[MOAB-dev] r2166 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Oct 21 09:09:52 CDT 2008
Author: kraftche
Date: 2008-10-21 09:09:52 -0500 (Tue, 21 Oct 2008)
New Revision: 2166
Modified:
   MOAB/trunk/VtkTest.cpp
Log:
fix syntax error w/ -pedantic flag--fixes nightly test issue
Modified: MOAB/trunk/VtkTest.cpp
--- MOAB/trunk/VtkTest.cpp	2008-10-21 14:04:54 UTC (rev 2165)
+++ MOAB/trunk/VtkTest.cpp	2008-10-21 14:09:52 UTC (rev 2166)
@@ -27,75 +27,75 @@
   return 0;
-DECLARE_TEST(edge2);
-DECLARE_TEST(edge3);
-DECLARE_TEST(tri3);
-DECLARE_TEST(tri6);
-DECLARE_TEST(quad4);
-DECLARE_TEST(quad8);
-DECLARE_TEST(polygon);
-DECLARE_TEST(tet4);
-DECLARE_TEST(tet10);
-DECLARE_TEST(hex8);
-DECLARE_TEST(hex20);
-DECLARE_TEST(wedge);
-DECLARE_TEST(pyramid);
+DECLARE_TEST(edge2)
+DECLARE_TEST(edge3)
+DECLARE_TEST(tri3)
+DECLARE_TEST(tri6)
+DECLARE_TEST(quad4)
+DECLARE_TEST(quad8)
+DECLARE_TEST(polygon)
+DECLARE_TEST(tet4)
+DECLARE_TEST(tet10)
+DECLARE_TEST(hex8)
+DECLARE_TEST(hex20)
+DECLARE_TEST(wedge)
+DECLARE_TEST(pyramid)
-DECLARE_TEST(structured_points_2d);
-DECLARE_TEST(structured_grid_2d);
-DECLARE_TEST(rectilinear_grid_2d);
-DECLARE_TEST(structured_points_3d);
-DECLARE_TEST(structured_grid_3d);
-DECLARE_TEST(rectilinear_grid_3d);
+DECLARE_TEST(structured_points_2d)
+DECLARE_TEST(structured_grid_2d)
+DECLARE_TEST(rectilinear_grid_2d)
+DECLARE_TEST(structured_points_3d)
+DECLARE_TEST(structured_grid_3d)
+DECLARE_TEST(rectilinear_grid_3d)
-DECLARE_TEST(scalar_attrib_1_bit);
-DECLARE_TEST(scalar_attrib_1_uchar);
-DECLARE_TEST(scalar_attrib_1_char);
-DECLARE_TEST(scalar_attrib_1_ushort);
-DECLARE_TEST(scalar_attrib_1_short);
-DECLARE_TEST(scalar_attrib_1_uint);
-DECLARE_TEST(scalar_attrib_1_int);
-DECLARE_TEST(scalar_attrib_1_ulong);
-DECLARE_TEST(scalar_attrib_1_long);
-DECLARE_TEST(scalar_attrib_1_float);
-DECLARE_TEST(scalar_attrib_1_double);
+DECLARE_TEST(scalar_attrib_1_bit)
+DECLARE_TEST(scalar_attrib_1_uchar)
+DECLARE_TEST(scalar_attrib_1_char)
+DECLARE_TEST(scalar_attrib_1_ushort)
+DECLARE_TEST(scalar_attrib_1_short)
+DECLARE_TEST(scalar_attrib_1_uint)
+DECLARE_TEST(scalar_attrib_1_int)
+DECLARE_TEST(scalar_attrib_1_ulong)
+DECLARE_TEST(scalar_attrib_1_long)
+DECLARE_TEST(scalar_attrib_1_float)
+DECLARE_TEST(scalar_attrib_1_double)
-DECLARE_TEST(scalar_attrib_4_bit);
-DECLARE_TEST(scalar_attrib_4_uchar);
-DECLARE_TEST(scalar_attrib_4_char);
-DECLARE_TEST(scalar_attrib_4_ushort);
-DECLARE_TEST(scalar_attrib_4_short);
-DECLARE_TEST(scalar_attrib_4_uint);
-DECLARE_TEST(scalar_attrib_4_int);
-DECLARE_TEST(scalar_attrib_4_ulong);
-DECLARE_TEST(scalar_attrib_4_long);
-DECLARE_TEST(scalar_attrib_4_float);
-DECLARE_TEST(scalar_attrib_4_double);
+DECLARE_TEST(scalar_attrib_4_bit)
+DECLARE_TEST(scalar_attrib_4_uchar)
+DECLARE_TEST(scalar_attrib_4_char)
+DECLARE_TEST(scalar_attrib_4_ushort)
+DECLARE_TEST(scalar_attrib_4_short)
+DECLARE_TEST(scalar_attrib_4_uint)
+DECLARE_TEST(scalar_attrib_4_int)
+DECLARE_TEST(scalar_attrib_4_ulong)
+DECLARE_TEST(scalar_attrib_4_long)
+DECLARE_TEST(scalar_attrib_4_float)
+DECLARE_TEST(scalar_attrib_4_double)
-DECLARE_TEST(vector_attrib_bit);
-DECLARE_TEST(vector_attrib_uchar);
-DECLARE_TEST(vector_attrib_char);
-DECLARE_TEST(vector_attrib_ushort);
-DECLARE_TEST(vector_attrib_short);
-DECLARE_TEST(vector_attrib_uint);
-DECLARE_TEST(vector_attrib_int);
-DECLARE_TEST(vector_attrib_ulong);
-DECLARE_TEST(vector_attrib_long);
-DECLARE_TEST(vector_attrib_float);
-DECLARE_TEST(vector_attrib_double);
+DECLARE_TEST(vector_attrib_bit)
+DECLARE_TEST(vector_attrib_uchar)
+DECLARE_TEST(vector_attrib_char)
+DECLARE_TEST(vector_attrib_ushort)
+DECLARE_TEST(vector_attrib_short)
+DECLARE_TEST(vector_attrib_uint)
+DECLARE_TEST(vector_attrib_int)
+DECLARE_TEST(vector_attrib_ulong)
+DECLARE_TEST(vector_attrib_long)
+DECLARE_TEST(vector_attrib_float)
+DECLARE_TEST(vector_attrib_double)
-DECLARE_TEST(tensor_attrib_uchar);
-DECLARE_TEST(tensor_attrib_char);
-DECLARE_TEST(tensor_attrib_ushort);
-DECLARE_TEST(tensor_attrib_short);
-DECLARE_TEST(tensor_attrib_uint);
-DECLARE_TEST(tensor_attrib_int);
-DECLARE_TEST(tensor_attrib_ulong);
-DECLARE_TEST(tensor_attrib_long);
-DECLARE_TEST(tensor_attrib_float);
-DECLARE_TEST(tensor_attrib_double);
+DECLARE_TEST(tensor_attrib_uchar)
+DECLARE_TEST(tensor_attrib_char)
+DECLARE_TEST(tensor_attrib_ushort)
+DECLARE_TEST(tensor_attrib_short)
+DECLARE_TEST(tensor_attrib_uint)
+DECLARE_TEST(tensor_attrib_int)
+DECLARE_TEST(tensor_attrib_ulong)
+DECLARE_TEST(tensor_attrib_long)
+DECLARE_TEST(tensor_attrib_float)
+DECLARE_TEST(tensor_attrib_double)
-DECLARE_TEST(subset);
+DECLARE_TEST(subset)
 int main( int argc, char* argv[] )
