[MOAB-dev] r2141 - in MOAB/trunk: parallel tools/iMesh
tautges at mcs.anl.gov
Tue Oct 14 10:54:32 CDT 2008
Author: tautges
Date: 2008-10-14 10:54:32 -0500 (Tue, 14 Oct 2008)
New Revision: 2141
Modified:
MOAB/trunk/parallel/parallel_unit_tests.cpp
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
In iMesh_getEntities, allocate array for entities only (without entity sets).
Fixing an include in parallel_unit_tests that shows up with gcc4.3.
Passes make check.
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-13 18:09:18 UTC (rev 2140)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-14 15:54:32 UTC (rev 2141)
@@ -6,6 +6,7 @@
#include "MBCore.hpp"
#include "mpi.h"
#include <iostream>
+#include <algorithm>
#include <sstream>
#include <assert.h>
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-10-13 18:09:18 UTC (rev 2140)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-10-14 15:54:32 UTC (rev 2141)
@@ -2673,8 +2673,10 @@
RETURN(iBase_ERROR_MAP[result]);
+ int num_ents = out_entities.size() - out_entities.num_of_type(MBENTITYSET);
CHECK_SIZE(*entity_handles, *entity_handles_allocated,
- (int)out_entities.size(), iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ num_ents, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
MBRange::iterator iter = out_entities.begin();
MBRange::iterator end_iter = out_entities.end();
