itaps-parallel Re: [MOAB-dev] parallel itaps (more patches)
Vitus Leung
vjleung at sandia.gov
Tue Sep 16 14:36:54 CDT 2008
Tim,
Have you had a chance to put the data for MOAB/Zoltan performance tests
on mesh.ep yet?
Vitus
On Mon, 2008-09-15 at 07:55 -0600, Tim Tautges wrote:
> Thanks Jed. I'm forwarding to itaps-parallel too. A few notes:
> 1. We spoke at length among the itaps team about iMeshP last week,
> resulting in some changes to the spec which will happen, particularly
> with exchanging tags. Stay tuned, but the changes will likely improve
> things rather than make things worse.
> 2. Your comments are relevant as much or more to MOAB's implementation
> of iMeshP than they are to the interface in general, and my
> implementation is partial at best. I don't do anything special with
> parts or partitions, so that support is questionable. I will have full
> support by the SC08 conference in November, but probably won't start in
> earnest until Oct 1.
> 3. We're still talking about load options, but in the meantime you're
> fine using the options below. They won't be interoperable, but I'm
> hoping the interoperable version will look something like it (started
> discussing this on Fri).
> - tim
> Jed Brown wrote:
> > I realize that the iMeshP interface has not stabilized, let alone been
> > fully implemented yet, but I'm beginning to use it anyway :-)
> > That is, I'm loading a mesh with
> > PARALLEL=BCAST_DELETE;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;
> > and interrogating it using iMeshP to create a global ordering from which
> > I can build a function space. It would be handy to have
> > iMeshP_ExchTags() (inconsistent case in original) implemented for
> > managing adaptive p-refinement. (I think this is not difficult so I'll
> > look into it if nobody beats me to it.) While implementing this stuff
> > in my code, I found more inconsistencies and made a few minor bug fixes.
> > The latest iMeshP.h mentioned on the itaps-parallel mailing list
> > http://www-unix.mcs.anl.gov/web-mail-archive/lists/itaps-parallel/2008/07/msg00016.html
> > does not provide a way to get a PartHandle. You can create one, but
> > cannot access existing parts without significant obfuscation (find an
> > entity, get the part ID of the owning Part, then get the handle
> > associated with the part ID). The MOAB implementation has
> > iMeshP_getPartsOnRank() which is only implemented when rank is the local
> > rank (I modified the function to return NOT_IMPLEMENTED rather than
> > erroneous part handles when the rank is remote). There is a comment at
> > the bottom of the (mailing list version of) iMeshP.h that
> > iMeshP_getPartsOnRank() may not be a good idea due to memory costs to
> > provide this without communication. For my usage, I would be happy with
> > the purely local
> > void iMeshP_getParts(iMesh_Instance instance,
> > iMeshP_PartitionHandle partition_handle,
> > iMeshP_PartHandle **part_handles,
> > int *part_handles_allocated,
> > int *part_handles_size,
> > int *err);
> > The 'const' annotations are meaningless for pass-by-value, but still
> > appear throughout the ITAPS headers. Is there a reason for this?
> > In iMeshP_getEntStatus(), the returned status is not dependent on the
> > PartHandle that is passed in. This is probably more useful, but it's
> > certainly not what the spec intended. (Of course all implemented
> > functions ignore the PartitionHandle but that is clearly a deeper
> > issue.)
> > Bug fixes include off-by-one and indexing beyond an array. I ran into
> > another incorrectly spec'd type in iMesh_extensions.h.
> > Since my previous patches have not hit the repository yet, the attached
> > patch is an aggregate.
> > Jed
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
