[MOAB-dev] r2193 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Fri Oct 31 17:19:39 CDT 2008
Author: kraftche
Date: 2008-10-31 17:19:38 -0500 (Fri, 31 Oct 2008)
New Revision: 2193
Modified:
MOAB/trunk/parallel/parallel_unit_tests.cpp
Log:
More fixes to existing parallel unit tests.
test_ghost_elements_2_0_1 still fails because MBParallelComm creates multiple
ghost copies one each processor for some quads and the test expects only one
copy.
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-31 22:01:06 UTC (rev 2192)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-31 22:19:38 UTC (rev 2193)
@@ -346,85 +346,25 @@
-MBErrorCode get_ghost_entities( MBInterface& moab,
- const std::vector<int> partition_geom_ids[4],
- std::vector<int>& ghost_entity_ids,
- int ghost_dimension,
- int bridge_dimension,
- int num_layers,
- MBRange* ghost_handles = 0 )
+MBErrorCode get_ghost_entities( MBParallelComm& pcomm,
+ MBRange& ghost_ents )
+ MBRange all_ents;
MBErrorCode rval;
- MBTag tags[2];
- rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, tags[0] ); CHKERR(rval);
- rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, tags[1] ); CHKERR(rval);
- // get first set of bridge entities
- MBRange bridge_ents;
- for (int dim = 0; dim < 3; ++dim) {
- for (size_t i = 0; i < partition_geom_ids[dim].size(); ++i) {
- const void* tag_vals[2] = { &dim, &(partition_geom_ids[dim][i]) };
- MBRange ents;
- rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET,
- tags, tag_vals, 2,
- ents );
- CHKERR(rval);
- for (MBRange::iterator j = ents.begin(); j != ents.end(); ++j) {
- MBRange tmp;
- rval = moab.get_entities_by_dimension( *j, bridge_dimension, tmp );
- CHKERR(rval);
- bridge_ents.merge(tmp);
- // get owned entities
- MBRange owned_ents;
- for (size_t i = 0; i < partition_geom_ids[3].size(); ++i) {
- const int three = 3;
- const void* tag_vals[2] = { &three, &partition_geom_ids[3][i] };
- MBRange ents;
- ents );
- CHKERR(rval);
- MBRange tmp;
- rval = moab.get_entities_by_dimension( *j, 3, tmp );
- CHKERR(rval);
- owned_ents.merge(tmp);
- // get entities of ghost dimension adjacent to owned entities
- // (these cannot be ghost entities because they are either owned
- // or interface entities.)
- MBRange owned_and_iface;
- rval = moab.get_adjacencies( owned_ents, ghost_dimension, false, owned_and_iface, MBInterface::UNION );
+ rval = pcomm.get_moab()->get_entities_by_handle( 0, all_ents );
CHKERR(rval);
+ std::vector<unsigned char> flags(all_ents.size());
+ rval = pcomm.get_moab()->tag_get_data( pcomm.pstatus_tag(), all_ents, &flags[0] );
+ CHKERR(rval);
- // find potential ghost entities using adjacency queries
- MBRange ghost_ents;
- for (int l = 0; l < num_layers; ++l) {
- MBRange tmp;
- rval = moab.get_adjacencies( bridge_ents, ghost_dimension, false, tmp, MBInterface::UNION );
- CHKERR(rval);
- ghost_ents.merge(tmp);
- bridge_ents.clear();
- rval = moab.get_adjacencies( ghost_ents, bridge_dimension, false, bridge_ents, MBInterface::UNION );
- CHKERR(rval);
+ MBRange::iterator ins = ghost_ents.begin();
+ std::vector<unsigned char>::const_iterator f = flags.begin();
+ for (MBRange::iterator i = all_ents.begin(); i != all_ents.end(); ++i, ++f)
+ if ((*f & PSTATUS_NOT_OWNED) && !(*f & PSTATUS_INTERFACE))
+ ins = ghost_ents.insert( ins, *i, *i );
- // remove from ghost candidates, any entities that are
- // locally owned or interface entities
- ghost_ents = ghost_ents.subtract( owned_ents );
- // get ids
- ghost_entity_ids.resize( ghost_ents.size() );
- rval = moab.tag_get_data( tags[1], ghost_ents, &ghost_entity_ids[0] );
- CHKERR(rval);
- if (ghost_handles)
- ghost_handles->swap(ghost_ents);
return MB_SUCCESS;
@@ -453,6 +393,12 @@
iface_sets.merge( ents );
+ // get all interface entities
+ MBRange all_iface_ents;
+ for (MBRange::iterator i = iface_sets.begin(); i != iface_sets.end(); ++i) {
+ rval = moab.get_entities_by_handle( *i, all_iface_ents );
+ CHKERR(rval);
// for each interface set
MBRange ghosts;
@@ -475,7 +421,7 @@
- // get entities in adjacent partitions not owned by this proc.
+ // get entities in adjacent partitions
MBRange adj_proc_ents;
for (MBRange::iterator p = parents.begin(); p != parents.end(); ++p) {
int id;
@@ -483,10 +429,18 @@
if (std::find(partition_geom_ids[3].begin(), partition_geom_ids[3].end(), id)
!= partition_geom_ids[3].end())
continue;
- rval = moab.get_entities_by_dimension( *p, ghost_dimension, adj_proc_ents );
+ rval = moab.get_entities_by_dimension( *p, 3, adj_proc_ents );
CHKERR(rval);
+ // get sub-entities implicitly within partitions
+ MBRange tmprange;
+ for (int d = 2; d >= 0; --d) {
+ rval = moab.get_adjacencies( adj_proc_ents, d, false, tmprange, MBInterface::UNION );
+ CHKERR(rval);
+ adj_proc_ents.merge( tmprange.subtract( all_iface_ents ) );
// get adjacent entities
MBRange iface_ghosts, iface_ents;
rval = moab.get_entities_by_dimension( *i, bridge_dimension, iface_ents ); CHKERR(rval);
@@ -622,11 +576,11 @@
// get the global IDs of the ghosted entities
MBRange ghost_ents;
- std::vector<int> actual_ghost_ent_ids;
- rval = get_ghost_entities( moab, partn_geom_ids, actual_ghost_ent_ids,
- ghost_dimension, bridge_dimension, num_layers,
- &ghost_ents );
- PCHECK(MB_SUCCESS == rval);
+ rval = get_ghost_entities( *pcomm, ghost_ents ); CHKERR(rval);
+ std::pair<MBRange::iterator,MBRange::iterator> vtx = ghost_ents.equal_range(MBVERTEX);
+ ghost_ents.erase( vtx.first, vtx.second );
+ std::vector<int> actual_ghost_ent_ids(ghost_ents.size());
+ rval = moab.tag_get_data( id_tag, ghost_ents, &actual_ghost_ent_ids[0] ); CHKERR(rval);
// read file in serial
MBCore moab2;
