[MOAB-dev] Incomplete types versus void * in ITAPS interfaces
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Sun Sep 7 15:14:43 CDT 2008
Tim Tautges wrote:
> Interesting question, which I'm forwarding to the rest of the ITAPS
> interface group. One question, would that require you to actually
> define the private structure, or just reference it? The extra type
> checking would be very useful (and would be useful inside MOAB as well...).
My first reaction was that I never would have thought that this would be
compilable. Jed obviously knows something about C syntax that I don't,
because it does seem to work, at least in terms of compiling and linking
(see attached files). I defined two different structs, one in C, one in
C++, and both linked fine (as in: both test2.o and test3.o link with
test.o with no complaints). Mind you, I never tried to do anything
beyond what's in these files, so it's possible that the compiler
optimized away anything that might have been a problem.
From the implementation side, if we made this change, we'd all have to
have an explicit iBase_EntityHandle_Private (plus half a dozen or so
others), but in exchange we get type checking and may be able to avoid a
bunch of casts (that's probably implementation dependent...
Carl
> Jed Brown wrote:
>> Sorry if this is the wrong list for this, but why are all the opaque
>> handles typedef'd to void * instead of incomplete types. That is, why
>> not something like
>> typedef struct iBase_EntityHandle_Private *iBase_EntityHandle;
>> in order to get some extra type checking? Correct existing code should
>> not see any difference. With this change, a possible logic error (using
>> EntitySetHandle for an EntitySet) in the VisIt plugin would be caught by
>> the compiler.
>> Jed
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
Type: text/x-csrc
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/moab-dev/attachments/20080907/0ee8d5ed/attachment.c>
Type: text/x-csrc
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/moab-dev/attachments/20080907/0ee8d5ed/attachment-0001.c>
Type: text/x-c++src
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/moab-dev/attachments/20080907/0ee8d5ed/attachment.cc>
