_handles_size,
- &new_entity_handle,
- &dum, &dum,
- &status, &dum, &dum, err);
+ // call MB directly to allow creation of higher-order entities
+ // directly from connectivity
+ MBEntityType this_type = mb_topology_table[new_entity_topology];
+ MBEntityHandle tmp_ent;
+ MBErrorCode result = MBI->create_element(this_type,
+ CONST_HANDLE_ARRAY_PTR(lower_order_entity_handles),
+ lower_order_entity_handles_size,
+ tmp_ent);
+ *status = iBase_CREATION_FAILED;
+ else
+ *status = iBase_SUCCESS;
+ *new_entity_handle = CAST_TO_VOID(tmp_ent);
+ *err = *status;
void iMesh_deleteEnt(iMesh_Instance instance,
