[MOAB-dev] r2120 - MOAB/trunk/m4
kraftche at mcs.anl.gov
Wed Oct 1 15:42:35 CDT 2008
Author: kraftche
Date: 2008-10-01 15:42:35 -0500 (Wed, 01 Oct 2008)
New Revision: 2120
Modified:
MOAB/trunk/m4/hdf5.m4
Log:
It is an error if the user specified the --with-hdf5 option and
HDF5 was not found.
Modified: MOAB/trunk/m4/hdf5.m4
--- MOAB/trunk/m4/hdf5.m4 2008-10-01 20:38:23 UTC (rev 2119)
+++ MOAB/trunk/m4/hdf5.m4 2008-10-01 20:42:35 UTC (rev 2120)
@@ -84,7 +84,7 @@
AC_HELP_STRING([--without-hdf5], [Disable support for native HDF5 file format])],
[HDF5_ARG=$withval
DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-hdf5=\"${withval}\""
-], [HDF5_ARG=yes])
+], [HDF5_ARG=])
if test "xno" = "x$HDF5_ARG"; then
AC_MSG_RESULT([no])
else
@@ -101,7 +101,7 @@
fi
# if a path is specified, update LIBS and INCLUDES accordingly
- if test "xyes" != "x$HDF5_ARG"; then
+ if test "xyes" != "x$HDF5_ARG" && "x" != "x$HDF5_ARG"; then
if test -d "${HDF5_ARG}/lib"; then
HDF5_LDFLAGS="$HDF5_LDFLAGS -L${HDF5_ARG}/lib"
elif test -d "${HDF5_ARG}"; then
@@ -151,11 +151,15 @@
fi
fi
if test "x$HAVE_LIB_HDF5" = "xno"; then
- AC_MSG_WARN([Could not find HDF5 library (-lhdf5)])
HAVE_HDF5=no
fi
if test "x$HAVE_HDF5" = "xno"; then
+ if test "x" = "x$HDF5_ARG"; then
+ AC_MSG_WARN([HDF5 library not found or not usable.])
+ else
+ AC_MSG_ERROR([HDF5 library not found or not usable.])
+ fi
HDF5_CPPFLAGS=
HDF5_LDFLAGS=
HDF5_LIBS=
