[MOAB-dev] Incomplete types versus void * in ITAPS interfaces
Tim Tautges
tautges at mcs.anl.gov
Sun Sep 7 16:21:09 CDT 2008
I don't think that's quite what I had in mind, based on Jed's question.
I see the struct pointers still as proxies for what the handles really
are down in the implementations; thus, my question about whether we
really need to define the private structure or just reference it. The
only thing I see us doing with these *'s is casting them to what our
handles really are, in the implementation. Using private struct *'s
simply allows us to differentiate between the various types of handles,
rather than using void* for all of them. That's what gives us the
compile time type checking.
- tim
Carl Ollivier-Gooch wrote:
> Tim Tautges wrote:
>> Interesting question, which I'm forwarding to the rest of the ITAPS
>> interface group. One question, would that require you to actually
>> define the private structure, or just reference it? The extra type
>> checking would be very useful (and would be useful inside MOAB as
>> well...).
> My first reaction was that I never would have thought that this would be
> compilable. Jed obviously knows something about C syntax that I don't,
> because it does seem to work, at least in terms of compiling and linking
> (see attached files). I defined two different structs, one in C, one in
> C++, and both linked fine (as in: both test2.o and test3.o link with
> test.o with no complaints). Mind you, I never tried to do anything
> beyond what's in these files, so it's possible that the compiler
> optimized away anything that might have been a problem.
> From the implementation side, if we made this change, we'd all have to
> have an explicit iBase_EntityHandle_Private (plus half a dozen or so
> others), but in exchange we get type checking and may be able to avoid a
> bunch of casts (that's probably implementation dependent...
> Carl
>> Jed Brown wrote:
>>> Sorry if this is the wrong list for this, but why are all the opaque
>>> handles typedef'd to void * instead of incomplete types. That is, why
>>> not something like
>>> typedef struct iBase_EntityHandle_Private *iBase_EntityHandle;
>>> in order to get some extra type checking? Correct existing code should
>>> not see any difference. With this change, a possible logic error (using
>>> EntitySetHandle for an EntitySet) in the VisIt plugin would be caught by
>>> the compiler.
>>> Jed
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
