[MOAB-dev] MOAB check for *AMD64-32* failed.
Nightly Test kraftche at cae.wisc.edu
Tue Sep 9 02:27:30 CDT 2008
HDF5-DIAG: Error detected in HDF5 library version: 1.6.6 thread 67381712.  Back trace follows.
  #000: ../../../src/H5D.c line 1169 in H5Dopen(): not found
    major(15): Dataset interface
    minor(48): Object not found
  #001: ../../../src/H5G.c line 1783 in H5G_find(): object not found
    major(10): Symbol table layer
  #002: ../../../src/H5Gtraverse.c line 395 in H5G_namei(): component not found
  #003: ../../../src/H5Gstab.c line 161 in H5G_stab_find(): not found
  #004: ../../../src/H5Gnode.c line 954 in H5G_node_found(): not found
==30850== Invalid read of size 1
==30850==    at 0x4C23238: memcpy (mc_replace_strmem.c:402)
==30850==    by 0x4EA78C: SparseTagCollection::set_data(unsigned, void const*) (SparseTagCollection.cpp:79)
==30850==    by 0x4E84F1: SparseTagSuperCollection::set_data(unsigned long, MBRange const&, void const*) (SparseTagSuperCollection.cpp:170)
==30850==    by 0x459E3A: TagServer::set_data(void**, MBRange const&, void const*) (TagServer.cpp:337)
==30850==    by 0x41ED62: MBCore::tag_set_data(void**, MBRange const&, void const*) (MBCore.cpp:1456)
==30850==    by 0x41004F: test_get_set(char const*, unsigned, MBTagType, MBDataType, void const*, int, void const*, bool, bool) (TagTest.cpp:481)
==30850==    by 0x410F6E: test_get_pointers_dense() (TagTest.cpp:672)
==30850==    by 0x411347: run_test(void (*)(), char const*) (TestUtil.hpp:276)
==30850==    by 0x411466: main (TagTest.cpp:48)
==30850==  Address 0x689b6cf is 3 bytes after a block of size 20 alloc'd
==30850==    at 0x4C21849: operator new(unsigned long) (vg_replace_malloc.c:230)
==30850==    by 0x416696: __gnu_cxx::new_allocator<unsigned char>::allocate(unsigned long, void const*) (new_allocator.h:92)
==30850==    by 0x4166C5: std::_Vector_base<unsigned char, std::allocator<unsigned char> >::_M_allocate(unsigned long) (stl_vector.h:144)
==30850==    by 0x41670A: std::_Vector_base<unsigned char, std::allocator<unsigned char> >::_Vector_base(unsigned long, std::allocator<unsigned char> const&) (stl_vector.h:117)
==30850==    by 0x416A94: std::vector<unsigned char, std::allocator<unsigned char> >::vector(unsigned long, unsigned char const&, std::allocator<unsigned char> const&) (stl_vector.h:235)
==30850==    by 0x40FF1E: test_get_set(char const*, unsigned, MBTagType, MBDataType, void const*, int, void const*, bool, bool) (TagTest.cpp:478)
==30850==
==30850==    at 0x4C23241: memcpy (mc_replace_strmem.c:402)
==30850==  Address 0x689b6ce is 2 bytes after a block of size 20 alloc'd
==30850==
==30850==    at 0x4C23248: memcpy (mc_replace_strmem.c:402)
==30850==  Address 0x689b6cd is 1 bytes after a block of size 20 alloc'd
==30850==
==30850==    at 0x4C2324F: memcpy (mc_replace_strmem.c:402)
==30850==  Address 0x689b6cc is 0 bytes after a block of size 20 alloc'd
make[2]: *** [check-TESTS] Error 1
make[1]: *** [check-am] Error 2
make: *** [check-recursive] Error 1
s: MBCN_FCDefs.h is unchanged
config.status: executing depfiles commands
make  all-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64-32'
Making all in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making all in .
make[2]: Entering directory `/home/jason/moab/test/AMD64-32'
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c -o MBRangeSeqIntersectIter.lo ../src/MBRangeSeqIntersectIter.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c -o MBReadUtil.lo ../src/MBReadUtil.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c -o MBWriteUtil.lo ../src/MBWriteUtil.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c -o MeshSetSequence.lo ../src/MeshSetSequence.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c -o SequenceManager.lo ../src/SequenceManager.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c -o TagServer.lo ../src/TagServer.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c -o AEntityFactory.lo ../src/AEntityFactory.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c -o HigherOrderFactory.lo ../src/HigherOrderFactory.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c ../src/MeshSetSequence.cpp -o MeshSetSequence.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c ../src/MBRangeSeqIntersectIter.cpp -o MBRangeSeqIntersectIter.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c ../src/TagServer.cpp -o TagServer.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c ../src/HigherOrderFactory.cpp -o HigherOrderFactory.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c ../src/SequenceManager.cpp -o SequenceManager.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c ../src/MBWriteUtil.cpp -o MBWriteUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c ../src/MBReadUtil.cpp -o MBReadUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c ../src/AEntityFactory.cpp -o AEntityFactory.o
mv -f .deps/MBRangeSeqIntersectIter.Tpo .deps/MBRangeSeqIntersectIter.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c -o MBCore.lo ../src/MBCore.cpp
mv -f .deps/MBReadUtil.Tpo .deps/MBReadUtil.Plo
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -Wall -pipe -g -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c ../src/MBCore.cpp -o MBCore.o
mv -f .deps/MBWriteUtil.Tpo .deps/MBWriteUtil.Plo
mv -f .deps/HigherOrderFactory.Tpo .deps/HigherOrderFactory.Plo
mv -f .deps/TagServer.Tpo .deps/TagServer.Plo
mv -f .deps/MeshSetSequence.Tpo .deps/MeshSetSequence.Plo
mv -f .deps/AEntityFactory.Tpo .deps/AEntityFactory.Plo
mv -f .deps/SequenceManager.Tpo .deps/SequenceManager.Plo
mv -f .deps/MBCore.Tpo .deps/MBCore.Plo
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o libMOAB.la -rpath /usr/local/lib AEntityFactory.lo DualTool.lo EntitySequence.lo ExoIIUtil.lo FileOptions.lo FileTokenizer.lo GeomTopoTool.lo HigherOrderFactory.lo HomXform.lo MBAdaptiveKDTree.lo MBAffineXform.lo MBAlloc.lo MBAxisBox.lo MBBits.lo MBBSPTree.lo MBCN.lo MBCartVect.lo MBHandleUtils.lo MBMatrix3.lo MBCore.lo MBFactory.lo MBGeomUtil.lo MBMeshSet.lo MBOrientedBox.lo MBOrientedBoxTreeTool.lo MBRange.lo MBRangeSeqIntersectIter.lo MBReadUtil.lo MBReaderWriterSet.lo MBSkinner.lo MBSysUtil.lo MBUtil.lo MBWriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ReadGmsh.lo ReadSTL.lo ReadVtk.lo ReadIDEAS.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo TagInfo.lo TagServer.lo Tqdcfr.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo VtkUtil.lo WriteAns.lo WriteGMV.lo WriteGmsh.lo !
 WriteSTL.lo WriteTemplate.lo WriteVtk.lo ReadNCDF.lo WriteNCDF.lo WriteSLAC.lo ReadHDF5.lo WriteHDF5.lo -lnetcdf_c++ -lnetcdf -lhdf5 ./mhdf/libmhdf.la  -lm
rm -fr  .libs/libMOAB.a .libs/libMOAB.la .libs/libMOAB.lai
rm -fr .libs/libMOAB.lax
mkdir .libs/libMOAB.lax
rm -fr .libs/libMOAB.lax/libmhdf.a
mkdir .libs/libMOAB.lax/libmhdf.a
(cd .libs/libMOAB.lax/libmhdf.a && ar x /home/jason/moab/test/AMD64-32/./mhdf/.libs/libmhdf.a)
ar cru .libs/libMOAB.a  AEntityFactory.o DualTool.o EntitySequence.o ExoIIUtil.o FileOptions.o FileTokenizer.o GeomTopoTool.o HigherOrderFactory.o HomXform.o MBAdaptiveKDTree.o MBAffineXform.o MBAlloc.o MBAxisBox.o MBBits.o MBBSPTree.o MBCN.o MBCartVect.o MBHandleUtils.o MBMatrix3.o MBCore.o MBFactory.o MBGeomUtil.o MBMeshSet.o MBOrientedBox.o MBOrientedBoxTreeTool.o MBRange.o MBRangeSeqIntersectIter.o MBReadUtil.o MBReaderWriterSet.o MBSkinner.o MBSysUtil.o MBUtil.o MBWriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ReadGmsh.o ReadSTL.o ReadVtk.o ReadIDEAS.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o TagInfo.o TagServer.o Tqdcfr.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o WriteSTL.o WriteTemplate.o WriteVtk.o ReadNCDF.o WriteNCDF.o WriteSLAC.o ReadHDF5.o WriteHDF5.o  .libs/libMOAB.lax/libmhdf.a/adjacency.o!
  .libs/libMOAB.lax/libmhdf.a/file-handle.o .libs/libMOAB.lax/libmhdf.a/status.o .libs/libMOAB.lax/libmhdf.a/tags.o .libs/libMOAB.lax/libmhdf.a/file.o .libs/libMOAB.lax/libmhdf.a/nodes.o .libs/libMOAB.lax/libmhdf.a/sets.o .libs/libMOAB.lax/libmhdf.a/connectivity.o .libs/libMOAB.lax/libmhdf.a/util.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making all in test
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/test'
Making all in dual
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/dual'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/dual'
Making all in h5file
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/h5file'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/h5file'
Making all in obb
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/obb'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/obb'
Making all in perf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
Making all in tools
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
Making all in converter
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/converter'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mbconvert convert.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o mbconvert convert.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/converter'
Making all in hexmodops
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o hexmodops makeops.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o hexmodops makeops.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
Making all in mbperf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../../src/tools/mbperf -I../.. -I../../../src -I../.. -I../../../src/tools/iMesh -I../../../src/tools/iMesh/SIDL/mserver -I../iMesh/SIDL/mserver   -DVALGRIND  -Wall -pipe -g -MT mbperf.o -MD -MP -MF .deps/mbperf.Tpo -c -o mbperf.o ../../../src/tools/mbperf/mbperf.cpp
mv -f .deps/mbperf.Tpo .deps/mbperf.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mbperf mbperf.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o mbperf mbperf.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
Making all in size
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/size'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mbsize measure.o size.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o mbsize measure.o size.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/size'
Making all in skin
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/skin'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mbskin skin.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o mbskin skin.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/skin'
Making all in tagprop
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/tagprop'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mbtagprop parse.o propagate_tags.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o mbtagprop parse.o propagate_tags.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/tagprop'
Making all in spheredecomp
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/spheredecomp'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o spheredecomp SphereDecomp.o main.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o spheredecomp SphereDecomp.o main.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/spheredecomp'
Making all in surfplot
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/surfplot'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mbsurfplot surfplot.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o mbsurfplot surfplot.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/surfplot'
Making all in dagmc
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/dagmc'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/dagmc'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
Making all in doc
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/doc'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/doc'
Making all in doxygen
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/doxygen'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/doxygen'
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making check in .
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test internals_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test kd_tree_tool kd_tree_time
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT scdseq_test.o -MD -MP -MF .deps/scdseq_test.Tpo -c -o scdseq_test.o ../src/scdseq_test.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DTEST_TQDCFR -Wall -pipe -g -Wall -pipe -g -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c -o tqdcfr-Tqdcfr.o `test -f 'Tqdcfr.cpp' || echo '../src/'`Tqdcfr.cpp
make[2]: `file_options_test' is up to date.
make[2]: `var_len_test' is up to date.
make[2]: `var_len_test_no_template' is up to date.
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT TagTest.o -MD -MP -MF .deps/TagTest.Tpo -c -o TagTest.o ../src/TagTest.cpp
mv -f .deps/scdseq_test.Tpo .deps/scdseq_test.Po
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND  -Wall -pipe -g -MT MBTest.o -MD -MP -MF .deps/MBTest.Tpo -c -o MBTest.o ../src/MBTest.cpp
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -g -Wall -pipe -g  -lm -o homxform_test homxform_test-HomXform.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o seq_man_test TestTypeSequenceManager.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o internals_test internals_test.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o scdseq_test scdseq_test.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o test_adj test_adj.o ./libMOAB.la -lm
c++ -DTEST -Wall -pipe -g -Wall -pipe -g -o homxform_test homxform_test-HomXform.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o scdseq_test scdseq_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
mv -f .deps/TagTest.Tpo .deps/TagTest.Po
c++ -Wall -pipe -g -o seq_man_test TestTypeSequenceManager.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o internals_test internals_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o geom_util_test GeomUtilTests.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o test_adj test_adj.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o geom_util_test GeomUtilTests.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -g -Wall -pipe -g  -lm -o xform_test xform_test-MBAffineXform.o ./libMOAB.la -lm
mv -f .deps/tqdcfr-Tqdcfr.Tpo .deps/tqdcfr-Tqdcfr.Po
c++ -DTEST -Wall -pipe -g -Wall -pipe -g -o xform_test xform_test-MBAffineXform.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o obb_test OBBTest.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o vtk_test VtkTest.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o bsp_tree_test bsp_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o obb_test OBBTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o vtk_test VtkTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o bsp_tree_test bsp_tree_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o kd_tree_test kd_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o kd_tree_test kd_tree_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o mesh_set_test Test_MBMeshSet.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o tag_test TagTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o mesh_set_test Test_MBMeshSet.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o tag_test TagTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
mv -f .deps/MBTest.Tpo .deps/MBTest.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o kd_tree_tool kd_tree_tool.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o kd_tree_tool kd_tree_tool.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o kd_tree_time kd_tree_time.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g  -lm -o moab_test MBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o kd_tree_time kd_tree_time.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST_TQDCFR -Wall -pipe -g -Wall -pipe -g  -lm -o tqdcfr tqdcfr-Tqdcfr.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o moab_test MBTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -DTEST_TQDCFR -Wall -pipe -g -Wall -pipe -g -o tqdcfr tqdcfr-Tqdcfr.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make  check-TESTS
Size of mConnMap = 9648
Size of mUpConnMap = 59904
Size of MBCN = 1
MB TEST PROGRAM:
   mb_adjacent_vertex_test: Success
   mb_adjacencies_test: Success
   mb_vertex_coordinate_test: Success
   mb_vertex_tag_test: Success
   mb_bar_connectivity_test: Success
   mb_tri_connectivity_test: Success
   mb_quad_connectivity_test: Success
   mb_tet_connectivity_test: Success
   mb_temporary_test: Success
   mb_hex_connectivity_test: Success
   mb_mesh_sets_set_test: Success
   mb_mesh_sets_list_test: Success
   mb_mesh_set_parent_child_test: Success
   mb_tags_test: Success
   mb_dense_tag_test: Success
   mb_sparse_tag_test: Success
   mb_write_mesh_test: Success
   mb_delete_mesh_test: Success
   mb_meshset_tracking_test: Success
   mb_higher_order_test: Success
   mb_bit_tags_test: Success
   mb_entity_conversion_test: Success
   mb_forced_adjacencies_test: Success
   mb_canon_number_test: Success
   mb_poly_test: Success
   mb_range_test: Success
   mb_topo_util_test: Success
   mb_split_test: Success
   mb_range_seq_intersect_test: Success
   mb_proc_subset_test: Success
   mb_poly_adjacency_test: Success
   mb_memory_use_test: Success
   mb_merge_test: ---Starting Merge Tests---
---Testing:"test/cell1.gen"---
Loaded test/cell1.gen
---Testing:"test/cell2.gen"---
Loaded test/cell2.gen
num hexes = 28
fl = 68 rl = 0
nodes.size() = 72
---Success---
coin_nodes.size() = 13
TIME: 1211.63 seconds.
Success
   mb_stress_test:     Beginning Stress Test . . .
        Reading elements
        Read 256000 entities in 28.49 seconds
        at 8985.61 elements per second.
        Transforming and copying elements
        Transformed and created 256000 entities in 117.11 seconds
        Creating meshset
        Created meshset with 512000 entities in 0 seconds
        Writing 512K element file . . .
        Wrote file with 512000 entities in 281.4 seconds
        Total time: 427.01 seconds.
Success
MB TEST SUMMARY:
   Number Tests:           34
   Number Successful:      34
   Number Failed:          0
PASS: moab_test
All tests passed.
PASS: homxform_test
All tests passed.
PASS: scdseq_test
Usage: tqdcfr <cub_file_name>
Success.
Success.
PASS: tqdcfr
PASS: test_adj
Running test_basic ...
Running test_lower_bound ...
Running test_upper_bound ...
Running test_find ...
Running test_get_entities ...
Running test_insert_sequence_merge ...
Running test_insert_sequence_nomerge ...
Running test_remove_sequence ...
Running test_replace_subsequence ...
Running test_erase ...
Running test_find_free_handle ...
Running test_find_free_sequence ...
Running test_is_free_sequence ...
Running regression_svn1952 ...
Running regression_svn1958 ...
Running regression_svn1960 ...
ALL TESTS PASSED
PASS: seq_man_test
3684 tests passed.
PASS: internals_test
Running test_box_plane_overlap ...
Running test_box_linear_elem_overlap_tri ...
Running test_box_linear_elem_overlap_tet ...
Running test_box_linear_elem_overlap_hex ...
Running test_box_tri_overlap ...
Running test_box_tet_overlap ...
Running test_box_hex_overlap ...
Running test_ray_tri_intersect ...
Running test_closest_location_on_tri ...
Running test_closest_location_on_polygon ...
Running test_segment_box_intersect ...
Running test_closest_location_on_box ...
PASS: geom_util_test
PASS: xform_test
PASS: obb_test
Testing edge2...
Testing edge3...
Testing tri3...
Testing tri6...
Testing quad4...
Testing quad8...
Testing polygon...
Testing tet4...
Testing tet10...
Testing hex8...
Testing hex20...
Testing wedge...
Testing pyramid...
Testing structured_points_2d...
Testing structured_grid_2d...
Testing rectilinear_grid_2d...
Testing structured_points_3d...
Testing structured_grid_3d...
Testing rectilinear_grid_3d...
Testing scalar_attrib_1_bit...
Testing scalar_attrib_1_uchar...
Testing scalar_attrib_1_char...
Testing scalar_attrib_1_ushort...
Testing scalar_attrib_1_short...
Testing scalar_attrib_1_uint...
Testing scalar_attrib_1_int...
Testing scalar_attrib_1_ulong...
Testing scalar_attrib_1_long...
Testing scalar_attrib_1_float...
Testing scalar_attrib_1_double...
Testing scalar_attrib_4_bit...
Testing scalar_attrib_4_uchar...
Testing scalar_attrib_4_char...
Testing scalar_attrib_4_ushort...
Testing scalar_attrib_4_short...
Testing scalar_attrib_4_uint...
Testing scalar_attrib_4_int...
Testing scalar_attrib_4_ulong...
Testing scalar_attrib_4_long...
Testing scalar_attrib_4_float...
Testing scalar_attrib_4_double...
Testing vector_attrib_bit...
Testing vector_attrib_uchar...
Testing vector_attrib_char...
Testing vector_attrib_ushort...
Testing vector_attrib_short...
Testing vector_attrib_uint...
Testing vector_attrib_int...
Testing vector_attrib_ulong...
Testing vector_attrib_long...
Testing vector_attrib_float...
Testing vector_attrib_double...
Testing tensor_attrib_uchar...
Testing tensor_attrib_char...
Testing tensor_attrib_ushort...
Testing tensor_attrib_short...
Testing tensor_attrib_uint...
Testing tensor_attrib_int...
Testing tensor_attrib_ulong...
Testing tensor_attrib_long...
Testing tensor_attrib_float...
Testing tensor_attrib_double...
Testing subset...
63 tests passed
PASS: vtk_test
PASS: adaptive_kd_tree_tests
Running test_iterator ...
Running test_box_iterator ...
Running test_tree_create ...
Running test_box_tree_create ...
Running test_leaf_containing_point_bounded_tree ...
Running test_leaf_containing_point_unbounded_tree ...
Running test_merge_leaf ...
PASS: bsp_tree_test
PASS: file_options_test
PASS: kd_tree_test
Running test_valid_struct ...
Running test_inline ...
Running test_non_inline ...
Running test_resize_ii ...
Running test_resize_in ...
Running test_resize_ni ...
Running test_resize_nn ...
PASS: var_len_test
PASS: var_len_test_no_template
Running test_create_tag ...
Running test_invalid_tag_size ...
Running test_get_set_sparse_int ...
Running test_get_set_dense_int ...
Running test_get_set_dense_double ...
Running test_get_set_bit ...
Running test_get_by_tag ...
Running test_get_by_tag_value ...
Running test_mesh_value ...
Running test_get_pointers_sparse ...
Running test_get_pointers_dense ...
Running test_set_pointers_sparse ...
Running test_set_pointers_dense ...
Running test_get_entity_tags ...
Running test_delete_sparse_tag ...
Running test_delete_dense_tag ...
Running test_delete_mesh_tag ...
Running test_delete_sparse_data ...
Running test_delete_dense_data ...
Running test_delete_bit_data ...
Running test_create_variable_length_tag ...
Running test_get_set_variable_length_sparse ...
Running test_get_set_variable_length_dense ...
Running test_get_set_variable_length_mesh ...
Running regression_one_entity_by_var_tag ...
Running regression_tag_on_nonexistent_entity ...
FAIL: tag_test
Running test_add_entities_ordered ...
Running test_add_entities_set ...
Running test_add_entities_ordered_tracking ...
Running test_add_entities_set_tracking ...
Running test_remove_entities_ordered ...
Running test_remove_entities_set ...
Running test_remove_entities_ordered_tracking ...
Running test_remove_entities_set_tracking ...
Running test_entities_by_type_ordered ...
Running test_entities_by_type_set ...
Running test_entities_by_dim_ordered ...
Running test_entities_by_dim_set ...
Running test_subtract_set_set ...
Running test_subtract_set_ordered ...
Running test_subtract_ordered_set ...
Running test_subtract_ordered_ordered ...
Running test_subtract_set_set_tracking ...
Running test_subtract_set_ordered_tracking ...
Running test_subtract_ordered_set_tracking ...
Running test_subtract_ordered_ordered_tracking ...
Running test_itersect_set_set ...
Running test_itersect_set_ordered ...
Running test_itersect_ordered_set ...
Running test_itersect_ordered_ordered ...
Running test_itersect_set_set_tracking ...
Running test_itersect_set_ordered_tracking ...
Running test_itersect_ordered_set_tracking ...
Running test_itersect_ordered_ordered_tracking ...
Running test_unite_set_set ...
Running test_unite_set_ordered ...
Running test_unite_ordered_set ...
Running test_unite_ordered_ordered ...
Running test_unite_set_set_tracking ...
Running test_unite_set_ordered_tracking ...
Running test_unite_ordered_set_tracking ...
Running test_unite_ordered_ordered_tracking ...
Running test_contains_entities_ordered ...
Running test_contains_entities_set ...
Running test_clear_ordered ...
Running test_clear_set ...
Running test_clear_ordered_tracking ...
Running test_clear_set_tracking ...
ALL TESTS PASSED
PASS: mesh_set_test
1 of 19 tests failed
