[MOAB-dev] r2146 - MOAB/trunk
tautges at mcs.anl.gov
Tue Oct 14 14:46:56 CDT 2008
Author: tautges
Date: 2008-10-14 14:46:56 -0500 (Tue, 14 Oct 2008)
New Revision: 2146
Modified:
MOAB/trunk/MBCore.cpp
Log:
Move bulk of delete_entities function implementation to range-based case, and call that from vector-based instance of this function. Ensures that entities are deleted in reverse order of type, regardless their position in the input vector.
Passed make check.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2008-10-14 19:43:41 UTC (rev 2145)
+++ MOAB/trunk/MBCore.cpp 2008-10-14 19:46:56 UTC (rev 2146)
@@ -1852,44 +1852,43 @@
-//! deletes an entity vector
-MBErrorCode MBCore::delete_entities(const MBEntityHandle *entities,
- const int num_entities)
+//! deletes an entity range
+MBErrorCode MBCore::delete_entities(const MBRange &range)
MBErrorCode result = MB_SUCCESS, temp_result;
- for (int i = 0; i < num_entities; i++) {
+ for (MBRange::const_reverse_iterator rit = range.rbegin(); rit != range.rend(); rit++) {
// tell AEntityFactory that this element is going away
- temp_result = aEntityFactory->notify_delete_entity(entities[i]);
+ temp_result = aEntityFactory->notify_delete_entity(*rit);
if (MB_SUCCESS != temp_result) {
result = temp_result;
continue;
// reset and/or clean out data associated with this entity handle
- temp_result = tagServer->reset_data(entities[i]);
+ temp_result = tagServer->reset_data(*rit);
continue;
- if (TYPE_FROM_HANDLE(entities[i]) == MBENTITYSET) {
- if (MBMeshSet* ptr = get_mesh_set( sequence_manager(), entities[i] )) {
+ if (TYPE_FROM_HANDLE(*rit) == MBENTITYSET) {
+ if (MBMeshSet* ptr = get_mesh_set( sequence_manager(), *rit )) {
int j, count;
const MBEntityHandle* rel;
- ptr->clear( entities[i], a_entity_factory() );
+ ptr->clear( *rit, a_entity_factory() );
rel = ptr->get_parents( count );
for (j = 0; j < count; ++j)
- remove_child_meshset( rel[j], entities[i] );
+ remove_child_meshset( rel[j], *rit );
rel = ptr->get_children( count );
- remove_parent_meshset( rel[j], entities[i] );
+ remove_parent_meshset( rel[j], *rit );
// now delete the entity
- temp_result = sequence_manager()->delete_entity(entities[i]);
+ temp_result = sequence_manager()->delete_entity(*rit);
continue;
@@ -1900,14 +1899,13 @@
-//! deletes an entity range
-MBErrorCode MBCore::delete_entities(const MBRange &range)
+//! deletes an entity vector
+MBErrorCode MBCore::delete_entities(const MBEntityHandle *entities,
+ const int num_entities)
- MBErrorCode result = MB_SUCCESS, rval;
- for (MBRange::const_reverse_iterator i = range.rbegin(); i != range.rend(); ++i)
- if (MB_SUCCESS != (rval = delete_entities( &*i, 1)))
- result = rval;
- return result;
+ MBRange range;
+ std::copy(entities, entities+num_entities, mb_range_inserter(range));
+ return delete_entities(range);
MBErrorCode MBCore::list_entities(const MBEntityHandle *entities,
